View Full Version : Tech / Misc
- Baking??
- 97 Civic Ex Questions
- serious problem help me please
- Intake Ports and getting the carbon out..
- toda vtec killer cams
- random pics
- RC310 ...resistor box
- Will AEM big brake upgrade fit 95 dx???????????????
- the correct chassis code for 01+ civic?
- CEL problem, and other problems after swap.
- b series stuff
- D16Y7 Engine noise
- help me!!!!!
- fpr needed or not.
- OBD0 or OBD1
- vtec?
- headlights on........no cruise control
- Is my exhaust raspy cause of the cold?
- which timing belt cover?
- the Differences between SOHC & DOHC
- tell you thoughts of a b20vtec daily driver
- Lost wheel lock key......any alternative to buying new one for 50 bucks?
- Power loss with factory cat?
- Mickey Thompson Slicks on lightweight 15" rotas possible on street car or just dumb?
- TB swap?
- zc motor... direct fit?
- headlights on = high rpm
- **SOHC N/A guys - Represent yourself**
- What do you make of this collector design?
- Single oil pump bolt causing leak?
- Cam Gear Question
- Speedometer Problems...
- Gsr and Civic intermittant misfire
- what fits what?
- Rollcage......
- Been awhile... cryo treat rods/pistons/rings?
- vtec falling off
- Valve spring removal problems
- Drum Replacement
- Is my oil pan cracked!?!? (pics)
- havCar ilding too low
- disappearing coolant
- I have a few questions
- 94-01 gsr dash in 92-95 civic
- Help!!!!!!
- Drop forks????
- Tightening crankshaft pulley bolt?
- Need help!! cv joint problems
- Should i take any steps to prepare car to sit for a while?
- Gasket Paper Throttle Body Gasket
- B20A5 crank questions
- jg b16a manifold
- ls tranny or gsr tranny
- Question about upper control arms...
- Steering Wheel Revoval 90 STD Hatch
- jdm header install
- I need some help with the woodruff key
- LS crank in b18c1?
- yOffset BJoint or Camber Kit
- can someone tell me my compression
- where to mount water temp senser??
- max compression on stock block???
- I have a b16a1 swap in my 1990 civic hatchback i wanted to know how i can gain alot of horsepower
- CV boots and rats
- Intake cam and iginition timing relationship?
- EJ1 Civic - DC2 Teg suspension compatability
- spring rates 4 autox
- How to Contact and Buy Header from an-r.com directly
- how to mount this seat?
- TDC and valves
- ATS or SRR 4.929 final drives?
- How do i tell if rotor is warn?
- Tach wiring...
- spun beering??
- GSR 1" master cylinder and brake booster for 00 DX
- I was wondering if u could add an acura integra Ls Vtec bottom end onto a B16A1 engine
- JDM Crank pulley...worth it?
- Looking for some parts, anyone know where I can get them?
- LS tranny with jdm final drive or GSR tranny?
- H22 tranny
- 1.5 insides to 1.6 block, can you do it?
- lowering springs?
- tech terminology for engines, ecus, trannys, etc...
- 96 Civic - failed O2 sensor heater
- aem vs haltek
- tranny
- squeak from new Konis... damnit.
- Fuel filter help !!!!!!
- Skunk stage 2 cams=CEL?
- Needed: Source who can verify part numbers for Euro accord Type R tranny
- Result of a 9200 RPM misshift w/ no rev limiter
- LS/ITR main caps for the crank
- flat spot or lean out when VTEC hits
- Ball joint bushing replacement q's (energy suspension)
- how much fuel pressure should i run in a high compression ls/vtec
- Frankenstein Engine - VTEC solenoid
- Price Versus Cost for HP Increase
- ignition, stock or aftermarket?
- aem cai
- VSS Bolt on S1 tranny...
- Where can I get this?
- h22 oil cooler bolt?
- Help!!! Car is idling high
- Will this clutch and flywheel work?
- Stupid Question not exactly tech but you guys would know....
- Brake Fluid/Clutch Fluid
- Wilwood brakes, any other stainless brake line usable?
- ITR intake manifold
- b20z head milling
- Rebuild question
- any honda shift boots fit 3gen intera?
- toda spec c cams
- dVictor X mani. is on throwing code 14(IAC)?
- KMS oil pump, any good???
- Who does Ecu chipping.
- what's better the better header?
- SAE vs Actual HP? (big dyno pic)
- motor heads look here
- tJust intalled new cams. Help!
- Anyone heard of KEM brake pads ?
- Can I use anything else?
- replacing coolant connecting pipe? help!
- trick to replacing valve seals
- whats that sound!!!
- where can i buy a b16a1 distributer? or can i fit an integra one?
