View Full Version : Tech / Misc
- not getting spark!! help asap
- racing seats using original seat belt?
- Throttle Body ?
- CEL #41 DTC #P0135 primary O2 sensor heater
- Brake problem...need expert inputs and hypothesis, i'm out of ideas
- Where are the EK SOHC rear mounts?
- How do I remove crank pulley bolt?
- Need a Venom VCN-1000 16-pin connector scheme
- long block??
- new distributor, now runs rough and LEAN
- Help me fix my stalling Accord please!!!
- LS-VTEC help with fittings/ oil line
- Disc Brakes Vs Drum Brakes
- overheating problem
- Car runs like crap after theft/mini rebuild help??
- Acura Integra & 92-95 Civic injectors interchangeable?
- need fuel pump info
- Shifter Bushing Question
- Please god someone help me. Main bearing issue
- rebuilt civic! Can i remove the main relay when i put switches in?
- Good video for valve adjustment diy.
- ef and eg interchanges
- Put stock exhaust on and got a CEL?
- EK9 CTR Cams in JDM B16A?
- Weres the vin? B18A1 1990
- crank problem???
- hyper voltage system
- Need help installing TPS
- How do you guys arrange you piston ring endgaps
- full throttle lags
- High altitude gsr timing question
- Vtec valve cover on LS head?
- ls motor gsr driven?
- how does compression effect you car getting bar'd
- Greddy Carb Sticker
- DSM Tranny Cooler as Oil Cooler
- LS in. Manifold on a B16 head?
- Lighter pistons?
- obdII A to B harness question
- Need wiring help ASAP, PLEASE!!!
- mini-me obd0-obd1 jumper code 41, last code!
- very black oil... help?
- How do you check if a tranny is good without a test drive?
- When a Honda TECH says your Fu(ked.......
- Mounting and routing 5pt belts, best way to do it?
- JDM CTR Camshaft?
- Putting car on time
- need some info
- Idle Problem !!!! PLEASE HELP!!!
- Timing belt question
- problems with my civic
- VTM-4 operation question
- LS/Vtec Help!!!! Please Help me out
- b16 crank in b20 block...
- question about ecu for my engine d15b e-vtec 98
- Hydro Clutch in Cable Trans will it work
- Can anyone tell me what cams these are?
- D16y8 engine
- How hard is it press out wrist pins on oem honda pistons?
- delete
- I need a 75 shot Venom nozzle,help!
- What Axels Integra (b18bMotor/b16 Transmission )
- b series ring gear torque
- No spark
- MSD fuel pump opinion
- Cylinder head question; 89 accord
- with this work for me ???
- oil leak.....
- Aftermarket cast head?
- First gear engagement issue..
- vtec is not engaging right ???
- car feels heavy sometimes
- ect sensor wiring
- Accord 04 v6... Management ??
- Need some help!
- severe shutter!!!!!!
- Found this:DIY: Modify K-Series Injectors to flow 490cc and 520cc
- B16A vs B18C Cams and Springs
- will any series pan work on b16 motor?
- cutting oem springs, how many loops?
- Please help - High & unsteady idle
- OBD-1 B18c1 motor into OBD-2 Integra GSR...
- map issue
- alternator plug help
- NON-Honda Alert...clutch wear issue on E36 m3
- ride height
- Need help with tuning OBD2B 2001 GSR w/Aftermarket intake manifold
- HELP!!!! ls/vtec swap
- Injectors. Can you tell me what they are?
- 93 accord crank pulley on H22
- need help check engine light
- loom issue
- rods
- question about a gsr swap and tunned ecu
- fuel pump question
- #4 Injector will not fire/ no signal..
- what kind of hood locks are these ??
- Hole in oil pan
- Car pulls harder with less gas?
- JDM RHD eg/ej optional audio console
- delete
- Compression weak, head gasket H22?
- Injector clip wiring order..
- pulsating lights
- B series oil pumps!!?! help
- Intake Heatshield issue
- Cel help- b18c
- Clutch and Engine Break-in question
- vtec solenoid bad or sensor!?
- quick site question
- Quality of pistons
- Freshly built engine hard to turn over at first
- checking the main rely
- IAC problem?
- HELP! resistor box wiring problem.
- Need some help with real JDM shop in East Coast!
- balancing crank and/or rotation assembly?
- B16 Question Please Help
- Need help asap about cam caps
- putting on Sparco pedals on an ITR? beginner
- 99-00 to 96-98 harness
- Which Oil Pump to Use Im Confused..
- gsr cam install
- Cracked cylinder??
- b series starters? auto vs manual
- code for Ignition Output Signal.. HELPPP!!
