what does the rotating assembly include?
Old Nov 25, 2003 | 07:54 PM
Propulsion's Avatar
Default what does the rotating assembly include?
basically, when people say balance the rotating assembly, what are they referring to? Crank, flywheel, clutch disk... what else?
pistons/rods are not part of the rotating assembly right?
Old Nov 26, 2003 | 06:54 AM
IN VTEC's Avatar
Default Re: what does the rotating assembly include? (SilverCIVIC96)
Technically speaking, it would not include the pistons/ring/wrist pins and the beams of the rods. Those are considered reciprocating components.
The big-end of the rods, crank, crank pulley, flywheel, and clutch/pressure plate are considered the rotating assy.
But, a lot of times, they all get lumped together for ease of speak.
You also have to consider that some things don't get balanced along with the crank, piston, and rods....like the flywheel, clutch/PP, and occassionally the crank pulley.
CHU-JDM-DC2
Engine Machining & Assembly
Feb 1, 2016 12:52 PM
GarageAlchemist
Jun 21, 2006 01:30 PM
euclid
10
Dec 21, 2004 05:46 PM
JMinSi2000
Jun 20, 2003 03:28 PM
mafay2
May 18, 2002 09:46 PM
