View Full Version : Tech / Misc
- oil pump gear for a b17a
- LSD in sohc
- Will CTR LSD and FD fit in a 99 Si trans?
- Motor issues?
- how to adjust the accelerator pedal?
- ITR rear sway bar on a Civic? Is it overkill?
- can anyone explain this?
- Daily driveable ITB's?
- pedal adjustment.?
- Help code 4, Crank Angle sensor
- help! engine is struck at 5000RPM (sorry, its a double post)
- Supertech valves... any good?
- Remember www.8120performance.com?
- Skunk2 front upper A arm replacement
- help, car is bogging still
- difference between 02 sensors...
- tec 3 or hondata?
- throttle body question
- b16a1 and b16a2???
- Which stage of clutch is best for me? Also, preferrably what brand? Give me the real answers.
- Does Air Conditioning waste alot of Gas?
- B-pipe for B18C swap
- Fuel Pump?
- Changing CV Joints
- Cam gear ?'s
- For those with the FJO wideband controller unit and display
- MSD RPM module problem maybe??
- Oil pump for turbo
- ITR LCA"S on a 2000 civic
- vtec in 93 civic with h22
- cooling down brakes????
- Will i run rich if i eliminate the 2nd o2 sensor
- Specs?
- Shift kit for 94 auto teg
- Nissin not Nissan =x
- what exactly is a "head"
- JDM power folding mirror help. I know it isn't tech question but wiring problem
- How to clay with vtec??
- GSRmaking 160+/120+ at wheels... exhaust question
- Intake tube length and diameter.
- Need B16 Assistence ASAP... Car sounds like it's gonna blow up.
- B18C1 / B16A2 exhuast manifold/header/cat question!!!
- need help on tire pressures
- balancing
- JDM vs. US header inquiry
- JG Edelbrock intake manifold?
- which brand cat. conv. is better? Random Technology or Carsound?
- Pls help, why are my fuel injectors diff?????
- 99 Civic Si (SiR in canada) SRS computer location?
- New BUILT Motor Almost Broke In And.......
- Check Engine Light doesnt come on at all (even when starting)
- is "HAD" aftermarket throttle body or OEM?
- Clearance Issues w/ block and pistons
- iacv check engine light. could a...
- Can I use an H22 Throttle Body on a B20 stock motor?
- neuspeed sport springs
- turning FPR's down..
- 6 speed civic???
- b16 distributor
- my exhaust smells like eggs
- Throttle cable replacement clarification
- anyone know of a good place that works on ecu's?
- overheating problem...
- throttle body questions
- cams........
- Unorthodox Crank Pulleys - DON'T USE...
- help code 20 !?!
- Type R Transmission Problems!!!!!!Help!!!!!
- Honda engines Microphish
- newbie crank question
- B20/Vtec
- Aftermarket cruise control
- vafc question - what sensor type
- Short Throw Shifter help or hurt tranny?
- How much should it cost for port work???
- What's the deal with Phantom Grip LSD and differential shims?
- compression
- Timing Belt & Water Pump
- Cleaning Engine Bay
- Please explain rear sway bars to me
- Back pressure From Exhaust
- bad things...
- starting up problems?
- Another mini-me!
- Immobilizer circuit
- 2point6's new look
- Exhaust diameter for mildly modded D16Y8...
- Re: What is the best time to check your oil for an accurate reading?
- how to change front and side engine mounts
- status on the approval of the skunk2 itm
- GSR intake cam and TYPE-R exhaust cam?????
- Comptech CAI
- B16a running only two cylinder now ....WTF ....NEED HELP >>>>PLEAse
- Have to smog check in California, but I'm not from here! Need help...
- Does anybody have any pics of the Greddy Evo exhaust on a TypeR?
- Need help with this sensor, see pics please----->
- will this engine stand be able to hold my honda engine?
- integra and civic brake rotors
- ? ? ? What's the best performance tire that can be driven in winter ? ? ?
- Alternator/ Power Charging Problem
- slow 3rd gear
- Cvic engine valve stems vs. Integra valve stems??
- Zerex coolant
- tach
- ES bushings help please!!
- jdm b16/dc header question
- distributor question
- Wheel/Tire weights
- ???Has anyone's clutch pedal's engagement point gotten closer to the ground????
- climate control
- how do i clean an O2 sensor?
- Crower 64025A Non-Vtec
- WHat might be wrong?
- Question about boring cylinders
- Purge at end of night, or okay to leave in lines?
- What kinda of oil do you use ??
- B20Z INTAKE CAM - Viable upgrade for a B18B1?
- older apexi AFC II on 94 integra rs
- Code 23 (knock sensor)..can't get rid of it..HELP
- advice on what tires to get
- Error code 54....?
- can I do this?
- can someone tell me how to fix this?
- engine temp gauge acting like a tach
- Jacobs Ice Pak Ignition
- Disappointed with my Z-10 bars..
