View Full Version : Tech / Misc
- OBD2-OBD1 Problem?
- Drilling into fiberglass/carbon fiber hood...?
- rocker question
- buddy club spec 4 snap my timing belt (need answer)
- Hesitation ONLY in Vtec
- zingle zc intake manifold on 99 y8 head will it fit ? searched no results...
- headers question.
- $10 paypal'd to the person to help me out with a Skunk2 I.m. install
- Idle/Full Throttle Problems
- putting Red S2000 seats in my DC
- Dead #4 cylinder help
- Is there a spec for Starter Clearance?
- a/c compressor problem!!HELP PLZ...
- Spark plug rethreading?
- transmission bolts
- please help oil jet problem
- car wont move (clutch or axle problem?)
- prelude with toe-like tire wear with good alignment - what gives!!?
- play on clutch disc shaft?
- Changine valve seals: Do i really need compressed air?
- nitrous help please!!!
- Help ID crankshaft
- Spark Plugs
- Won't shift from park after swap...
- obd0-1 conversion pinouts?
- B series Valve Guide Seal driver
- Guys who tune with Crome and Freelog, please read. Datalog issues
- NEED HONDA GURU HELP, ect problem
- car wont start
- intermittent no crank no start, solenoid always clicks
- b16 swap
- help with TDC what do the valves underneath look like? help!?
- F22a head application question
- CAM KINGS and GODS
- HOOD DAMPER ??? Anyone?? EG
- whats a good brand torque wrench
- B16A minor idling issues, but its annoying..
- honda civic power window relay
- SRS light
- TYPE-R OIL PUMP ON LS/VTEC HELP!!!
- p28 instructions
- College student not getting correct info please help explain Forced induction question
- b20vtec pistons?
- Rywire Not Answering
- Need help with ITR intake manifold
- How you can save fuel and the environment
- need input
- Question on wiring of the Field SFC
- Coolant temp. sensor
- Building a B16A Head. Info needed.
- Car won't rev past 4,000 ish. Timing at 4 degrees? HELP.
- gsr block ls or b16 main caps what would work?
- have fuel pressure, but no fuel at injectors
- Possible to reuse torqued but not heat cycled headgasket???
- Need alternator wiring diagram
- ECU HELP...
- 94 Civic B20b Injector Problem
- WTB B16 Variable Assist unit for power steering system
- map sensor questions with skunk 2 mani
- honda connectors and pins
- Oil Catch tank on D16
- after installing my header...
- crx bogging problem
- Ignition timing question.
- can anyone tell me what cams i have?
- Re-using ARP Headstuds and Rod bolts?
- Help Me With My Rim's.....
- Boosted B16a2, compression test warm and cold engine
- injectors not firing but have power and signal?
- Shaking while accelerating, but with new axles?
- Need to replace hose but distributor in the way!!!What to do??????
- What car did this ECU come from?
- can an car with a ignition controll modulue thats test bad still produce a spark?
- need help wiring distributer
- someone know...
- Low Oil Pressure....need HELP
- Dead cylinder on b16a1
- gsr bored...
- del sol & civic key cylinders
- What valve stem seal to use with oversized valves?
- Rad fan wont come on - not typical cause
- NEED HELP WITH WINDOW SWITCH AND MOTOR 2001 integra
- i call him....mini me
- D16z6 bogging down on power?
- b16a2 ek swap need help please
- Crank Fluctuation Sensor (CKF Code 54) Did search
- LS VTEC Cylinder Head Question
- obdo to obd1 distributor question
- Need Help!!!!!! Da Integra with B20Z swap
- Opinions on this port job.
- how to identify crower cams
- Idle Air Control valve problems...
- Auto to Manual swap.... does the TCM wiring need to be modified?
- FUSE PROBLEM OR SHORTAGE NEED HELP!!
- Fog Lights fuse - newb question
- what gauge wire to relocate battery?
- what kind of lsd is this?
- Avid Motor Mount Help!!!!!
- 06 coupe dash lights coming on
- Please help me identify valvesprings
- h2b problem
- Eliminating the Vtec valve
- fuel pressure issue on jdm b16a in a 93 civic si
- breaking up under boost?
- Is it safe to test ECU fuses with multimeter?
- wheel bearing replacement problem
- Axle stuck in Wavetrac LSD...
- TPS adjustment prob - only 0v/3.3v WOT
- wiring b16a2, need help?
- has anyone installed heated rsx seats in a 99 civic hatch?
- resistor box wiring 99 integra gs.. obd2 harness need help...
- Wierd check engine light problem on my turbo car
- 2"-6" Dial Bore Gauge - Which one for engine build...
- Name the gasket! where does it go?!
- Passenger Door Power Locks problem
- Carpet/Upholstery cleaning question.
- bore alignment on cam journals
- electrical seats
- head leaking oil?
- lengthen intake manifold?
- head valve cover!!
- what fuel filter is this
- jackstransmissions.com ????
- rear main seal with oil pan on...
