View Full Version : Tech / Misc
- JUN Internals in a H22A
- honda oil pressure port
- how do you clean the fuel system?
- HELP identify my ecu setup
- h22 ecu?
- No Start condition No spark
- brake problem
- Bent Mainshaft? More Tranny Problems!
- will i pass cali emissions wit I/H/E????
- Header problem!!!
- Power windows question. please help
- Code 15! Please help me out guys
- need swap/wiring expert in nj area
- Please Help Hondata Users. Please tell me how to synchronize romeditor timing to distributor timing.
- Car won't start! Emergency Help!
- what should I get to rebuild my h22a after it was just rebuilt incorrectly?
- SOHC Hybrid Guys Help Me Out!!!
- Serious Engine questions
- Turbo Kits
- clutch and pressure plate
- Spring Rate difference between H&R Race and Neuspee Race?
- Anyone have know of any good DIY's for installing Quaifes and synchros???
- ebrake problem
- Code 17,How do i fix it?
- Will a H23 block and H22 Vtec Head have the same problems as a Ls/Vtec?
- asdf
- air/fuel gauge stays at rich please help
- what would be the cause of this????
- NEED Help!!
- DIY Port and Polish PICS
- obd2 civic ex injectors in obd1 gsr engine
- Codes 3,15,21. Yes, its a triple. VAFC related.
- weird problem...car wont crank
- Help AC not working??!!!
- Zex Nitrous=bad???
- Do Torsion bar bushings squeak?
- Integra intermediate/half shafts: differences between manual, auto?
- crazy oil/water burning problem!?!!!! HELP!!!
- spoon thermosat in a b18b1?
- Need some help
- Nitrous Express????????????????????????????/
- where can i find the silicone lubricant for polyurethane bushings?
- Burt Valve.. what are the signs?
- upgrade fuel injectors for lsvtec
- skunk2 cams
- d series oil pans
- Rear swaybar size
- Need help in San Jose, CA
- My clutch is not grabbing like it use to. What can be wrong?
- Alignment Issues
- VAFC unmt setting?
- ECU difference?
- 40K (?) service...What do I need to do???
- Quick Tranny Question
- Electric Problem(please help)
- cluth and fly wheel install help!!
- h22 guys
- what is the actual diameter of......
- another claying motor Question. we are stuck..
- I've searched! Once and for all. can somebody post the correct grounding diagram.
- Just finished swap but car just won't start.
- Speedometer went out and lights dimmed????
- What should I buy? <--serious question?
- Are imported JDM motors going to pass US emissions??
- B16a won't start......analysis inside, please help.
- how to change integra sliders
- 1979 Civic CVCC electrical problem/ignition problem/HELP Y0
- Rod bearing / Wrist pin question...
- What comes with Koni Yellows?
- Ys1 cable tranny rebuild help!
- Understanding Transmission Ratios...
- d16y6 head for 88-91 hatch?
- adjusting your idle
- Wheel is wobbling back and forth ???
- Replacing Front Wheel Stud
- engine
- head or the block.
- sohc motors
- B18C Tranny or B
- 86 Prelude 112 CI carb won't hold idle
- Skunk2 cams, or gsr block??
- Which Clutch for a 1st Gen B!6? 90-91 LS right!
- slotted vs blank rotors????
- Edelbrock stuff
- ok, i need help tonight.
- Heater removed. Cap off or loop hose?
- Weird sound from passenger side wheel...
- anone hear of Ultima Performace????????
- how do i reduce emissions?
- where to get head rebuilt in New York?????????
- Just curious... weight of lugnuts...
- how to tell itr head
- 2jz in a 240sx
- tranny guys look inside
- 01 Integra Type R LEMON???
- b16a2
- Wheel Problems
- OBDO-OBD1 harness
- Question about the Civic CX.
- Cuting spring!
- where i can i find chip programs so i can compare???
- Oil leak?
- effected ride height due to bad alignment?
- will timing be retarded if not running a knock snsor in 1st gen b16a??
- 3 connectors or 4 on 94-95 gsr engine harness
- 94 GSR ECU question
- Fuel pump not turning on :HELP:
- URGENT! I can't get my B16 started!
- ??? b16 internals how to get???
- God-Awful Bogging got worse last night!
- Kenji P28 ECU with OBD1 conv. harness in to 2001 ITR
- DC2 Tech Question
- Tein Suspension
- machine shops in south fla
- engine vibration
- Gear shift does not come out of parking
- Lost control of car going around a cornor and now I smell gas....
- difference between 99si clutch kit and 92-93 integra clutch kit
- 91 si engine non obd harness question , obd 1 thermo housing related
- cutting springs
- JG/Eldlbrock T/B(65mm) for the ITR's.................
- My new clutch :)
- Is my clutch gone?
- team honda vs nismo on tv?
