View Full Version : Tech / Misc
- JDM b18c R timing issues. Please help!!!!!!
- Hondata help
- Clutch Fluid change trouble..
- Car won't start...
- HELP A/C wiring digram for 96-98 civic
- Rims
- D16Y8 Block with D16Y7 Head what timing belt?
- ARP head stud nut size?
- ?UBERDATA Qusetion?
- 1.7 vtec mods
- need help on '95 4cyl 2.2L odyssey engine
- Haltech E6k stand alone fuel management
- titanium or magnesium retainers
- b16 exhaust mani bolts
- will a d16z6 intake manifold work for a multi port swap
- really low compression in #4!?!? bent valve or piston rings?
- Need help Idle problem, car constantly Idles at 1000 and revs to 2500 or 3000.
- Running auto p28 car with 5 speed ecu?
- Low oil PSI when Hot
- jdm b16a tranny help...!?
- D16Y7 swapped to a D16Y8, major craziness, HELP PLEASE!
- gains on a k20/k24 frank motor?
- Distributor shocked the hell out of me
- Cyl (CYP) and Crank (CKP) sensors swapped?
- gear shift is not smooth at high RPM...why n how to solve it?????
- engine just dying after driving for long periods of time, can anyone help?
- wheel alignment issues
- D-series dunebuggy idea.
- longer muffler hanger bushings
- crx si not starting need help!
- possibly jumped timing...car sounds like a go-kart
- B20VTEC oil leak
- 1st gen b16
- which is best...b20v-tech OR LSv-tech?
- b16 in GSR electrical question
- Problem with my TPS....code 7
- Northern California hondata tuners?
- What Size Wheels to USE?
- 04 ex gauge cluster into a 98 ek??
- Blinker in mirror wiring?
- Idle Bolt on the back of tranny?? Spliting the 2 pieces of the tranny, any sugestions?
- jdm b16a tranny...
- Hondata tuning units.. Help please...
- Wiring on Integra parking lights and turn signals. Need help please
- fuel filter Banjo bolt
- Should I replace gaskets with new header?
- Radiator Resovoir Overflowing?
- Accord questions (rings, valve seals, timing)
- Need brake help please - Wilwood brakes
- what is code 68
- computer resetting itself
- injectorproblems
- traction bar question....
- HELP!! AC compressor noise w/ revs
- problems with dying 90 accord w/h22
- 5 different ZC engines?
- Is My Cam Timing Straight??? ***koo pics***
- B17 Pistons in a b18a would it be safe
- Need help with Ultra MDI (Does anyone speak japanese?)
- suspension help!
- opinions on header and intake manifold
- Help:Pulled vacume hose off of brake booster brakes wont work when I put it back on
- help !!!rear brake pads jamming !!!
- too much oil?
- I need a Clutch Alignment tool in BAY AREA!!
- engine shocking
- Turbocharging 4.gen Accord - what do I have to consider...
- What size tires for 15x6.5" +40mm offset wheels?
- Oil pan bolts??
- Metal Shaving in Engine Oil
- Bad Tranny??????
- help with code 21 :(
- quick timing light question:
- Frustration with B18B Camshaft Holders
- arcing! help
- K24 specs needed *Help*
- automatic transmission question...important
- where can i find a big brake kit for a 91 civic hb?
- GSR head bolts are the same as B20 bolts?
- HELP WIRING IN 12v harness greddy remote switch
- ignition guru's here my call..
- No spark??
- Can i use DSM injector clips w/RC 310cc injectors??
- b20vtec throwing code need soem insight asap
- ITR CTR Cam Speculation?
- ITR BRAKE CONVERSION.... everyone knows about the front, what about the REAR????
- JDM B18C w/ LSD - What gear oil to use?
- Compression tester solutions
- Solve my problem and receive $10 thru paypal
- accord hesitation question
- Who was selling those P/S removal kits a while back?
- Bent Valves, Low compression?
- secondary o2 sensor making vss sensor cel
- HyperClutch ACT Clutch Went Bad on Me! Take a Look Here! Less Than 5K Miles!
- **HELP** 93 prelude idling problem
- can this be a clutch problem?
- muffler volume vs. tip length - question
- skunk2 upper arms
- guage cluster not working....
- Capping off oil line??
- #1 cylinder not firing
- P72J ECU in 00 Si EM1 (Tach Problems)
- tranny issues, help please?
- Please Help -- Transmission / Clutch Trouble
- K series
- Break-in question (not the usual easy vs. hard debate!)
- V-AFC II
- reconditioning fuel injectors
- turbo d16y8
- synchro question
- fried ECU because of larger injectors?
- need help bad please help me
- How much slack in timing belt? Just want to be sure.
- Looking for Hobby shop in the Bay Area...
- OBD-2 4 Wire Oxygen Sensor into OBD-1 EG w/d16z6 *Searched and no help
- progressive vs. linear
- Eg6 Hatch auto to 5spd changeover
- what can happen if i run without the timing belt cover?
- what can tokico illuminas handle?
- 96 accord ex vtec...knocking sensor help???
- Oil Pressure Gauge Help
- those experienced with alignment racks
- Help-Lucas Injector Seals
- antenna problem!
