View Full Version : Tech / Misc
- Paddle shifters?
- question on sway bar for g2 gsr
- A new sound. Is it rod knock?
- I want to know how it is possible to put oil squirters in a non-vtec block?
- Skunk2 Coilover Adjustment Help
- vafc
- Stock camber specs on a 92 civic?
- Can someone explain this to me??
- removing water spots
- Mugen Cam specs...
- zdyne gold secu
- What is stock VTEC X-Over point for B18C1?
- oil squirters in ls block
- Now that there are some new cars out, are there new engine swaps available?
- Spring rates: 375F/425R for a 92 Accord sedan?
- Radiator question
- Quick! whats the socket size for Sparkplugs?
- Has anyone tried the ryanne motorsports knuckles and endlinks?
- Leak Down Test
- stalling
- Stock Pr3 speed limiter
- Wheel HOP in SI...
- Tools, valve adjustment toool, where ?
- How does a lowered car drive in SNOW?
- nu-skool v. old skool (iVTEC v. VTEC)
- bore
- would stalling in a new clutch during the initial break in period wear it out prematurely?
- Low $$$ ITR/CTR 5 lug conversion...
- lowering car durability
- vtec-e
- best way to remove paint overspray on motor?
- Temperature
- loosing oil, HELP?
- Need Help Droppin my teg??
- V-AFC settings for a mini-me
- Help, Ground control install!!
- How to check if Motor is Stolen???
- question about rx 7
- Help on Brakes
- Question for those with Eibach Pro-Kit
- I think I may a have a problem....
- OHV?
- what pistons fit in an LS integra block
- Octaine Boost Question
- Question Regarding Civic Type-R Pistons & Toda Spec. Cs
- car won't start...
- need help with the Z6 vtec solenoid
- suspension question....
- compression ratio??? b16 pistons in a b17
- 99 Honda Civic Si Valve adjustment specs
- Cat Bypass on OBDII
- KAAZ tranny oil alternative?
- I need engine specs
- is it possible to get the headlights out without removing bumper?
- brake peddle sitting really low...need help
- Clutch Gurus: Master cylinder problem?
- ATTS Fluid Change - Help
- any1 have past tech threads about nitrous?
- Problem when Braking ITR - Throws to the right Dramatically! Need Advise
- Broke the tip of the lug nut stud off!!!
- attn: DragII Civic
- Changing from Conventional to Synthetic oil
- Idle problem...tech are not helpful
- California Smog a JDM
- GD MF POS AXLE NUT!!!!
- Which muffler to get?
- I need advice about my Transmission ASAP
- what ECU do I use?
- Extrudehone
- getting oem bumpstop off
- Coilovers vs. Lowering springs
- Are injectors OBD specific?
- need a headgasket for ls
- Wiring harness q for B18C EK
- Any experiences with Top Fuel products?
- Electromotive Inc
- honda valve adjustment tool ?
- what's VTM ?
- Head Gaskets
- Question on brakes.......
- Will ITR lsd work in a s21 tranny?
- Red Lining???
- clutch
- Autometer gauges
- PCV Valve
- I am so fucked!!! PLEAE HELP.
- need shoft shifter for 95 Accord, should i get the bushing?
- Torque Steer?
- How hard is it to put on the OEM body kit?
- I know this is a dumn question, but i never read anything about it>>>>
- removing resonator
- No compression in my type r shortblock
- Need Motor setup advice...
- Proper mounting of oil pressure sender for autometer guage?
- 01 GSR Front Strut Bar Factory to Aftermarket worth it???
- Has any one tried a steped exhaust?
- Visible changes from 98->99 LS intake manifold?
- JDM Transmission Woes
- CTR cams in B16A engine - what else do I need?
- Code 14, rough idle, 90 Accord
- gsr manifold on b16?
- HOW MUCH TO PAY FOR A B18C1 ??
- How Motor Oil Works
- clutch problem
- Hondata and ecu tuning.
- Upgraded brake master cylindar?
- Who is a good engine builder?
- Stupid questions I hope somebody has answers for
- Is my o2 sensor bad? (rich/lean)
- Is the absence of weight delusional to speed?
- Can somebody tell me where...
- Best machine shop to send your block to?
- tuner shops in central florida
- Oil pump/Assembly
- 2.4 L....is it worth it?!?
- Speedometer Calibration
- Removing apper ball joint?
- Need tranny codes!
- hp and syntec oils?
- Would eibach prokit springs blow out my shocks?
- secondary O2 sensor.
- gauge cluster
- Koni yellow install help?
- B series Transmission question
- carsound cat's.
- How the hell do you seperate the tranny from the engine?
- What is wrong with my tranny?
- Aem Power Pulley for LS integra..
