View Full Version : Tech / Misc
- fuel adjustment....
- G3 prelude question? (trannie question)
- b18b1
- MSD Ignition Window Switch
- chipped p28 ecu ???
- Spun bearings / rod bearings question
- Engine temp
- Tach wiring issues
- B16a
- 1.8 Crank on a 1.6 block..Question
- automatic to manual
- polishing pistons, prep for install
- No VTEC engadgement...Help!
- bad block????
- Need General Info on New LS/VTEC Swap
- Compression sleeve wont stay on hose. Crimp it?
- 1995 EX sohc vtec, engine went.. BOOM
- biggest bore on stock sleeves
- Skunk2 cams are in but have some questions on cam gear adjustment...
- Clutch Fluid
- jdm civic type-r headlights ,day time lights wiring?
- Obd 2 to Obd 1 problem
- vafc problem?
- Help, 4th Gen Lude, Code 1 & 43
- 93 Lude Si / 92 Lude Si Question, Any answers?
- JDM D15B Non Vtec?
- si clutch temp needle going crazy
- Opinion Type R Suspension... Yay or Nay?
- Valve guides in B16??
- CTR cams/pistons in a zc
- keep my ls or go gsr with b16 head?
- How the extra cam in DOHC produces more power than in SOHC?
- b series distributors?
- EK weight reduction - structural support?
- Apexi VAFC installation question
- Two part ?: Idle and TB cable problem
- car won't start
- leakdown test?
- steering gear box?
- need hondadata help
- Threadlock Question
- Question about exhausts and resonators
- I think its my valves???
- Non vtec ECU with vtec motor?
- breaking in the 2.0
- $400 and a prayer...
- cam gear removal?????
- Crankcase vent/pcv valve?
- Greddy SP vs. RSR
- Need Help and fast! GSR/HATCH
- h22 ek linkage
- Control arm camber kit???
- valve job
- Spun bearing questions
- Need help with Chipping ECU, adding Spoon/mugen Chip...help
- 96 GSR Catilitic Converter question (need Specs)
- If my Hub and bearings the cause of my problems?
- shot peened rods
- what internal set up would you use when boosting a d16y8 or z6?
- DIY alignment?
- 97 civic ex transmission
- what is a good way to clean dust and grease out of a head without hurting seals?
- short shifter?
- My horn stopped working....
- turbo
- Tokico Suspension kit (illuminas)
- gsr and b16 cam specs...again...
- got ctr cams was wondering what header compliments these best, jdm or...
- Do 1997 civic's have the big reinforcement beam under rear seats???
- how often??
- opinions welcomed.. or needed
- shot peen/glass bead/sand rods?? wtf??
- Anyone having trouble with their V-AFC?
- cel 45
- b16 intake manifold on a GSR?
- ECU pins
- 95 EX sohc Vtec, oil light keeps coming on?? help
- Can I unplug my skunk2 ecu from my P08 computer and use it in my chipped P72?
- o2 voltage readings
- HEAD gasket Question???
- Ignition Misses
- GSR cams or SI
- SMC Plus
- Pistons Rings
- Detonation and timming
- what sensor is his?
- ls/vtec questions
- How do I get "ferrule" onto pressure hose???
- Tuning Ignition Timimg
- I live in Florida and my AC just stoped working!
- Axles won't come out!!
- YOKOHAMA avs es100 tires
- New timing belt is on, but now my engine idles funny....
- Strange intermitent Hondata problem.
- Exhaust question
- trouble starting?
- sunroof weight
- H22 Head Torque Specs. (stock head)
- obd0-obd1 trouble shooting ??
- anyone heard of the "comptech dry cell motors"??????
- 94+ service manual for free,,,,,
- DA tach going haywire
- S1 Tranny Questions
- Ignition Problem i think ?????? drivin me nuts
- Anodized color for performance parts?
- how to remove driver's side axle from intermediate shaft
- thermal HEADER WRAP??
- Anyone tried DOHC Vtec ZEX cams?
- ME 1 - Fuel Filter 0
- Timing belt changing question.
- h22 ek axle ?
- I Found ARP Head Studs for B16a!!!
- B16 valves in the B20 head ? Someone who knows....
- ARP Extended Wheel Studs
- RC 310 fitment problem !?! pissin me off
- Please let me know what you know about this DOHC head
- Oxygen Sensor Removal: What tool?
- What Head should i build for b series...
- Neuspeed Sport Clutch Kit
- extremely fast awd 5 speed talon for sale
- What to do w/stock flywheel?
- Koni yellows warranty?
- exhaust
- p28 ecu with b16a2??
- b20 crank in ls block
- OBD1 Ecu questions on a b16a2 swap
- H22a into Crx?
- Any cheap places for new distributors?
- What's that thing that they put on the engine that makes it sound louder?
