- Nitrous Question!
- putting ITR sway bars onto EG si.
- Exhaust Question
- My car is overheating and I can't figure out why?!
- shifter bushing install--help
- adjusting fuel pressure?
- Accord Injectors
- valve stem seals
- recommended axle for NA GSR? (from driveshaftshop.com)
- LS TPS on GSR throttle body
- Piston tops
- Hot/Cold gauge not working... What can I do?
- Motor indentification help...
- Is something wrong with the search Feature???
- zex cam install q?
- Where is the #1 piston
- all hoses/bolts/manifolds disconnected...cylinder head stuck!
- Umm Anyone know whats going on here??
- Replacing spark plug SEALS.
- putting ITR calipers onto an EG si...
- Oil Squirters on b20/vtec? Possible?
- o2 Sensor help
- HELP! O2 sensor? "No return topics in search"
- Knocking on startup
- 4-1 vs 4-2-1 headers
- built b16
- RSX type s oil filter on a 94-95 gsr
- Help removing crank
- Oil on injectors?
- ***MY CAR IS DEAD***
- are injectors interchangeable
- 94 Integra LS/GSR oil pumps, the same?
- Please help me with my GSR
- Si Timing Belt Question...
- What cause the timing belt to loose teeths?
- how can i tell if i have a dead cylinder
- dx to zc wiring help
- gsr vs ls shift linkage
- what would i need?
- GSR fuel pump in LS
- Flushing brake fluid?
- cylinder head replacement tech questions
- o2 simulator ???
- Adjust TPS sensor?
- Steering wheel return-spring tension
- need fast help now!!!!!!!
- help -> Hood latch cable stuck open!
- Exhuast Sound
- Vredestein Sportrac Tires?
- B18C/B16A Hybrids
- stock GSR fuel pressure?
- Tranny cooler/ Oil cooler - what do they do?
- B17a Block With Pr3 Pistons
- Z-Rated Tires vs Others
- Why No Torque?
- ECU makes car die....whats goin on?
- mini me question
- b16 cable?
- Help me out here please! (Head Removal)
- problems with slotted rotors
- help bent valve maybe ???????? h23
- ls trans
- Location of Speed Sensor for 92 Civic Si
- Fuel rails ...
- What shld i do first?
- Sound from aircon compressor ...
- leaking coolant... can't find source
- Dying motor ...
- Re-using B16A Block Gurdle ...
- Who makes 2.5 exhaust systems for 92 hb?
- tranny gurus please help ASAP
- 38mm offset on kosei k1s. any problems?
- Integra Trottle body sizes? Civics?
- Engine Problem in a B18C1
- Just one quick question?
- Identifying year of ITR ecu
- 96-00 civic o2 wiring color codes?
- GSR vs CX fuel Pressure
- Valve adjustment for..........
- JDM S1 Tranny
- Tach - Ignition Question
- Opinion: Should I take out the back seats in my civic for daily driving?
- B16A SIR 1 long block in 90 civic dx?
- Rod knock or piston slap????
- changing synchro's
- *****VSS Question*****
- Oxygen Sensor Help Please
- Wierd rumor about Reverse lights and VTEC not working... (more)
- ****Very easy GSR question. quick one answer. Take a look gsr owners. please.
- will it harm anything if i take off the header heating shield?
- is it a basic bolt on if i...............
- Tech questions ...... any clues ?
- Transmission Leak.......please help
- 99/00 Civic SI instrument cluster in 96-98 Civics
- header tech 4-2-1 or 4-1
- electrical vs mechanical guages
- I need a wiring diagram for a LS B18A ecu.. Help Please
- cold air induction on 90 civic dx
- ?? Size of nut on end of axle??
- Plz help: idle problem?
- cracked open my teg motor today....
- Help Troubleshoot MIL code
- Knock sensor capabilities in a P28 or Hondata stage 2...?
- mismatched ground control springs...HELP!
- cam gears
- Mounting Trans on Motor
- 8400+ RPM in ITR
- Correction factor on Dyno plots..??
- noise from my new springs
- p28 Chipping
- Holley pump probs
- I'm new to cars and I want to become a racer
- ractive headers?
- how to hook up EGR on h22 in EJ????
- Do you put liquid gasket (or something of that nature) on an exhaust manifold gasket?
- Got the front Ground Controls in! Pics!!
- doing a tune up have a ZC need some help!
- what kinda 1/4 times could i get?
- ANYONE WITH A TURBO GSR IN NORTHERN JERSEY?
- CAMARO V6 TIMES
- need help
- All can reply!!
