View Full Version : Tech / Misc
- Measuring exhaust pipe
- My How do I fix my sloppy Linkage
- Suspension question
- B20 Build UP
- converting from cable to hydraulic
- Engine Torque Dampering ??
- dyno numbers of toda b's i was impressed
- Exhausts
- Rev Limit At Vtec Help
- DSM 450cc injectors for NA
- stock USDM ITR header vs. Save my money
- How high can I run CR on 92 octane gas with 100shot?
- crane valve train
- need some serious help asap"
- Crank Pulley
- ZFR5F-11 spark plugs??
- vtec changeover???
- 3rd gen lude with S-AFC?
- anybody know exact weight on b16a???
- Oil pan info
- Synchro
- If you had $20,000, and wanted to build a Honda, what would you do?
- VTEC will not engauge on B16
- OBDII harness or OBDI?
- tech people
- I need your advice QUICK!! What radiator should I get?
- Jegs Fuel pressure gauge
- Mufflers in CA need CARB #?
- reliability????
- fuel pressure guage install
- Diff noises?
- clutch problem, help please!
- LS/Vtec Head bolts
- Stock Unchipped P28 ECU on B18C1 w/ Skunk2 Intake Mani
- 2001 civic engine light? how to check the code?
- What is the difference between the jdm Ctr or ITR 4-1 header compared to dc 4-1?
- Best SOHC cam?
- 4 part question about turbo/injectors
- Need picture of Action Kevlar disk.
- Code 36? can anyone help?
- cam question
- purpose of es motor mount inserts?
- right on time
- Exhaustsoundclips.com ... where are the Honda clips???
- Bypass Knock sensor
- What heads are these???
- 02 sensor wiring help....
- HCP mounts???
- spring length...4" vs 6" vs 8"
- Gasket kit from Acura?
- [Q] HOWTO:Bypassing key-code check in ODB-II ECU
- looking for better charts.
- Hondata Question
- v-tec wire?
- Quick Header question
- h22a question
- gauge cluster swap
- n2o timing?
- camber problems
- HELP: car won't start!
- Will dc2 lowering springs fit an ek?
- Do you think the Japanese know something we don't
- Brakes - Why would front right wear out before others?
- O2 sensor Question
- Are there any ACTUAL honda-technitions here?
- oil pressure question
- gst/tsi motor into dodge avenger.
- Check This Engine List/Stat Table.
- important! 96-00 civic susp. parts in a 96 gsr? will it work?
- Shot Peen
- Accord Distributer problem..... How do you get the dam thing off
- Need Help Problem with swap
- DC2 Front Clip
- Something's wrong with my teg....alternator maybe?
- OBD1 GSR motor
- clutch master cylinder
- Question to those with ground control kits
- High flow cats??????
- Squeak in rear...only dropped an inch.
- Rear shock mount bolt broke off...what to do?
- Need Help With Engine Stats.
- Good regrind cam for LS head?
- Balljoint Welded to my ITR Knuckle?? Why??
- A few questions about valve springs
- code 23: knock sensor
- OMG,Only one quart came out after oil change!
- JDM Motors and CA Smog???
- WA people look here>>>
- anyone know what a gutted 92-95 coupe civic weighs?
- 2g CRX front suspension overhaul pics (Dial-up *BEWARE*)
- k. The Cant start my car??? need help
- What chip for high comp LSVTEC (did search)?
- Electronic LSD
- A6 Block & Z6 Head in a 92 CX?
- Showa vs. Nippon Denso vs. Generic Radiator
- ODB 0 to I conversion
- Is JIC coilovers good or are the generic?
- engine guru's please help! My Vtech will not engauge
- Looking to find out what the black box on Y8 intake manifold is.....
- autometer water temp gauge
- Milling head, How much????
- Faster steering ratio
- need help with projector headlights!!!!!
- Limp Mode??
- Anyone know the weight of Volk Gram Light 57Pro wheels?
- Breaking in my built B16????
- itr 4 lug....civic break lines???
- all motor B16
- Max 00 B18C5 cam advance/retard???
- radiator quiestion....
- B18B Head Flow Numbers
- fluid damper?
- upgrading a jdm b16a1
- 2000 USDM ITR head onto OBD1 car - how to?
- Need some serious help
- Marine Exhaust tubing, is it possible?
- Is running Nos safe wit over-bore?
- h Hood Pin's for a CF Hood?
- Rear Spring Noise?
- Headgasket Question
- alignment cost???
- Will tranny have impact on dyno#'s
- Speedometer not working on the 3rd one
- anyone have the SARD FPR?