- Starting circuitry problems
- Cleaning cams
- oil light on 1994 accord
- Effects of an engine being flooded with gasoline
- Help! Starter not working!
- D15 revs up and Down issue PLEASE HELP!!!!
- Vernier Cam gears timing?
- Stiff shifter for h22 swap
- oil inside my distributor??
- Throttle body question
- dampness problem?
- help with my h22a Alternator relocation kit
- LS/B20 VTEC masters, PLEASE READ.
- Exhaust Civic 95
- Identify these cams
- Alternator help!!!
- Block Noise plz help
- Car starts, then feels like its not getting petrol?
- how much horsepower can these blocks handle
- Please help! ! ! ! !
- help with d16z6 build. Main bearing question
- -Help!- 2000 gsr gas gauge not working !
- CTR Steering Wheel Horn Problem
- LSVTEC into 96 Integra- Which upper PS bracket?
- Removing fuel line from fuel filter?
- issue with supertech springs and titanium retainers. ned help ASAP
- Obd2-Obd1 conversion in ek IABs? ECU gurus PLEASE HELP!!
- gsr rebuild with type r pistons
- engine shut-off on 99 dx automatic w/gsr swap
- d15z1
- HG question
- H22 damage. Lots of detonation
- crx b16a obd0 fuel cell install-help
- 95 gsr with obd2 itr swap, won't run
- Temp. Tags
- What Cankshaft Pully???
- 04 Accord Rear Wheel Noise/Vibrations
- Oddysey batteris...enough to power sub/amp?
- mini me swap
- b16 main cap and rod bolt torque specs
- 1997 CRV maintence schedual?
- force 2 or z intake manifold
- GSR AUTO Cams
- 95 gsr problemz!!!!!!!
- Recaro vs. Bride Crash Test Simulation
- Oil cooler question
- How to convert cable trans to hydro?!?
- starting problem on my 2000 si
- Problems with custom exhuast
- Poor mans type r low low idle!!
- Oil Pump (TECH)
- CRX w/ D16Y8 swap
- DIY: Red Wrinkle Paint valve cover
- silly computer question please help D16Z6
- heater core by pass
- Valve spring/Retainer question
- grinding noise in rear...help
- Inline pro blocks????
- I have a question on rod bearing clearence.
- Valve Adjustment
- I think im a noob Help! b16a into 96 ek hatch
- swapped motor starts but now steady high revving idle
- E85
- Eagle Vs. Stock crank? broken an oil pump gear too...
- MAP Sensor
- D16W1 - will any D-series engine fit?
- Garage build? (tips n tricks)
- Starter Clicking Rapidly, Good Battery and Starter
- Another Front O2 Sensor Slow Response...
- Automotive relay to handle constant 50+ amp?
- FWD to 4WD Conversion kits available for Integras???
- Need Info on AN size fitting for brake and gas line
- stupid question
- 95 Prelude...A/C not working...
- Another engine harness question? ls vtec this time
- automatic vs. standard engine harness
- B16 Turbo Questions??????
- replacing guides
- has anyone done a coolant drain bolt mod?
- Over Heating Problems...Please Look
- AEM Tru Time Cam Gears, ls/vtec
- what length header ?
- Final drive swap question
- fuel issues and maint req. light?
- clicking noise
- Anyone have trouble with AEM CDI?
- What could be the problem?
- What fitting is this for FPR??
- Wheel stud helpp!
- L.A. sleeves??
- getting the axle splines back into the tranny?
- Magnetic Pick up Wire?
- Braking vibration - NOT rotors - difficult problem!
- radiator size! half size?where to get one?
- Need work done
- Temp gauge problem
- Takata Eyebolt Size
- 92/93 YS1 and 94-01 Y80/S80 - 5th Gears Exchangable?
- P72 Rod markings??
- its not honda but im honda guy lookin for advice
- what kind of internals would you want
- if you could buy built blocks for a fair price!
- Ignition timing and timing belt
- H22a timing belt issue please check out
- OBD0->OBD1 issue
- eg dohc distributor
- surging
- B20 vtec knock sensor issues.
- Walbro 255 issue
- Help needed with gsr cluster
- B20B timing question
- Water line CAPS
- NRG Steering Wheel Quick Tilt..?!
- Help Please, No Start!
- Anyone using the DYNA BATT dry cell bateries?
- Where to have Bushings pressed into Control Arms?
- b18b swapin integra gsr shell 97???? confused help please
- Plans for an all motor build
- Plans for an All Motor
- Fuel Gauge Ohm rating
- B16/B18 Engine Parts Weight
- I need help!!!!!!!!!!!!!!
- I have searched a no results! what cams do I have?
- LS or VTEC oil pump
