View Full Version : Tech / Misc
- Vtec Solenoid help :(
- b16a and fields controller???
- touchy tps??
- Installing new water pump....
- no oil pressure in head = no vtec someone help
- How do you take off a h22 vtec head?
- new tranny or rebuild?
- Torque Wrench
- defi egt probe
- number one cylinder not firing
- what cable clutch can i use?
- b20 vtec headgasket??
- o-ring head
- h22 or h23 tranny??
- sleeving AFTER pistons??
- d-series distributers
- What spring rates are recommended for my Rear to run a Type R 22mm sway???
- ls/vtec pacing the build up
- B18B1 piston and compression questions
- B to S Ratio...
- external coil wich wire do i tap for the negative side of the msd 92si
- RWD Civic info and suggestions needed.
- any one have a ecu pin out for a p13?
- Help please! d16y7 pin out diagram anyone?
- i need some help from anyone who is a HID whore
- lower balljoint welded in?
- Turbo Cams
- hondata led out?
- how hard is it to put a 94+ LS in a 90 integra?
- How Low Do You Think This Is?
- Did a compression test today
- b18b eg what bolt on exhaust?
- oil pressure light is flashing?
- is there an ecu fuse?
- battery light on while car is off???
- removing screw from distributor???
- Hondata Gsr Base Map
- lsvtec where is the power
- ecu swap
- Z10 Catch Can Overflow Problems.
- cel code 41
- how do I know which final drive I have?
- Seatbelt Question
- do cams affect compression????? camshafts
- vss problem?
- OTS ground control spring rates wrong?
- b16a smog issues
- Who can revalve koni shocks?
- D16Z manifold
- car wont start up...
- NEED HELP!!!!!
- obd1 p72 (help)
- How meny lbs are 5Zigen FN01R-C?
- Spanner wrenches
- Tranny Fluids
- TurboEdit: how does it work and is it any good???? Also, any tuenrs near SC???
- Weird Ass Problem: H22a into 99 SI.
- need help!!!!
- knock sensor wiring???
- d16z6, y8
- need help .. no vtec engagment
- Wheel bearings on a 94 accord
- tps prob, always on full throttle
- wiring...want to have bumper lights turned on & still wk as turn sig.
- Is there a benefit of having forged wheels over cast?
- I need votes and technical advice
- Picture request: OBD-2 crankshaft fluctuation sensor B-Series
- skunk 2 spring rate formula>>
- APEXI filter WITH 3" adapter!!!!
- Apexi Filter needs Adapter?
- fuel injectors question
- SRS light on 94 civic please help
- Which USDM aftermarket LSD for a JDM j1 cable trans?
- putting in new valves
- Upper and lower Radiator hose
- Where can i get an s2000 motor?
- S-AFC vs. S-AFC II
- tranny problems need help
- Timing Belt Kit? What do you guys use?
- pulley kit
- ?? 97 civic VTI
- Quick release on stock hub??
- Will this OBD1 distributor work correctly with my OBD0 B16A? NEED help ASAP
- rod journal numbers D16 B16
- 954rr 75mm forged pistons
- Looking for STL Area Tuner
- REbuilt gearbox - installed, now car will not turn on...
- PDN-A00 (USDM 98-00 GX)
- rear trailing arms
- why does my car feel slower at full throttle????
- EK4 Civic fresh car how should i tune the car for mint handling( track and road use ) My second civi
- piston assembly
- how to determine hose size.
- Weird rattle from engine under load. WTF.
- help with squeaky suspension
- HELP ... CONTOL MODUALS ISSUES..
- bent control arm
- big brake kit that will fit on 15" si rims
- Thermostat opening temperature??
- fuel injector removal D16Z6
- oil in radiader??
- fuel pressure gauge help! dips down on rev
- Can't get crankshaft pulley bolt off
- disintegrated ground strap on spark plug - plz help
- Radiator hoses swelling?
- b16a2 problems all over the place please help me out guys
- How does brake fluid work?
- Blown diff/tranny?
- what could i use to lower my car since i dont have the coil over tool?
- CONTROL MODUALS CREATED EQUALLY??
- what are these 2 notches on my intake manifold? (pic inside)
- need to fix my tach
- Which Spring to buy H&R EIBACH SKUNK TANABE?
- car stalled pls help
- REALLY BIG HELP ON TRANNY QUESTION!!!!!!!!!
- Oil Psi Gauge showing abnormal readings
- gsr tranny w/itr lsd
- can you go back to regular motor oil if you use synthetic oil ?
- Transmission Help:: Car Poppiing out of 3rd and 5th
- venom i/m help
- H22A not idling / pinging
- b16 wont start, help!
- will k24 crank fit in a f-series block.....
- Just got my ef on the road now have a few probs??..??..
