HELP! Speedo Freaking Out...
Old Nov 24, 2003 | 04:43 PM
beedoublejay's Avatar
Default HELP! Speedo Freaking Out...
Ok, I was just wondering if anything besides my VSS being bad could make my speedometer not work once in a while. Some times it bounces around like crazy, and some times it doesnt even work. Any help would be appreciated.
BTW: the car is a 96 civic hatchback with a mini-me motor.
Thanx in advance.
Old Nov 24, 2003 | 05:29 PM
MEANB18's Avatar
Default Re: HELP! Speedo Freaking Out... (beedoublejay)
Check out your grounds, I had this happen when the ground was bad on my battery terminal.
Old Nov 24, 2003 | 06:56 PM
Default Re: HELP! Speedo Freaking Out... (MEANB18)
I'll try, that thank you.
Old Nov 25, 2003 | 08:39 AM
Austin's Avatar
I also had this happen on my car when the primary O2 sensor heater ground shorted out, it blew a fuse under the dash...I think that it was the VSS fuse, could have been the alternator fuse though...just pull every fuse and you'll find it if it's blown.
Austin
Old Nov 25, 2003 | 08:47 AM
doublejz's Avatar
Default Re: HELP! Speedo Freaking Out... (Austin)
don't forget about the ground on the thermostat, had that happen to me b4
GSREXMan
Apr 14, 2009 01:22 PM
6speed-ferio
Mar 16, 2008 06:55 AM
Diet coke boii
19
Jun 10, 2007 12:54 PM
blackie
Jul 27, 2005 02:17 PM
hitvtecgetloud09
Nov 12, 2004 02:42 AM
