View Full Version : Tech / Misc
- CEL stays on after i reset. CEL10 stays on when set to acc
- HELP!!! ALIGN-A-MATIC WHEEL ALIGNMENT GAUGE
- D Series Head Codes
- tranny question!!
- clean engine bays, how is it done?
- i need some good tech advice
- take a look,,,bent valve...?HELP
- Gas guage not working?
- Cold Start AFR?
- wheel hub removal, without new bearings
- mini me swap on 89 crx si problems???
- ecu question
- dx map sensor on 89 crx si???
- obd I into II chassis
- after motor swap and fuel pump swap--- I have no fuel pressure
- obd1 conversion on '00 itr...i have a question about getting a signal to the injectors
- which HEADSTUDS do i use?
- Schaeffer Gear Oil Transmission Synchromesh Syncromesh Fluid Gear Grind
- HELP with my DA suspension - upper A-arm rubbing
- Proper Way to flush coolant System
- Are all TPS the same?
- Crower LS valvetrain question
- simple question, what would happen if motor tips over?
- a/f ratio gauge
- Screeching sound in Reverse and low speed
- B18C bore?
- Breaking in oxygen sensor?
- LS Trany gear ratios when equiped w/type R final drive
- what makes the wheels spin?
- Alternator replacement
- Wiseco Pistons on Stock RODS
- Obd1 and Obd2
- LS/Vtec question.... Sorry
- need help at/mt swap
- Oil Pressure gauge install?!?!?!?! HELP!!!!
- CAR WONT START NEED HELP EF(d-series) experts!!!!!!!
- stock honda coil springs dimensions?
- AC Line question
- Good Machine Shops in Socal
- sohc and dohc vtec harness, cna i plug up a dohc wiht my sohc harness?
- Hondata intake manifold gasket and skunk 2 manifold going to hit in facotry DC2 gsr strut bar?
- are all vtec solenoids the same?
- water temp. gauge
- VAFC Settings - need help
- Paint to Match Tein Green
- measure dome volume?
- Sensor on bottom of block by pulleys?
- what dizzy for a odb0 lsvtec
- fuel pressure not holding on the gauge when the key is on
- VTEC solenoid bolt is broken!
- wiring harness
- SEARCHING DEVELOPED MORE QUESTIONS
- Prostreet Timing belt for b16a, make sure to buy the right one!
- what is right suspension for this setup?
- crower rods w/ctr piston
- OBD 0 To OBD 1 Distributor Pinout Differences (or how does 8 wires go to 9)??
- 92 integra bogging
- GE Girdle w/ B18b
- Attempted to tune my car today, but it didn't go so well...
- AEM wide band
- D17 motor??
- bad map sensor maybe???
- tranny whistling/humming
- integra auto to manual conversion
- Apexi Turbo Timer Installation Help!!
- ALTERNATOR FUSE KEEPS BLOWING! wheres the short???
- Minor Problems with the new motor....
- reuse rod bolts?
- Removing the hub from the steering knuckle
- Crank angle sensor question
- OBD0 ECU Tuning
- What exactly do I have here???? TRANNY EXPERTS !
- What do i need to do too out perform a stang gt?
- I just can figure it out....Kinda long....
- 4 point racing harness install???
- camber kit messed up!!!!!
- Signs of a failing Fuel pump ?
- HELP!!!!!!!!! Valve adjustment ????
- oil in coolant
- Cooling system from Hell
- changing tps sensor
- Simple poll about best manual tranny oil
- gsr 2 door exhaust on a 4 door??
- Koni yellow adjustable perch.
- no start need help bad, tried too much already
- Frustrated and need help!! No Start.
- question about j's racing intake
- No spark/fuel no start
- Loud squeaking noise from front tires. Need Help/Advice
- 3rd gear syncro?
- Will an overfilled A/T leak?
- Chipped ECU + Msd 3bAr?
- fastbrakes...?!?!
- Dropped in B18C1 into EK... Something's shaking.
- Just changed tranmission and car wont start
- Can these Rods still be used? (HUGE PICS 56K don't even try)
- do you think i will pass smog?
- Exedy Vs ACt who makes the better clutch?
- shift light still stays on w/o green wire hooked up
- Timing belt deflection (video)
- price of tires?????
- whats diffrent from a b18b1 ls oil pump and a vtec b16 & 18c oil pump
- 45+offset & 205-50-15r tires on a civic????
- catch can setup with no oil seperator? please post pix.
- Question about rods??
- better understanding after researching limp mode, but still need help???
- HELPPP!!! oil problemmm
- Ring gear in tranny, how low is it supposed to be?
- Recommendation for transmission fluid for an ITR needed
- How much am I looking at for new fuel lines, fuel pump, brake lines in a eg hatch shell?
- Carburator
- idle/starting problems.. need help asap
- 4wire O2 sensor heater resistance. can I increase it?
- D16z6 pistons and rods d16a6 crank
- Problems with HIGH Water Temp
- my intake cam gear sliped
- Timing Belt Install, Car studders? Help!
- Screeching sound from motor at idle (vid inside)
- Timing off? advises please
- synchronizer set
- what would this be ???
