View Full Version : Tech / Misc
- car WILL start with jdm ecu but WONT start with usdm ecu -b18c in civic-
- Reverse Lights
- D16Y7 TRANNY QUESTIONS
- PLX O2 sensor
- Instrument Panel (Trunk Light) Problem
- uh oh, NEED HELP??!!
- ID this Throttle Body for me, please!
- So I buy this built block extended deck 86mm...Couple of questions
- Air Compressor??
- Pic of my bend valve...
- Leaking valve seals or Piston rings=Veg oil or atf trans fluid?
- tuning and instaling hondata
- rsx type s differential tollerneces???
- B16B ECU help
- Quick B16 Head Question
- preventative maint. question
- GearSpeedEF7 question for ya
- Failed Emissions :(
- K20A OR BUILT B18C BOOSTING 20PSI SAFE?????? HELLLLP
- h22a swap wont start???
- D16 TB swop with B16 TB
- Check Engine Light goes away before i have a chance to pull the code...
- compression test adapter stuck in cylinder, HELP!!
- gsr into a ls integra
- competition clutch
- In need of professional help with ecu
- how hard is it to install AC?
- 4.4 or 4.7 final drive for autocross
- Rod knock 1990 Accord EX
- Is this block repairable ? UPS scratched my deck
- Valve Lash Causing Scary Noise???
- Removing freeze plugs from an intake manifold
- Overheating.....kinda
- Overbore d16z6 with Nippon Racing/NPR 75.5mm pistons...what specs?
- Emissions problem
- Changing Throw out bearing help
- cat question?
- Rebuilt transmission: differential spins freely?
- lookin for a good tuner in eastern NC
- mini me help
- Axle seal for B16A out of 91 CRX SiR
- auto B20b cams...?
- newbie question!
- VAFC Issues
- no vtec pressure switch
- ZC DOHC ignition timing
- b16 tranny wont shift
- HELP!!!!! White Smoke and Oil on spark plug
- Tracking down why Vtec doesnt work. Look at this. PICS
- Running poor
- 99 stock accord and VAFC II
- Vtec solenoid missing pressure switch?
- b16b vs. b18c map help from those that know
- AEBS (meziere)electric waterpump on a B series
- I need a ring gear for my B16 hydro transmission, which one?
- blox cams
- Thread pitch for hardline fittings on brake and clutch cylinders
- auto bseries in a ek chassis
- FRIED Hondata s200 p75 ECU. HELP ME! What caused it? SMELLS TOASTED!
- B-16 obd0. Which distributor do I need?
- HELP need to fill my tranny???????
- Nology Hot Wires with haloplug sparks
- cat question... steel or ceramic?
- Installed cams now car wont turn over, sounds like no compression
- Best wideband gauge setup? cheap quality?
- Fluctuating speedometer...crank sensor?
- OBD2A to OBD1 Conversion Harness diagram.
- computer chip auto to manuel conversion?????
- obd2 with only 1 02 sensor?
- ls vtec!_!_!_!
- Need Help with My Civic 1.6 Vtec
- Ls Crank in GSR....????
- Spark plug wires and spark plugs Q!
- gsr tranny quaife lsd
- ex wiring harness question
- Overbore questions for a d16 engine.
- Tempratures effect on power output
- Craftsman 4-Ton, Low-Profile, High-Lift Floor Jack with Fast Lift
- a/c EXPERTS! air conditioning Q's : used system, exposed to air, sitting in garage. should i do a fl
- Colder plugs?
- MSD IGNITION QUESTION
- need help with blinker problems
- LS oil pickup same as GSR???
- B20 piston pin removal???
- Windows Vista and Crome ?
- GSR No start, replaced cam seal, wires, spark plug, distributer cap n rotor
- Illinois Emissions
- XTD STAGE 3 clutch sucks!!
- s300 problems
- need to set initial timing B series
- EK9 and DC2 recaro seats difference.
- External water pump
- VAFC Tuning (Modify Vtec Engagement)
- How to differentiate between EK4, EK9 and DC2 cams?
- Integra Pulleys?
- Act clutch?
- 91 hatch question
- VAFC II -- HELP NEEDED (problems)
- Valve cover question
- bad head gasket ?
- 88-91 y1 factory ef9 lsd - quaife y1 ef9 ls- fitment into 92-95 delsol vtec transaxle
- LS/VTEC or B20/VTEC for road/canyon/track racing
- 114.3x4 axle question
- BLOWN HEAD GASKET ?
- Pulling vaccum from intake tube?
- Engine Block Questions?
- ACT clutches = junk
- car won't start
- S80 tranny Qs
- Is this axle bad? VIDEO
- NSX caliper on delsol
- Crazy combustion / octane ideas (theoretical ponderings)
- tranny problems d16y8 trans
- 90 LS CODE 43
- H22 Help!
- 92 95 civic radiator help!
- 92 95 honda civic
- Ls tranny into b16a motor, would it fit properly? If so, would it be efficient? Good or bad combinat
- Which clutch and flywheel?
- GSR ITB help
- Anyone run short sweep guages?
- Tuning an obd2 D15b 3 stage
- o2 sensor wiring
- b16 gsr lsd
- CRX with ITR brake swap problem !!!
