View Full Version : Tech / Misc
- Timing Belt BS
- Car stalls after warm up (10 min)
- AC PAG Oil System Quantity
- ECT, IAT, TPS, and O2 ground wiring splice location before C103/C223???
- 2007 RDX long Cold Starts. No CEL
- Accord speedometer dropping
- Dual solenoid Vtech d16y8 head
- 2014 Civic AC Compressor housing fix?
- boost controller not working
- Looking for the spec of the connector plug for oil level sensor
- GSR Head
- 93 hatchback
- Problem with 2015 Honda Odyssey
- Weird idle problem
- no power to starter signal wire causing No crank/no start
- 78 Austin mini- D16Y7 engine swap wiring
- Speaker wiring 1993 DX
- Adjust FPR?
- VSA and TC Light On (2009 Civic Si)
- B series thermostat issue
- evap wiring issue 00 civic HX
- repurposing a key fob?
- No Crank/Start
- 99 Crv Auto to Manual swap help needed
- 99 Integra Auto Trans into a 98 CRV AUTO AWD?
- d15b JDM Knock Sensor
- FUEL delivery issues
- Exhaust bolt keeps spinning
- Bad ecu or oxygen sensor
- Refillable Wiper Blades still Exist ?
- Bad Oil Pan Gasket?
- 2020 CR v Hybrid Touring AWD Power Tailgate
- AC Troubleshooting
- New Fully-built Transmission Popping out of Gear - Usually 5th
- 07 rtl ridgeline ac will not shut off advice please
- suggestions after timing belt replacemnt
- Change 2016 CRV Date
- Tucked harness ac wiring.
- Need alternator wiring diagram for 2012 honda odyssey
- 91 civic no crank
- Looking for oem equivalent GSR valve springs
- B16 tucked engine harness
- Broken valve cover breather hose fitting
- Honda JDM service manual
- Ek coupe gauge cluster swap
- Oil pressure too high on built b18
- Heater 95 civic
- What works with what?
- 78 Austin mini w/ D16Y7- harness question
- D16y8 conversion issues
- Need help finding replacement clips
- Identify distributor cap
- External coil?
- 99 civic si battery won’t charge
- How to convert auto ecu to manual P76 - 902 ecu
- 91 accord runs bad when warm
- 1997 Honda CRV AC Issues
- Alternator Relocation
- Out of ideas with fuel issue
- Weird ass issue with dizzy cap on b18cr
- Knock sensor by pass
- OBD2A Ecu - Repairs?
- Is it a good idea to buy Civic DX?
- How much wider is the Duraflex TKO RBS widebody kit than stock
- Tips removing fuel line
- Pablomg's Injectors aren't working!
- Chip tuning with Crome, Solid CEL
- Problem with CarPlay/Siri no longer providing audio feedback
- buzzing sound underneath car 5 hours after parking
- LS-vtec with vtec killer question
- Compression test reading 0-0-9-89?
- Radiator fan works but won’t turn on.
- '03 Accord V6 SRS - seatbelt tensioner & SRS unit?
- Bought an EK hatch could use some advice
- Troubleshooting: 2.7 V6 Vibration at idle
- temp water sending unit (ECT) thread measure
- Honda Stream - Gas pedal occasionally not able to depress when driving...
- Normal ECT range?
- How to reset dashboard lights without infotainment screen?
- Bisimoto header not lining up with exhaust pipe
- Walk away auto lock doesn't work
- No V-tec, cannot find similar thread anywhere!
- 98 Civic EX Starts and then Stalls *Solved* Replaced main relay
- TOP 3100 burner help
- Crank no start, no fuel pump priming.
- Backfiring out of the intake tdc and 150 psi
- Honda SUV 2009 Not starting
- B16a EF Not Starting HELP
- D16y8 engine problem
- Difference between YY ECUs and X5 ECUs
- Looking to replace Pin in alternator
- LSVtec not engaging VTEC EK
- My Honda is overheating, and I have no idea why
- Is it possible to set #1 TDC after timing belt is removed?
- Is it good practice to disconnect battery during timing belt/water pump replacement?
- Newbie needs advice
- Tilton Flow Control Valves?
- Immediate change in compression numbers?
- Innovative traction bar for 91 civic help
- Honda civic d16y7 vs d15b crankshaft pulley differences
- Type R Swap Rotors
- Is it OK to DYI a/c recharge?
- Engine knocking sound
- Help. B16a2
- Fuel Pump replacement; Walbro 255
- Accord 13 AC Clutch engaged after 10-20 min driving
- Coolant temp sensor causing P0171 on start up? Curious about the cause.
- Part number of door lock rod holder plastic bracket?
- Please identify this distributer
- back up camera
- 99 Civic Auto to Manual Swap b18a1 NO START
- Jdm 93 civic no scs connector?
- Aftermarket Battery Terminal with voltage sensor?
- D15B7 Re-Ring Question
- Injector Help!
- hack with cobra rtp honda edition
- 1998 Honda Civic EX coupe headliner clip
- Air getting in power steering system
- AC works briefly and intermittently; 2008 Honda Accord
- B16A2 ~1500rpm vibration
- EDM 90-91 STD cluster (NOT SiR)
- Need Opinions 2001 Honda Accord LX 2.3l IACV Issues
- How to fix cruise control clutch switch
- Replaced Rear Rotors - Right Rear has Streak after 4k miles
- Honda Civic EX misfire codes immediately after new exhaust pipe welded on
- Can Someone tell me what brand of wheels these are?
- Alternatives to NLA Fuel Pressure Regulator
- MPCS service connector tool - where to buy
- Honda iN EPC and service info
- Honda accord 1994 windows and control gauges wont work
- Deleted Downstream O2 Sensor causing Misfire?
