View Full Version : Tech / Misc
- what exactly is the difference between the itr and the gsr engines?
- wut could be the prob wit my cx
- ls/vtec idle and temp prob help!!!
- Did my buddy bend a valve???
- I can't start my car!!!!!I mean, no power AT ALL!!!!!!!???
- question about hydrolocking and effects of a wet air filter
- integra front brakes on a 91 civic hatch
- LAF sensor, #1 cylinder sensor.
- Injectors question
- Unable to start bike
- best upgrades for a d15...............please i need your input
- power delivery sucks!
- H22a - Engine tapping/tappets
- B16A2 UK Timing Belt Advice
- B20 Vtec question
- IAT question
- Converting from auto to 5 speed?
- Need 440 injector..Could anyone help me out???
- Good Quality Camber kit: Skunk2? Spc? Ingalls? other?
- idling problems????
- 96 DX front brake swap
- will b20 sleeves hold?
- Headers!!
- Tien Coilovers: Left side vs. Right side ride height.
- help with drive shaft removal.. I want to lift out motor!!!
- nickt crankshaft pulley-ok-or not. help please
- hydro tranny / cable car
- Can anyone send me instructions for an Oil Cooler Install??
- Crane or Skunk2?
- I found the perfect Gear ratio fo 92-95 civic
- looking for info on apexi n1 dampeners
- cel question that needs an answer... please read :-(
- valve adjustment?
- Signs of a bad starter?
- 00 Type R header fit 95 GS-R
- cam sensor trouble
- Level 10 Auto Tranny.
- Need tuning help with D16z6
- Wrotten egg smell after acceleration?
- My compression #`s on JDM GSR w/ ITR slugs: your input please...
- any info on the JG VT35 cam???
- b16a fit on gsr shortblock right? compression?
- whats a good site to buy ITR valve springs?
- Running lean after driving on freeway?
- Constant Valve Adjustments
- blow by & low compression
- first upgrade
- PW0 worth modding...
- Civic Junkyards in Atlanta!!!!
- gsr intake manifold on a b20
- bad fuel economy
- Header design question??
- no search results: flywheels torque specs?
- Install of ignition switch
- which a/c bracket b16a??????
- where to find info on DIY on my honda civic?
- Alignment Issue
- Jdm B18C. What fuel pressure?
- h22a transmission tech
- what exactly is????????
- Which Pistons to use??
- Legend/ NSX Calipers on 99 Civic Si ???
- does the valves close when cams are taken off?
- Distributor problem :(
- bent crankshaft pulley :0
- Need help on readjusting FMU<<<>>> Help >>>
- What's better?
- need help fast
- need help with intake manifold
- AWD Del Sol?????
- AEM CAI swap
- Problem with JG throttle body?? (pics)
- HID help
- Radiator
- USDM and JDM ITR header the same?
- "ACTURBO" twin turbo set up
- ***My Idle Wants To Stick Around 2000 RPMs***<<<HELP>>>
- Already searched...need help
- TRANNY
- how do i put fuel injection on an EW1?
- How To unfreez pistons
- tranny snap ring
- ITR Distributor Good on OBD II GSR?
- after obd1 conversion (idle needed)
- Lets have a h-t header test.
- Starting engine without trans fluid.
- Installing Peak and Hold injectors without using resistors.
- boost controller dilema.
- how to hold the axle still while tightening nut
- help! skunk 2 manifold problems
- shifter broke
- dunlop lemans 701 tires?
- what size fuel injextors for my civic?
- does anyone know what the specs are on ITR valves???
- CR-V (1998) Technical Questions
- ROD knocking... easy rebuild or crank work needed?
- Does Honda really break in the new engines at the factories?
- STR cam gear replacement bolts?
- car vibrates nasty when turning right.
- Swap Help
- Piston to valve clearences.
- jdmb16 cams or gsr cams on a stock b16
- LS vtec recipe
- ECU Question ( P61 and P72? )
- Looking for an old thread about how to trick secondary O2 sensor.
- saturated injectors in 90-93 integra ?
- TPS problem, possible lean condition?
- '97 Civic LS stalling problem.
- EK - obd2 b18c1 - P72 ECU - IAC - Help!!!
- how to see if your CEL light is dead
- Skunk2 Cams Stage 2
- fuel pump question for a rebuilt motor
- DSM 450cc Injector Question
- i need to know compression for d16y7!?
- JDM B16A 1st Gen Fuel Pressure
- Civic Type R Cam, How do I know if is real?
- sucking air thru the breather in the valve cover?
- 1st gen b16 to obd1 distributor question
- Stuck TB
- Hybrid H22 Guru's. Help!!!
- D16Y7 motor in my 93 vx hatch.. it wont stop overheating no matter what! HELP ME!
- vibration in the steering wheel
- ITR LSD in GSR tranny?
