View Full Version : Tech / Misc
- Odd problem with dash clock and turn signals
- coolent temp problems
- s2000 o2 sensor on ITR??
- 99 00 si ebrake cable same as the rsx?
- what b18c1 parts to keep
- 1988 Prelude SI Idles at almost 2k
- B series ring gap size
- Questions on opening own performance shop
- HELP, ONE QUESTION B18C-R
- help! fuel issue with my gsr
- Engine Harness - WHat do i use?
- B18a1 Block sensor?
- Valve cover ?
- Seating question
- distributor internals swap Question
- vtec solenoid?
- reman'd alternator bad after 1 month ???
- 3.5 turbo
- B18C1 obd1 to obd2
- 1991 Crx HF 8 Valve burning Alot of oil. Please read!
- * * * D15Z1 Smokes * * *
- 91 awd wagon questions/
- First car 88 Honda Hatch please help new to cars
- [ Broken header bolt ] What drill bit will drill broken stud / bolt like butter ?
- The next ten years???
- block rebuilding
- need ecu help ASAP
- you have got to see this!!!!
- Counterbalance Shaft?
- Integra Injector size?
- Homemade Thermostat?
- Emissions and cams?
- CRV Balance Shaft?
- heating/cooling issue
- hardwiring map sensor on 97 integra?? help!!
- Impossible Code 1 HO2S Problem.
- dx to b series help!!!
- Catbacks? Is it street Legal?
- What throttle body is this? GSR?
- what does semi built motor means?
- Keys Racing steering wheel with NRG hub
- **(Main Relay)**
- Whats a good rebuild kit?
- Auto Gsr cams?
- V6 dual to single exhaust
- Custom Gauge Mounting....?
- brake proportioner valve leaking help!
- Injector problem?
- freshly built b18c sounds like a diesel.
- This hose is glued on!
- engine build? 400whp soch non vtec? f22?
- yoparts ripped me off 1000$
- ENG WONT START HELP *FEMALE NEW TO THIS*
- need help - code 15 ingition output signal
- is map sensor and tp senor backwords?
- help me identify this valve cover
- ECT sensor problems
- Cold starts die; Warmed up its fine
- z6 vitara ycp or tik pistons
- TP sensor plug wire colors?? 94 gsr
- Antenna replacement
- valve adjustment...loud tick but healthy motor
- shifter bushings, shifter is rly loose
- ls crank + gsr rods, which bearings ??
- VATS relearn
- breather box vac lines
- injectors
- honda accord v6 2011-pipes
- NO SPARK, NO FUEL please HELP!!
- Spoon Sports Wheel and NRG Quick Release
- Map Sensor Problem...
- I have a stumping fuel question for experts on here
- Which BAR Stations is the easiest to get a car/swap BAR'd around SoCAL?
- B16a starting promblems Need help
- 1.6 SOHC vtec
- skunk2 IM w/ sk2 TB on b18c1 questions help
- JDM B16a sputtering/bogging
- DB1 RS power window conversion questions??
- 1989 crx si speed-o-meter
- obd1 ls motor in ef wiring help...
- 96-00 honda civic radiator aftermarket???? HELPPPP!!!
- Question about recaro's
- problems: car slowly died no spark has accpower...
- crank sensor question and timing marks
- stripped engine mount threads
- Matching Engine vin and dash vin
- Need help with some check engine codes please. "eg9"
- RHD EK Conversion; Gas & Trunk Latch Part#'s?
- Valve Float and other cool vids.
- Brake Fluid under $1
- Need help wireing aftermarket radiator fan
- 1997 civic d16z6 turbo swap misfires bad
- Charging system problem
- b18b1 throttle body swap on d16y8 with bouncing idle problems, please help me!!
- Will I need a tune after an N/A build?
- 1986 EG Hatch.
- 1993 civic hatch
- car seats diy for gaming chairs?
- Valve springs for p8r
- gsr scored walls
- Different codes with different ecu's
- What do I need to start and run a D16A6
- Oil colored water
- Steering Wheel Shaking
- NO start...NEED help...i got sparks, compression, fuel pressure...
- Turbo LS-V no vtec!!!
- wiring diagram question
- Engine no start issue
- B16a2 to b18b1
- What timing belt would i use for a d15b7 swap with a y8 head?
- Timing Belt tension problem
- code20 eld car wont start
- low voltage causing throwing 41 ??
- Where to Buy Shielded wiring
- ICM SCHEMATIC
- Timing belt tensioner bad?
- what is this sensor
- Tach Signal Explaination?
- Fitting Manual Windows - EG Civic
- Motor wont start Help PLs
- High Idle is driving me crazy
- first swap need help!
- Complete EVAP delete
- Piston to Deck height: What is recommended?
- B20 Question
- High Idle Problem
- What b series cams have an A on the end ?
- Finding and cleaning 1993 Honda Civic VX EGR valve
- CEL in cold weather somehow linked to brakes
- Honda Logo Fuse Box Diagram
- which would be a better measure of engine temp? oil or coolant temp?