- Ignition not giving ecu signal
- Scan tools?
- Dohc Zc engine issue
- Pls help my car is bugging out
- Force Cluster on to read odometer
- 2003 Accord Battery Won't Charge
- Unsettling noise at vtech crossover. help!
- Ac compressor
- 2022 civic si with upgraded brown interior ??
- Speed masters B16 casting. BEWARE!!!
- 2006 CRV P0135 Front O2 Sensor After Stolen Catalytic Converter
- Two datalogging outputs from CN2 possible?
- 2001 accord 2.3 spark at coil but not at the cap. New Spark Cap. Thoughts?
- B18A1 from Storage unit
- B20block b16 head timing belt
- Not starting WEIRD electrical Problem
- Obd2 alternator wiring help!
- 1997 Honda Civic Coupe DX D16Y7 Rod-knock
- Wipers stopped in upright position.
- Raising factory 6,800rpm redline on 600hp turbo J32A2
- Radiator bleed with bubble never end
- 91 civic battery relocation
- 96 Civic Fuel Pump Only Primes When Warm?
- Getting conflicting info on a GENUINE HONDA BATTERY purchased from the parts Dept.
- 96 civic sedan no 12v power to ignition
- Brakes locking up!!!!
- All ground wire locations.
- I NEED SOME HELP PLEASE !!!!
- Dizzy obd0 to obd1 swap and injectors
- Clock spring wearing
- Programming key fobs
- Journal bearing damage, fixable/runnable or lost cause?
- Fuel Pumps
- Power to coils?
- GSR No spark
- Can you ID these cams?
- Civic eg6 rhd b18c swap elecrtrical problem
- lifetime warranty on Brake Shoes?
- Sway Bar Link - Broken?
- 2010 Honda Accord LX Harness
- AC Compressor/Clutch replacement
- HKS High-Power Exhaust
- Fuel pump not priming. 92 eg
- 2014 Accord Cigarette lighter failure
- Anti-seize, grease, oil, Loctite… what’s appropriate to protect nuts and bolts?
- Fuel Injector not getting PCM Pulse (1 unit only) '06 Odyssey
- No power to ECU/Fuel Pump, please help!
- Gsr ef sedan
- H22a problems
- 1999 honda odyssey CAS fault code
- Need Tips for OBD1 or OBD2 distributors sensors
- does oil flow from VTC actuator to solenoid or solenoid to actuator?
- Some k24 chains have 5 coloured links, some have 3. why
- No power to climate control
- Coolant Loss B16B Swap
- Converting 1992-1995 civic OEM fog harness to work on 1994-2001 integra??
- EK A/C lines and components in 94-95 EG?
- Cranks but wont run
- What Gasket is this???
- 2013-2017 Accord EPS rack q's
- 91 civic bswap issues
- Computer not Seeing Bad Alternator
- Dented radiator fins - should I attempt repair?
- Honda Pilot Navigation Errors
- Zero clearance valve lash?
- Where to source ecu thermostat ground terminal
- 07 Honda Accord system connection failure Help!!
- Is my 2017 Accord Touring Haunted? Random text messages
- what brand of wheel lock is this?
- 2019 Odyssey, passenger side water leak and water sound
- Obd2a vs obd2b dash harness
- 200k B20 motor, burnt exhaust valve common?
- Does a new A/C compressor come with enough oil for a virgin A/C system?
- Fast idle thermo valve
- Type r or sirg?
- Need help with igntion marion, virginia
- 2018 Odyssey showing many error messages after service from the dealer
- Changing Condensor
- cracked head??
- Does brass wire brush remove plating ?
- B18 Oil Pressure Sensor Bypass
- Please help - Hondata and AEM Wideband
- 94 civic eg coupe exhaust destroyer
- Rough Idle After Engine Swap and White Smoke from Exhaust
- JUST GOT PULLED UP FOR LED HEADLIGHTS!
- obd1 code 11? huh?
- Rear bumper reinforcement
- Assistance Needed 2002: Honda Accord F23A1. Cranking but no start issue.
- 2013 Accord electronics intermittently shuts off while driving
- Assistance needed: OBD0 91 civic B-series but no spark despite diagnostics
- ECU 37820-PM5-A59 for Honda Civic DX?
- B18b1 Head 3 boxes with Japanese writing
- One high beam not working, no power to fuse
- RPM Surge only at 1500rpm, harsh buck and idle hang on pressing clutch
- Adding a 12v switch to a car stereo. Any suggestions?
- Can I use a JBP part on a KCP Accord?
- 03 accord radiator cap failure. Could this be signs of a bigger issue?
- Crank Positition Sensor Placement J35Z5
- Engine harness plug holder brackets...
- AC Bracket To Block Bolt
- 96 accord 2.2 o2 Extender route help
- crank position sensor
- Need some help testing OBD2A power pinouts...
- Ignition lock problem after cylinder fix - Honda Ridgeline 2006
- 2000 EM1 Stock Motor / Tranny P0172 Requesting Help
- Starter solenoid connector broken
- 2003 civic high rpms
- P0a ecu cannot be used in an OBD1 swap.
- AEM EMS1 vs. Hondata S300
- Help! Northern NJ
- I hate to ask....but I have to know
- Which Fuse should I use for a Fuse Tap?
- is this legit? (battery testing/charging)
- 91 civic b18 swap
- Assistance Needed: Car will not start due to relay, battery or alternator. Discuss?
- how to disable injectors
- Temperature sensor question
- Any clue where this plug goes ?
- Is this "Defected" Fuel Filter Good Enough?
