View Full Version : Tech / Misc
- How high of spring rate can KYB AGXs handle?
- Valve adjusment
- D-Series Tuning
- valve adjustment? should rocker arms move ?
- frame straightening question
- Please Help Me With My Bump Stop Problem!! =(
- Second gen b16 alternator
- CTR pistons in GSR... Few questions ?
- Anyone know the bearing codes?
- any hope for the d16y7?
- how much does hondata cost?
- b18c1, high compression, almost done.
- Carbon coming out the exhaust
- How do i know if my crank is still good?
- Speedo issues
- Flaming exaust?
- JDM shift boots
- O2 sensor interchange (for wideband)
- H22a in an EG clutch/flywheel/header
- steering rack fitting size?
- What is all need for rebuild?
- Block girdle.
- what size injectors for all motor?
- i need help???
- Stock injector flow rate for F22B2
- What alternative MTF can I use
- ways to improve suspension
- Help with wiring CTR headlights.
- Did i waste my money???????WTF
- Those with the act hd ss Clutch on there car??
- need help with install of power folding mirrors for an EK!!!
- civic and Integra pedal assemblies
- Differences between 96 SPEC. and 99 SPEC. for ITR moto?
- Desktop Dyno 2000 + B18C5 Specifications = WTF?
- This Sucks...HELP!!
- Clutch install
- Stock axles???
- Steering Wheel Alighment after installation?
- Found bad connecting rod bearing, now what?
- whats the best intake for a 94 teg Ls?
- Porting intake manifold?
- How do i take off the crankshaft drive pulley!?!
- Red Line fluids to use???
- Who runs ACL bearings in there daily driver?
- price of b20z cams
- adjusting cam gears
- Need help - what are symptoms of bad differential?
- Could the head affect compression?
- Need info on B-series
- ls vtec oil leaks?
- Transmission shifts into gear only when l let off the gas pedal
- Car won't stay started after fueling up?????
- spoon ecu advice needed
- exospeed dyno sheets?
- code 23 and coolant problems?? very worried.
- Is this compression calculation correct?
- Ever seen this happen to a crank?
- Kevlar clutch break in and some other clutch questions.
- poss radiator prob...hopefully not blown head gasket!!! HELP
- tranny problems?
- Question about Coilovers? How do you know which car it's made for? Can you buy 1?
- spoon ecu
- itr cams !!! how high can i raise my redline in a b16a
- rough idle
- SMALL oil leak below VTEC solenoid (H22)?
- What to do about B16 camshafts?
- Is there a difference with motor position???
- projectors
- is the ignition coil and dist ignitor the same thing??
- good place to buy jdm engines?????
- Injectors and ECUs
- Gas??? 93 octane??
- are bseries fuel rails compatible?
- My CRX wont pass emisions!!! It has a B18a1 swap!
- difference between the different ACT clutches
- Distibutorless ignition.
- Zex vs. Gude. vs. Crower vs. Skunk2 Sohc cams...
- Power gains
- p28, p30 - same, differences??
- Code 9 or Code 90?
- B16A2 valve clearence specs?
- Which O.E.M. Swaybar kit gets the vote for Good Quality???
- more power for the b16a1 motor
- engine swap?
- best oil?
- Anyone know the Felpro part # for a valve cover gasket for a B18C1?
- Internal fan problems
- Searched already - Important Question on fuel rails???
- vented hood......
- Engine noise!
- Vafc questions...
- Weird Suspension Problems
- main bearing torque specs B18C
- Intake question.
- head light went out
- Comptech Exhaust Silencer: Yea or Nay
- Timing belt install, TDC problem
- Yielding Yet Another 5-Lug Conversion Question (Searched)...
- VAFC Throttle Position Settings
- How do I add VTEC?
- help please
- suspension help mcpherson struts/dropzone coilovers. urgent!!!
- where is that long-ass sohc tuning post by someone here?
- does the civic to integra front brake swap throw off the front alignment? (93 civic)
- getting axle nuts off from my engine swap??
- Pivot shift light wiring??
- broke a bolt
- Question about Piston rings, order of installation
- Gsr main caps on a ls crank and block??
- where can i find info on 88-91 civic b swaps
- surging motor
- supspention website?
- Need help w. gf's Accord
- what are control arms?
- Turbo Install web page?
- I have a couple ? for the techs.
- SOHC EXPERIMENT! (crosspost)
- does performance intake & other performance parts take away from good gas mileage?
- Location of ABS controler in engine bay?
- actual weight for b16a block
- vtec not workking ppleease hhhheellllpppp!!!!!
- 90-93 integra pass side seatbelt won't go back up help!!!!!
- vtec not working pleaseee help.
- brake swap
- Quick Question About Removing the Head...
