View Full Version : Tech / Misc
- hex plug on block behind flywheel
- How do Airbags work ?
- 91 Civic DX Dual Point to Multi Point Injection
- injectors from 96 EX better than 92 DX ? or same?
- What grade of oil to use in my new Swap?
- Modded B18A - Need a separate AFC??
- GSR tranny identification
- Tech2Tech, is it any good?
- Just curious about my b18a1?
- anyone know if this tech malual (softwere) is any good?
- OBD II - OBD I conversion
- What OBD version? 96 civic..
- why don't i have permission to post anything in the classifieds?
- Quick spark plug question?
- Could use some help, opinions, *coolant system*
- 1.6 vs 1.8 clutches.. are they the same or different?
- A´pexi Rev/ Speed Meter GP/ G-Tech worth the money?
- help-rear suspension problem
- the easiest way to get off the intake manifold gasket.
- leads on GSR radiator replacements
- can I weld........
- rear main removal
- Si interior "K" or "F"
- pros and cons of b16a and b18c
- what kind of exhaust would i use if i did a b18c swap into a 96 hb?
- b18c for 3800?
- Fuel Pressure
- engine removal/installation technique
- WTD:anyone who knows how to install a 5-lug conversion that's in the bay area!!!!
- Nos? Why the bottle of Haterade?
- HELP: IS my ecu F***ed? it cuts out at 3200 and runs the same with no chip
- remanu'd brake calipers...
- Recomended ECU program for non-vtec
- Auto -> Manual Swap
- I am getting a front lower tie bar and swaybar 92 Civic, but have some questions
- machine shop experts... block fixable?????
- 12:1+ Compression on 91 octane?
- Need help...with A/F gauge
- So many swap choices! ! ! ! !
- vtec switch??
- ls vtec back to ls timing belt.
- H22a
- CR question
- what vtec and fuel controller to use?
- LS/VTEC - which spark plugs wires to use, B18A or B16A?
- re-grind cams
- fuel setup for nitrous question
- I want head work done, but where is the best place to do it?
- transmission shift
- Will a cx timing belt fit a lx?
- Where to buy gasket for JDM engine parts?
- 94+ stuff on 92-93 GS-R
- anybody ever have this problem?
- The role of spring rates in drag racing AND Linear vs progressive springs
- B16A/B18C head bolt questions
- how much do people or shops charge for a 5-lug conversion?
- Feul setup
- what water pump & timing belt for mini-me swap?
- Does the B18A block bolt up to B18B head?
- How good are the OEM rod bolts?
- How much to re-drill D to B series Turbo manafold ?
- Hondata Help......
- Does anyone have a schematic of where the spray bars are located
- Mechanic says, "Harmonic Balance broke loose and fell to the floor."
- weird water temp gauge prob...
- Is touching a clutch with fingers bad?
- What type of injectors for turbo???
- Cometic LS/CRVTEC headgasket confusion.
- JDM GSR engine have an oil cooler...?
- I'm not getting any oil pressure to the vtec pressure switch and solenoid
- diagram please
- jotech
- Fuses are blowing left and right!!!
- B16 throttle body, on D16z6 IM???
- Spot on my driveway this morning.
- A/F air/fuel guage, i know its inaccurate...
- a few question about 5-lug conversion on a 99 ek hb!!! PLEASE HELP!!!!
- Port and polishing in Bay Area?
- 60,000 mile maintenance?
- Can this hurt my performance?
- Dart blocks
- Engine sputters and gets weak sometimes then the power returns
- crx engine questions???
- vtec not working
- Oily Grime on b18b? Problem?
- Cam gear settings?
- ls/vtec, stock bottom end anyone?
- need transmission help 90 accord with h22?
- MSD vs. Accel
- Head work for B18b...
- Ignition Problems Interfering w/ Audio
- Stock fuel PSI?
- fastbrake rotor replacement
- 5k miles used Koni Yellows or brand new AGX's for Integra?
- GREDDY 60mm A/F Gauge...
- VTEC Activation
- How do I check the quality of a ground?
- My Integra won't start
- Code 1 - O2 Sensor Help
- what is better to do?
- b18...b20
- injector question...
- Underhood rattle
- Inividual throttle bodies.....a few questions
- anyone know a good place to get motors down here in So. Cal. with a good rep?
- After market crank pulley?
- cel code 67 catalytic converter
- cv boots
- MSD 2-step rev limiter
- 01 Prelude SH - Intake Install
- tranny problems...
- B18C1 internals into a B17?? (2 questions)
- Civic/Integra Type R hybrid: suspension problems!
- What is this motor out of!!!
- DA integra gs-r weight!
- CEL code 20 (ELD) how do i fix
- Q's about cam timing
- Fuel pressure guage?
- 89 Civic DX to SI
- What happens when I don't replace my belts?
- Low miles ZC with headers for sale
- 2000 Accord
- Will A P28 D15B ECU Work On A D16Z6
- Getting to 200 whp in a B16?