- Dyno question : DynaPack Dynos
- crush bend vs. mandrel bend on N/A application
- Tanabe RM.....SRM
- NGK PLUGS
- Front sway bar sizes???For sols? Civics? Tegs?
- 86 crx si swap ?.
- Are AEM fuel rails worth doing??
- CAn someone tell me Bent Valves or No?
- which cam seals for b16?
- Idler pully
- do i need a bigger fuel return line when i swap in my b16?
- Tranny idea...very hypothetical
- Comp Test
- 240 whp?? whoa...
- are the gears between hydro and cable tranny interchangable?
- spark plugs
- are Findanza aluminum flywheel any good?
- What to do with old oil filters?
- Ground Control install problem
- Proportioning valves ABS vs. non-ABS
- Civic Type R camshaft for 1st gen B16A
- Does this exist?
- removing pressure plate/clutch/flywheel
- Code 12??????Help
- Clutch Master Cylinder Go Bad?????
- vtec problems... I'm out of ideas!
- needs to know if other peeps have problems wid CLUTCH MASTER
- please help me with my swap
- questions about adjustable shocks
- Ran dry of oil - exhaust cam won't turn
- Pt.2 Problems installing Ground Controls! Pics inside!!
- Looking for wiring diagram for S-AFC on a B18A
- Wiring diagram for Spoon VC 3E?
- Stiff spring rates without the slammed ride?
- Which flywheel?
- broken timing belt?
- Lost Motion Assembly
- VAFC Installation - Tuning
- gear ratios - d16z6 vs d16y8
- koni yellows
- Which Header to use on LS/VTEC...
- a/c question...
- rebuilding B18C1 motor--what do I need to replace?
- Code 54, is that bad???
- Do you need an alignement after removing axles for a swap?
- :::HONDA-TECH BBQ IN VA:::
- fuel psi setting??
- Transmission heads....
- DIY Wideband O2 & Lambda meter
- Tuning Honda Civic (97-98 model)
- Race fuel: Experiences?
- obd1 scan tool
- what size hub hole?
- Boring out a motor... lowers compression?
- different size tires
- 2.5" exhaust with these mods?
- B18 block questions
- rear disk question???
- Compression Ratio's
- Tein SS
- Please Help. Trying to Troubleshoot suspension.
- whats the point of turning brake rotors?
- Monroe shocks
- to all weekend warriors and DIY'ers
- how much do 16" mugen mf10's weigh??
- OIL SCHOOL fan problem !!!!
- d16z6 in a 90 crx dx
- ****HELP****
- anyone know where i can find the pcv valve in my 96 ex civic?
- Bottom end rebuild...for those who have rebuilt one..
- pcv valve? what function does it serve ?
- Compression and noise/sound
- 92 Prelude Si Header Questions
- Anyone using a phantom grip LSD?
- ECU pinouts
- MSD Boost Retard Wiring Question???
- Installing valve springs with head on car? (dohc vtec)
- Nos on a ZC worth it!
- obd1 & obd2 injectors; is there a difference?????????
- Walbro In-Tank fuel pumps... loud & annoying?
- wrong brake fluids
- Just going to buy b16 head....what else...
- Max Lowering Distance for KYB - AGX'S?
- cold air intake lenght limits?
- Where to put Water Temp gauge sensor?
- check engine code 20, electrical overload?
- Anyone punch out your cat??
- B20 Question **HELP**
- Excellent resources for any automotive enthusiast
- Brake fluid info...
- Help me understand
- EK possibilities???
- ITR won't start...any ideas
- How do I know if I have a vacuum leak?
- shift lite w/ no tach...possible???
- How much does it cost to replace transmission fork?
- Need help to put tire???
- Any ideas on spring rates - VIS sleeves?
- b18c5 -> b20c5
- o2 placement on 88-91 b16 engine
- Ram air intake causing early fule cut off
- CRV Head on A LS Block
- ITR LCAs and Neuspped bar
- Just a question...
- Adjusting throttle stop?
- what would happen?
- I pick up my car today. Tranny is finally done.
- LS/VTEC or B20/VTEC
- Tein coilover question about adjustability...
- Auxiliary Gauge Reccomendations?
- Shifter Bushing install!
- Code 8
- TPS reads .38-.39 volts at closed position.. is this right for a H22A?
- boring out a d16y8 1.6L into a 1.8L
- Problems with LS fuel pump with an ITR motor?
- AEM Engine Management System
- Alternator help
- Stainless STeel and heat?
- Please help
- o2 sensor and ecu problems
- camber adjustment products
- Secret mods that can be done b4 a race so the car can perform better ?
- Car running rich?
- ACT Clutch
- crank shaft pulley
- TB question?
- Help with Koni Yellows..
