fuse problem?
Old Nov 25, 2003 | 11:52 AM
marc.ejay-twenty's Avatar
Default fuse problem?
i went to start up my car this morning and everything seemed normal...
1)i stuck the key in the ignition and it made that annoying beeping sound
2)i turned it to accessory (position I) and the radio turned on and cd changer turned on
3)i turn the key to ignition (position II) and everything shuts down. it made the sound like a fuse just blew, but i've checked almost every fuse and nothing happens. there is fuel pressure so im guessing it's problem with a fuse to the starter or osmething?
the initial and accessory positions still work...interior lights and everything. the problem is when i turn the key to position II nothing electrical works...the dash is not lit and no power to the ecu cuz my vtec controller is not lit. the only thing that seems to work is the injectors. anyone have any ideas asap so i can get to work LOL. thanks in advance!
Old Nov 25, 2003 | 12:04 PM
Perfectionist's Avatar
Default Re: fuse problem? (marcdogg816)
Try jiggling the key in that position. Might be your ignition switch is going south.
Old Nov 25, 2003 | 04:42 PM
PHiZ's Avatar
Default Re: fuse problem? (Perfectionist)
Was it warm/hot/sunny? Honda main relays give up the ghost in the heat. can you hear the fuel pump click on?
-PHiZ
Old Nov 25, 2003 | 11:40 PM
Default Re: fuse problem? (PHiZ)
funny story...my alarm thought i was tryin to steal the car for some reason. i just unhooked the alarm and it was cool. f audiovox prestige alarms...
91sedan_kid
Jan 19, 2025 09:13 PM
efcivic317
Dec 2, 2010 02:25 PM
mike03,95civic
Dec 31, 2008 08:11 AM
vnguyen850
Mar 4, 2007 07:53 AM