- Motor nightmare
- GM 3 bar map sensor For civic turbo
- Stopped on the side of the road today to help someone out today....wish I could have done more
- How can I tell if an ECU is chipped ?
- anyone got this setup , what could help with more hp
- Opinions on RS*R exhaust system
- Centerlock braking system?
- Need help on tranny...
- need help on conversion from a/t to 5spd
- State Ref BAR cert. California
- Help! clutch problem...
- aem fuel rail
- #1 cylinder position sensor-just did swap-runs like dirt
- Is there any way to make a cel go out while running a "test pipe"?
- How to remove transmission
- Shatterd Aftermarket Sunroof!!!1
- Any special tips.....
- ctr cams in gsr question.....
- Mini-me questions and alternator belt question!!!!
- Carbotech Panther XP = streetable ?
- How to tell the difference between LS and B20 Cams?
- ok torque specs for 94 integra same as 01 type R
- can someone help me ?????????
- fuel pump swapping
- simple oil change question
- What is the best program to run on a close to stock b16a?
- 90 integra release bearing same as 92 1.7l?
- Manual V Auto
- What do i need for a swap?
- Finally rebuilding engine, need compression help...
- Where can I get plastigauge?
- CRX starting problems
- Technical question....d series cam selection help!
- 90-93 teg rear bracket same as jdm 89-91 b16a bracket????
- quick o2 sensor help
- GSR burning oil
- tie rod boot install
- B16a longblock..... with bent valve
- what is tenchioner and idler bearing for?
- jdm 4-1
- Transmission problem. Need help asap!
- OBD2 Distributor on an OBD1 Motor - Crank angle and Cylinder Position ?'s
- ek sus on an 88 std hatch?
- vafc question
- Skunk2 Camber kit Replacement balljoints.
- Charcole Canister?
- compression
- Rounded caliper bolts
- piston to valve clearance
- Overheating problem not going away!
- valve seals or rings? heres what mechanic told me - do u agree?
- SWAP SHOPS IN NC?
- H22 Engine noise - MP3 inside
- Engine Help....
- what chip to get
- starting problems.
- Will altenators off D-series Civics work on B-series engines???
- sir cluster
- anyone know how to intsall nos
- Why does my top end die off?
- stock fuel pressure on b18b
- Car will not start
- Mini-Me question!
- mustang owner has a question about a vetc mod
- HELP! engine died! Valve broken! read!
- What should I do if I cant identify bearing colors?
- stock eg motor mounts for b16?
- boreing and honing b18c5 or for us c7 block to 81.5mm ok???
- Got some prices on some motors I want to build, which one should I pick?
- quick smog question
- Quick Question....bet riding in this!
- No Oil thread again
- How to determine what transmission it is.
- Headgasket problem/questions???
- Anyone have any suggestions of removing cam caps? (already searched, and pulled out most of my hair)
- Code 9.... Faulty Distributor, can i fix it or do I have to buy a new distributor?
- Broken Bolt in Block, HELP!
- WTF my speed sensor!!!!!!
- Spoon Block Brace
- b16a Pistons in b18b ?
- need advice
- Thread size for a ls block head bolt..
- Need Help with Tranny
- 4th gen Accord Help
- highest rev?
- need help finding the vtec solenoid
- smoke from intake?!?!?
- CV Band HOW?
- 95 GSR or 1999 Honda Prelude Type SH
- "lowboyz" strut/coilover combination
- ------//> removed Cruise Control Switch causing HORN BUTTONS to not work.. why??
- Source for front shock collar piece
- sluggish take off / just installed and tuned my skunk stage 2s
- Hondata s200 problems
- how is this as far as price goes for a tranny?
- AEM Cam gears
- LS/VTEC build....please help
- Compression calculation help
- Code 15 Problem ?
- Removing driver side axle on 97 teg....getting pissed off!!!!!
- Headlight Install Help ***City Lights***
- welding equipment help
- 8500 Rev limit on stock b16 head?
- inner joint problem
- b16b advanced timing
- Blowing smoke..
- Moonroof install help! 95 civic hatch... anyone that has one please look!
- 4-wire Heated o2 sensor wire up
- Obd0 (pre-obd) Timming...no service conector... anyone help ?
- VIOLENT KNOCK!!! no oil!
- Tire contact patch Q
- removing oil pan
- h22a injectors
- no vtec? need help
- oil feed line fitting
- help my friend in a dilemna with his sleeved jdm d15b vtec
- LSD question
- d16z6 ign. timing
- for the H22A peeps out there.
- bad vibration after swap
- help me diagnose low oil pressure
- Lightened fly wheel or new clutch?
- Car wont start
- Fidanza flywheels
- Cam tuning
- ITR Exhaust on EG Hatch
- putting a 99 crv motor in a 95 integra. wiring issues?