- Ground Controls
- shot my engine/what can I put in it?
- head lamp woes
- crucial all-motor setup ?s LS/vtec w/ crower stroker kit...
- slave cylinder boot is ripped..is this bad???
- JDM 4-1 header hole question
- longetivity of engine with performance parts
- Pulley kit benefits
- Pros and Cons of Exedy and Action clutches
- Coilovers
- To Z10 Girdle or NOT to Z10 girdle??
- NEW suspension?
- 12:1 CR safe for 91 octane?
- Vaccume leak i think? back me up
- Honda flywheel weights
- O2 Removal Help
- URGENT Head Bolt Tech Question.!~!!!
- Will chrome plated header flake?
- D16Z5 EDM-CRX n/a Setup ?
- How to check SRS light code??
- Oil Pressure Sender question
- Cam Seals Tech.
- anyone replace their worn break booster...
- More from the shady-garage
- TIming belt
- SIR guage cluster wiring sites? 90 CRX HF.
- High Pressure Grease gun hose for Autometer Oil Pressure Gauge?
- Different VTEC for ITR intake manifold?
- Toda Bs
- 1980 Honda Accord Idle issues.
- what cams to run and be safe wit milled head
- clutch questions...
- Whats the best spring rate?
- Piston Polishing
- H22a specs?
- another idle problem, please help(searched but nothing similar)
- whp and wt on usdm type R and on jdm type R dc2r?
- Engine Codes
- Apexi Headers???
- can't get nut off of steering tie rod
- R/S Ratio question...
- DIY resonator almost finished.
- O2 code being thrown ?????
- stroke D16z6 ??
- Removing head..anything to watch out for??
- Timing Belt Help
- clutch slipping?
- 1 wheel wheelie bar setup or a 2 wheel setup?
- shifting problems
- get ready to drool
- axle question
- really really simple exhaust question i just want to double check
- clover leaf combustion chamber
- built B18B questions
- sloppy shifter
- ummm.....help??????
- Question to those who have built all-motor setups
- Any one in Austin know where..........
- HELP!!!!!!!!! Stock Fuel Filter Fitting!!!!!
- B16B w/ GSR crank
- 2003 Civic SI (DYNO RESULTS) From Import tuner
- type-r sway bar
- new aem cai ver 2
- Grinding Away!!
- increasing displacement on a B18C
- DIY Brake Sites
- b16 b18 or h22...
- Torque specs for Cam Caps on b17 engine.
- 8 tenths of r/s ratio worth it?
- bearing and rod?
- is there any difference between jdm vs usdm ITR intake manifolds?
- what do these ef, eh
- pimping my services
- Tire question? 195/55/15 to 205/50/15?
- tranny seal problems
- AEM fpr question...
- Ignition timming for 2000 Civic DX
- Compression too high for N20?
- HELP ASAP lb. ft. for B16 rods
- Turbo timer install on 97 GSR????? help
- help
- suspension woo's
- Electrical problem... please please help me...
- Ground Control Coilovers...Quick Ques.....Please Help....
- Loud grinding,crunching noise?
- I messed up my engine
- does anyone have DYNO charts from the RS*R header?
- turbo mixed with vtec
- aftermarket thermostat... for lower temps..
- Need help on lsd
- Come on TECH's need help real quick!
- what is a j1 transmission
- help meee !! headache w/ car !!
- how to remove oxygen sensor
- Just did a Compression Check on the rebuilt engine...
- Any special kinda grease needed for rubber bushings??
- People with skunk2 coilovers need your help
- Block re-sleeving question?
- ignition timing, idle, octane.
- a 12v ignition source
- Correct Foot Pounds? Help me out?
- eg guys with teins...what are your settings?
- n.o.s. fogger
- Engine Specs?
- testing the distributor.
- wiring pins...searched but nothing
- HID Help
- Springs vs. Coilover
- Can someone confirm this: YS1 gearing = ITR gearing
- What synthetic motor oil do you run and why do you run that particular brand?
- Strength of LS rod bolts??
- Question about valve seals?
- What size..............
- TB work
- Good SOHC Cam............
- B20vtec headwork???????
- Installing cams
- Stock size got intake and exhaust valves on b16A2 2000 Si.
- what is needed to make a B18c5 into a 2.0 liter?
- longblock vs shortblock????
- Excessive Play in Steering
- Why low compression pistions?????
- Check spark on DIS ignition?
- Need more hp, what next?
- B18C ITR and B16A cambelt question??
- Q for VAFC users