- quick question on b series header
- replacing internals for a distributor
- Vibration Issue (searched but no definite answer)
- ka24de need help carburated???
- How to take out CHECK ENGINE lightbulb?
- cv axle has popped out or its broken
- RMPs Matching Speed
- Hondata tuners in Dallas area?
- Payn Tech?
- Car sputtering and dying.
- do i have a factory freak?
- 75k motor..what to do before install
- CRV awd setup swap
- B series headgasket
- A8 - Engine Performance
- Electrical Troubleshooting Question
- Stupid question: Need install write up for urethanre bushings - 92 Civic hatch...
- Can you machine your clutch pp ? :dumb question:
- compression on mini-me turbo
- CRX WIRING HELP
- Tranny help: JDM GSR vs USDM GSR difference
- Where's the horn Relay??
- Rod bearings.
- have parts, now which way to go?
- Where did all the oil go!?!?!?!?!?!?!
- Uberdata help, car idles up and down
- Since the search is disabled currently... what is P06 ECU???
- Uberdata Users, need help.
- HIGH IDLE
- B16 VACUUM LINE DIAGRAM
- Horn Relay part #? (pic included)
- cam gear timing, which way is which??
- I need All you Engine builders to look at this........
- Timeserts for a b18b
- quick engine temp gauge question...
- Low oil pressure?
- Is it cool to clean a new clutch disk with brake cleaner?
- Does anyone know how to reset the SRS light?
- anyone here do suspension work?
- b16 tranny go boom
- How do I test a bad alternator?
- What WHP to expect out of my build?.... in progress
- rewire engine bay??
- altenator rebuild
- car sputters when decelerating
- d15b in a ef si 91. what wire clips cannot be used
- TDC Sensor CEL 8 dizzy is good, what now?
- Axle Replacement
- bouncing engine temp needle
- SRP Pistons
- Gas Milage, I am not getting what I should
- How To: Install SRR Ignition Switch
- Dizzy cap....
- cam gears
- a question about equal length half shafts
- h22 boosted?
- Need your help/expertise
- chipping p05? vx?
- Cold Suspesnion?
- Help tranny problems
- New Darton Location!!!!
- General Tuning Question....Easy answer I'm sure
- Madison area Tuner dynotuned
- sohc and dohc vtec solenoid
- code#61 Primary oxygen sensor ???what is it ???
- something fucked up in my engine, now I gotta put a new one into my 00si...any suggestions?
- Which would you prefer?
- Which parts would you prefer?
- which type of header to use?
- Stock tach
- dx brakes onto EX 92-95... will ABS still work?
- VERY technical question....Dyno Tuning, AFC, A/F Ratios....*PICS*
- starting problem
- k20 into 00 stratus se? (leave flames at the door)
- O-ring material type for alb modulator
- code 2??? no check engine light but cel flashes constant
- Need Help with Girls Jeep
- OC Alignment Shops?
- SPC or Ingalls camber kit
- avc-r install tips
- Was this worth it. Pics of ls longblock,please look
- Swapping Type R in 92-95 Civic is it poissible
- need advice on intake manifolds
- Fuel filter/gas milage question
- axles problems
- distributer not sparking
- catch can?? don't you need vac. to your block?? a lot of people deny this please clear this up
- sohc/dohc vtec soleniods?
- what is this???
- ALWAYS WANTED TO NOW, WHAT PASSES THROUGH THIS
- High HP and timing belts ???
- What other bolt ons should i do before i head to the dyno??
- Evap Valve/Canister...easy fix?
- Datalogging on JDM P30 ECU?
- CEL code 3 on in a 95 cx w/ b16. will vtec engage?
- part number for gm syncromesh
- Anyone have the part # for the oversize arp headstuds? the 1/2" ones
- forogt to put oil cap back on and now car won't start HELP!!!!!
- Quick grounding question
- Need Help with Engine Build
- Tranny problems
- B20/VTEC'ERS WHY CHANGE OUT WATER PUMP AND TIMMING BELT TO VTEC ONES
- Vtec problems
- starting problem...not cranking
- air suspensions
- H22 swap into 96 civic
- Water Temperature and Oil Pressure Gauges...
- what sensor is this?
- CEL CODE: P1071
- would this be ok?
- suspension install instructions for 4th gen lude
- What the hell kind of ECU is this?!
- Can someone help me w/ oil pump sensor question????
- unpluged o2, car runs great!
- Purge control
- auto to 5-speed
- b16a swap -- RUNNING PROBLEMS- confused
- HX TUNING
- Squeak/Rubbing from rear left wheel - Picture included
- oil pump turbo ls. too much pressure from a type r pump? how many psi should i see
- Dropped the pan and.........
- Clutch questions?????? searched
- power steering pump
- D16W1 engine block from HRV.
- car feels slower with resonator
- just got a car for $500
