View Full Version : Tech / Misc
- b18b Missing after cleaning?
- Seized Camshaft????
- i need help...! please help me..
- Car stalls on initial startup
- Diesel fuel in gas engine? What are the symptoms?
- JUN cam gears
- dc2 jdm hid bulbs
- Replacing my O2 Sensor, but still untuned, will it screw up the sensor?
- info please!!! 00 si tranny what will i need to fit an itr lsd.
- foam from radiator
- Are VAFC's shit?
- mines ecu
- i think my b16 needs to be rebuilt!
- STUPID QUESTION BUT IT NEEDS TO BE ANSWERED
- compresion test helpp....
- B16 SIR-2 swap
- Getting code 21 over and over, resetting ecu fixes it
- obd2 head on obd1 block?
- swap help....
- Overheating = warped head?
- HELP PLEASE!!!!!!!!!!!!!!!!!!!!!!
- blue printing & balanceing an h23 vetc?
- Which Engine management would be good for my setup?
- Alignment specs for hard street driving. LOOKING FOR PROFESSIONAL INPUT
- I need help on an odd no start condition....95 EX...
- wiring a/f gauge to a skunk2 OBD2 to OBD1 harness...anyone tried this?...
- Which timing belt is better?
- b18c1 with piston questions
- Lost!! Help Plz!! Ecu Chipping Info!!
- cold air intake
- car wont idle and just overheated
- b18b vs b18c1 inejctors. Are they the same?
- oversized head stud?
- throwing code 12 egr
- Idle Adjustment Problem... Need Help. :(
- Oil pan gasket?
- what size crank pulley remover kit do i get? for the timin belt, plz help
- too rich or lean?
- wiring autometer A/F guage to 4 wire eg????
- diy poly motor mounts question
- AEM EMS or MOTEC?
- HELP - Engine light on!
- Can i use CRV manual tranny with 4x4 and to cancel the 4x4 to use it on integra?
- Changing U joints on toyota truck
- pilot bearing install on flywheel **56k nope***
- Noise in my B16A , need help ......
- obd2b ecu , help .....
- Suspension Conversion help
- how do i replace/fix this harness?
- how to extend catalyct.
- freakn temp doesnt get high
- Squeacking sound after timing belt service
- my turbo D16a9 wont start
- b20/vtec running stange
- upgrading pistons???
- Will a chipped hondata stage 1 2 or 3 P28 work with the s100 or s200 version?
- S1/YS1 tranny with a longer 5th gear...
- coilover installatin ?'s
- what are the torque specs on the following? head bolts, clutch
- Why aren't my RC 550's fitting into my D-series manifold??? Little help here
- New forged pistons
- Car won't start... need some help.
- why is my engine in me 00 SI getting slower and slower
- Progress Camber Kit
- a/c compressor will not turn on!
- wire harnessess
- b16a emisions and other problems
- KNOCK SENSOR?
- Motor not turning over....bad starter?
- Omni coilovers (My review)
- need help cluster not working
- Check Engine.... CODE 22
- skunk2 install question...pics inside
- Home-made valve adjustment tool advice needed...
- Ground Control extended shock mounts with KYB AGX? Will it hit the hood?
- b16a2/p30 pistons in a gsr bottom with itr head
- Assembling a 95 GSR motor. Crank questions......
- HELP! ECU throwing CODE 21
- cltuch problems
- Honda OEM Fuel Injectors...
- What Is The Size Of The Alternator's Bottom Bolt?
- Carbs
- CUT DOORS...
- DOUBLE POST but i need help (PROBLEM WITH B16)
- different oem cranks, rods in blocks
- jun chip
- Big problem with clutch please help!
- weird Wheel problem
- BAD STARTER?????
- Advantages or drawbacks of having or not having a fuel pressure riser with I/H/E
- Setting timing on 1989 CRX si
- b20 swap
- hf im on si head ???
- Amsoil really that much?
- B-series Distributor Cap?
- Popped a fuse big time.......little help!
- ignition/injectors? what is my problem,please help!!
- itr im vs. gsr skunk2im
- Check engine light (MAP sensor)
- Wheel alignment and balaning.
- Koni Yellow Stuck Adjuster
- h22 eg axle help..
- physical inspection of a throw out bearing. fast reponce if possible.-
- Lowering My Integra
- bearing help
- Anyone have a contact at Clutchmasters ???
- Car is back firing.
- Uneven Camber, causing car to pull to one side?
- is my stock exhaust contributing to my detonation problem?
- aluminum fly wheel
- Just ordered Ground Controls...
- screeching noise after changing my alternator
- mpfi ---- help please
- 5th gen civic rear camber q's
- leak
- Tranny gurus braincells workout
- ID of Integra Rad Hose??? (need to know asap)
- H22 crank pully bolt STUCK!
- ZC trans went limp last night?
- building a ls-vtec
- 00 b16a2 head / 00 B20z2 block HELP!!!!!
- Quick Head Gasket Question
- h22 question
- CAT laws
- General Engine Rebuild
- Easiest $25.00 Catch Can in the WORLD
- Need Tech Help On H22...Please help.
