View Full Version : Tech / Misc
- Where to apply anaerobic sealant to rocker arm assembly on a D16Z6.
- what b series syncros interchange?
- itr 5 lug conversion on ek PROBLEM. brakes doesnt work and doesnt have presure.
- Overheating, No Fan, No Heat!!! Please Help ASAP! Driving Me Insane...
- over heat is deadly
- a/c dont work please help
- trying to start my car annnd
- gsr cams in B16 or any other mix of cams in B16
- Engine cuttin out!!!
- engine makes a ticking noise once warm? please help!?
- obd conversion ?
- ecu help....... sorta
- A/C problem!!!! The compressor is not kicking in... any ideas?? *****NEED HELP!!!*****
- Online service manual
- What exactly is a 'body ground'?
- !!!HELP...ENGINE BOGGING @ 3500RPM
- transmission interchange d- series
- Need help identifying a set of b-series cams.
- HONDA TROUBLE - hit pot hole and engine has cut out
- where ae the marks on the y80lsd s80lsd gearbox and b18cr engine??
- zc intake mani on y7 idle problen
- engine wont rev past 3500rpm
- MFactory Competition Oil Cooler Kits
- Who can chip obd2 ecus?(or can fix the problem)
- Problem with my EG
- ys1 tranny case broke.
- New Axle or CV Boot?
- motor help
- TPS help.
- apexi vafc problem. need serious help and fast.
- h22 parts
- ECU Code 68 on an ODB1 P72 ECU
- 99 hx problems
- delema with main bearings
- A/C Recharge
- Think i have a wiring problem
- motor knocking. problem?
- Y5 vacuum diagram
- Engine Problem
- please help motor won't run
- 4-1 header, Which two cylinders get o2 sensors?
- B16 overheating
- car dont start.
- intake air noise
- LSD identification
- Black buildup by the exhaust ports
- leaking valves/3 angle valve job/shim question
- eg hatch exhaust
- Slipped timing belt help!!!!!!!!!!!!!!
- Sparkplug holes filling with oil
- possible to replace rod bearings w/o removing head?
- autometer egt showing 100f when key off/out???
- idk if this is the right thread but i need some help
- Engine flooding, need help!
- DA6 RHD conversion engine wiring harness problem
- Blower Motors Works on speeds 3/4 but not 1/2 - FIX + How-To
- spark plug? broke?
- rebuilding a d16y8 motor..
- HELPPPPPPP!!!! I need fast help
- NEED HELP WITH CHROME !!
- Car idled w 1000cc inj. Now dies with 450cc inj. Never ran, too rich.
- Surging idle ???
- ECU chipping
- Built motor, no oil pressure?
- Help need fule setup questions
- what obd 1 ecu for a b16a2 motor?
- Do you guys use Hondabond on B18 pans?
- ecu female pins?
- Who tunes crome pro?
- hot tanking
- B16a block with B18c1 internals
- Help need to get my car tuned
- clutches
- wiring help
- civic94 transplant 1.5lsi to 2.0ls from accord98.
- SC4 trans??
- k24a2?? VS. k20a2??
- speedometer surge/malfunction
- Cylinder Walls and Sleeves...
- Pls HELP, i need good H22A
- help!!! situation doesn't make sense
- Valve Adj. with Aftermarket valvetrain
- D16Y8 head on a D16Z6 block in a OBD car (EF)
- golden eagle oil sandwich and remote oil pressure sender install.
- FPR & Fuel Filter location? Higher than fuel rail??
- Question about putting on carbon fiber hood
- AC Compressor Problem
- intake manifold question?
- electric speed sensor in a crx not cable
- Hondata
- Anyone using a JVT Radiator??
- where to buy JDM and USDM GS-R block
- intake manifold
- launch control for obd0?
- Solid CEL after faulty romulator
- Instruments Lights
- B16B Civic Type R motor - oil cooler / water pump help
- 2 oxygen sensors in my car, 1 in my header
- MATINENCE REAQUIRED LIGHT!!!how do i make it go away!!!
- Need Tuners Locations in SoCal
- Engine burning quarts of oil every month, but no smoke, no leaks
- extra cat bad for MPG?
- Will runnign too rich melt or eat up pistons?
- Removing Intake manifold
- B-series headers fitment
- itb ?
- NEED HELP FAST PLEASE!
- I have a 96 civic hx and a 99si motor and need a power steering line. and exhaust
- tuning pricing need some imput
- High Boost ok to tune with 100 octane?
- Ever heard of a magnet on your fuel line, saving MPG??
- Will 90-93 Half Shaft Support fit 94+ Half Shaft?
- So I was taking my head off my GSR...
- 1989 Integra Transmission small question?
- alternative to adjustable cam sprockets
- civic swap
- Integra Tranny Problem: Cannot get into gear...
- Innovate LM-1 AFRs vs ECU AFRs
- ** 2001 Integra - "Retrofit" - How To?|Walk Thru|Help Plz **
- new to tuning, almost got the boosted b16 running
- Electric AC??
- Engine building tools?
- Automatic Civic Ex trying to swap in a B16 manual
- Locking out of gears??
- gsr head bolts on a b16?
