- best motormounts?
- air hose from air dam into engine bay
- skunk2 cams???????????????
- obd2 ecu ( us spec. vs jmd spec.)
- built b20vtec redline
- Weird clutch... b16a/t21
- Engine Rebuilding OEM Parts Inquirey (Ls Vtec Related)
- Fluctuating Idle, Need help before I lose it...
- Installation of Skunk2 front camber kit
- installing 450cc dsm injectors in a gsr
- How much would it cost me to convert my DC2 to RHD??
- bizzar leakdown test question
- oil in my coolant reservoir
- Need to replace head gasket...
- 97 Civic Distributor questions
- Cat converter replacement - EG w/ LS motor, which cat?
- stp smoke treatment
- resonator box
- Re-programmed P28?
- (pistons)floatingpin or pressfit on stock rods
- How to adjust cam gears
- Fuel Pressure #'s?
- Itr manifold issues
- First gen integra trouble
- Will a 90-93 Integra Passnger side axel Fit b16
- Dnr Performance Pics
- How Can I insert a Picture??
- AEM intake help
- need help picking integra LS cams
- PCV Valve replacement???
- building my sohc
- Autozone valvespring compressor?
- piston wrist pin locks?
- Where to get new bumpstops?
- Accord Car Concerns
- clutch/flywheel/shift linkage swap now problems shifting. Help!!!!!!!!!!
- Removing Shift Linkage From EG Sedan?? please help!!
- STR Cam Gears?
- b18b and b20z cams, are they the same???
- what the fck... is up with search
- KYB AGX and Tom's coilover sleeves...
- piping size on header and turbo manifolds?
- skunk2 s2 vs jun 3 dyno charts
- cranksshaft bearings?
- ECTG location/testing diagram for CM-R
- Headers (As if this question has never been asked)
- 99 Gsr suspension..... on 92-95 civic
- ground wire kit
- Creaking Tranny!!!
- are you supposed to change your head bolts every time you take off the head?
- Autometer Water temp gauge????
- Here's a little progress on my D16Z6...input welcome
- Oh damn I think I hosed my axle. Help?
- when turning a crank how hard should it be
- ???? JDM itr--USDM itr cams ????
- Head Bolt!!??
- oil light!! help
- retainers
- Upgrade suggestions........help please!!
- strut bar ?
- vtec solenoid will this work
- need help asap my computer fuse keeps on going out
- b16 running too cool?
- Help! tranny gearing and turbos....
- Tech help!!
- intake manifolds
- Fuel pump
- Real quick question lining up the clutch
- Quick B-Series Question
- leakdown test
- AEM or Axxis?
- would a D16A/ZC rod bearing work with a LS crankshaft
- Injectors.....does it matter?
- Skunk2 Coilovers: cutting the bumpstops
- What to do with H22 IM?
- rotor screws.. help?
- will type R valve springs and retainers work on a Ls??
- wheel spacers..
- Converting JDM B16A to OBDI
- B17 cranks but wont start
- Swaping Guage Clusters?
- inspection?
- Spoon N1 Exhaust owners, comment about them here
- Boring out the B20
- whats the difference between this EBAY wideband and others?
- Cel Code 61
- Itr throttle cable
- custom radiator?
- my theory on ......its a lil outa the BOX
- I need help Wiring...Please!!!!
- about to buy techedge DIY 1.5??
- SRS and CEL41 after clutch install. Need help
- Nology wires ? Good or Bad ?
- H22/B16a2/B18C* into 1995/6 EG Coupe
- Stupid Question...But really need a Serious answer
- best muffler on the market
- OBD0 B16 coil in a GSR distributor.
- just INSTALLED vafc HELP please.
- OEM block and head gasket kits. What do I get?
- Who makes the best valves
- Unsticking Oil rings Idea
- A Question about Camber kits available for 92-95 Honda Civics.
- NA Type R setups with dyno results, please view
- ITR and GSR retainers
- pistons/rod? and tuning?
- what tires on 18x8's
- OZ alloys
- B16A identification
- distributor squeeling...
- what to look for when buying used cams?
- apexI v-afc install Qs
- What size wheels can I get to use my existing tires?
- how to change fuel filter on 00 civic?
- brake lights constantly on?
- Pr3 ECU Question
- milling and compression dealing with honda heads
- Dnr Performance
- Strange loss of power when engine warms up
- 88 LXI starting
- .040 Over Pistons
- speedometer and tach doesn't work
- Taking a JDM B18C to 180whp...
- b18 install no spark
- 99 Si timing belt on first gen b16?
- Help!
- Need answer quick....
- Electric RX-7? WTF?!
- #4 injector not firing HELP!
- crower stage 3 cams
- ECU questions?