- pr8-1 head
- hmm what to do with a mess up h22a
- B16 hydro mount question, and block?'s
- BRIDE SEATS...help determening if their fakes or real.
- can i still use this clutch?
- maintenance required on a 2000 civic si?
- Intake air temperture ...??
- 93 civic dx wont start
- motor mount leakage
- pivot fan controller wiring diagram
- what do you recommend for seat harnesses
- huge huge electrical problems.. in desperate need of help.. tyring to get my car to this show tomorr
- lsvtec no crank on start.....please help
- header fitment
- H22 auto tensioner???? WTF
- Valves not seating right... HELP..
- taking aem uego apart ?
- Thought i spun a bearing
- H22 eg hatch
- Ways to moisturize axle boots?
- hasport mounts rattling my windshield
- Transmission whining?
- Should Oil Pump Gears Look Like This??
- Which hondas dont I want to buy???????
- Rocker Arms B18B1 (Searched)
- Tucked My Hatchie's INsides!
- skunk2 throttle body gasket
- cam moved with timing belt off?
- what is the difference between pr3 and pw0 ecu's?
- difference between ecu's
- Structural Reinforcement
- Camshafts Help Jun cams?
- BDL B-series fuel rail installation help
- Looking for Repair Shop Cedar Park TX
- NEED MAJOR HELP WIT MY EF9!?! BTICH KEEPS OVERHEATIN N IT DRIVIN ME KRAZY!
- espelir jgt 500 exhaust
- I JUST BOUGHT A H22a
- H22 PISTON
- whats this valve cover from?
- obd1 ob2 head question
- What happened to Sohfast.com?
- OBD1 B16 cap/rotor same as LS? need answer asap thnx
- Surging while engaging clutch in 1st gear or reverse....
- different stage disc...
- D15B RATTLE QUESTION!!!!
- car won't start after ls/v swap.
- Weird Clutch Issue...
- xs intake any good?
- D16Y8 crank-pulley bolt
- Getting a JDM B16 Tranny..
- honda swap mazda
- Drilling engine mounts cause of vibration...U done it?
- b series in a 92 civic ex the ABS unit by the trans does the b series trans fit without relocating A
- thermostat help!!!!!!!!
- Please help! No Heat and cant change from main vents 97 civic with si conversion....
- Ok to run fuel hose behind the brake lines?
- throttle body
- Problem with keyless entry
- Hondata problem
- HELP !!!!! 92 Integra SPUTTERS AFTER 3,000 rpm.
- What car are these wires for *help*
- Bolts for Engine stand
- repair VSS wire harness
- help not starting
- How long does aftermarket valvetrain last?
- dscustoms gone?
- B20 vs. bored/stroked ls
- Mercedes c230 kompressor
- cam timing off?
- HomeMade DIY flow bench's ?? Has anyone ever tried to make one and susceded?
- ITR cluster question
- Recaro Seat Weight?
- i-vtec article
- Help! Car wont start after tranny install
- NEEDED ASAP: OBD2B INTEGRA GSR VACUUM LINE DIAGRAM
- How to adjust AEM tru-time Cam gears HELPP
- Both radiator hoses are hot.. is that normal?
- Long block Vs Short block??????
- Rear Harness Wire Tuck Ground Wires
- 2005 Mercedes Benz(supercharged 1.8) C230 Kompressor or 2004 Infiniti G35?
- Help! wat kind of wires can i use to extend my o2 sensor wires?
- intermittant cel code 9
- I'm working on the 5 lug conversion on my 4th gen Prelude-- I [freak]ed up--- help!
- Timing Belt alignment problem
- Do 2 door integra seats fit 4 dr?
- Gas pedal stud snap!! help please!!
- skunk2 stage2 cams with 70lb or 85lb supertech valve spring rate
- what is the thing on back side of intake ???????????
- Can you interchange manual flywheel bolts?
- Need advice on timing my motor!
- Stock hatch 94. cold start problem help plz.
- MD modification laws
- EJ1 -b18c conversion problems.
- map sensor wiring question..
- Will having a quick release fail you in smog tests?
- turbo B16 No vtec?????????
- GSR Swap Problems......
- rpms jump.. engine break up
- just got a swap, ecu problem
- Tranny problems?
- will cusco 1.5 with t1r 4.9fd fit my hydro jdm ys1
- JUN VALVES B18
- B series header?
- Anyone from Missouri?
- timing belt slack
- Wheel offset questions...Please help
- help my sister's on fire
- Questions of the cost of building a motor(pricing)
- Car was Attempted to be stolen, now having problems with mechanic/insurance. Please help
- mini-me swap , did I get screwed?
- Which set of plug wires?
- VTEC not working after engine rebuild
- No Tach with 01 gsr motor in 97 gsr?
- Oil burn-off (EM1)
- hks twin power ignition
- Losing Power
- Oversized Valves???
- oil pump check??
- o2 sensor (in cat) question
- auto to manual mount!!HELp HElp
- Running a cooler thermostat...
- Question: valve guides
- oil burning question