- Spark plugs fouling out? Car has problems cranking more info inside
- 98 HX w/ the CVT.... need some info please.
- Single Slim Fan on Integra with A/C
- are EG si rear brakes the same as DC2 rear brakes???
- need help with TPS.
- omni power titanium axles
- NEED HELP! OBD 1 with codes
- sohc oil pump limits on turbo?
- first build h22 questions jun cams/portflow/type s os/smsp/vafc
- Timing belt durability above 7k rpm
- ??? S80 LS 5th gear into hydro B16 tranny??
- Car Falls Flat on its Face.
- Cam wear problems
- BASEMAP for a D16Y8
- Car shuts off after startup when car is warm
- OBDO B16 - Cap n Rotor. What Car Do I Buy From? 91 TEG LS DOESNT FIT!!!
- gear problem
- Need B20Z2 Crome basemap
- Can I reuse my head bolts??
- Autronic Traction control......how?
- What size clutch master cylinder for type R tranny?
- Help need for tunning Honda FRV (Honda Edix)
- VAFC Won´t start.
- Moto Man's 8 phase motor theory
- valve to piston clearance
- 2000 integra type -r tranny problems
- b18c5 problems w/ ecu n hondata!!!!!
- msd???
- need help with cracked sleeve
- need help finding wire diagram
- Backpressure vs. Exhaust Velocity Explained
- exhaust spring bolts?
- SRS Light Modification with 2.2ohm resistor
- Failed CA smog..high nox..need help
- optimum bearing cleances???
- Temp gauge recalibration
- Y1 Parts in a S1 Tranny?
- Help..My car tops out at 112mph! De-limit???
- 4.9 final
- Is it safe/ok to sandblast a head??
- Another Vtec bogging question! YES, I searched. Bone Stock Motor here!!!!
- WIRING! Code 6 - Is My Wiring Correct? EASY QUESTION!!!
- Hondata S200 serial # s200-3242 What options does this have?
- not spark on first startup
- Nitrious oxide questions
- DISTRIBUTOR NOT FIRING HELP!!!
- No 3rd gear??
- SOHC NON VTEC to SOHC VTEC!!???
- JG 301 NonVtec Cams in B20B...OPINIONS Please!!
- REALLY Slow Starts, Misfiring Idle - Whats The Problem
- car over heating on temp.
- OBD2 CODE
- could bad cat be cause of problems?
- Pulstar Spark Plug replacements - "Pulse plugs"
- SPEEDO DIALS
- B186--What car does this motor come in?
- oil cooler kit
- Apexi VAFC2...
- Locking Vtec with compressed air (where to buy tool?)
- Individual throttle body making (cbr 600 too small?)
- Carbon build up
- Engine Dampeners ???
- 2001 auto tranny in a 1998
- B series transmission id
- A/C compressor help!!
- engine swap problem!!!
- CYP cel effecting ignition adjustments?
- AVID MOTOR MOUNTS?
- b16a timing w/heat issues
- Read my Plugs
- Stock ITR failed E test. Anyalize results... oxygen sensors or injectors or what?
- B16, Fuel In Oil?
- Wideband not reading............
- b17a rods
- Which valve seal?????
- type r or gsr block
- O2 sensor problem ... its a CRX
- Transmission Building Questions, and Gear Ratios?
- Tranny fluid for LSD
- PISTON RING END GAP
- jdm b16 w/LSD problems.
- Found this while taking off my oil pan....any suggestions to fix it???
- s2k idling problem HELP!!!
- HOW DO I BUILD A 500 HP GSR TRANS?
- Catalytic converter connected to header?
- cometic phuzion .051 head gasket PROBLEM GT35R
- American Motorsports Limited Slip Differentials???????
- Chip burning???
- PCV QUESTION??? Need answer.
- overheating and coolant level rises?!?
- With slightly higher compression will a stock ecu map work?
- extreme low idle. NEED HELP
- testing testing testing
- Civic SI shift fork fit in a integra GSR transmission
- 96 integra ebrake help
- ported gsr intake manifold.... Am I crazy?
- Engine is making a strange sound... please HELP!
- havin a hard time going into gears after a bit of driving
- (Leakdown Test) Air coming out adjacent cylinder
- 2200rpm idle while warm......i've searched high and low
- itr pistons in a gsr block??
- shifting problems
- Vtec Test light?
- head gasket help?
- LSD D16Y8???
- Skunk2 stage1 cams
- HELP ME JESUS! My car won't start after new fuel pump install, No spark from Dizzy! whats goin on? *
- Trailer Setups
- megan racing test pipe intsalled
- High Idol
- LSD for cable trans quaife or OEM?
- WHICH BULBS ARE THE BEST BASED ON PERSONAL EXPERIENCE???????????
- need to pass inspection in nj
- Cylinder Damage
- HELP spliting a jdm b16a motor
- spoon strut tower bar, k series???
- Distributor Position Help. TDC
- bad vibrations!
- 2006 Civic R18A Valve clearance
- wideband lc-1
- clutch doesnt fully disengage
- im stumped, car starts then dies.
- ecu frying
- Poor Mans Type R,HELP PLZ
- over heating problem
