View Full Version : Tech / Misc
- Want to run a push button starter...need ot know best way.
- Which Dist. and wires?
- Looking for a little help.
- D15B non vtec questions
- Need help please... will sp2 muffler bolt up to an evo2?
- What is the Compression of a JDM GSR supposed to be??
- Starter whines but motor doesnt turn?
- What are the upper displacement specs for a B16, B18 and B20 block?
- Auto tranny problems
- What 5th gear will fit
- b20vtec ITB's or Skunk2 Pro Series Mani?!?!?
- EUDM Civic B16A tranny + LSD ?
- Power door lock noise. please help
- Endyne breather kit
- rebuilding motor and just bolted in crank. now it wont turn?
- jkobd obd0 to obd1 conversion, alt light coming on and oil pressure light not working
- Eliminating coolant lines on a BLOX intake manifold
- Torque Everything Down? Please Don't Lie, i know you dont.
- how do i convert my usdm integra to a rhd?
- question on innovate LM-1 and LM-2
- 02 civic eld power problem well i think i found out what i need to do to get it to always be puttin
- Fuel pressure Gauge mounting next to battery alright?
- Can a bad valve job = loss of oil?
- Need help with b20 vtec?
- Easy, just need confirmation.
- Help: CRX battery light on, tach down and radio problem...strange!
- Broke something off of my dizzy, need help.
- DSM Injectors
- how to clean a cylinder head?
- Need Help with CR-V ABS
- check me pistons out (earl)
- where do you guys buy chips etc?
- peterson single stage oil pump??
- Tunning near the Charleston area anyone
- Engine alignment in engine bay, engine mount related....
- new transmission and stalling
- willem burner
- lowest cr for boost
- B-Tranny Rebuild KIT?????? who sells them
- Question: Toda High Power Single Plate Clutch or ANY single plate clutch
- K series transmission selection help?
- Help Identify this B20
- how to get S200 to connect to laptop
- 2006nCivic & Sybthetic Fluid Recomendations
- fuel pump going bad? makes a bzz sound
- Can someone help me out?
- Strength of '04 Accord 3.0 V6 motor?
- IACV for B16
- B series crank snout outer diameter/crank damper inner diameter?
- Bearing and rod question?
- Help Map Sensor
- OBX-R air/fuel ratio gauge wiring????
- A20A4 engine? Accord Aerodeck 2.0i
- FUEL PROBLEM WHEN USING THE VAFC
- transmission questions
- Any difference between the USDM ITR Header and JDM B16 Header?
- HELP PLEASE? EG with D16y7 runs lean and doesnt adjust fuel
- rpm meter dont work, need help?
- vafc question b18c5
- AUDIBLE ALERT CHIME FOR WHEN HEADLIGHTS STAY ON (CIVIC 1994)
- master cylnder
- Quick head milling question
- P30 speedlimiter HELP
- Does anyone make a short shift kit for a Generation 1 CR-V?
- b20 or something else
- hondata S100 on a stock b17 with I/H/E???
- SI Distributor DOHC ZC?
- lack of compression?
- 99-00 D16Y8 Question..
- Bare block to running block...
- Tranny sitting in garage for 8 weeks +
- Spoon N1 Axle Back from EK, will it fit DC2 ITR?
- jun 3 or skunk stage 2
- Which specialty tools do I need to do a 98 B18B LS rebuild? Advise on Rebuild?
- Electrical short (BAY AREA, CA) will pay you
- AEM 3.5 bar map sensor with hondata s200?
- Guaranteed good Head? Need series of tests before i run it on my new block.
- Oldie 1983 Civic 1.5 cal emison
- Starting a brand new motor!!!
- different ls header lengths ?
- Ls block with pr3 pistons/b16a head
- mystery gas mileage drop, sluggish motor
- h22 obx lsd???
- Dyno testing of synthetic oils
- Wanted: Stock DynoJet DYNORUN files for various Honda/Acuras
- Request Opinion on Exhaust noise
- Apexi VAFC II problem
- cracked heat sheild
- wideband O2
- closest high temp paint color to engine block
- Where does this do
- *Help* Boring ?.....
- Need help finding a wire....
- Transmission: OEM Internals w/ LSD....how much hp
- Excessive Rod Sideplay...
- problems with fuel
- AN (Army Navy) Fittings Explained
- oil catch can set-up
- Orlando Members(Need Help With Wiring A Swap)
- CTR Tach wont go past 4.5k help
- New to Honda stuffs...
- how much hp can b18c1 crank withstand....
- question about hondata
- Crank pulley sensor question
- B16B questions HELP!!!!
- Vafc-Tuning it? Help anyone
- Installing AC into a 2g integra
- head lights & brake lights dont work
- car wont start 92 civic hatch
- cold start idle
- tranny cooler ok to use and engine oil cooler?
- Auto tranny problems, shifts waaaaaay early.
- compression rings or head gasket?
- how can i tell if my s100 is with the boost option??
- Cam Gears?
- Tranny problem please help.
- How many quarts?
- delsol / d16z6 manuals in pdf?
- i searched but it was no help. IDLE, COOLING and BREAK ISSUES.
- Seals...
- High flow oil pumps
- 88-00 fuel rails all the same?
