View Full Version : Tech / Misc
- Difference from VTEC and non VTEC oil pumps B-Series
- Anyone knows what does NA engine and LSD mean and stand for?
- JAy SMITH...HEEEEEEEEEEEEELP! rhd conversion
- Camshaft???
- Gasket question
- NEED HELP w/ spark problem asap!
- Radius ros and endlink question
- Want to use P06 w/ b18b1..need information on it.
- problem with 3rd gear 98 JDM itr tranny
- lowering my89 civic si hatch
- braking shaking?
- HELP!!! Crank and Camshaft alignment.....
- ECU Questions!!
- SOHC Vtec Experts HELP ME!!!
- IDLE problem? please help
- NEED HELP!!! ENGINE!!!
- noise from gas tank..kinda long story
- Nsx injectors
- d15b7 tranny mated with d16z6
- still prob with chipped ecu
- 92 ls diff into 99civic si?
- What is the best gas
- Question For Pro
- How to identify a Moroso oil pan?
- H+R or Progress springs...HELP ME OUT!
- zc SOHC vtec
- oil on plug threads
- Wiring Up JDM Fogs Without Harness...(Searched)
- Rear strut Bar Questions
- Oil Cooler Question?
- another b20z vtec question
- Noob question alert! b16a2 tranny w/gsr block question
- D16Y8 mods?
- Driving with a >COLD< engine after a swap>>???? :X
- Matchin up a Header with Cams
- b20z/vtec racing mounts back to stock mounts?
- 15x7 wheel on Civic
- Hookup an oil catch can to EVAP canister vaccum line?
- which tire to pair with nitto 450s?
- best tire to pair with nitto 450s?
- dumb ? but jus gotta ask
- itr tranny ?
- obd1 or 2
- Please double confirm me about acorn lugnuts on 99-00 Si Wheels.
- O2 sensor HELP
- throttle body
- no spark....
- B18A BLOCK shaved, B18B HEAD shaved... what's the CR?
- Automatic Tranny: Whats first to go with power??
- Camber
- difference in blockgaurds...
- Padawan power steering kit?
- Alternator differences
- Wilwood calipers and Brembo Sport slotted brake rotors
- Transmission Shimming????
- What is this?!
- a specific problem....tranny
- power steering ?
- Cold Air or....
- Car wont start. Starter problem?
- Weird whining sound coming from pulley area **Video w/ Audio** 56K danger ------>
- Dashpot Diagram??
- what kinda motor swap could i do with a 90-91 celica
- Crower 404's.........tuning questions
- pwo chipped ecu
- lower ball joints on 99 si - how often 2 replace
- Swap just done at NRG Tech:
- makin a decision.
- When do you need a resistor box?
- Need install diagram for VAFC!!
- problem with chipped ecu
- rpm help
- Tein pillowball anodization peeling
- fuel pump swap
- Rebuilding a front suspension on a 1991 Honda Civic DX 3dr hatchback
- chipping an ecu
- Typical price for Milling/decking head?
- Hondata and Eclipse 450cc injectors.
- Has anyone tried adding vtec to the b18b head?
- CEL STAYS LIT ONCE CAR IS TURNED TO ACC
- Rocker Arm Resurfacing
- In Desperate of Help
- Can someone confirm this part for me?
- Advantages??
- TEIN Flex on a 2nd GEN TEG
- hyprid trannies
- Help! Cylinders flood with fuel on start!
- Running w/o EGR - question.
- hf and dx cranks.. Whats the difference
- car wont idle when warm or hot
- Calling all Crvtec owners
- Damaged crank pulley questions.
- Rings w/JE Pistons? Already gapped or no?
- 1991 xsi integra sir motor in 91 dx hb, need help with CEL
- CEL codes can't be read after OBD1 swap?
- USDM Hondata prepped P28 CEL Problems
- Wiring Gurus--Need help bad 89 DC HB to SiR wiring questions.
- tow hook after traction bars
- ahh universal?
- loud back fire,popping from throttle body,and very low idle500rpm f
- wilwood brakes under 15" rims?
- What happens when your intake-mani leaks?
- WTF? Check out my motor. What is this plug for?
- Gas usage while coasting downhill?
- ls rods...shot pened?
- Install ?'s
- Piston slap + rough idle
- What exactly does the service connector do so you can time your engine?
- Will bad thermostat Knock Out VTEC activation?
- anyone know of a good shop in the La area
- dyno for b18b with b16 pistons
- Bore and Hone question
- b18b head with b16 valve springs
- Engine suddenly died, could this have caused it?
- whats the best cam gear..
- car running with out o2 sensor questions..
- d15b jdm rev limit, does anyone know this info?
- manual to electric fuel pump conversion
- Acura tranny gear sizes question...
- Boost Sensitive FPR Install
- picture needed for timing belt change.
- skunk2 p30 ECU??
- fixing knicked crank journals?
- Hondata w/p28 question...