- Need Help with Solenoid
- Wheel Spacers?
- TrannyB16...final drive
- how to remove eagle rod bolts
- help me out
- best complete coilovers for around $1000
- ecu problems?? 00 gsr???????
- Pillowball mounts
- What color is the Vtec wire on a '00 Integra?
- personalized licence plate
- When do the Tein SS coilover's come out for 90-93 integra's?
- Do canadian blocks differ from thier US counterparts?
- ECU self-diagnostic
- Upgrading to Si or Integra brakes.. what do I need?
- skunk2 cams b16a
- intake and exhaust question on hb with swapped motor.
- custome exhaust question?
- HELP, problems with lug nuts
- a/f ratio gauge problems, need wiring help asap
- Porting b16a head.....
- APEX Power FC....
- What Clutch is best?
- need some help ASAP...window came off of rail some how? how to fix?
- Messed up idle on h23, after putting on head and timing belt
- Car doesnt feel like it is pulling as hard?
- building a b18c1
- SI tranny slowing down my b20?
- What ECU/car had.....
- Mustang throttle body on B18A
- Blue Printing an engine
- Please help newbie here
- Next step...
- IAT sensor on D16Y8??
- To bore and hone b17a or Echange for b18c1
- Y1 tranny and clutch problem
- All in one pressure/temp/etc.. meter/gauge?
- B16 Head on JDM B20B
- How to tell the difference between intake and exhaust cams...?
- ported & polished and intake manifolds question
- Superflow Chassis Dyno
- Using CTR pistons in a non-vtec LS build explpanations...!!
- Ok, I am putting 2 mufflers on my turbo tegra, one on each side...words of wisdom?
- n/a maintenance?
- Trans. Hydro to cable conv.
- More low end torque for F22 ?
- Need More Low RPM Power From My B18C Swap!! Help???
- Strange Noise
- LS/VTEC Head Gasket
- Will a d16z6 head fit on a d16y7 block?
- Ractive FPR
- help me post pic in ym signature...
- new gasket...adjustable cam gears
- Dissapearing coolant....
- Best ecu to use
- stupid question on tail lights?!?!
- What the hell is wrong with me car?
- JDM final drive in LS tranny
- Installing Mugen thermoswitch....
- B18C1 Head Gasket Question
- B20vtec having trouble catching falling idle...
- my car is burning oil! wut could be the problem??!! hook it up!
- kSkunk2 Cams breaking, anyone hear of this???
- O2 simulator not working
- need pic of knock sensor
- Building a B20Z for nitrous
- any body running a lsvtec setup like this?
- No oil pressure at vtec pressure switch
- HEAD Combustion chamber Mirror polish or 180grit finish which is better for performance
- back pressure
- Quick Clutch question
- Resonator Prices and Availability?!!
- ITR Cams in a B16
- Idel Problems
- question about Koni yellows.
- Distributor question
- Lots and lots of questions on my f*cked up Integra and some other things.
- Rebuilding b16a1......
- Question on DSM reliablility??
- alternator siezed
- Cam Question? need input
- immobilizer(sp?) question..
- WOOHOOO soooo happy..
- is it necessary to resleeve the block if running 82mm pistons
- JDM ITR 5-lug conversion on a civic Si...
- All your base...
- Think Clutch is slipping? Need diagnosis, Please help.
- NEED a pic of Engine Coolant Sensor
- which tps sensors are interchangeable?
- ACT Clutch Question
- Stroker Kits
- cylinder position sensor.. if bad, what symptoms would it give?
- b18b header
- Ooops, accidentally snapped fuel rail bolt, now what?
- Can an Apexi VAFC work on a non-vtec engine?
- Cant get car to start. Need help please.
- stock GSR motor, 18 BTC timing, 91 octane, is this safe?
- DC Sports JDM 4-1 Header VS DC Sports 4-1 Header
- h22 in EK
- B20 crvtech
- Intake INstallation
- I need Tech Info about Vtec Camshafts/engine
- upgrading 6th gen transmission....
- Piston to Valve Clearance Issues....
- 6th gen coupe getting h22 need suspension advice
- No Spark... Give me some advice...
- shocks and camber advice
- squeaking brakes
- car shooting out flames from the exhaust?? why??
- Anywhere online or otherwise to buy an a/c line?
- interior light's
- Camber problem
- question about eng swap and smog regulations.
- Time to rebuild suspension....
- emmissions dynometer?
- Coolant overflows when parked... car doesn't run hot.
- H22 how to tell JDM?
- When is time for engine rebuild? (based on leakdown test?)
- is this the correct way for a catch tank
- A/C lines have been off for about 2 weeks, replacing now, do i need a new drier?
- shaking at take off
- shifting ...
- timing question (rather involved)
- Specific type of grease to use for ball joints?
- ls tranny or si tranny
- my fast (2k) idle problems have resurfaced, any ideas
- Jun 3 valve clearance>?