- GSR Wiring Issues
- 92 civic shock?
- tranny question
- fuel pressure regulator.. how do you adjust?
- need someone to read these plugs for me
- how do you determine if jdm ecu is MT or AT
- vss question..cable to hydro
- What the F*$% is wrong with my brakes?
- Chirping?
- koyo racing radiator
- Fuel filter washer
- dpfi to mpfi ....... just a few extra questions ......
- Getting ready to put new piston rings in. Need walk though on rehone.
- Engine Firing order Questions
- Noise in engine?? 1989 CRX-si
- Best Inline Fuel Pump?
- how much of a difference does a fuel pressure regulator make in richness?
- Valve Adjustment Concern
- good source to get air to liquid intercoolers?
- Can i use a 00 civic Si thermostat in my 95 GSR cause i bought one from honda and they look a little
- Engine Smoking Assesment ( + 1 other question )
- stock fuel pressure regulator same for all 94-01 integras?
- belt noise
- obd2b - obd1 DIY harness question!!!
- WTF. no vtec pressure switch?!?
- Anyone using a Camp1320 quick release steering wheel setup?
- ls/vtec blew up....need help rebuilding
- quick radiator cap pressure question
- how to intstall underdrive pulley kit
- D16 Timing
- obd1 vtec problem
- Car dies when slowing down???
- question about ctr pistons
- help me with my stinkin crank bolt
- Are DOHC ZC injectors different from 89 SI injectors? (in size(cc's)).
- Dohc ZC no power over 4500rpms
- Does anyone have specs/dimension of a b series motor?
- I have a wiring question can someone help me out please
- who makes a carbon fiber dash?
- k20 bearings
- Injectors size in K24 engine?
- chipped p28 ecu reprograming
- wet ephrom chip? still good or trash it?
- master brake cylinder brands
- loss of power
- VAFC initial settings??
- How Much Does Your Car Weigh?
- New tyres then Wheel alignment or vice-versa???
- stock 240cc injectors w/ resistor box
- Changed oil pan gasket on 89 LX now HORRIBLE noise
- ls into 97 dx iacv prob
- Aftermarket oil cooler + accumulator + more .. ideas for routing?
- precision injectors??????
- Vtec pressure switch pin on ecu
- NEW DYNO IN THE HUDSON VALLY NY ARREA
- Help Installing Greddy EGT probe
- hf im on dx head ???
- Idol Control
- Timing Belt ?
- Is there a secret for axle repacement that i don't know about...
- Do Jdm H22 come with vtec oil pressure switch
- jun3's vavle adjustment
- Header Question
- race eng. bloack guard
- *Pix* integra suspension damage. need help
- axle configuration for h22 integra?
- Helms help
- rod/piston question
- help pls....
- Distributor red dust
- Has anybody had problems w/MUGEN headgaskets?
- how to install oil pressure sensor??
- Identifying My B16B Crank...Katman pics are here
- How to wire a 4wire alternator OBD1 to a 3 wire OBD1 alternator?
- reusing parts: all motor
- Welding advice please?
- f22b1 95 accord vtec bored out
- distributor id codes?
- JB Weld on Lug Studs?
- where to find these valve/head tools
- Cant Get my Car Started...NEED ANY HELP I CAN GET!!!
- leaking anitfreeze
- Looking for some dyno results for Toda spec A cams
- Oil pan torque sequence
- b16 or gsr?
- I HAVE A JAP COMP, HOW MANY CO2 SENSORS DO I NEED??
- blue printing
- M3 mirror wiring
- looking to buy a prelude engine
- Heres the pics of the b16a1...whats wrong?:)(56k maybe)
- JDM Final Drive kit into a 99 Si....ITR/GSR Diff needed...
- Rod & Stroke
- Throttle body??
- Is my flywheel OK??
- NO FUEL - NEED HELP!
- Bore Vs. Swap??
- Alternator Questions
- suspension/spring rate question
- notvtec vafc
- skunk 2 manifold or accord euro-R?
- I need some know-how with the purpose of camber adjustment..etc.?
- Is it ok to...
- D series coolant diagram
- obd1 intake manifold sensors...question?
- TB
- OBDII chipping info for all
- Transmission Burden
- What could make syncros grind, other than worn out syncros?
- rebuilt engine, still smoking at 850 miles...is this normal?
- Air/Fuel ratio question
- Intermediate (half) shaft on A D-series trans
- main bearings/rod bolts for frank motor
- To all Uberdata genius'
- Is It Possible?
- Oem rings or je rings for my srp pistons
- are you not supposed to take out or install spark plugs when engine is hot?
- Will I mess anything up by Rotating Crank With No Timing Belt???
- Ignition timing bouncing...??
- Distributer ignition timing ....?? HELP!!
- SOHC ZEX cam timing question HELP?
- Very bad news for the good ole b16a1:(
- Skunk2 Camber Kit / Upper Control Arms Bolt Size
- Just did compression test..
