View Full Version : Tech / Misc
- help! stripped tensioner bolt!
- Got my belts changed. Now my steering is lighter. Is this common?
- need info on gear ratios
- what's the honda part # for the knock sensor? n/m
- need help my daily driver is down
- I've done a search and where can i order???
- wat is a standalone...hondata, motec, etc....
- LSVtec compression???
- check idle speed
- hybrid turbos
- Coilover inquiry
- spark advance - is it really hard on a bottom end?
- Help with installing a boost gauge.
- Rear LCA bolt, why won't it break loose?
- GSR Rods on LS Block??
- OK! why does my tach jump all over the place over 4,000 RPM?
- question about injectors
- ADJUSTABLE FPR
- aem intake making a whistling noise?
- My car won't start!! I need help!!
- Piston to wall clearance CTR pistons & b16a
- i want a GS-R engine for my 94 ls
- RC injectors? fake or real?
- Swap out stock tach?
- I hate my car.......help
- all 4 sparkplugs covered in oil
- Anyone with an in car cam mounted?
- Best speed for DSL to down/upload video???
- please help...my car won't start after new distributor parts
- port match
- Clunking noise while turning
- flywheel?
- How to Identify A blown shock or strut?
- Has anyone used 1 or 2 plys of factory head gasket successfully????
- clutch problem
- 10mm or 12mm tool for the civic's?
- 2.0 h22a N/A motors?
- How strong are Honda Automatic Tranny's?
- oil problem
- Help me setup shooting fire exhaust.
- help with budget all motor setup
- OT: Endyn pistons - the way I think it works
- Any shops with a dynomometer in the Gaithersburg, Rockville - MD areas?
- Any difference between obd1 and obd2 distributors besides wiring harness?
- next mod?
- Safe to hot-tank a head assembly?
- PR3 vs. P30
- Questions of the allmighty B20VTEC???
- apexi world sport
- LS Vtec ???s
- Sites with flow/pressure charts for Keihin injectors? (long)
- Modding turbodiesel engine for more power? Help.
- knife edging and balancing crank
- help, wiring problems....
- GSR Rebuild 101
- I beam or H beam?
- Ideal Rod/Stroke Ratio?
- Me again with da ROUGH IDLE...ARGH
- How do you cc a head?
- icebox intake
- which parts?
- Which Should I Get?
- # to Jamex??
- Winter Tires
- Knife Egding Crankshaft
- Do my compression calculation seem correct?
- Q about oil filter relocation kits
- Help-Rattle in the rear?
- ls/vtec where can i get one????
- Having a problem with idle surge on ITR Please Help
- Whats wrong with this motor??? Worth rebuild?
- how to remove back windshield wiper
- lower steering ratio?
- Quality A/F Meters?
- arp rod bolt for b17a?
- Is the 2000 Prelude ECU harness the same as the 1998 Prelude harness?
- Anyone heard of or experienced AEM computer?
- AC Compressor clutch/pulley is noisy. Anyone had this prob? Easy fix?
- Do honda engines burn oil?
- Need help removing axles
- The great Stand Alone ECU debate.
- On VAFC if VTEC L-H was 5400 what should H-L be?
- 99 Si tranny in GSR??s
- Toda genII cam gear settings...how do I read these things!?!?
- POST if any Diff in ET after New flywheel?
- Ok, used bare block, what to do next?????
- JDM dc 4-1 header info
- itr header on a b16a head
- piston to wall clearance with forged pistons
- Help w/ Tranny Rebuild & FD Install
- When Separating Front Hub from Spindle, Do I need to Replace Wheel Bearing?
- HELP with turbo LS/Vtec?
- Fan turning on too late or thermostat not working?? Need help please
- Parts List
- Type R transmission oil?
- Wheel and Tire Weight Poll
- Poor man's SS brake lines
- what the hell
- Highest Compression for 93 Octane
- Idling problems
- Aftermarket Fuel Rail 4 ZC
- Need help troubleshooting front-end
- Urethane bushing question
- Eibach Sportline VS. Eibach Pro Kit
- need sugg. on cat back
- Engine problems HELP!!!
- Max milling on b18a1/b head?
- Take a Look at my throttle cable is it OK? ---PLEASE LOOK
- Need some technical Info for CTR 5-lug !!!
- code 4 & burnt exhaust valve(s)...need advice
- shiftin in a auto?
- What's better....
- ** Sound from brake/wheel
- What kind of HP gains should I get w/Skunk2 cams in ITR?
- ***I have an idea for a safety feature...tell me if I'm crazy.***
- anyone ever experience check engine code 54?
- Modifying Motor mounts
- I have a Mechanical Oil Pressure Gauge from autometer -- NEED HELP
- Top of block scratched lightly, can this be fixed?
- Is the Rev-limiter on the ITR Mechanical or Electronic?
- 205/55-16 to 205/50-15???
