View Full Version : Tech / Misc
- 00 si...Idle problem
- Mods
- Leakdown - air into first cylinder, coming out of third?
- Fuse box diagram
- Engine parts for sale
- Reprogramed ECU for LS/VTEC?
- Wheel hop with tokico illuminas(adjustable shocks)
- dyno of ls/vtec *please post some numbers*
- starter...no power?
- obd1 or 2 injectors w/ obd0 ecu
- Help~!!CTR ECU and B16A2...
- need to resurface flywheel....
- Comptech Icebox vrs AEM CAI
- Any Dyno there AEM CAI and then put in the bypass and Dyno?
- When to do First Oil Change
- Motor testing questions
- a/c belt sort cut
- Square throttle body??
- ok hondata of chipped and tunned ecu with vafc???
- need ecu pin out# for p75
- code 14?
- 5G Front wheel bearing diameter
- need knowledge on OBD11-1
- Will somebody please help me with my S-AFC. I want to get it installed ASAP!
- What fuel pressure would you reccomend?
- Pulling tranny apart, should clutch be replaced while I'm at it?
- Drang racing
- HKS head gasket
- (B20vtec) Can stock B20 rods support ...........
- CEL Help
- TRANS experts help please!!!!!!!!!!!!!!!!!!!!!!!!!!
- Automatic wire harness, Manual car, computer : Car wont start
- what's the difference between b16 a1 and a2 bottom end?
- Do the 99-00 Si, P30, pistons and wrist pins fit the P72 rods?
- Info on CR-VTEC
- How many people have dustcovers on their suspension setup?
- short ram w/hydrolock dilema>
- LS-VTEC or sleeved and bored B16?
- Typical Lifespan of Titanium retainers
- transmission install questions....
- Opinions on intake manifolds....
- Do JDM B16 come with LSD tranny ?????/
- B21A question
- Another Hondata question
- Detonation on new motor?
- Total seal rings
- telling a GSR tranny by counting the gears?
- Is it me, or are Apexi's manuals bad. It doesn't say how to hook up 4 wires for my SAFC!
- Will JDM ITR sway bar fit on to a 2001 Integra GSR
- NA custom exaust, would like your opinion
- gas pedel hard as rock!! need to stump on it to accelerate!
- What's the difference? Which one do I use?
- The Stages Of Clutch Deterioration
- hondata.....
- Is hitting rev limiter bad?
- ECU ID codes; thought this would be good info
- resizing valve reliefs - b20vtec - Part II
- Revamping my cooling system.....
- Soldering on Blaster 2 coil
- motor setup, any good???
- my steering wheel is shaking
- O2 and knock sensor woes. I need some advice.
- Do you know the mileage when getting a swap?
- just finished swap, motor runs like CRAP
- emissions test coming up....test pipe probs.
- code 3 on b16a jdm
- When swapping out radiators..
- What hose is this?
- 2.5 inch piping exhaust using a 2.25 inlet piping muffler. will it work adequately?
- help with posts
- oil system questions
- 90 Integra LS brake booster on CRX
- S80 (S4C) Integra Type R Gear box (Transmission)
- V8 Ford Focus!!!!!!!
- starter, battery problem
- Larger injectors w/ Mugen N1 ECU ??
- Where can i get a set of Accord/ ITR calipers ?????
- car always lagging power
- Anyone have high compression pistons for sale?
- need ls block tapped for vtec, where in arizona can this be done?
- LS/vtec question
- head gasket
- super tranny
- AEM or ?
- Type R sway bar into 5G hatch
- Type R say bar into 5G hatch
- knock sensor
- PRoblems Affter Turbo install
- Any info for lowering an '85 REX?????
- need help! great loss in power
- aftermarket cams, engine noise
- V- AFC with ZC
- lightweight battery -vs- cold weather driving, who has some experience?
- Oil is dissappearing + grey smoke = ?
- Which layer of the head gasket to use when going to one-layer?
- N/A Heads: Toda C's in B18C1 with JDM Slugs
- Gauge cluster indicator lights
- how to find code from check engine light
- EACV Question
- 88dx wiring problems
- Just intstalled new clutch master cyclnder.. problem!
- Palm OS obd-1 data logger
- Need help on tranny rebuild please....
- fuel pressure regulator...
- where to buy tires?
- Can I use my D series alternator for my B series LS motor???
- inline injector resistor pics
- intercooler piping for a integra ls
- Partial throttle driving with larger injectors/hondata.
- Clutch And Flywheel Install
- Gasoline Direct Injection kit for B series head ? ? ? ?
- OEM Honda Main Bearing Sizes - in inches?
- nitrous problem...backfire
- Am I suppose to bleed sumthing?
- LS vtech???
- Tranny Problems Please help.
- Code with chip P28 ecu ?
- Does anybody have an Air/Fuel Gauge in their car???!!!
- Why does my VAFC drop settings?
- Short Shifter Install
- exhaust problem
- VTEC switch??
