View Full Version : Tech / Misc
- rspec controller
- brake pads: pro ceramic and ceramic
- fuel pump trouble
- Tool needed in the Pittsburgh PA area-valve spring compressor
- Opinions on my set up, please leave comments!
- IS This Motor Any Good?
- FORD, HONDA.. ETC.... aftermarket parts
- What is a Better swap b20 or b18c1
- How do I get timing belt to be tighter?
- Problem with Engine Identification / Cross Reference..
- Stainless and Aluminum would it sound weird.
- AVCR & VAFC II SETTING
- D15B questions
- GSXR 1000 ITB... air ???
- d-series hybrid question about vitara pistons on ls rods..
- new injectors, now #4 wont fire.
- LS Rods in a D16 or ZC Rods??? I can't find the Thread
- Tranny gear swap??
- VAFC2 on a K20A
- Will a b16 head on a LS block raise or lower compression...
- Jumpy Tach
- 1ST GEN H22 QUESTION!
- head gasket service at dealership
- ARP H22 Studs - what torque ??
- Electrical or mechanical gauge???? oil pres. water temp.
- B16A SiR2 Erratic Idle +Video
- shimmed oil pump & cam seals leaking
- What rotors to get.. Autozone rotors or Brembo Blanks
- Timing question: dissy position with relation to degress
- Block decking questions
- CAT cams: wtf is wrong?
- Crank Pulley Bolt Stuck...tried everything
- best oval muffler
- I need to find out what cams i have....did a search....94-01 GSR yes/no?
- Toda B16 stroker kit
- gauges jumping all crazy?
- will a d16z6 mind revving to 9k with just zex valvetrain, eagle rods and wiseco pistons?
- WHAT TRANNY FOR LS
- ctr cams causing me to loose power?
- Help Installing New Koni Yellows/H&R Sport Springs...
- color code for rod and main bearings d16y7
- URGENT - Are all basic EXEDY clutches organic?
- valve grind???
- distributor crack.. still good i think, please confirm
- BASELINE DYNO Numbers for a stock SiR?
- Will a 97-01 Predlude TB fit a B16 IM???
- I don't think I installed my afc right. Please help.
- Fuel injector position...
- Whats wrong with my engine?? HELP
- Fuel injection problem...
- Defective Stainless brake lines?EARLS
- head work help!!@
- tranny
- weight saving suggestions(ive searched)
- Spark Plug Gap and Ignition (MSD SCI)
- quietest exhaust setup
- Low Idle when engine is cold but ok when warmed up? IACV maybe?
- which OEM fuel pressure regulators will work for my GSR?
- Polishing exhaust
- rod cap stuck on there... any advice?
- Anybody heard of Top Fuel Intakes
- Does a GSR oil pan work on a b16?
- Rearsection Length Question, have searched.
- timing gun skips flashes..wtf?
- the problem with vortech fuel rails (and others)
- valve to piston clearance
- Drill Str fuel rail
- just started h22 project
- where did you learn to weld?
- Crank bolt wont come off!!!
- sinking clutch pedal...
- Toda Cams-how can i tell if there really toda spec c cams?
- clutch problems
- Engine shuts off after warming up....
- **Mosquito Joe's revenge?** (I can not believe what just happened!!!)
- Engine Cleaning
- rebuilt motor...solid CEL?
- dyno places in baton rouge or new orleans areas?
- 90-93 integra Front Wheel vibrating problem Need a lil help from the HT Family
- Help need OEM part #'s for pressure plate bolts and flywheel bolts for b18a(b series)
- engine swap for a 1995 Accord
- Accord ACT clutch install.. clutch release fork PROBLEM!!?!
- which is the higher rever??????
- need some info about short air intakes
- gsr swap on crx, passed REF visual, but not emissions... hi HC at idle... HELP!!
- How to upgrade fuel on turbo applications?
- timing
- zc fuel pressure
- AVCR - I need help!!!!!!!!!!!!!!!!!!1
- D16Z6 head gasket and arp head studs
- what a pr4 ecu out of?
- what oil do u use on initial start up
- please help with vtec
- Need answer about rings!
- I have a 93 DX hatch with a SOHC ZC swap. What ecu should I be running?
- What would be the best ignition system to use?
- HELP!!!!
- whistle noise
- What is the best Head for Vtec turbo Gsr vs B16a2????
- y8 intake manifold on z6
- help! asap!
- 98 GSR ECU code 61 thrown: Primary O2 Sensor
- Help with my tranny
- web site for vtec controller instal?
- Throwout And Pilot Bearing ?'s
- Two problems: belt squeling and coolant........
- H23 accords
- steering hose...disconnect
- whats the spec for usdm p30?
- Check Engine Light(knocksensor) comes on after i hit 45mph
- Differences between B-series starters
- Civic and Integra Spring Interchangability
- Using aftermarket bearings ( Napa)
- NEW GUY PLEASE HAVE MERCY
- engine installing about sensors
- Anyone been to the College of Alameda smog Ref? (bayarea CA)
- AEM fuel rail question
- itr max revs
- ODB2 to ODB1 distributor converting problem
- Help: 97 prelude base 5 spd, clutch pedal is floppy, and will not engage. please help.