- quick ? to check my logic in somewhat ls/vtec setup
- I would like to congradulate the honda-tech.com team on teh race vs the nissan ppl
- few B20/VTEC questions for those who have done it
- backfire through intake?
- Golden Eagle Mfg. 12V Dry Cell Battery!!!!
- Tranny Codes.....
- what is a S1 out of?
- Question concerning full coilovers and there limits
- ****What happens of you put too much oil into your motor?
- timing
- lowering springs on 99 hatch
- Anyones Fuel Gauge not go to Full when filled??????? not going to F
- brake pads for slotted rotors??
- !Help!
- What bolts to use for engine stand?
- Ecu Brands
- h23 w/ h22 head.........will it work????
- Fuel Realated Question about 2000 cougar v6?
- tranny code?????
- My ITR suddenly pulls HARD to the left !!!
- Help me build a 10.5~11.0:1 motor!
- please give me some input on how to install jdm 5 lug conversion?
- Problem with Unserdrive Pulley (Help!!)
- ex tranny on a zc motor?
- i have a 1990 b16a1 motor and lsd transmission
- where is the coolant going???
- how to install pillar mount gauge pod in 92 integra
- b20 piston: picture of notched piston for valve clearances for big cams
- v tec controller
- Code 21
- Are gsr and b16a rocker arms the same or interchangeable???
- 93' Accord Vibration
- Getting Code 9 - CYP Sensor?
- Brake chatter, any ideas?
- check engine code 1 long 4 short ..14??? IAC
- How to install Autometer electrical oil pressure gauge? Eg/GSR Hybrid!
- vtec and the butterflies on a gsr..??
- Is a 1987 CRX a good buy?
- Sleeving, questions and concerns
- Stock ITR header and Comptech Cat back?
- Gsr harness on jdm b16a?
- Amazing condition of B16a3 sleeves after 100k (50k hard miles)
- Help with ITR big end bearings
- Bad differential on 91 crx-si??????
- changing out the diff?
- what alternator
- Toda A's in a B20vtec
- building my gsr block check it out :)
- B20 main cap torque setting??
- 1 Million miles?
- I need help with my brakes...
- I need help now!!
- any one intersested in trading gsr cams for itr cams?
- changing head gasket
- Can Tein Basics from a 94-00 dc integra be used with a 92-95 eg civc??????
- Can anyone check my vin for me?
- shotpeening rods?
- Taking tranny apart
- i have a stupid question, can anybody help
- does anyone know how to wire a tachometer it is a autogauge tachometer!
- 1995 Auto EX, how do i get crank pulley nut off w/ out having to buy high dollar tools? AUTOMATIC!
- Flywheels
- Suspension theory..... Explain it to me please =)
- D16Y8 build complete!
- Help Fuel leak :( :hammer: need help asap
- still Idle.. sorry for the same topic but need help badly
- machine shop costs?
- Cams?
- Drain Brake fluid to install SS Lines?
- Redoing Harness, now no fuel or brake lights
- timing mark on block.where? any pics?
- B18C Vtec is not engaging and CHECK ENGINE light is on
- what alternator belt do you use w/a single ctr pullie
- 02 Port
- Ok take a look at these bearign and tell me if they look good.
- white smoke when hitting vtec...help!
- Spark plug question
- How exactly does VTEC work?
- Wiring/ECU question...help please!!!
- How much is a Spoon ECU and VTEC Controller with harnesses worth? (PICS)
- Greddy Oil Adapter.....LEAK
- n00b ?: Where is the service connector on my '96 EK to check the CELs?
- how to repair dsm 450cc injectors?
- Type R piston
- ZC valve lash adjustment spec needed
- Problem!!!
- idling big non vtec cams
- Cometic headgasket b18a, .030? .035?
- Engine noise???
- Open header --> Full exhaust..?
- what clutch do i get it for??
- ctr 4-2-1, 2.5 cat, and 2.5" piping with a stock gsr muffler. Bad idea or good idea.
- is this my IAC valve?
- need NA chip reprogramming freeware software..!
- B20z or B18b.? Which one is better for B16 head.....
- Questions about my motor.
- body repair?
- removing exhaust question
- stock ECU could take up to 1psi of boost? (ECU gurus help...)
- What A/F ratio should I shoot for?
- ohm range on 88-91 CRX fuel level sender?
- zex or b16?
- Stroking a B18 to 2.0?????
- fuel injector cleaner... kerosene?
- JUN 3/4 Exhaust Valve Lash
- No oil squirters on GSR block...
- need help with my civic si
- Advice on suspension
- where is my oil going?
- PGM-FI Light
- How hard is it to recharge your A/C?????
- Knock sensor for a b16a1?
- More problems, check engine light too...
- ECU 1993 Accrod
- tranny gears inspection
- Aftermarket Shock boots
- idle drops
- My oil dipstick keeps coming loose
- paint help
- Will Coolant affect idle ?
- Head Questions