- Does the stock radiator fan blow air, or pull it?
- b18b turbo...which plugs?
- VSS...& Code 17
- Resetting stock d16a6 ecu?
- help on ls vtec build
- anyone with the fastbrakes 4 piston caliper kit help me
- Has anyone here used a slim fan from dicount auto?
- 92 CX ignition coil same as 91 si?
- b16 header on b18
- Diagnostic Tool Brand of Choice?
- Wiring headlights to turn off when i turn my car off
- How far can you port a GSR TB?
- Detonating spark plugs
- Just installed a 98+ JDM LSD ITR Tranny(4.785FD) and Action Clutch in my 99GSR....
- gtech instructions?
- off topic but funny stuff
- Best way to increase compression
- changing brakes and rotors
- engine misses/jerks/surge of power, loss of power above 2500 rpm
- Expected power gain from Cams
- Break in process.
- Clutchmaster Flywheel
- idle problems....2000 civic Si
- O2 sensor hole on exhaust manifold stripped out, Need help!!!
- exhaust question
- Idling problems at startup
- looking for rear crmoly section for crx
- Air Bypass valve for cai
- Rough idle. Help!!!!!!!!!!!!!!!!!!
- Block main bore codes - missing; misc journal measurements
- do JDM ecu's programed for 100 octane?
- Funky Engine Stank!!!
- Moving from Cali to The MidWest!!! How to deal with import in Winter????
- DX to SI wiring problems
- floor it?
- FJO 341B Engine Management
- Top gun nitrous kit,,, question on jet sizes??
- Nitrous: Who is running it and what is your experience?
- Everytime i shift quickly, i feel a bump
- 1000 rpm idle would this be casue by skunk2 springs and reatiners???
- CEL 14 prob
- please help settle our arguing...
- fan sensor.
- Need help choosing next mod!!!
- Is this Book any good?
- Post dyno tuning woes
- Please Help. Need picture of intake manifold or the gasket
- I need to pass emissions, can anyone help me?
- question about ctr pistons?
- LS/VTEC 1/4 mile times?
- Air conditioning question? for the smart ones out there
- Ground Control ??
- My problem with a header.
- Rich or Lean?
- tell me what you think
- need tips on modding on ex manifold on 90 Dx
- Need help with a 2003 3.2 TL
- car doesnt start...help..need to get to work
- half shaft
- JDM GSR cams same as USDM (1995) ...?
- No Power to Fuel Pump WHat to do??
- question about raising rev limiter on LS engine...
- 4,000rpm idle
- need help (broken bolt head)
- Breather tube question
- Brake Problem
- Unsprung weight question.
- More chances of detonation with head lifting up while boosting?
- universal 4 wire 02
- after market rods for all motor ????
- which sit lower integra or del sol rails
- Need some basic help on common problem.....
- CEL # 43...need a little help...
- off-hand...
- My car died this morning!! HELP!!!
- Crank pulley and flywheel?
- Cracked Headers Possibly Causing Cylinder Mis-Fires?
- How Exactly Do You Correct Rear Camber With Longer Bolts?
- My Cruise Control quit working today!
- Tire Storage - How
- ls vtec catch tank
- v-tec or no v-tec??
- My problem, and what I thought was a blown headgasket....
- what size plug wires you guy runnin ?????
- Where's the wire I hook my A/F gauge up to?
- For all you Tech Guru's .....Stroker for a D16a1 ?? Thanx
- EG6 suspension recommendation
- is the this tube an inlet or outlet?
- light for instrument cluster???????
- helms help
- Need help Calculating CR
- distributer for b16a1 ?????
- Sequence for Spark Plug wires into distibutor (H22A) Need ASAP THANX
- striahgt piping
- IACV Question
- Best add-ons for H22A4
- B18 or B16 distributor???
- Cam seal broken?
- need to read thread my block (head stud holes and tranny side bolts)
- Problem with Cylinders Firing???
- broken header stud
- D16y7 w/ no2
- Why is my rear ride height higher on the right??
- ? about obd1 jdm H22A ecu
- NOS question
- b-series dyno charts
- question about my tach??
- Check this out......what do you think......TOLUENE?
- Koni settings
- IS300 owner in action.
- I switched to an R ecu and need some help, asap.
- port and poloshing
- JE pistons...???
- More LS-VTEC Turbo problems.
- 96 Civic Ex ECU with GS-R Engine.. How to upgrade...??????
- what is the best oil pump i can use
- Code 12 - EGR system with H22A into civic
- Dyno discussion >> B16a
- Help looking for Good machine shop near Nashville!!
- GSR block or bore stock block?"
- Clutch Masters Stage 3 ... Shattered
- What injector size for 220-230whp NA w/ Hondata?
- HX vs. EX
- Stupid Speedbumps
- Getting ready to buy my setup, just some last minute opinons
- Using a +45 offset rim along with a 5mm wheel spacer?
- TDC on the crank.. Is it the white or red marking.