- USDM engines?
- Idle problems
- A/C problem car keeps stalling
- LSD - JDM and USDM - the same exact part?
- prelude type-s valve train
- CEL code 23 what is it???
- b16a2 A/F settings
- rsx 5-lug conversion on a dc2 ?
- Location of IACV?
- need help!! what sized bolts to use when mounting engine on engine stand
- Skunk Stage 2's and CTR pistons in a b16-cutting it too close?
- Changing my sisters oil -----> what weight?
- cant floor it?
- Will a b16a head (1 st gen) bolt on to a b18c block (USDM) ??
- chipped p28 for h22???
- bigger engine or turbo
- Let the build up comense
- Which to choose?
- rare/special ECU on a 93 G3 AUTO Integra SI ?
- Check engine light came on
- high end problems
- ***people w/ AIR-FUEL ratio gauges***
- Which has more HP 2.3L dohc non-vtec or 2.2L dohc v-tec
- Need an opinion on a engine noise
- Checked plugs after running n2o, looks good..opinions, and more Q's...
- Converting 91 CRX into Mini Me
- Stroker kit for the b16
- Help! 02 Si oil filter ?s
- what 1/4 times could i expect with this setup?
- mini-me
- Alternator problems w/my 98 ITR
- Ls block
- v-tech head swap on a
- 95 Civic Ex 3psi turboed, really sluggish before boost, really sluggish under boost
- continous motion wheels...WTF!!!
- tyre tread wear ratings???
- all motor LS in a crx-whats needed for low 13 sec. ET's
- HELP:distributor plug doesnt fit......?
- NSX injectors...saturated or peak&hold?
- a dumb question about a fuel filter
- Second gen B16 flywheel pilot bearing questions...HELP!!
- i just started out on imports!!!!!
- Cooling Fan Problem Reaches My Last Nerve
- ACCEL DFI....... Who uses it...... How well does it work...... who can hook it up right???????
- .25mm overbore CTR pistons in b18a/b
- Pinning the block.. can anyone breifly explain the process??
- how many of u work under jackstands
- mixing viscosity
- JDM 4-1, Carsound 94006 & ITR b-pipe
- Those with D16Z6 disassembly experience (bottom end)..
- After market Valves!!!
- Zeal Function B6/ JIC/ or Tein HA for EK?
- Stock NGKs ruining my gas mileage!!!
- quick questoin - install B&M FPR
- help me...3rd to 2nd over 9000rpms while sparying :(
- safc tuning
- b16 kaaz lsd speedometer gear
- parts interchange
- Help with Ignition
- Do the B16 cams have more lift than the Gsr cams?
- Is a DC 4-1 Header worth buying for the ITR?
- Valves
- electric water pumps - need advice from those w/actual experience
- D16a6 Crank Pulley Question
- those with viper alarms
- Question on camber
- honda maintanence question
- ok, here is the most Noobilicious question of all time, please help!
- Royal Purple?
- Honda ECU timing numbers on the big end?
- never got an answer........
- ACL Bearings available NOW--Here's pricing.
- Where to resurface flywheel - Bay Area?
- apexi rev/speed meter vs apexi tach vs others
- blower motor
- Brake Caliper Problem
- good or bad?
- I'm gonna BLOW my car up....
- Tranny problems
- Injectors like eclipse 450's but from another car?
- O2 Sensor
- What's gone bad on you first? Ignition Coil or Ignitor?
- Leak out of linkage
- Leaking Oil...
- n/a b16 power
- My reserve antifreeze dissapears
- Dumb Speed Bleeder question
- Valve guides?
- Timing belt snapped....no damage
- inspections> muffler leaking
- Can't take the dist. rotor off!!!
- port/polish head
- brake upgrade question
- What are the usuall things that go bad on a Civic's suspension?
- Part Number and Help needed
- B18C1 users..
- what should i use/ get?
- chipped obd1 ecu and V-afc??
- Does Honda make a 2.3L for the prelude.
- Having probles taking ou the engine harness, plz help!
- Any Info on new Product?
- b16a hydro vs b16 cable?
- which ls motor for 92 hatch?
- VAFC Apexi controller
- Head swap on '97 Del Sol
- 90 Civic + 89 Integra LS = ??
- Main bearing cap bridge (block girdle)
- Is my ECU resetting everytime...?
- vafc install questions
- 4g Civic Sway Bar Question
- rear lower LCA shock bolt G3 teg
- tranny makes clicking sounds???
- black oil pans
- Who is from Florida?
- How do you clean an intake manifold for a 97 Civic EX
- 4 inch drop
- Nitrous question
- why does IAC Valve need coolant flowing to it?
- fuel injectors not injecting
- Sometimes RPMs stick when i come to a stop. Idle problem.
- need 250 whp
- got a axel hub related question for a 89 Civic Si w/B16a w/ys1 lsd
- cruise and horn?
