View Full Version : Tech / Misc
- lean condition- tuning
- REAL OEM parts online?
- ELD? Electrical problems? Charging System light + loss of power in boost.
- P0108 MAP sensor curcuit high voltage, need some help
- B18c1 VTEC
- Eg civic oem fuel pump
- Skunk2 Pro1 cams and Springs. What retainers?
- smoking h22a1. bad valve seals are suspect.
- vx in a dx
- t belt tensioner for ac bracket?
- What fell out of my gsr head? Pics
- 2006 Cr-V cluster swap conversion
- Works Bell Lock on a NRG QR?
- Mugen Formula 1 valve cover??
- yep! another cel
- CEL on but throwing no codes
- Looking for Guys in Mass for Garage Space
- Accord to Civic electrical swap help!
- Pictures of factory honed cylinder walls-D16A6
- Fake or Real Sparco? ( Pro Circuit model)
- ckf bypass question
- new style injectors upgrade. which ones?
- F22A1 w/ F22A5 head?
- 14.1 compression on 91 knocking and over heating motor dies. HELP!!!
- Quick question about....
- N/A car with Turbo Muffler
- skunk2 certified??
- Ej1 to da9 Trade
- Beefy upgrades on gearbox, HELP needed,,
- Please help me find my stolen black honda hatch :(
- HELP! Car broke down Jeffersonville, OH need Reputable Shops nearby
- HELP
- gauge cluster quit working..
- VTEC rockers not locking?? video attatched
- common honda sickness
- d15z1 with auto tranny any updates?
- b18c sensors
- buddy club cam gears degree markings
- Cracked cam holder
- map sensor voltage?
- rywire harness problem
- Mystery noise??
- Telescope Gauges a big no no for a poor mans Dial Bore gauge ??
- Want heat back in my car, what's all needed?
- on tools
- P28 C15 Capacitor
- DC power to manual steering rack swap
- JRSC experts please chime in 99 si
- HELP!! obd harness ecu distribtor questions
- Which engine to choose for mid engine build
- 91 honda accord ex stalled and now back fires
- Half shaft issue
- 06 civic dx window issue
- What parts do I need for a thorough timing best replacement.
- MAP sensor question
- Need advice for fuel line/filter change..please look guys -__-
- 94 Accord EX Problem with Turn Signals/Hazard Lights
- Intake Backfire, broken rocker. Ideas?
- Brake Fluid and Paint removal on Plastic
- delete
- Recurring vtec solenoid leak
- Compression Ratio w.r.t Fuel Octanes
- FMU
- help with sohc harness in 00 si
- GSR gushing oil out of oil pan gasket!
- how to find out if the head was milled and how much?
- Steering Fluid Type for Modified System???
- ef w/ob1 po6 pin a23 gnd questions
- my b16 eg9 doesnt turn on anymore
- How To Rebuild B Series Engines book
- Ebay upgrades, does any of it work?
- B16a jdm 2nd generation wont pass emissions! help!
- Annoying tach Problem...help?
- Sputtering/bogging after compression test
- set timing manually
- need help with loss of power above 5500 with h22...
- eg b20b starts then slowly dies after accelerating
- B16a sputter 3200rpm and up
- Whats a good honda slick
- A solution to the 22 mm crank snout problem
- B Series crank identification
- B16a wrong grounding points??
- overheating and cant figure why
- Engine urethane mounts
- VTEC Solenoid wire getting 12v with engine not running?
- Help...skunk2 b series composite fuel rail spacer length?
- Help me Honda heads
- how does my first try at honing look? feedback welcome
- Deadend connector cap missing, dsm injectors question
- Help! Stuttering and intermittent power with b16a DA
- rocker arm assembly
- have center brake light but side brake lights dont work
- No battery light, no vss, no charge, obd1, HELP
- Sqeaking on front end=ball joint?
- gsr coolant pipe with skunk2 intake manifold
- Pr3-3 CTR head ls/vtec Questions please help??
- Lock Cylinder Options 96-00 Civic?
- Turbo D16Y8 - Does This Main Girdle Look Right?
- Del sol windshield washer reservoir...wire?
- Correct water pump/timing belt on b16ahead/b20 block
- Flywheels: EXEDY / FIDANZA / BISIMOTO
- stripped oil squiter on the block.. please help
- HEY MODS!!! what do you think about this
- eg hatch no turn signals hazards work...
- Can I seafoam again 500 miles later?
- Overheating issues - b18b3
- k20 manifold on f22a
- Strange AC freon / refrigerant leak
- Good option for exhaust locknut?
- JDM ZC NON Vtec vs JDM D15b Vtec
- D16y7 to Y8 IM Swap
- Distributor rotors...gsr vs type R
- turbo 94 hatch D15
- 2007 Honda Pilot radio error codes
- cfk bypass trick
- 94 civic dx no power, no start
- Question about swapping heads
- em1 lighting problems
- Main Relay question....RZ-0132 vs. RZ-0159
- which way does shift knob jam nut go on?
- Blox P1 cams with turbo....not working for me.
- Car wont start need help with some wires! thx
- DC Sport headers Bent in at Bottom
- Is there a write-up on how to change heater core without removing whole dash??(99 ek)
- Opinion on Motor Mounts. EG/B20
- wierd main bearing problem (h22a4)
- b18c4 with b16a crank pulley what belt do i need?
