how can you tell when...
Old Nov 30, 2003 | 11:17 AM
delslow94's Avatar
Default how can you tell when...
how can you tell when ur plug wires have gone bad. im thinking mine are since at higher rpm cruising at a consistent speed i get a hessitation that was not there before...possible arching btw the wires? i have an msd external coil which i dont think is bad because when i am in low rpms it runs fine but when cruising or under a full pull when spark is on demand, the car jerks. thanks guys for your help
Old Nov 30, 2003 | 11:24 AM
IN VTEC's Avatar
Default Re: how can you tell when... (delslow94)
Check the resistance and for cracks in the insulation to start with. If one is really high, it'll be really obvious.
Plugs might be fouled or damaged as well.
EG6Hatch95
Jun 30, 2011 02:27 PM
turbo gsr2000
Sep 23, 2009 06:56 AM
GraphiteMW
Nov 7, 2006 03:55 PM
cdk001
Mar 30, 2006 09:57 PM
Yambor
Jul 30, 2004 06:55 AM
