View Full Version : Tech / Misc
- anyone in upstate NY wanna adj - my valves
- thoughts on caliper rebuild kits?
- any tips on installing axlebacks?
- what are my options with this?
- Compressing Rear caliper piston
- Replacing struts?
- How to measure TPS voltage?
- cracked exhaust manifold- affect performance?
- any1 have 00 teg with a testpipe/racing cat?
- Hacked off muffler + clamped tip = LOUD exhaust?
- Low Compression on motor..??
- My first Honda, first V-Tec. I have a need to know.
- type r cams, aem cam gears and gs-r head for sale
- Primary O2 Sensor
- posting up pictures
- HYDROLOCK? what is the damage?
- Timing Belt what if it breaks?
- Mailing Address for Honda America?
- Need some serious help on a b18a tranny ASAP. Experience preferred
- best glue to use when come to metal
- Who was it on this board that make's the EF to EG ecu adaptors..?
- my fuel gauge is messed up! anyone know whats wrong?
- what do i need to hold up and lower the tranny if i'm swapping out the clutch?
- need help on painting a spoiler.......amateur
- HELP!! Synthetic oil problem--
- ignition install/ type r throttlle body
- OT: They call this a strip job????
- Valve question
- Is ZEX 75,.... really 75?
- Check Engine Light!!!!!
- tachometer hesitation
- B18C1 in 94 Del Sol S
- Help! Brake light stays on while driving
- ls vtec emissions, PLEASE HELP!!!!
- vafc...static on the screen
- Need some help diagnosing weird problem with my hybrid!
- Neuspeed Coilovers
- Rod Ratio.... rods in motors
- you hear the power but cant feel it???
- Setting ignition timing w/ adjustable timing light...
- Does anyone know how to install valve springs?
- Neuspeed coilover system and other Coilover Qs
- CRX radiator stopcock
- Field SFC Vtec Controller owners please read!
- Torque specs for Type-R strut bar?
- All motor question for All Motor Gurus
- Dealer/ Independent Honda Techs?
- Air intake causing car to run lean?
- Clutch Install Questions
- which pistons to get?
- R tie bar: will it fit 93 ej?
- 90-93 teg Ground controls on a 2nd gen CRX
- Made a mistake trying to replace cap and rotor.
- Leakdown test
- Coolant temp
- What does a valve job consist of?
- help w/ installing vtec controller in minime swap
- custom exhaust... what to do and what not to do ??? + ideas...
- Measuring throttle body-How to?
- Flaring Help: GSR Master Cylinder in EG6.
- what tools do i need to remove and install a new clutch? and what lubricant should i use?
- Would it be possible to turn one's...
- Whats the difference between GC and Skunk2?
- When does the cooling fan come on?
- Strange noise
- What can be done to fix running rich?
- Spark plug gap inconsistencies
- Wheel Weight(s), interesting link . . .
- Need Help Fast!!!
- Some "post swap" mysteries.........
- HELP! Want to keep my motor strong!
- replacing hub bearings...
- Neutral safety switch part II...
- please help!!!!
- Continuation of Attention:BAY AREA!!!!
- Attention:BAY AREA!!!!!!!!
- Best setting for cam gears ?
- Differences between b17a and b16a heads
- Push button ignition install on 98 gsr
- running rich, side effects.
- How to wire up msd 3 step and 6al
- Shakey Steering wheel, what's up with that?
- vtec vs non vtec d-series
- Attn: Peeps with VAFC's
- Laser shields - Jammers - Stealth devises - Hype or do they really work?
- Please help. What catalytic converters will fit my '96 GSR?
- air rods/air bag suspension.......where to get information on it?
- engine swap.......trade in old engine?........................................... ...............
- Those of you that have KONI Sport shocks (yellows)
- best settings for cam gears on 99 civic si
- I need tires. Any suggestions?
- shocks
- checking compression
- Can you flare plastic fenders??
- knock sensor problem
- Coolant Fan Problem
- Window problem?
- O2 SENSOR PROBLEMS: NEED HELP!!!
- What should I use to clean under the hood
- Head installation questions
- Anyone have engine dyno/creation software?
- b16a2 tranny compare to b18c5 tranny
- Spark plugs and wires
- valves tapping and diesel sounding motor
- Sleeving a 1.8 to 2.0 what head to use?
- supercharger or turbo for an accord
- Will JDM DC 4-1 Headers pass smog?
- Where do I find clutch alignment tool and what brand assembly lube
- !HELP! ITR intake manifold on 1st gen. B16a, idling problem
- O2 sensor extension help
- dumb question but good to know
- dieseling (sp)?
- intake manifold...how do you best check for a leak?
- CAI question???
- Tranny Q?
- knock sensor for b16a
- autometers????
- Junkyard in MD/DC/VA?
- OBD wiring problems
- Which is which!
- A/F gauge not working - NEED HELP!
- flywheel remover
- What suspension should I use to get 10's
- Call me an idiot, but...