- misshift
- hard shifting into first and second.
- Head swap question?
- Need help in Delaware
- Is your transmission knocking when you idle? Is it loud? I fixed mine (Pics + Parts)
- Will i pass emissions?
- intake mans
- skunk 2 cam gear ?s
- 97 Cluter to 03 Cluster
- need engine codes for 94 eg
- Obd2 and state inspection ??? NJ
- stumped on CEL, are you smart enough?
- T bolt Clamps
- question!! d series
- obd2 harness plug help!!
- GM Syncromesh Fluid
- code retreaval
- simple wiring question...resistance ? for all you guru's
- ARP Flywheel and Pressure Plate blots
- help please..? new clutch
- Auto tranny problems: Codes and a description inside
- DIY: How to make fuel lines
- Need help Main Relay Keeps going out!!!
- REAL Hydraulic Transmission Conversion
- I need help man
- NEED HELP ASAP!!! MY CAR HAS CODE: P1129
- i am having problems with my hondata
- B17 fuel rail problem
- Messed UP!!!!
- Low rev, oil in spark plugs. HELP!!!
- is my caliper gone?
- B16a3 distributor question
- Civic Si fuel pump same as GS-R/ITR?
- Cam Gear Covers Interchangable?
- what b- series tranny do i have ?
- Aeromotive FPR Users
- walbro fuel pump
- which o2 sensor?
- Crower 402T Cam Question
- ARP Main Stud and Girdle question!!!! HELP!
- H22 needs new rod bearings ??WORTH IT? ???
- ATS gear kit - jumping out of 4th
- O2 Sensor Wiring: Which wires matchup? (GSR)
- kaaz lsd install need help please!
- skip at 1200ish rpm
- code 6 and 14 sensors gone bad?
- 92-95 d16z6 throttle body. Where does the small hole on the bottom left lead to?
- boosted b20v ecu help!
- help>>>stock sleeves question
- wire tuck connectors ???
- F1 Racing clutch and ACT Plate??
- windshield knife ??
- is eg gears interchangable w/ ek gears??
- Best OEM head/intake combo for tq?
- ls/vtec turbo low oil presure help
- anyone know if supertech valves...
- d16a6 crank in a d16y8?? will this work??
- car won't start again...could it be the timing?
- Need a write up on trans dissasembly/reassembly
- anyone know how to convert a 5spd p28 to an automatic?
- b16 transmission problemss
- installing a built head?
- k20 type S surging idle
- temp gauge not working and throwing code 6(ect sensor) help...
- check engine light not working!!!help me please.
- Need a transmission specialist for my transmission question.
- Block sleeving question
- obd-2 97 ls teg w/obd-1 swap???
- Hydro Conversion
- What VSS To Get? OBD0 B16. Do D16 vss's work?
- PCV Diagraming/Installation
- Stored my car, now diffuculty braking + burning smell... HELP!
- VSS Code 17 Vehicle Speed Sensor Cable speedo No VTEC SEARCHED
- bent spark plug?
- can anyone id my B series trans by speed and rpm?
- cable to hydro
- wiring diagram?
- low compression help maybe timing??
- Solid cel sporadicly
- piston pin removal???
- B20B redline???
- Need Help identifying These camshafts (Pics)
- b18ci head change to itr!!
- clutch master and slave
- Ebay Tri-y header vs Profab header
- Brake issues...
- few questions bout swaping parts (teg, civic)
- B18b Ls-t STOKER KIT????
- Can you remove the IAT sensor?
- obd2+turbo+emissions=FAIL! obd2 turbo guys plz help!
- 15A ECU Fuse Keeps frying. What can it be? 92 SI. Electrical Go
- Intake port dimensions
- Dyno opinions needed, ECU reset before or not?
- New clutch acting up?
- Fuel pump won't prime... main relay seems ok?
- Opinions on cams + valvetrain
- sleeves sinking
- CRX JDM Front End H4H Headlight wiring...
- EK wiring conversion for crank sensor, need help asap.....!
- quick help with tps/map sensors on obd2b engine harness('00 integra)
- Yet another OBD2 to OBD1 question
- CN2 Straight Header Yo pro burners and chippers i need a quick answer!!!
- Vtec not kicking in
- fact or fiction
- Power steering removal in a 95 prelude
- Axle Help
- Hydrolock
- PLX wideband and Hondata S300 question
- obdo to obd1 conversion HELP
- Motor Mount Bolts
- b16 header
- Will a exedy stage II clutch Work for my setup ?
- just got a BLOX dual bend short shifter
- High Flow Catalytic Converter Question
- TRANSMISSION BLOWN:WARRANTY CLAIM DENIED
- o2 sensor still good?
- legend springs
- Motor swap question
- ???? whats the stock fuel pressure for 98' B18B1 ????
- JDM gsr swapped hatch needs Obd1 help (wtf is going on w/ this car?)
- Emissions failure, hydrocarbons too high
- Does Wilwood Road Race Brake kit work with Mugen M7's 15"s on a Del Sol???
- question about bore size and forged pistons
- O2 Sensor CEL Help?
- wideband sensor placement