- am i wasting time and money
- Any know the Spring rate of Neuspeed Sports?
- Mix-Matching Shocks? KYB AGX in front and something in the rear?
- emissions testing JDM B16a
- "exercising" ABS
- integra sway bars
- anyone know what pistons and rods to put in a 1.6 sohc non v-tec thanks
- why not obd2?
- Which clutch/tranny do you prefer w/ pricing.
- would 16" rims and tires dropped 4" rub the well?
- New turbo kit??
- pinning the vtec - need pins
- jdm itr ecu
- CRX dx with new zc swap, Codes 7 & 14...Suggestions???
- venom 400 ?s
- Clutch removal/replacement
- need info i engine swap
- How much oil do you guys lose by 3000 mi?
- Torque and horsepower curve data
- Need help with suspension (DC2 components or aftermarket?)
- Shocks vs. Struts
- Short shift kit shifting like shit...
- rear strut bar...do they work???
- Compression test for my B18C1.. the results are in!
- formula for compression ratio
- Best ways to cool down a b16a...
- PROBLEM:Strange clank clank clank noise after vtec is engaged
- o2 sensor?
- idle again,
- Anyone have Jacob's Electronics I.C.E PAK?
- ATTENTION HELP.LSVTEC
- Can a CRV run okay with a gsr bottom?
- Building block for B18...please look..
- up the compression in my Ls
- Using a computer in the car
- Installing Beaks itr bar kit...what a pain!
- straight pipe
- KAAZ LSD for $400?
- How can my Civic HB(5G Si) with B16A run 12's all-motor or Nos?
- Accord Calipers
- need tips on breaking in rotor and pads
- tips on breaking in a clutch.
- help with ite intake maniold on first gen b16.
- catalytic converter ?
- changing coolant in V6 6gen accord
- Anyone have info on hondata? mostly the adapter cable that lets and obd2 car use an obd1 ecu.http://
- b18 - Gen III drag kit = what times?
- Bleeding ABS system. Please help ('92 Accord)
- putting a vtec into a non-vtec car
- LSD what are the options?
- cheap suspension?
- Wiring Greddy Gauges into Dimmer Circuit?
- Breaking hub nuts to remove driveshafts
- if i take unbolt one of the brake lines off of the caliper, do i have to bleed all four wheel?
- gauge clusters
- skunk2 coilover install please help
- tensioner bolt hole stripped
- Bridgestone Potenza RE950
- Tranny: The truth about synchros?
- code 67..???
- Need help hooking up step 2 modulator.......
- retarded car w/ retarded short
- Short Shift adaptor
- Custom exhaust piping
- Takin Tint off the back window??
- Codes
- H&R Sport bumpstop trimming
- 96 gsr diff works in jdm s1
- ignition advance rules of thumb
- Any one know of Bay Area Tranny Conversion Shops?
- What pistons and rods to use on B20vtec?
- Head Bolt Removal Sequence
- should i get a new motor?
- b16a engine problem
- B16piston/Ls Block CR????????
- Desktop Dyno
- ClutchNet clutch....
- Electrical help please
- ATTS v. LSD
- Saturated or Peak & Hold
- Hondata Users: Quick Question.
- Need more power
- damn emissions testers!!!
- custom piping or cat-back?
- dumb question... relocate battery in the trunk
- b20 injector flow rates!!!!!!!!!!!
- Erratic Idle **Need Help**
- Suspension set-up?
- Radiator fan not coming on
- Thread size for oil pressure sender
- 200+H.P. Civic EX! From Bolt Ons!
- Funny Story, or Not
- Can I swap out cranks?
- nitrous kit installation
- Floorpan Damage Possible?
- how to set up fuel maps for VTEC?
- How harsh is an unsprung clutch disc?
- Jet reprogramming..
- 90,000 mile tune up
- R&D Stroker Kits??
- Lowend Exhaust Power
- Carbon buildup on pistons
- Weird sound coming from car at idle
- ex/cx/dx injectors the same??
- Check Engine Light
- Sears Auto-center Dunlop tire story
- accord=interchangable
- Opinions on Cams for SOHC D16Z motor?
- Timing and TDC questions?
- ITR cams
- IS a lighter flywheel safe? Balance wise?
- Do any of you know this guy??
- Best type of muffler?!?!?!?
- Toda Cams
- 14.4@94mph WTF is TRAP SPEED so low
- 92-00 d-series injectors all the same??
- Clutch....please help!
- Bad trottle response/acceleration
- Steering wheel shakes/ and other 97 EX problems
- Who Cryo's their Rotors? ...and where
- New Tires........
- Nology Hotwires + Silverstones, Good or Garbage? Need Testimonials