- How much fuel can the stock fuel pump flow for a wet shot of NOS?
- exhaust question
- K-Series Oil filter on B-series motor
- a few questions...........
- Will a will b18b intake man. fit on b16a head?
- help with engine hot restart
- F22B1 vs H22A: Who wins the torque war, RPM to RPM?
- Compression Test results on D16Z6?
- Want to build an NA B20 Vtec motor? any setup suggestions.
- B18 head vs. b16 head - Good Info
- Porsche Calipers on an R ?????
- ZC engine problems
- redline ? on a LS
- projector headlight question
- fields sfc-vtec controller work with non-vtec ecu???searched
- Loosing Fuel Pressure?
- Wiring Diagram Web Site
- SKunk2 Stage2....vs.....ITR Cams
- oil pressure guage = boost guage?
- Just got TEIN coilovers any advice? or what i can expect?
- clutch installation$$$$$$
- what kind of timing are you guys running w/ 12:1 compression or higher
- Should I replace tranny?
- Where does the VREF pin from the ecu go to?
- how does ECG o2 simulator work
- Kelvin temp of S2000 HID's?
- need the best manual for...
- Anyone have a picture of a IACV?
- emissions machine?
- The ultimate LS/VTEC?
- hondata question?
- max bore question ??
- Car Won't Start Please help!!
- Question about OEM replacement headlights. 98+ integra
- ****Will a CTR intake manifold bolt up to a JDM b16 SiR II?
- broken differencial
- 5G Tower Bar Help
- How radiator cap lower your engine temp?
- B18b engine, what else do I need??
- dohc interga with a sohc
- 95 civic thinking about engine swap
- What tranny do I have??
- h22a swap help
- LS vtec turbo piston compression ration?
- Flywheel bolts ripped out!! =(
- PE timing belt for a H22A4
- fuel cut off "pr3"
- Car won't go into gear.....HELP
- White smoke coming out exhuast..Help....
- Anyone know the size of the threads of this fitting on the head?
- B16A3 OBD-1 Sol with Greddy 99-00 Civic Turbo Kit, Many Complications
- Will a GSR ecu work in an ITR?
- ACL bearings are they universal?
- Where to go to get hondadata s200 tuned??
- flywheel to motor bolts.. need help quick
- hydraulic operated transmission
- Compression ration question B16
- 99-00 Civic front lower lip aftermarket/OEM fitment questions
- Highest Comp on 91 Octane?????????
- what bolts?
- Is this CRX Repairable? Rear LCA metal support thing is mushed
- Sound Deadening
- Lost motion assembly question
- anyone out there know hp gains with a Gude head package on B motors?
- PGM FI relay?
- B16 vs. B20
- anyone got an injector i can have
- need TB bored out...who can do it? Port match to IM too
- chip
- anyone know a DIY site for making a 3" custom cai?
- Blown headgasket or busted valve seal?
- SC GSR VS. SC SI??????? PULL!
- Car won't Idle?
- Highest Compression on 93 Octane?
- car doesn't shut off in reverse and reverse lights don't come on
- do "racing" clutches affect reliability of a tranny.
- Increasing grounds to free up HP
- ITR cam install question
- ?s about injectors...
- going on third distributer cap jdm b18c problems
- what fuel pump for my setup?
- "Properly " breaking in a New OR completly rebuilt VTEC motor???
- B16A tranny in my 98+ Integra. ***What rear mount do I use?***
- Audi TT conversion ?
- Compression Ratio on pump gas
- EX side mirrors wiring?
- wheres the coil on my si distributor
- d16y7 bottom end- d16y8 head (mini-me)
- short shifter for dc2 R
- exhaust for integra
- Just did swap and low end sucks...timing???ecu???i need a dr.honda!!!!!
- Effects of driving with E-brake partially on..
- ** LOW Oil pressure on a b18b .... Running 3PSi ! ! ! ! **
- help with timing belt
- Trouble Code: 1259 help!
- K20A Engine Swap
- B16A rich at idle
- Knock Sensor
- my door popper owns me...
- Q about AEM bypass valve
- A So Called "Complete New" Harness
- b18c stroker kits???
- ls internals, what to get?
- GSR dash in EG wiring
- Removing engine
- Gen2 has no compression
- Metal radiator hose.. need some help
- Crank no start - 91 Civic
- APexi Vafc on a non vtec ecu??? MINI ME
- thump..thump..thump...thump
- exhaust question
- ouch....(not 56K friendly)
- What to do next on my GSR?
- does it matter which way the rod goes into the piston?
- exhaust
- 205/60/14 on a 5.5 inch wheel?
- oil pressure guage install
- what does this do?
- How much boost can a b18c1 handle safely?
- sensor on intake mani..??
