cleaning head and block......questions....
Old Nov 30, 2003 | 12:44 AM
see_our_vtec's Avatar
Default cleaning head and block......questions....
i'm going to be cleaning up a head and block that have been laying in my garage for a month or two. and i'd like to know what you guys have used to clean your blocks, heads etc. etc.
just curious on a cost effective way to make them extra shiney. or look decent.
lmk
brian
Old Nov 30, 2003 | 06:37 AM
Kendall's Avatar
Gunk Engine Brite, available at Wal-Mart. And a pressure washer for the outside of the block.
Old Nov 30, 2003 | 11:10 AM
HEAD's Avatar
Default Re: cleaning head and block......questions.... (JDMlude92)
brake clean and water. gunk. make sure you blow them off and not let it just dry
Old Nov 30, 2003 | 11:16 AM
IN VTEC's Avatar
I just send blocks and heads off to be hot tanked at the local machine shop.
Old Nov 30, 2003 | 01:16 PM
Default Re: cleaning head and block......questions.... (IN VTEC)
like i said. cost effective.
i've heard good stuff about gunk and simple green. are there any certain procedures i should do?
i've also been told you can fill a barrel full of solvent/brake clean/simple green overnight and in the morning just wipe it all off. whats the truth to that?
Old Nov 30, 2003 | 01:47 PM
redlineintegra's Avatar
Hot-tanking isn't expensive, I paid $40 CAD to have my block cleaned, and they even painted it with aluminum paint for me. Worth it imo .. cleaning the block/head by hand sucks, especially if they're covered in years of crap .
Old Nov 30, 2003 | 03:32 PM
myhatchrips's Avatar
Default Re: cleaning head and block......questions.... (redlineintegra)
LIKE THIS? well i got mine done at school. no charge. 90 b18a
Modified by myhatchrips at 4:42 PM 11/30/2003
Old Nov 30, 2003 | 04:05 PM
doublejz's Avatar
just buy a **** load of mineral spirits and soak it yourself
Old Nov 30, 2003 | 06:25 PM
AzG35's Avatar
Hot tanking is probably the best way to get all the grime off. Make sure you rehone the cylinder walls afterwards because the solvent will "wash" down the walls some.
Old Nov 30, 2003 | 06:29 PM
Kendall's Avatar
Default Re: cleaning head and block......questions.... (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 &raquo;</TD></TR><TR><TD CLASS="quote">Hot tanking is probably the best way to get all the grime off. Make sure you rehone the cylinder walls afterwards because the solvent will "wash" down the walls some.</TD></TR></TABLE>
This man speaks the truth.
Old Nov 30, 2003 | 09:12 PM
greebler's Avatar
can of Gunk and a local spray and wash.
Old Nov 30, 2003 | 09:42 PM
Fastist12's Avatar
You can use any kind of degreaser and pressure wash to ckean block and heads , gunk, simple green ect you can do this at home
Your local machine shop can jet wash these parts for yu
[ have you had any blocks return from the hot tank LOL it eats alum. ]
Agood machine shop will NOT hot tank alum
Stormpower
Old Nov 30, 2003 | 09:53 PM
HONDADNA's Avatar
Default Re: cleaning head and block......questions.... (Fastist12)
3 words"Castrol Super Clean" - This will clean any thing better than any other stuffs.
Old Nov 30, 2003 | 10:37 PM
riceball777's Avatar
i payed $33 to get my blocked hot tanked at rs machines
Old Dec 1, 2003 | 03:24 PM
Yup, it's actually jet washing and not hot tanking, but everyone calls it the same thing when it's not .
Old Dec 1, 2003 | 06:26 PM
prestoned's Avatar
Oven cleaner works decently
Old Dec 1, 2003 | 07:37 PM
AzG35's Avatar
Default Re: cleaning head and block......questions.... (HONDADNA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDADNA &raquo;</TD></TR><TR><TD CLASS="quote">3 words"Castrol Super Clean" - This will clean any thing better than any other stuffs.</TD></TR></TABLE>
The only problem with that stuff is that it "stains" the aluminum. I used it, and it leaves water stains but it doesn't damage anything.
tootybaby
19
Sep 21, 2009 03:23 PM
drumbum87
Apr 21, 2007 09:18 AM
LudeyKrus
Aug 12, 2003 08:50 PM
rasta420
May 21, 2003 08:15 PM
275Performance
Feb 1, 2002 09:13 AM