- rod bearing caps... can they be on backwards?
- Number needed for Distributor Shaft on an '88 Honda Civic LX
- gsr tranny or clutch chirping noise please help
- looking for some info for h22 turbo
- Help with Small Oil Leak w/Pics
- where to go to upgrade ecu
- H22 Ek guys... Hole through firewall for cables?
- mystery noise in new engine, hoping someone can help
- removing my engine harness, I broke a sensor....what is it???
- Weird ECU Code on my D16... :help:
- Question on B-series cable tranny?
- ITR Cams in GSR head. Stock springs OK?
- Help!! 1994 Civic LX Valve cover bolt sequence
- Can ECU's Go bad?
- Royal Purple Dyno Results!
- JDM ITR header dents affect performance?
- Ball Joint Seperator
- Piston Biuld Up?
- Lowering compression with a thicker head gasket
- Check engine light(Code P0505)
- Piston/Valve clearance issues with oversized valves.
- Engine will not run
- -Quick H-T... I need help- My Car wont start!
- best way to go from hondata base s100 to s100 w/boost or s200 w/boost
- Spark plug gap?
- Clutch Catching Adjustment?
- Need help w/ Power Steering in EK
- ps to hp conversion?
- Degreeing Cams
- D series flywheel ; how much weight I could remove from it....
- does hondata work with automatic for street
- Laptop Requirements??
- usdm or jdm??
- Vtech ?
- HELP! WHICH CAMS???! and....
- 1996 GSR Headgasket
- New fuel setup, one question
- Auto p72 ecu with manual gsr?possible??
- dowel pins help!! lsvtec
- clutch replacing questions
- Electrical problems with 89 CRX
- transmission fill plug?
- Apexi Vtec controller Vs. Buddy Club V-CON??????????
- b16 overlap question
- Speedo not working. Need help!?!
- I hate everything about my hmotors swap so far... need suggestions..
- Coil Voltage? Dave Chappelle?
- Bad timing belt
- Question about the safc2
- amcparts.net lsd
- b16 obd-0 idle surge (non repairable ? )
- wtf is wrong with my god damn car now
- How to ground my ecu??? *dumb question*
- D series OBD/oilpump discovery, might help u cali folks
- Dyno'ing soon. Q's about cam gear tuning w/ no fuel upgrades.
- Engine problem...
- Poor Gas Mileage
- Ls VTEc type R head with B18a1 block
- light throttle bog
- car bogs at 3500rpms
- ground from thermostat housing?
- what do i need to make silver auto lock switch to work?
- How Close Is To Close For Oxygen Sensors?
- 89 CRX Sunroof won't close
- SP Engineering big yard sale SUCKED!!!
- Car running hot and burning oil, but why?
- Have a b17a 93 gsr in my crx what would be the cheapest for lots of power gain
- chipping an ecu
- CEL 9...clueless.
- automatic transmission squel (searched)
- Timing belt side of motor making ticking/knocking noise...not rod knock...
- b16a3 question
- Troubleshooting code 16
- custom piping
- timing problem, need some help
- need help please!!!!! with injectors. not working!!!
- B20vtec, VTEC NOT WORKING!?!
- h22 swap
- Just got gsr head back from shop.
- Everyone thats installed a Aftermarket clutch..
- Tuning Guestion
- Car wont turn over
- 91 dx B16a vafc hack
- fujitsubo RM-01A flow rate required
- JDM b20b does it have the CFK (-Crankshaft speed fluctuation)
- I know this is a Honda place, but I need to find a place that sells toyota longblocks.
- how to remove k20 valve seals
- No power to left headlight plugs help...
- US 99+ SI Transmission vs. USDM ITR Transmission
- Sputtering and Idle problem's.
- CRX vaccum system with a b16
- have a solid check engine light....
- h22 clutch housing
- skunk2 dual valve springs... one spring "loose"??
- Need tuning advice. b18c1 turbocharged, thinking of p28???
- Need help. Engine question..
- Help!!!
- 4 cracked pistons on a brand new motor
- MINI MEE build up
- Gauges.
- Attention EK Owners: Help.. Tires Rubbing
- B20vtec vs LSvtec
- Engine suddenly stopped running. Need help badly please!
- uberdata
- How reliable?
- Help ASAP Please.
- just rebuilt motor and car idles too high!!!
- d16y8 distributor vs d16z6
- GRIPFORCE CLUTCH *warning*
- Vtec solenoid cleaning question??? did search
- Those Damned Cali Smog Laws
- which wideband?
- damn piston speed calculations
- IAB and knock sensor??????
- need help with ZC motor
- spoon/mugen/toda part makers?
- WHY Blank rotors are better than cross drilled and/or slotted
- Who invented Variable Valve Timing?
- oil burning problem on rebuild
- Hey Nimrod!!
- 2001-2005 Honda Civic Instrument Panel removal to install new reverse glow panel
- selling hondata?
- ABS!!!!!@!@!???!
- Is it worth to tune the Air/Fuel ration of an NA OBD2b B18c1
- Cylinder Head Hell, HELP!!!
- Ceramic coated exhaust ports
- urethane as a mount...?
- LS/Vtec question
