View Full Version : Tech / Misc
- some serious oil burning
- b16 sleeved block...good price?
- Crank Pully
- Car Keeps Dying on me, HELP
- What is the Civic Type R B16B rod/stroke ratio?
- FAILED Emissions!
- how can i make my SI motor fast? real fast
- Where can i find these..
- b18c into 93 EG help..
- How Do I take these sensors off?
- stock keeper+Ti retainer =
- 98 GS-R normal operating temperature
- Physical difference in an OBDI and OBDII GSR block?
- help me post a pic!!!!please!!
- Idling problem continues...
- Car want rev past 6500rpm
- OBD2 code p1337??????
- ?????? JDM S1 3rd Gear Synchro Ring Set Part Number ???????
- my timing is crazy (help)
- Single layer head gasket...
- shift point??
- help...is there anybody familiar with hydro to cable conversion kits
- does running rich clog a cat?
- anyone have pictures on how to change ignition timing?
- 5 lug conversion.
- what is my compression?
- Where to buy ECU Connector Pins
- need help with cam #'s......
- Type R Pistion in LS
- Plugs on the back of a b-series block........
- All d-series cam specs.
- accord motor help!!!!
- Best Sounding Exhaust
- Tools shown in Honda Helm's Service manuals
- Which Intake manifold to use on a b series?
- Seat cleaning help!!!!!!!!
- screwed over by stock cat...
- has anyone heard of this...Electrical issue...
- EMISSIONS HELP!!!!!!!!!!!!!
- brake system light come on
- What temperature rating for thermostat
- Apex'i Power FC and MSD DIS-2 / DIS-4?
- clutch problem
- super charger or CTR cams?
- Electrical Problem in EG, HELP! (detailed so i can possibly get some kind of help)
- DIYautoparts??
- Suspension Recommendations: Koni or APEXi
- TEIN Question??
- differnce of a d16 and b18/b16 shiftlinkage pics!!
- Overall Best Engine.
- d16z6 build up!! need a bit of advice?
- dizzy clicks and shakes at random times....why?
- arp main stud install???
- Clutch Master cylinder upgrade??? Easier and smoother to shift?
- Bad AEM's?
- typeR optional side skirt
- Wideband O2 Sensor and Datalogger for $350...Anyone Used It Before?
- b18c Idle Issue after obd1 conversion
- honda radaitor fans, do they suck or blow? (nt)
- regarding obd2 b16a in a 92 civic dx hb
- VFAC problems!!
- First time replacing valve train and working on h22 head...any tips before I kill myself?
- EJ Suspension
- Burning Smell Is it bad
- Which Piston Rings.....And Where To Get Them
- Honda crv engine into a mini?
- SOHC Turbo with White smoke problem? Any suggestions?
- oil on my piston......HELP
- Yes or No with this swaybar.
- Engine Horsepower Power Low
- auto to manual conversion list...
- got a quick question
- EGT or AEM UEGO
- Accord Brake Upgrade Question...
- 5-lug for EK
- Could it be my tps
- PLEASE READ y8 Exhaust help!
- b2 flywheel...
- creating power with a throttle body
- Help: Goodridge Lines Installed (Pics)
- Will a B18a crank and rods work on a B18c1 block
- D15 idle question...please help?
- 02 sensor question...easy one
- D-series tranny rebuild now clutch wont work
- ls trans ?
- ls/vtec dowel pins
- hooking up o2 sim?????
- DISCOVERY CHANNEL SHOW
- Sending unit for Autometer gauges...?
- transmission identifying
- GENERIC EBAY HEADER N E GOOD?
- i just put in a 89 si motor in my 91 dx and having problems
- arp headstud part# 208-5402 which motor is this for ?
- transmission question/problem
- 1990 honda civic dx 4 door sedan engine rebuild
- clutch problem or master/slave cylinder ?
- oil pours out when i pull out dizzy d16z6
- TPS signal only at 2.3 at closed?!?!
- P28 ECU
- boring thottle body
- Skunk2 Stage 1 Powerband ??? RPM Dropoff
- distributor-----running a VW engine with a p28
- Can anyone tell me the size of my exhaust? (Qtec Question)
- d15b7 into crx hf
- Gainesville, FL Alignment Rack
- is this rear mount for a B16? ? ? heLPPPPP! ! !
- HELP! water pump bolt is broken! what to do?
- Ek hatchback Suspension question?
- Shifter & Idle problem
- Bore Diameter and Specs- Need Info! LOOK!
- Factory Tuned Parts
- Idle problem... revisited
- Tranny swap from DX to EX..?
- Skunk2 Stage 1 Power Drop Off
- new build idea gsr block and ls head (Kendall, styleTEG)
- Questions about D2s and D2r differences.
- clutch
- Brake Specific Fuel Consumtion?
- Detailed Discussion: ITR cams + GSR head/ I/M
- 90 accord dropped...need cambers?
- where can I buy pr3 pistons?
- Re-pinning
- 92 Civic 4dr -> 97 GSR
- Code 41 for oxygen sensor, Limp mode?
