- lose power 94gsr
- aluminized???
- Skunk 2 primary/secondary lobe specs
- what is it with N/A folks?
- ls/vtec swap???? need info
- JDM Conversion....Help?
- I'm a newbie with a question about my exhaust system..?
- bare itr block question
- need help quickly!!!!
- Gsr air idle control valve connecting to p28
- Jiffy Lube's Honda price
- DPFI to MPFI...Wire for Dizzy!?!?!
- 88-91 crx/civic distributor question
- Wierd question, would rota slips fit mini cooper?
- ID: B18B1: "Longblock"?
- chipping a p13 auto ecu?
- b16 vavle springs vs b18c5 springs
- easiest way to go from 11:5:1 to 12:1???????
- carsound cat?
- Can you identify these struts???
- need help asap!!!!
- torque specs
- Need help locating a few things on my b16a2
- Real Life effect of bigger rims? How many .1's will I lose?
- GSR and LS crank difference
- Has anyone tried using JimFab motormounts?
- Does the stock B16a air box restirict that much?
- Check Engine Light "ADAPTER"! How to. . .
- power steering problems
- will running open header put more wear on internals??
- Will a Ex Hp Racing header fit in my 1998 Lx civic?
- Bosch <or> NTK Oxygen Sensor??
- Which exhausts have 2.5in piping?
- Wheel bent, where can I get it fixed??
- Are CTR & ITR piston rings the same
- AEM Intake and Water Ingestion?
- HELP..95 gsr,skunk 2 stage 2 cams wont start when its cold outside dumps mad fuel
- What is the best brake set-up and why?
- work on my SI
- Does a tranny that lost fluid = dead tranny? (PICS)
- Buying the right clutch for the situation
- Putting strut bar on after P72 Skunk2 Manifold
- who do i CHANGE OIL?
- sequential shifters
- sleeves ?????
- Odd idle problems.
- PLEASE help me!!
- Vtec oil pressure switch help
- NEED HELP asapwant pics of Je pistons vs Endyn
- need help
- clutch question
- what to do next?
- hondata ?
- what size exhaust for b18c5
- automatic tranny install...question
- Difference in b16a sir2 and b18c1 worth the money?
- putting in pistons on a budget
- Preferred brake fluid?
- Hondata now has AUTOTUNING
- Flywheel for an H22a???
- coil over help
- b16a for 90 crx
- HELP... what does this mean(blown motor?)
- Funny Bump???
- Gearing VS MPH w/ B-series transmissions
- RC Prelude injectors in my GSR...what do i need for em to work?
- Cam gear TDC problem
- tranny rebuild ?
- different exhasts...
- quick qiestion on exhuasts...
- brought it to the state reff and failed the emission test
- SI or GSR wheels??
- MSD on obd2??
- What forged pistons have the least piston to cyl. wall clearance? or they all the same?
- B series valve train question
- bobbing idle??
- Stock GSR LSD durability?
- Size pitch of flared fitting going into clutch master cylinder?
- colder plugs
- AEM Intake QUESTION!!! Filter!!!
- AEM V2 power output?
- do high performance valve come with the cotter
- 83mm bore with stock headgasket
- Looking for Type-R flowbench results
- stainless steel question. cutting welding.
- how often are you supposed to change drum brakes...?
- Reading Material.
- Teg LS transmission differences?
- What is this?
- 99 ek airbag srs lights up????help
- Type R Valvetrain
- anyone think these work? J's fender brace...
- Please Helppp????????
- CX Tranny VS EX tranny
- running rich at idle helpppppppppppppp!!!!!!
- how to spend $1500 in tax money ?
- cost of bore on a machine shop and piston rods install?
- differences between jdm 96 and 98 itr tranny??
- What's wrong here??
- obd2 will skunk2 stage 2 cams set a check engine light
- B18C CEL code.. code 1 or 10?
- Camshaft question...
- Coolant Question
- Updated problem description
- Quick ? for all you OBD2 to OBD1 guys
- Anyone get the s-afc2 yet?
- Car won't fire / start...
- RE: Vin
- School Tech Project
- b16a cable tranny question?
- Topline piston and rings set???? Import performance parts???
- Headgasket replacement
- C/R of b16a head on b18c block?
- skunk2 or jg cam gears?
- Need help fast, car wont start
- Are all b-series oil pans the same?
- which throttle cable
- How much HP can LS rods withstand
- Check out this head and give me your opinions.
- Grinding VTEC
- Help me please!!!???
- Suspension Techniques Rear Sway Bar
- HELP!!! Timing belt tensioner bolt stripped....
- time to extrude hone intake mani ?
- Type R B18C help
- New Ground Kits Show Added HP
- First B20 run
- top speed with 4.785 FD???
- What comes in a tranny gasket kit?