- noob with h22a rex
- 92-95 Hatch Rear View Mirror Metal Mounting Bracket Adhesive?
- Intermittent no start
- Which way does exhaust manifold gasket go?
- Shift Linkage Hardware
- eg civic cb accord da itegra or cd accord
- 97 civic catback exhaust
- Failed SMOG. Too high NO and HC??
- Bright 168 bulbs
- Any Idea as too How much a B17 is worth?
- 94 accord gears wont engage
- intermittent fuel cutoff on freeway. ideas?
- H22 LMA testing procedure.
- Need a complete F22A1 PCV system diagram, help!
- What part number for my CAM SEAL? (pic posted) on my JDM B16A help please?
- B-series Auto into 5th gen civic.
- Rod bolt upgrade.
- my speakers??
- A more fun Automatic
- EM1 Civic B16A2 - High pressure/bloating, upper radiator hose.
- car problem
- where can i buy the ABS sensor gear/ring for b series
- Vtec solenoid testing
- NEED HELP with the distributor
- rywire vs no name ecu jumper
- 1994 Honda Accord EX Losing all power, On and then Off
- car shuts off and bogged tach jumpy when driving for a while
- 1991 Honda CRX 5 speed transmission noise
- Headlight/turn signal wiring gets hot!
- Spherical Shift Knob
- wiper problem
- 89crx d15b2 dizzy wire problems
- Turning headlights on makes wipers come on???????
- Distributor Cap for external coil
- Problem with 1994 Honda Civic EX
- coolant temp sensor thread pitch
- Coolant flush for removing rust from outside of sleeves?
- E85 advantages over gasoline?
- mounting oil pressure sensor to vtec pressure switch test fitting
- Check engine light help code 21 p28 ecu
- What Happen to my Honda City?
- 94 civic coupe center console replacement
- Rebuild kit, best place to buy them ?
- B16a swapped EF, high idle/Idle surging (port inside throttle body sucking)
- Jackstand high or low for safety?
- grinding/squeeking
- Ek coupe odd dip in idle randomly
- obd2 jdm gsr into obd1 eg si :S how do i go about this
- ECU's
- D16y8 with d16y7 cam/rocker assembly
- N/A b20 Vtec questions
- 200,000 Mile mark
- piston ?
- R12 Freon conversion to R200 Propane
- how to wire obd2b dizzy to obd2a plug
- auto meter tach reading
- d16y7- y8 swap..... need help plzzzzzzz
- just picked up a b16 block. need some help
- loud noise coming from steering pump, pulley & tensioner area..
- Blox Tuner B centerlines
- Custom Manifold Idea for Nitrous B?
- y7 and b7 share same valves?
- 1998 honda accord lx dash problems
- Engine balancing question.
- p06 problem
- Emission help with JDM motor Type R motor in 99 EK
- 94' Integra problems after TB replacement
- OBD1 h22 distributor to OBD2 96 civic harness Diagram
- Any way to extend a speedo cable???
- Motor Code Help!!!
- B20 vtec idles great, revs rough
- odb1 scanners
- aftermarket seat question in del sol.
- 95 civic with 2.2 l vtec. No spark
- Less Negative Camber
- camshafts
- Poor-Mans Type-R swap in 94 dx coupe Code9and 17
- Spark plugs flooded with Fuel causing No Start
- 1998 Honda Accord EX 4cyl - Code 1457
- Are Shell and Chevron superior to other gasolie brands?
- B16 ticking, not valves or LMA
- Fuel pump wont shut off when key is on
- F20b fpr
- type r manifold hose hook up
- ERL Performance any good?
- Dual pump help
- Mild rebuild advice
- IACV Cleaning
- what or how to clean transmission
- Got fuel, got crank but No spark PLEASE HELP!!!
- What cams for all motor b20 vtec build?
- D16y7 Blown motor, locked up or HG ??? VIDEO >>>
- 90 rhd crx sir throttle cable help
- Can someone explain the basics of air tools to me? (In regards to axle nut)
- Does this look like a sunken sleeve?
- Motorcycle Gas Tank in honda civic trunk??
- 1990 Honda civic HB Key Starter Wiring
- d16a6 bock with z6 head
- ITR Rod bolts in LSvtec ?
- So Cal Transmission Shop Recomendations?
- which nrg combo to go with
- chirpping from the 98 si
- EK9 -99-00 Civic hatch Power window?
- Fuel smell on stock GSR with aftermarket IM
- b16a3 with ITR cams/IM need advice
- b16a da problem
- Possible bolt missing from mount?? w/PICS
- CLEANING RED RECAROS
- GSR in a VX P28 harness P28 hondata ECU?o2?
- b20b in 91 civic dx help me out please
- cluster help my speed at zero
- dohc cam gear settings discussion
- radiator fan wiring
- hasport mount problem
- Most efficient way to ship wheels/tires?
- Vtec Problem PLEASE HELP
- Honda H23a vtec in a French Goddess!!!
- EF Civic Mugen Foglights - Genuine or Not?
- Car Overheating with thermostat but running fine without a thermostat
- Weird performance issue after SWAP to a D15b HELP!
- VTEC Help!!! No CEL even when Solenoid/Pressure switch are unplugged!
- Doin a wire tuck on my 95 coupe need help/suggestions