- clutch question
- 1300$ what should i use it on?
- do exhaust resonators restrict airflow?
- Dyno Analysis
- check engine light...unable to diagnose...S2000...ideas?
- how bad is a little ping?
- Should I just get cam gears and a CTR cam instead of...
- how much would this cost?
- what else do i need for a b20/vtec.....?
- ITR Tranny: When you drain the tranny oil, is everything drained out?
- arias pistons?
- tranny questions?
- topend tuning of B18C OBD1
- alignment specs
- Drag shocks
- where do I install IAT sensor?
- Rebuild
- For Sale: Shock and Spring Combo... COMPLETE!!!
- TECH 5 SHOCKS
- Need Help - Question RE: Code 2 - 2nd O2 Sensor
- 87 CRX Spark plug problem
- ECU Problem Or Not? Help!
- Starting system help needed.....
- ECU question
- Squeeking Coilovers
- '87 CRX Exhaust options
- I have no clue.
- Best alarm?
- Keeping or not ??
- IAT mod????
- HOW to install FOGLIGHTS?
- need help on msd installation
- Unorthodox crank pulley: Question about timing mark
- Apexi N1 Damper or TEIN HA?
- HELP
- Mustang Throttle body on b18c1???????????
- How to Build an A/F Guage from scratch
- Turbo on a GSR
- Which will be faster? Need tech help!
- Gear Ratio Question
- ABS unit leaking, help
- can KONI SPORT ( not revalved) ahndle 600-700 LBS/" springs ?
- are stroker kits reliable?
- b18c1 (1800 vtech sir-ii integra) head b16a bottom end
- Neutral Safety Switch
- oil tap.
- ok...i keep blowning my ecu fuse(7.5)..help!!!
- Does a Type-R clutch work in a LS
- Japanese Honda Oil Filters
- Dyno in the area
- What is a good shock/ coilover combination? I t is for a 90 hatchback.
- problem
- wassup with exhaust cut out dump valves? does it work?
- Wiring woes, ECU code worries
- Scatter shield.....
- Stumbling on at beginnig throttle position
- ice box and skunk2 mainfold need help
- DC JDM Header specs??
- Not kidding..need help!! Throttle Cable/Throttle Rotor on Skunk2/GSR
- Help: Radiator fan
- HELP: Just broke bolt on suspension component...
- which motor oil should i use?
- making the horn work with momo wheels
- Wiring Aftermarket Coil
- Low idle, and ticking sound, this might be....?
- HELP! Throttle cable sticking after new TB installed?
- torque specs for strut bar
- greddy sohc turbo kit fit a DOHC????
- OBD1 and OBD2 starters why whould they be different?
- custom exhaust..from skratch to muffler ...
- PR3 B16A Pistons in a B18C
- Engine temp woes
- New Clutch Slipping
- How to remove fuel hose from fuel rail on B16a?
- Smoke from the dipstick hole
- What rpm do you like your H22 to engage your Vtec?????
- Are B16 and B18C5 exhaust valves the same?
- internal components
- ECU chipping?
- JG Class Action Lawsuit. JG giving you problems? Please Read
- how to connect proportioning valve in 89 civic
- synchro stuffed , help !
- Which would be the best, and have most potential?
- Stock fuel pressure vs. upgraded FPR
- spark plug wear
- Quick question about valvesprings
- es mufflers??
- To bore, or not to bore...
- coil-over system decision
- Heeeeeeeellpp my transmission in my si seems to have taken a minor shit on me!!!
- Procedure for dyno tuning GSR
- Looking for wire harness or ecu pins...
- Who does good Headwork in So. Cali??
- si wiring harness for 88 hb
- Top end? or Bottom end? Which is first? What is the most bang for the buck?
- could we bypass/eliminate o2 sensors?
- Help with hesitation problems please
- toda with turbo??
- Medium size portable air compressor for mechanic work... sugestions?
- PAEX Power FC CELight flashes at 4000 RPM--WHY????
- what is the best low compression pistons to use
- Best spot for water temp sender?
- Brakes on TL
- tranny problem + double clutch question
- Can a turbo timer clear out nitrous from system?
- My buddy needs some advice/help, whatever u want to call it..
- Injector impedance - help me out electronics guys
- ecu question
- Lot's of play in clutch pedal.
- Rust, please help
- help with B&M Command Flo on my civic!
- lag at vtec crossover point?
- Code 22 - VTEC System Malfunction
- fields vtec controller??
- Anyone have the CROWER 63403s????
- Hallelujah... it idled fine! =) B16A PROBLEMS REPORT
- What should be used to hold down CF Hoods?
- Balancing Shaft Questions
- cam sprocket question
- Help with AC..
- pinging sounds
- fields VTEC controller anyone!!!!!!!!!!!
- Hey, which do u prefer? hood pins or hood locks?
- NYState Inspection - Pass or fail w/ Nitrous?
- b16a idle problem??????
- HESITATION