- B18c1 all motor build
- NIRA Sold Out!!!
- Blown head gasket = richer mixture??
- Will this work?
- Clutch install
- Supension Question
- Difference between OBD 0 and OBD 1?
- Oil pans which will work
- Koni yellow Settings on an EG6 Si?
- Which intake manifold is better?
- weapon r
- Intake installation inquiry
- Need help with tranny cooler.
- Integra or ZC ECU?
- Troubleshooting FYI
- mt main ecu fuse under the hood keeps blowing, how do i fix this?!!?!!
- rotated tires and its going "gung gung gung"
- b16a I.mani on a b18b1?
- Rod ratio
- How to keep flywheel still while removing it?
- Engine Building?
- starter button
- low low low Idle???
- Regarding transmission and engine wear
- 2.6L h22
- Check engine light giving me code 8 (top dead center sensor)
- ITR Head questions
- Anybody have the Tanabe Sustec Strut bar?
- Can a Mugen HeadGasket be used more than once?
- DC Header from GSR to LS???
- Sounds like im braking something!!!!
- Car revvs from 6000-7500 in like 1/4 second WTF?
- stroking a b16a
- EGR problem
- hot spots in my clutch?
- Sleeved LS block piston questions
- o2 sensor problems, yet again
- Fuel Pressure in b16a - modded?
- props/con on this set up people!
- Please post good mods for increasing Throttle response.
- Any real HP loss when the AEM/CAI has the antihydro valve installed?
- Winter oil???
- Spring Rate of Eibach Pro-Kits?
- ITR Intake manifold install:: need help!!
- Oxygen sensor question
- Acura EL (Honda Civic) throwing a code - ??
- Took off head, I need HELP!
- 2nd -> 3rd gear crunching.
- Popping/Whining sounds
- Leaking clutch fitting
- will gsr rear sway bar fit on a 92 CX?
- obd 1 pin out
- Help! 98 turbo teg stalled out today and wouldnt start back up, it sounded like it was trying to go
- Apexi dunk, Apexi WS, or ITR muffler
- Catback and Pulleys.???
- Question??????
- b20b =)
- h22a tranny 5psd or new act clutch?
- How to "tighten slack in steering"
- nitrous helpp
- Obd2 ecu pinouts???
- RPM's going up and down
- JUN 1 cams compare spoon cams and toda A cams which is the best for street?
- ALL MOTOR HELP W/ SPOON STUFF
- What kind of timing gun?
- Need some opinions on engine setup
- Where can I get a clutch alignment tool asap?
- anyone change the cv joint
- rear motor mount
- Blowing Fire., Help me out
- cool thesis - "5-speed semi-automatic transmission conversion"
- LS/CRVTEC 411!!!
- Interesting suspension. Please check this out!!!!
- ECUs
- LS cams question
- h22a swap
- good reading
- Intake Manifold for a an HF
- Shift Boot on Automatic....
- AEM cam gear stripped. Worthy fix?
- Urgent Question Re: installing ITR shocks/springs on GSR
- compression - anyone know what this will yield..
- Bent Frame?
- Vehicle Info Request
- ecu programming?
- Dyno for sale
- please read, i need help badly...car broke down again
- The "Preferred" Service Manual
- Need advice on what shocks to get .. Neuspeed Race springs + shocks? = best ride
- Comptech sway bar & LSB?
- jdm 88-91 hb headlights
- Rear brake lights stay on...keeps killing battery
- new site , would love some help
- whining sound in power steering area!!
- Check out this site
- How does HONDATA work? Anyone?
- How do you tell if your ECU is the correct one after an engine swap
- Intake Manifolds???
- C/V Boot Replacement Question
- What's the C/R of the JDM B20B?
- 11.1.1 compression for emmisions
- Slammin' my GSR
- Whats the safiest lowest VAFC VTEC Engagement Point ?
- Any body have experience with STR Intake on non-turbo car??
- Distributor wiring question???
- What happens when your gears stick???
- LS/VTEC not as easy as i thought, u have to . . .
- which parts?
- How much for JDM final drive install?
- need help on prelude before i leave work
- Race exhaust on OBDII car - code question
- short shifter
- Attn Orlando people- need a good shop
- What kind of TB is this?
- ==H.I.D. Ballast==
- Question about ITR shocks/struts
- Brake Bleeding Techniques
- i hear sounds of a flat tire, but i checked and nothing?/..........
- Will LS distributor work in GSR engine?
- To all who want to see what sorry shape my ecu is in...
- Strut bar inquiry
- Please help me...I need clutch torque specifications
- Another wiring question, but maybe less common :P
- tips for valve adjustment
- opinions on GUDE performance
- Civic Si needs help!... oil light blinks and bogs at 6500rpm!
- S pistons
- High Compression Pistons on 93 Octane
- OT, Customer Service and a pending car swap