- half shafts stuck!!
- hub removal
- d15bvtec...2 stage or 3 stage
- Check out my ALignment #'s plz
- VTEC: What does it stand for?
- Hasport mounts... Is it true?
- strip bolts
- header differences???
- More power ; technical help plz..?!
- Problems with SOHC motor: Car runs.. but not hardly.
- ouch *spark plug*
- Shift Light
- Bleeding brake fluid?
- Lower Ball Joint Problems...
- limited slip diff???????
- Cam GEAR HELP!! ASAP
- ACG fuse? What does ACG mean?
- stock retainers, are they good for high rpm
- Man. Tranny swap
- motors anyone!
- Aeroquip socketless or Earl's Super stock fittings for fuel?
- i really need help please!
- DOHC Cam Timing
- MSD wiring problem, throwing a code 15 (Ignition output signal) help?
- vtec oil pump badly burned in fire is it ok to use
- burned b16 b16a pistons will they work???
- ls/vtec rods and b16 pistons
- metallic clicking from rear
- Just bought ITR Outters and Portflow Inners
- I'm doing a b16a2 swap into my 96 civic hatch.....
- timing at what degres
- do all honda head have studs coming out of the exhaust ports
- Electrical problem
- Odd Question: D15B7 head on D16Z6, what timing belt, headgasket & head studs?
- Tapping noise
- Pullies............???
- Look at this pic on quaife install and tell me whats up please!
- if your in texas hit this thread!
- valve settings with zex cams
- All Wheel Mount On Dynos
- Help with trans code
- IAT sensor relocation due to nitrous?
- HELP!!! NEED A MODIFIED HARNESS TO PUT A B SERIES MOTOR IN A 96-98 civic
- read my dyno sheet.... WTF??
- Dropping idle after reving
- b16 and ls tranny questions???
- Need help on a distributor code...
- ITR rear sway bolt up to EK LCA's?
- and the best shop in so.cal award goes to.......
- Hondata idle problem.
- TRANNY PROB, PLEASE HELP
- Woe Is Me -- Trials and Tribulations....
- cam shaft
- broken ring land?
- Which Springs are Better?? H&R/Eibach? Neuspeed???
- h22 type-s cams and spray
- options for a grinding ys1 trans
- fuel pump with internal cooler.
- spun bearing??
- is this free hp website bull?
- need help my momo steering wheel is stuck!
- 93 civic governor
- need help
- Anyone Have CAD drawings of Honda/Acura Chassis?
- Can I use OEM Pistons with Forged Rods???
- Holley Fuel Rail
- can;t get car to idle correctly??????
- Grrrrrrrrr.... Code 14.
- Help! Buddys car just turns off..
- I have an obd1 engine, harness and Ecu. Wiring question?
- hondata programing
- TPS Sensor Voltage Question
- Help, possible bearing problem....
- question on brake lights....
- running Hondata, do i need a FPR?
- b16a is bogging and stuttering
- swapping driverside mount and bracket with motor in???
- b20 block 404 cams LS Dyno Results
- Getting check engine code "18". Please help.
- noob: whats the easiset way 2 pull my motor out!
- Rebuilt motor with new clutch.......
- lets try this question in here
- Adjusting APEXi N1 Coilovers damper
- d16z6 distributor question
- Haport Mounts
- 96 ITR suspension ?'s
- Shift Light
- suspension diagram
- Intake manifold insulater Kit
- smog questions
- Motor swap NEED HELP!!!
- ls ys1 question
- building my motor, advice needed
- Engine weak when warmed up?
- anyone have a Type R OBD2 pin out
- what's the best suspension set up for the money??
- torque specs on head bolts and bearing caps ??? help !
- Need to know why my car idles the way it does.
- lsvtec main / oil seals
- Skunk2 vs. Crower vs. Comp Cams ??
- LS/B20 Block, GSR/ITR Crank, Which Main studs?
- Is this driveshaft 'useable'?
- Fuel Injection Installer in Lithuania
- ***Golden Eagle vs. STR cam seal plug - which one doesn't leak***
- Do you need a OBD1 cat if you have a OBD2 car with OBD1 ecu??
- what spark plug wires for my lsvtec?
- my car is acting really wired, something voltage maybe?
- How to reset the computer to clear OBD II code P1456
- What exhaust works good with a Turbo'ed Motor
- fixing/hiding cracked windshield
- Do you need ac bracket for b16 swap if your not installing ac?
- need help asap
- Tec III tuning help?
- wheres my oil pressure sending unit????
- are all 4 wire o2 sensors the same???
- D series forged internals
- Bypassing (searched)
- Odd idle, slight ticking, hope its not bent valves...need input!
- b20 vtec caranck pulley
- Are B and D series valves the same?
- What does the EGR valve actually do?
- Motor Mount Question???
- can't decide on exhaust for my b18c5 swap
- VAFC-2??? Anyone have luck with.......
- Upgraded spring retainers, are they really needed?
- VAFC help needed.
- clutch set-up?
- Do 96+ jdm motors use a CKF sensor?
- what is on top of 96+ gsr manifold