- NEED HELP!! COOLANT ISSUE
- ignition switch integra
- Honda Training Center Pics inside
- installing shifter bushings?
- Please help me end all my decisions.....
- In general, how good are stock retainers?
- Help b18c5 swap
- Car won't start, I think it is ignition switch, but need someone to confirm
- obd2-to-obd1 pcm question.....
- NEWBE Q Wiring Harness
- what is on this ITR axle?
- What do you think of DSM injectors????
- Amber Gauges?
- Rust on Clutch???
- injector question
- Just a little tech tip for pulling codes.
- NO SPARK
- Lighten Flywheel
- Vtec Low cam problem
- techedge wideband 1.5 problems
- 4 wire o2 what wires go where?
- Swelling lower Radiator hose.
- b16b valve question
- what timing covers do i need
- Has anyone used a mugen ecu?
- HELP! my speedometer bobs whenever i gun it past 5k rpm!
- ABS Going out, I think?
- SRS light..HELP EVERYONE!!!!
- 2 plugs running rich
- Alright to change only 1 side of my brakes?
- what are some causes of low oil pressure?????
- Type R trans bearing confversion
- ignition control module (icm) interchangable??
- my b16 wont start
- What fuel pressure should I run on my B16?
- where is the map........
- 1.8L into 2.0L,, Which Head Gasket??
- Who can say it took them more than 13 hours to do rear coilovers??????
- please help me
- just changed destributor and smoke poured out of my intake ---obdo
- P72 ECU good for LSVTEC setup?
- found idle problem, need advice on how to fix
- piston to cylinder wall tolerances???
- Dart block with LS crank, what bearings??
- Will ITR throttle bolt onto a b16a 1 manifold..
- complications with k swap in eg.????
- 91 Civic stalling problem HELP
- car sputters and idles funny
- b18b
- Apexi turbo kit
- b18a a/c compressor same as b18b?
- What does...
- building an engine
- Speedometer does not work
- did i get the right sparkplugs for my b16 turbo?
- JUST MAKING SURE THERE IS NO DAMAGE?
- What honda comes with a 4030 prop valve?
- Honing FRM sleeves
- A lot of white smoke when starting the car
- removing immobilzers
- Anyone ever used an Actron Sensor Testor Professional?
- PCT Pistons in B17 - Build Problems
- is LS/GSR fuel feed hose/rail/filter the same.
- Proper size tap for b18a/b block
- Rear Disc Brake Conversion On EJ... Worth It?
- Need some advice for a b20zvtec
- Trannies with straight cut gears and dogs, no synchros...
- b16 and a6 ecu
- Fluid Leaking From Between The Oil Pan & The Block
- Oil Problem Please Help
- aem 3.5 bar map sensor
- Left a bolt off of my IM
- Need Help With Car Trouble Mini-me Problem
- Camshaft caps question
- no compression...need help...will pay $5.00 with paypal for right answer
- b16a3 VS b18b
- feel vtec but dont hear it??
- Help with coolant..
- stroke: does more make the engine weaker?
- Will a obd1 map sensor work in a obd2 car??
- WTF! should i SUE KYB!?
- springs to coilover transition
- External fuel pump problems Need help please
- LS/VTEC PROBLEMS.........HELP PLEASE!!!!!!!!
- hp ?
- do EG/EK trans parts interchange with EF/crx?
- Need help with distributor swap
- rpm idle question
- what cams cams can I run with is setup?
- home made turbo (1st time here)
- will a Greddy Probe kit work with a Autometer EGT gauge?
- DAMN TACH!!!
- Tranny Opinion...
- Measuring Main and Rod Bearing Clearances - More accuratly then Plastigage
- engine codes
- Jumping Tach!
- Buying wheels and tires, need help with sizes
- edelbrock turbo kit
- ohio sleeves???
- D16y8 spark plug tubes... how do u take em out? lol
- Final Drive (JDM vs. USDM) tooth count on ring gear / differential?
- Comp Cams Stage III, now no VTEC
- distributors?>
- shop in 949/714
- Need detailed specs ( factory issue) on valve seat grinding/cleaning on a d16y8 head!!!
- What size socket to remove ECT sensor on DOHC VTEC Head?
- 96 cx.....mini me swap!!! please help me out a little bit!!!!
- Is a manual Vtec possible?
- alighning clutch?
- Another oil pan thread...
- Differential help
- can the VAFC II do the same things Uberdata does?
- ABS and seized LCA bolt. Can you drop whole suspension? ABS line runs between LCA and shock.
- I want new Tranny Synchros
- Paint for brake parts?
- Oil probs
- ****did b16 swap need help****
- Problem with throwout bearing in cable tranny..
- New Clutch...Big Problem, Pls HELP!!
- all d series 92+ civic use same shift linkage?
- '96 Hatch e-brake problem.
- Bent Half-Shaft?
- how do I confirm identity of these injectors?
- Help me troubleshoot why this happened
- Will my car 'turn over' without a distributor?
- Can I use a peak and hold injectors (obd0 2nd gen integs) with my stock obd2 ecu???