- need suspension upgrade help
- cell code 16.. wierd circumstances.
- Shaking under acceleration .. help!
- Mount theories......
- PROJECT! I'm building a DOHC Honda motor from scratch! [pics]
- Wrecked CRX question
- cracked block near freeze plug is it fixable!!!! i wanted to drop motor in tomorrow HELP!!!
- get codes from ecu..
- want power but not for 1/4
- STR cam seal vs. GE cam seal
- check this out doesnt happen every day
- Golden Eagle fuel rail problems and problems and problems.............
- need help with vafc2 intial setup
- Possible WARPED BLOCK on a b20/vtec ... need options... please read motor experts!!
- Hello, I need help with My CEL light comming on
- 92-93 grs tranny questions (experts wanted)
- Rubbing alcohol? does it really help emissions?
- R-Spec VTEC controller
- Questions when remounting a B16A head - what to do/not to do
- CRX to DC cluster swap pinouts, just if you need or want them...
- Installing Neuspeed Koni Yellows w/ Neuspeed Race Springs
- muffler fell off!!!! now car shakes
- B18C5 Turbo, what kind of numbers...
- Radiator size C&R need some measurements.
- B & H series Rocker Arm Ratio ????
- 99 teg LS parts fit on a 93 civic ex?
- Anyone used POR-15 before?
- Failed smog (Hydrocarbons): here's my plan before I go in again... what do you think?
- Skunk2 extended studs...Has anyone ever had this problem?
- Automatic Tranny with Chipped ECU???
- AC Compressor not working
- Who's got a 4:7 fd on b16 tranny
- bad gas milage but o2 sensor is fine..
- 8 pt roll bar - where do the other 2 bars go??
- vafc 2
- y7 y8 mini-me IM and head swap
- knock sensor
- Any D-series parts fit B-series??? (Alternator, starter)
- difference between the f22a1 and f23 engine
- Hello! Problem with B18B1 consuming oil
- stupid question
- what's the deal with these mounts?
- WILL THIS WORK????
- what is the bore size of a stock jdm GSR?
- Brake questions
- Welding, where to learn? (Chicago)
- Loose cam gear problems?
- ??? SHORT SHIFTER TOOL ???
- Engine Building
- what is this for
- honda fuel problem
- Whats the best bang-for-the-buck Wideband O2 sensor..
- I'm looking for good mechanic around Milwaukee, WI area?
- Why every 3 month’s?
- any good hi-flow cats besides carsound
- head gasket
- timing problem
- B20b smoking but compression and leakdown look great. Any help?
- 76 Motor Oil (5W-40)
- Can anyone??
- BORING out a jg manifold for a 70mm throttle body
- Hey guys I am new But i need HElp with the Hondata S200
- Resonators Reducing Exhaust Flow
- Legend Brake upgrade adn rear disc questions
- how to install oxygen sensor on new header?
- 96 itr ecu
- TB screw lost in motor!?!
- weird intermitent ticking sound front right
- axles help
- Bearings interchangability
- Engine oil Q?
- hydrolock
- PISTON OVER FIRING
- nitrous
- JDM SOHC NON V-TEC 1.6 liter
- Not enough electricity. Stalls when cold.
- LSVTEC Which dizzy and IM?
- 94+teg half shaft question
- MSD injector driver requirements
- Lowering springs; do you need to replace shocks too?
- The need to balance eagle rods??
- adjusting stock cam gears?
- Is Upper Driver Mount for B20z same as 00 Civic SI ???
- Valve adjustment problem
- DC2 Fog Light harness
- will a gsr FPR work on a ls? and tbody?
- Where to find 02 sensor eliminator
- Oil light
- distributor problems need help ( not honda)
- How light is to light for a flywheel, and a couple other questions ?
- does dohc zc block accept z6 head?
- How to tune your fuel?
- Pros & Cons of Propylene Coolant?
- HID BULB! *searched* but to no avail!
- Tein Basic Damper Kit
- Need help installing apexi rev/speed G-Sensor
- need help
- Quick bearing question
- cure for hondata hesitation?
- What should compression be on a b16?
- what is suspension techniques website?
- Oh MY GOD THE HORROR need help with this swap
- Help! Ripped upper control arm bushings!
- TPS
- How do I take these sensors off?
- valve trouble
- make your own fiberglass parts
- Valve adjustment Question!!
- will a 97 integra ls distributor fit a b16a1
- Running skunk2 stage 3 turbo cams w/ ITR valvetrains
- need help: installing earth/grounding kit
- msd b18b wires..can you use them on a b18c1?
- Apexi N1 99 spec coilovers ?
- Does suspension technique sell cv boots?,
- DC2 lower control arm into EK?
- ABDC valve closing degree of skunk2sand spoon cams?
- Short shifter stuff..please help me understand
- cost?
- How can i test my oil pump?
- Is my Timing off? and Alternator pulley question
- Wiring questions for b series vtec swap
- S1 and J1 tranny question
- throtthle bodies
- Need help with OBD1 O2 Sensor connections
- where to get a 12v power source for a gauge
- ***Hondata eprom burners so on so forth***