- h22a auto timing belt tensioner breaking need help
- TPS problem.
- quick quaife question
- diagphram assy vacuum. vtec. neeeed help
- NEED HELP PLEASE PLEASE, CAR WONT START!!!!!!!!!!!!
- Help car wont start
- Can JB Weld hold on a block?
- oem seat belt swap from 91' hatch to 90' crx?
- Any one know the spring rate on the Skunk2 Coilover?
- motor swap troubles (need help)
- ???what size are my swaybar bushings???
- MPG question
- Converting PS into HP
- b16a distributor codes...are they interchangable???
- Help on obd0 wiring harness! did search and no luck.
- Cams vs CR
- How much does it cost to install ARP rod bolts? Have searched
- Quick synchro question:
- Who has OEM Honda Bearings?
- d16a1 problems plz help....
- about cams
- Any programs to scan my s2000 engine with a laptop?
- need help on ls motor
- 92-95 eg hatchback emissions
- Possible tranny/axle problem
- hiding the wiring harness and wires within engine bay
- transmission stuck in 2nd
- tranny question
- Will type r oil pump work w/ a 91 b18a
- how do i adjust my FPR
- F***ed Up EF I NEED HELP
- Clutch for JDM big spline YS1
- Different Lowering approach
- Bolt Removal Tip
- b17a1 longevity
- Suspension question: Rear swaybar on stock struts/springs?
- B-series headers on Ebay: SSAutoChrome
- 92-96 Prelude Injectors for a B16a?
- SAFC II worth it?? or Chip??
- Anyone using S&B "Powerstack" air filters?
- Odd noises comming from 94 h22a engine, possibley transmission
- Changed my plugs, and i'm stumped...
- specs on b17a stock injectors
- Where to buy cap and rotors?
- Will a b16 header work on an ITR
- guage cluster not working
- Engine Building
- ls- vtec or keep the b18c for build?
- omnipower coilover
- help!!!New to DOHC builds.. Flywheel question?
- Transmission help please
- i didnt have much help in forced induction forum so im asking u guys
- HELP!!! Noise after Rear Disc conversion...
- Code 54 - CKF Sensor
- maintenance required light
- uberdata tuning in South florida??????
- Anyone ever heard of a computer progam called Sport Tuner Pro?
- Vtech problems
- P2P OBD2 Ecu help
- rpms idle when jump
- Intake Versatility
- msd sci ignition with no rev limiter...can it be upgraded?
- distributor clicking
- question on testing an injector resistor pack
- can someone help
- cannot pull code from ECM
- Would a OBD2 distributor work on 94 GSR Head
- drag springs and camber kit for a 94 civic
- Pcv valve...need help!!!!!!
- Difference between shortblock and longblock?
- Is anything Using b16 ARP headstuds with their GSR blocks?
- Blown two ignition coils in two months !?!?
- Speed Governor on P06
- Pinging even with a knock sensor
- HiD question
- engine block leaking coolant
- alignment to steering rod, any connection?
- Fuel Question
- What ARP's for ls/vtec??????
- Pinhole pissing coolant out of back of block...
- shift light with msd rpm activated swith no tach reading help!!!
- gsr block - moroso oil pan
- intake manifold hoses
- 2 easy questions
- Coolant leaking coming from under Intake Manifold? thermostat side...
- suspension help
- how do you adjust a hydro clutch
- 4 u turbo folks
- Missing VTEC pressure switch
- wheel offsets
- fan problems
- Weapon R fuel Regulator and Hondata
- I need the help of any ECU gods out there.
- 'grade 8' versus 'class 8' bolts... difference? bolts for engine stand
- Worm clamp holding cat shields together, ok?
- gsr crank in a b16 block
- con rod enquiries
- Engine braking myths?
- How can one tell if the engine is a type r jdm?
- Hesitation when I punch the gas???
- Need Cam lobe to rocker arm clearance spec on a 90 teg
- 1.8 accord performance
- 02 CIVIC SI CHECK ENGINE LIGHT
- removing the cam holder... wont come off help!
- advanced cam gear, no top end?
- Ready to install - Torque questions ?
- Poor performance!
- B16A swap into 95 cx
- Flashing Code 70...assistance needed
- JDM vs USDM GSR Cams
- Tourqe the head more ? on d16a8 turbo ?
- gsr head on b16 bottom block
- oil light....
- Popping sound in JDM Spec R engine... Help please!
- thinking about what to do with my suspension need ht's help
- CAM SEAL
- interior is shaking like mad
- what ecu to use on ls vtec project?
- very wierd tdc problem...
- How hard to build a motor with a helms at hand?
- '96 - '00 Civic CAI Cold Air Intake question
- URGENT Broken bolt! while changing tire
- Quaife LSD oil?
- bottomed out detent bolt in the tranny, won't shift into 3rd or 5th
- Which crower cams for my b18c1???
- efi university
- bigger fuel injectors....hurt me?
- Just lowered Integra need someone to help me read measurement sheet
- Harness guru's I need your help answering a question
- Burning Oil...Valves?