- Impending Brake Upgrade...Need Suggestions!
- I give up.
- Is it illegal to remove an airbag steering wheel?
- can i shave the block 0.040?
- ----hEaDeR TeCh 4-1 HEADER----
- Where to Port Intake Manifold's? (searched)
- humming noise when ignition on?
- another 02 sensor related problem, please help me out!!!(kinda long)
- Hit a curb, what to replace?
- o2 sensor
- chattering noise
- Underdash 94+ fusebox diagram
- Fuel injectors are not spraying fuel
- My VX's crank pulley is solid aluminum....
- 215/40/16??
- 92-95 Vtec Wiring harness?
- code 43..?!?
- Any comments on the quick time electric cutout?
- Dart B20/VTEC questions
- Is a SOHC VTEC silanoid the same as a DOHC?
- length on intermediate shaft???
- O2 sensor question..
- do ys1 and y1 trannys use the exact same clutch disks and pressure plates?
- obd2 motor with obd1 harness ?
- What's wrong with this Alignment spec sheet?
- NGK's for B16a1???
- carburators on a b18c
- EEPROM problem
- Bearing selection help @!!
- major thermostat issues. . . help
- Tein RS Question?
- /////YS1 tranny Question//////
- 4wire o2 sensor question
- Cant figure this out!?! DAC intake problem.
- crazy idle
- my plans for forced induction
- Dyno Day Mayhem Meet.
- ticking
- Dual Port 2 Multi Port????
- f22b jdm turbo fiability
- I need help with wiring
- to vtec or not?!
- Check engine light help needed ASAP!!!
- Clutch Alignment Tool??
- Carbon around mani:Blown gasket or worse?
- jun 3 owners...........fuel question
- Turbo cheaters list
- please help!!!fuel cut for b16b
- refrigerant oil - where to buy?
- tokico blues and springs no instructions need help!!!!!
- Hone myself or have shop do it?
- all the parts needed to install JDM ITR pistons on b18c1.
- Blown Head Gasket Diagnosis
- Can I use these head studs?
- Apexi Dunk exhaust fitment problem...Please Help!
- fmu install?
- Air/Fuel Gauge installation
- intake mani Y8 on a Y7?
- Wiring B18C
- Exhaust
- Ignition Problem
- dent in oil pan
- Rev limit on a built motor ??
- Wiring question??
- Best NGK's for Nitrous?
- Jet-Coating -
- Need Info on Rewire of OBD2 to OBD1!!!
- would a ls drag turbo kit work with my lsvtec setup?
- Buzzing from dash on hard cornering
- o2 sim...
- General Hybrid Question
- What do you think of these headers? Hytech
- tick tick tick tick tick
- Steering Wheel
- B16a vs B18a - part 2 (ignore the first post)
- B16a vs B18a
- New piston rings - make break in or not and WHY?
- What is the biggest muffler I can fit in my EG Hatchback with ITR Swaybar?
- Quick question on engine removal
- Halfway throught my DIR Ground kit
- Possible CV problem: Plz help!
- Weird ticking?
- Cam gears.. anyone have these?? Review??
- air conditioning freon
- ls/vtec low ass compression problem????
- Gen2 Timing Belt
- H22a won't start up and puff of smoke
- Automatic B series starter in B series 5 speed trans?
- b16 block with gsr or itr head
- crower stage 3 cams web springs and retainer setup
- what is the best setup for NA b16.....
- Short Ram Air Intake?
- 1979 Civic Weber Car problem. Choke? helppppp
- Taking Tranny Case Off. Snap ring?
- ITR Valve Adjustment Specs
- fast idle problem help
- CEL Misfire
- wheres harness to check engine light 5th gen lude
- OBD1 ECU help please
- Should the Main shaft spin freely while in gear when off the car?
- Emergency brake light poping on while in Vtec?
- TPS Voltage at Idle
- Yes i have another question about basic mantanince...
- checking for continuity on voltmeter?
- Lude injectors?
- weird hesitation
- spw mufflers
- asapmotors.com any one dealt with these guys?
- mugen head gasket w/CTR pistons
- Cusco Can can, mounted ?
- coolant leak
- D15B ECU for CA Smog Ref
- N/A guru's: question about cams, LMA and Lash
- built d16a6 with wicked cam and 11.1:1 compression...fuel setup help
- b18 build?
- Anyone ever change 96-00 civic steering racks???
- Exhaust Article
- check engine light refuses to disappear....
- S-AFC II Wiring for OBD1 ECU
- TIG Weld vs. MIG weld??
- D16Z6 Engine Overhaul Yeilds Problems When Done
- blown head gasket
- Crankshaft Pulley Question
- d16y8 tps
- wiring Safc on OBDII 2001 integra LS auto
- skunk2 cams + ctr pistons