- Crower Rods for B18b Torque Specs
- Cheapest way to ship bare block or good machine shop in the Southeast?
- b20 crankshaft question
- wiring diagram from ecu in 93 teg?
- which honda OE crank pulleys have no harmonic dampeners?
- Need help with ECU...
- b18 or 20 for turbo....?
- ls/vtec fuel/bog issues
- Spark plugs: running lean or just too old?
- What´s the difference between GSR and ITR;Civic intake manifolds????
- How can I tell if I have 345cc Prelude Injectors???
- snaped cam bolt off in head
- Used valve springs and retainers ok?
- skunk2 manifold question B16 help!
- Idle Problem
- skunk2 manifold and EX harness to B16 questions? need help !
- built LS head, need tuning info
- searched and searched, need weber dcoe app. list?
- oil squirters might be hitting crank
- dam CEL code 8 and 15
- hooked up oil pressure guage...my readings...need your opinions
- What do i need?
- 2000 usdm itr steeringwheel+eg?
- need help bad -
- hondata ??????
- Valve adjustment-GSR
- Question: What does the car term 2+2 mean?
- whats the spark plug gap on a 93 b18a?
- Can someone please tell me what clutch this is?
- 11:1 GSR block, B16 head, which oil pan?
- I need valvetrain help
- High idle w/loping
- Lug studs stripped, help taking out
- checked compression need help
- lower radiator leak... any experience with this?
- K24A4 modz? what are the best bang for the bucks? i can't find anything... help
- Need help 0bd0 - obd1
- JG Edelbrock Throttle Body ?
- Who is running block girdle on their LSvtec?
- what catalytic converter on jdm dc 4-1 ?
- replacing pistons/rings
- looking for a 93-94 supra lamorghini door kit!
- resurfacing cylinder wall tool?
- mount swap ?
- ****problem please help!!****
- 1990 integra aftermarket suspension ?
- fitting issues-AEM fpr with JG manifold
- what is highest compression you can safely run on 91 octane gas
- taking out the rivets on the TPS?
- Can't hear when cold ... but Hear when warm????
- upper spring perch installed wrong?
- Swapping from manual to automatic
- balance question regarding clutch
- Hard time removing Front Lower Control Arm??? Please Help!!!!
- help code 8
- D16Z6 or D16Y8 swap
- External oil cooler + OEM unit?
- coolant bubbling...is it normal?
- What ecu do I use to switch from my obd0(pr3) to obd1?
- Is doing a obd2 to obd1 conversion better or make no diffrence....
- Dimension of exhaust pipe
- Noise?
- question about di-electric grease
- Gude Throttle Body for GSR specs?
- Intake manifold gasket Q
- Eliminate O2 sensor altogether.
- Draft:ls/vtec tuffy try this one
- B18 Interchangeable Replacement parts?
- New headgasket, headbolts, if Ivtec it?
- Exhaust stud broke in half! damnit
- Help me identify my tranny [PICS]
- Which wheel weights --> Stick on or Clip on inner lip?
- obd2a to obd1 conversion harness help!
- Whine question, tranny question, issues.
- Need help with H22 PLLLLLLLEEAZE!
- Injector question?
- HP and 1/4 mile time guesses please
- B20 injector size?
- jdm gsr or itr cam?
- afc hack what kind of resistors to get?
- No VTEC On Re-Build - HELP!
- aemv2
- did i mess up my lsd?
- which set of tires would choose
- How to cut out valve cover for cam gears?
- piston pin location
- Rebuilt motor, getting knocking sound... CANNOT FIND ANYWHERE
- Help Plz, 98 EX civic
- obd2 distributor on a obd0 b16 is it possiable
- D17 tach wire?
- who makes a wiring harness adapter for f22 to h22 swap?
- close ratio for y2 gear box
- Use factory 145k main and rod bearings on rebuilt motor?
- no cover 4 me
- HELP!HELP!
- stupid canadians!
- H22
- Car not starting!!
- what Clutch to get
- What does the Purge Control Solenoid do?
- Idle problems
- wheel offsets question
- San Diego people wanna help me out?
- good throttle body cleaner? and fuel injector
- CWest Civic Bodykit Made from?
- Clunking Suspension (HELP)
- NOVA people, I need your help....
- KYB AGX on Eibach Pro-Kits
- Need help with tech on Prelude Test-Pipe & Related issues
- D16y8 ARP head stud problems.....
- Fast Idel Thermo Valve Fix
- anybody know what this is??
- 37820-pr3-003 Manual or auto Ecu ?
- Going from b16a1 to b20b help please
- obd2 injectors on obd1 car
- B18c1 with B16 head compression?
- Skunk2 coilovers
- how to tell if a shock is blown
- what would be some reasons for the oil light to come on?
- Pulling the head off my B16
- hybriding
- DC cam gear error (pic)
- Kaaz LSD
- I have a Idle problem
- Checking transmission bearings: what are some not-so-obvious wear indicators?
- Can someone school me in ECU's and Hondata?