- Hi I am trying to decide to go with a coilover or a spring.. can someone help me?
- Craftsman torque Meter
- Check engine light problem...
- bottleneck theory
- GS-R crank Girdle which Oil pan??
- Port and Polshing Heads
- Oil Pump Housing TQ Spec
- running rich??
- can someone explain gear ratios???
- Would an si exhaust manifold fit on a vx?
- stock shocks
- Shot peened rods??
- waht kinds of bars???
- Sway bar specs?
- Will a GSR TB bolt up to a ZC intake?
- B16A mod
- How can a coolant leak short out a coil and spark plug?
- Emissions help
- Torque sequence for B18C1 valve cover?
- Master Cylinder Noise
- Long Block and Short Block ?'s
- tranny bad knocking help, thanks
- Should I clean my 10 yr. old gas tank b4 doing the swap?
- mods advice
- Help, running way too rich
- ARP Main cap studs help for high rpms??
- Electrical woes :(
- GSR ?'s
- Best Adj. Cam gears
- Will a B16A (siR I) bolt up to a stock HF cable tranny?
- What is a good site to buy a B16a from
- hesitation and stalling?
- skunk2 cams dyno charts?
- Who makes these?
- Gsr bottom end
- v-afc boost hack??? anyone else??
- Type R Front Lip
- alignment/toe/washer question
- tech question
- Pulling out H22A
- Wheel Question: Are hub-centric rings neccesary?
- ATTN: everyone with AEM Cold Air Intake
- Is it dangerous to use "high-revving" cams in an LS/VTEC?
- leaking hatch
- Rod Bearing TECH'S! HELP!!!
- slave cylinder question
- How is the user end of Hondata controlled?
- honda transmision specs
- engine ground kits?> are they worth it?
- ying yang
- what cylinder head is a PR3-4??
- Could someone interpert this for me?
- Cometic headgasket questions
- new dyno tuning in sacramento area
- resetting the CEL light, how to?
- gas prices?
- Exhaust for the F23A1 Engine
- ? on piston size & cylinderbore
- Weird timing bellt noises
- HELP: Installed Momo steering wheel, how do i get rid of the SRS light ?
- worth it to put a new engine in an '89 accord?
- D16Y8 Transmission Swap?
- dumb question if you don't mind
- Inspecting a tranny before purchase (what to look for?)
- Tool rental?
- Test fitting pressure plate to flywheel. Have a problem....
- Which bolts need lock tight on clutch install?
- My moms car is broken can somebody help determine what is wrong???
- solder and wire splicin ** any tips ?
- Moon Cut valve covers
- What now? Help!!!
- exhaust?
- advanced timing killing top end?
- Guages
- L00K HeRe!!! HuRRy!!!
- Best H22 Cams
- fuel injector compatability
- obd1 pr3-j51 rev limit?
- Possible to have a bad igniter and still have spark?
- calculating displacement
- ob2 ecu pinouts
- Any reason to get exhuast bigger than collector?
- Strange Noise When I Brake...
- what does warp mean and how do you know if you warped your head?????
- OBD II Distributor using OBD I plug with OBD I ECU , that OK?
- Installing Sk2 intake mani on B20b Q's
- b16/b20
- B20A build up
- Ground control vs skunk 2 sleeves
- ECU to firewall harness..... 92-95 p28 with 92-95 del sol interchangeable??
- I NEED TO SETTLE, are cams and cam gears considered internals.
- Turbo
- WTB: Throttle Position Sensor
- Help! I messed up pretty badly!
- RS Machine Products?
- coil overs with tokico blues???
- Is the block number a false sense of security? What am I not understanding here?
- d16z6 How to change trans fluid
- Need help with clutch line intallation
- Any reputable machine shop near or in the SF Bay Area?
- if speedo cable is not pluged into transmission,, Will VTEC work??
- Header design features
- B18C1 all motor idea
- how to tell if the ecu is bad on 90 civic dx hatch?????
- What cam to run in my B18a???
- GSR head on ITR block
- Cluster's that will fit?
- Crane ignition... cap and coil needed?
- Can you have a bent valve even with high compression test results?
- Stupid Q: Will I notice anything with an upgraded radiator?
- Will 90-93 B18a dist. work on 95 B18b?
- OBD II vs OBD I LS distributor, will it work??
- What air intake???
- Taking apart 6th gen (EK) coupe taillights?
- White smoke coming out of the exhaust manifold
- How to build up my b18c1.............................
- Is there any specific way to clean an O2 sensor?
- rough idling sound from exhaust after valve tune
- s2000 motor
- Engine oil dipstick and oil leval qustion
- Hydro clutch problems, please help!
- sputtering in vtec
- will lud efive lug fit civic?
- gavtec/rev of p07
- any 1 need a S-AFC-Profec-B