- what oil to use
- link to how rt4wd works...check it out
- rotating the crankshaft
- BIG problems with little Apex'i V-AFC!!!!
- D16a6 rebuildin !! any links ??
- 86-87 pistons in a mini-me?
- please help me
- Rough Idle Whats going on??
- Where Does My Coolant Go? / Lsvtec Problems
- Calculating compression on this setup?
- Best swap for my money..
- valve to guide clearance?
- Anyone with LSVTEC videos?
- Car won't start...
- LS ECU P74 Pinout
- Adjustable Upper Control Arms - Need your opinions and input
- S1 trany syncros- what year teg syncros will work?
- Skunk2 Stage2 cams with 10.5:1 compression
- Help!!! Car wont start
- Guage questions. Autometer
- Header question
- throttle body gasket
- Difference between 5 lug ITR and 4 lug ITR
- need help with wiring with front turn signals on prelude ww bumper
- I need help converting my DX to Mpfi for my B18a1 engine
- can i use 88-91 prelude B20 block for b20/vtec?
- can anyone help me? I FAILED my Emmisions test
- Failed CA smog w/ Z6 head on CRX
- anyone know how much a b20 block weighs about?
- question about fpr setting for gsr...
- 440cc injectors too big for fully built NA/Hondata GSR? Sgt?
- J&S safegard install with JRSC question.
- Need help tire inflation? I have Toyo T1-S.
- Dyno #'s- Tuner guy's NEED HELP!
- erick's racing TB help
- apexi s-afc removal
- Axle Back pipe no muffler... is this sold anywhere new for 95 Integra?
- g-tec pro meter
- maximum injector size using stock ECU
- Anyone had head work done by these guys ?????
- who sells d16Y8?
- Will a LS crank fit a B16 block?
- lugnuts - acorn or conical (tapered)
- dipstick interchangeable?
- B16 Potential
- z6 tb on y7 mani??!!
- Tranny noise after clutch install, VSS?
- breaking in a new engine with turbo...?
- gas question...89 octane in ls/vtec bad????
- H22a------->suspension
- B16A1 in EG5.. !!!!!!
- Rusted Flywheel!!!
- my price on B16A
- question about eirck's racing throttle body...
- header question
- VAFC works with all??
- B series thermostat housing w/ integrated water-temerature sensor
- what flywheels are good?
- Bay Area People: Shops for transmission and engine work
- my new project
- Are 2k ITR axles the same as 94 gsr axles?
- ??? about itr cams
- integra 91 trailing arm on civic 95
- does anyone know flywheel surface height on an integra?
- oil light on start up, is this normal?
- How to disable Apexi vafc vtec x-over?
- A/F Meter Wiring Questions
- removing rev speed meter and vtec controller
- removing itr valvetrain WITHOUT removing head
- who knows about RS MACHINE, heard there better then golden eagle>>??
- installing a b18a
- Which brand of spring provides the biggest drop for an RSX?
- Fuel Filter leaking from Banjo Bolt (top)
- vafc?
- Help Needed Badly
- Name another engine with a 56mm main journal
- anyone have this setup? gettin it dynoed and i wanna have a ballpark of what numbers to expect
- I needed to use a P72 timing belt on my stock LS?
- Spoon PW0 ECU Question
- Increasing the redline and rev ability on a b20?
- got a free exedy street/strip clutch disc...what if i..........
- balancing tires??
- need pics of 90-91 ls engine bay
- gauges
- Comptech Header vs B16a Stock Header
- OBD1 ZC EACV broken
- Knock Gauge
- Best way to adjust perch on Koni Yellows?
- Question about Sparco's Grip Pedals
- CTR Cam Tuning
- 1999 civic si tune up
- Pressure in exhaust system??
- ITR five lug conversion
- Single or Dual diaphragm pressure plate...
- Custom Test Pipe?
- Rod to Stroke ratio on non Honda engines
- good first mods for ls motor?
- I need your opinions!! What mod should I get next?
- nitrous express on d16y7
- Priming rebuilt motors
- *off topic*
- Mechanical vs. Electronic gauges...water temp.
- Torque Vs HP / A Big B18B Vs VTEC
- timing check
- Type R Oil Cooler vs Aftermarket oil cooler ie b&m
- b20 + GSR tranny = ? how does this work...??
- spoon sports vtec controller?
- jdm and the usdm h22a vtech distributer...
- D-series distibutors.
- 94+ ls or 96+ civic ex?
- Brake mix and match?
- If you could build the perfect header?
- B16A, which tranny?
- vafc or e-manage?
- DPFI-OBD2 Injectors??? JDMspecEG6 Help!
- a question about my 5th gen. civic
- what would happen if you used 1 layer the gasket?
- 99Si in limp mode and CEL will not give up a code. Please help!
