Where can I find some pistons and cams?
Old Nov 26, 2003 | 06:46 PM
Hites
Guest
Posts: n/a
Default Where can I find some pistons and cams?
i just noticed that the 97-99 cl has a 3.0 liter engine that only produces 200 hp; you know what that means: untapped power. what cr does the v6 97 cl have? how much horsepower should i expect with 11:1 pistons and some slightly more agressive cams with an aftermarket header, exhaust, intake, and cat? would that get me at least 300 hp? who makes 11:1 pistons for the 97-99 cl, and who makes aftermarket cams for the 97-99 cl?
Old Nov 27, 2003 | 05:16 AM
Hites
Guest
Posts: n/a
Default Re: Where can I find some pistons and cams? (Hites)
anybody?
Old Nov 27, 2003 | 06:13 AM
KTeller8's Avatar
You could go with some Custom CP Pistons.. run your around? 525-ish
Old Nov 27, 2003 | 06:28 AM
Hites
Guest
Posts: n/a
Default Re: Where can I find some pistons and cams? (KTeller8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">You could go with some Custom CP Pistons.. run your around? 525-ish</TD></TR></TABLE>
got a link? them babies forged?
Old Nov 27, 2003 | 05:06 PM
Kendall's Avatar
Also, it shouldn't be that hard to find a place that will make some custom cams for you, or some forged rods, or just about anything else for that matter.
Old Nov 27, 2003 | 05:11 PM
Hites
Guest
Posts: n/a
Default Re: Where can I find some pistons and cams? (dc231)
just found out the place that offered custom pistons only does domestics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 &raquo;</TD></TR><TR><TD CLASS="quote">Also, it shouldn't be that hard to find a place that will make some custom cams for you, or some forged rods, or just about anything else for that matter.</TD></TR></TABLE>
you got some links? links would REALLY help. anybody know what the bore of the 97 3.0 cl is?
Old Nov 28, 2003 | 10:04 AM
Hites
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hites &raquo;</TD></TR><TR><TD CLASS="quote">just found out the place that offered custom pistons only does domestics
you got some links? links would REALLY help. anybody know what the bore of the 97 3.0 cl is?</TD></TR></TABLE>
Old Nov 28, 2003 | 01:30 PM
Kendall's Avatar
I know Crower does custom cams and rods. CP should do the pistons for you, just call them with the application and specs, then send them some money.
Old Nov 29, 2003 | 07:20 PM
Hites
Guest
Posts: n/a
Default Re: (dc231)
how much power do think ill be pushing with the cr bumped up from 9.4:1 to 11:1, 03 acura cl-s cams, the basic bolt ons, the af ratio evened out, and the redline raised from 5500 rpm to 7000 rpm?
battle2.0ek9
Apr 27, 2007 05:01 PM
Hites
Acura TL, RL & ZDX
Nov 28, 2003 08:44 AM
Memo6453
Nov 16, 2002 09:32 AM