- reviews or feed back on Innovate LED gauges?
- open differential
- cam degree kit...
- Solutions for loud exhaust
- Needed 87-91 Honda ZC timming belt cover
- Brake pedal low after changing brake fluid.
- 93 civic w/ b18a
- Oil Bearing Clearance Calculator...need to know if its correct
- Greddy Header???
- timing right ? PIC INSIDE!!
- where to find air temp sensor grommet??
- replaced tranny but my car wont start??
- 89 Crx HF, B16A, EG OBD-1 Harness, what ECU?
- 1990 integra no start s300 all new Injectors have constant power need help!!
- b16 emissions problem
- K24A4 Build Help
- How do I remove the clutch pedal brackets or pedal, can sum1 guide me thur it?
- what i need to get bar
- p72 socketed: Burnt iat resistor? Idles rough/dies
- b20 decided to die any help???
- Need help ASAP. Car wont start cause this happen.....
- whats up with evans tuning forums/dyno section?
- Test pipe question
- axle issue on Ek9
- ac question
- trans seal part #
- Main bearing cap replacement
- Does this gsr head look ported?
- AC Fuse keeps blowing?
- brakes stick.. New everything
- WHERE CAN I GET A RHD EF STEERING RACK?!?!?!?!
- possible or not f22 in civic coupe/hatch
- Sealant on cam end caps?
- d15b7 head on d16z6 bottom end
- Resource: What OEM steering wheel fits my car?
- piece broke off end of camshaft... usable or fixable?
- Registering/Inspecting a car in CA that is from Canada.
- anyone use powerhouse engine rebuild kits?
- accord > prelude steering wheel swap
- cuts out when reved? & Slow Acceleration
- Torque specs
- block help plzzzz
- 01 gsr Power Steering Pump work b16a
- GSR VICTOR x Install help!
- B20B VALVE TRAIN IN A B18A1
- D16Y8 idles but dies when i press gas-CIRCA 2010 issue.
- B20 Vtec Question please help.
- vtec help
- losing power on 7000-9000rpm, question.
- Ls motor in a 97 EX coupe. what stock B-series header would bolt up to the EX cat?
- Question about code 15...
- Diagnosing Vtec problem (VTS Error Code 21)
- Bad Speed Sensor..need help!
- Need help finding this fuse please!!!
- Cracked block
- aftermarket cams identification
- Camber kits, measurments, diy questions.
- Can I convert my obd1 dizzy+alt. to obd2?
- Em1 Sunroof? Odometer?
- BLOX LCAs pieces of CRAPs
- 3 Holes In Block 4 Motor Mount Is Stripped!!!
- Warped valves in F22A4
- My Honda car key battery is dead
- DSS 5.9 Resale price???
- h22 obd2 o2???
- Is line hone and line bore the same?
- What injectors are these?
- engine bolt sizes, bolt torque, diagrams(2001 gsr listed)
- Doing A Swap MISC INFO needed - Thanx!!!
- JDM Seats?
- Seat belt question.
- WIRE TUCKS IN NYC AREA
- Full Slicks on Street?
- Honda's and clutches!?!?
- Do I need an ICM to use a MSD digital 6?
- input needed on compression test results!
- prelude vs type r hubs/bearings
- Hardened valve seats?
- Post Your Drag Cooling setup
- Battery acid burned hole in carpet :(
- Speedo Malfunctioning after Wire Tuck ?
- WitchHunter Performance review?
- certain solder to use in engine bay?
- LS vtec piston/valve clearance questions
- Sun Systems Hot Inazma Voltage Stabilizer GT(WASTE OF MONEY)
- Wiring problems
- D series owners, what valve spring compressors work for you?
- steering wheel install - steering column doesnt have those two nipples
- New Motor.. TONS of new problems
- budget wideband solutions?
- jdm b16a pistons on b16 rods in gsr?
- H23a Compression Issues..
- Why is my freakin' car overheating?
- Honda electrical connectors
- Engine/Chassis MYTHS and FACTS - please contribute
- ignition cut out?
- Aem cam gears
- 99 civic ex with 96 gsr swap ecu problems?
- gear question please help
- Turns over but dies immediately
- CRVTEC boggin out after 2k
- d16y7 broken/ someone tried to weld back together exhaust manifold
- guage clusters
- Anyone have any tips on what to use to get really clear windows?
- Having trouble disengaging the clutch.
- idle/ maybe Vacuum hose
- TPS and MAP color of wires
- 8 valve distributor on 16 valve?
- 90 EF charging issue
- b18a1 swap into a 95 civic in need of some help please.
- Possible to warp block by manually removing crank pulley bolt without holder tool?
- Need help with ENGINE MOUNTS and REPLACING CLUTCH
- 1995 honda civic dx
- any issuses with ebay style fuel pressure regulator?
- honda parts catalog on paper or download?
- Need help with running lights