- Wrench set question
- will a quaife for b16a2 fit a ls tranny?
- AEM V2 intakes? your thoughts... hype or innovation?
- tanabe coil overs
- shift knob thread specs
- B20B Dist same as OBD-II B18B?
- Imput bearing part # for L3 trannies.
- can someone answer these questions. Thanks
- Where did you get your motor built?
- No Vetec
- 2 Layer head gasket?
- 6th gen exhaust interchangeable with 5th gen??
- B series tranny question
- CTR .25 over pistons can i use stock b16a wrist pins?
- MAP sensor wiring?
- Stuck in park, need help...
- fter out of park without sticking the key into the release slotHelp with automatic tranny problem (p
- Hondata
- polished rod pictures
- ecu messed up?
- how doi choose cams and cam gears???
- u96 GS-R cams in a b16A SIR1. what all is needed and will it gain hp on a turbo application?
- worth the money or not
- Help with taking off manifold
- ITR intake manifold.. worth it?
- where does the coolant go?
- Rev Limiter
- Cam gear bolt!
- Hondata ???
- LS crank pully qustions alternator belt not fitting
- tranny help...
- b18c into DB2
- aftermarket parts and factory warentys
- MSD 6A Problem (Intermittent starting)
- What is actual "tuning"
- ls rod....question???
- Will a D15b7 Distributor work in a D16z6?
- battery issues
- MSD BTM on a DIS system.
- Just bought a beater few things wrong....
- koni yellow perch setting
- b16a block//////b18b head.....bolt up????????????
- Will ITR swaybar fit on a 97 GSR w/ Apexi N1 exhaust?
- Higher compression = Higher rpms?
- Euro Accord motor or type s in a GSR
- Nology Hot Wires
- what header to get ? ........................i searched
- What is your Idle RPMs
- Lots of Shaking... '90 Accord LX
- OBD code reader
- eg harness
- How does an LSD work?
- fuel pressure regulator?
- How to check codes when you convert to obd1 from 0
- opinions on WALKER o2 sensors..?
- Removing rear bumper support
- Can a downpipe be used for NA applications???
- liquid gasket that will plug leaks
- Need help on correct tire pressure.
- emissions..i failed..i need help
- Need advice replacing head gasket (88 accord carb'd)
- my car boggs after vtec or around 4k.
- ITR CAMS question
- Bent Valves: Replace or Upgrade (if upgrade, with what) ??
- difference between ctr and itr 5 lug?
- CRV motor's
- Upgrade or downgrade? VX internals.
- Got this motor that is obd1 but look at the O2......
- Views upon Spoon Type R tranny
- Stupid Problem, please give opinions?
- 5 heat range spark plug too hot for B18B ?
- need help... car seems higher than usual
- h22 header selection
- ASAP axle swap in D16 Q's TYIA
- Help!
- Cooler JRSC temps...more info...still no pics...please read and heed...
- NGK plug number info
- Glossy rod bearing
- Any EE people that can help me?
- help me diagnose my problem =(
- How can u tell if its an LS trans
- What is an LSD? transfers power-to-wheel?!?!
- hondata tuner in putnam county NY
- what color main and rod bearings for ls motor??
- What size fitting to fit in spark plug hole???
- problem getting keeper off, help pretty please
- erratic idle w/ new program : RPT,PYR,JET,XS maps
- What is the meaning of Over bore and Honeing?
- who can tune carbs?
- rough idle
- Stock Rods in the b20???
- Sylvania Silverstar
- overbore?
- tranny or clutch question
- are B16 and B18 pistons the same size?
- ngk wires vs. stock sumitomo's
- 96 obd2 alternator in 90 civic hatch.
- Auto Transmission Problems when COLD
- Clutch recommendation for mild B16
- Help: swap heads
- B18c in EK
- HAVE A SHORT. . . need help to find the problem
- Question about brake lines, are they interchangeable among honda/acura models?
- lower radiator hose leaking
- Never crank an engine backwards.. WHY?
- Can someone please tell me what this is?
- Which quiet straight through muffler?
- b16a turbo
- Fueling a High compression motor...
- VAFC display woes.... not showing up when cold
- want a nice quiet muffler
- i know its asked often: removing stripped bolt
- camber kit question
- B16 head specs
- JDM R header install, o2 sensor clearance prob...
- Link section
- I need help, ecu question
- Rebuilding motor but have 2 quick questions (rings+stem seals)
- bonnet cooling
- b16 head all apart and need to put back together
- Leaking Coolant, please look at this pic and tell me where it's coming from
- Help! Clutch problem maybe...
- super d16y8
- is this legal
- Idle problems
