View Full Version : Tech / Misc
- itr exhaust cam necessary?
- "Red" Suspension??
- tach mounting question
- has anyone tried this with their...
- Replacing Tranny Synchros
- Can I use a 92 CX Ecu and hondata to tune my b20/vtec?
- b16a2 build up 200whp?
- accuracy of a compression calculator?
- got a b18c5 (with no vtec pressure switch) fitted the solenoid with switch but no where to plug it i
- ls/vtec
- Repairing Blown Headgasket on d16a6
- '99 Accord gone dead.
- jg edelbrock or skunk2 intake manifold?
- A/C affecting idle?
- Last Try...Anyone in South Bay/So Cal Help Removing V-AFC?
- 99 si tranny?
- I need part #'s
- power plant
- swapping a bare d16z6motor(no sensors) into a cx what electronics from cx can i reuse?
- spoon tb specs?
- intake manifold help!!!!
- HOT plugs OK in HIGH C/R engine?
- Is AutoCarParts.com any good?
- Crankshaft Oil Seal
- What does a fuel pressure regulator do and how does the adjustable ones work?
- Which donut gasket for JDM header?
- Swap for my Beater Si
- HELP on 94 civic DX kinda long (sorry if this posted twice still new to this board)
- ITR CRX swap??? Need help BAD!!!!!
- hydro tranny to motor from cable tranny...flywheel and clutch to what
- Civic Wheel Bearings
- b20 swap in hatch??
- idle problems
- Q on Crower 63403 valve train setup....
- Shocks
- Curing Excessive Wheel Hop
- Nasty Overheating Problem, Please help!!!!!!--------->
- HELP! in deciding which header?
- removing studs from stock im for skunk im????!!!! help!!!.....
- hooking up an electronic speed sensor to a cable tranny
- PLEASE HELP: Body shop says radiator doesn't fit in my GS-R???
- tps and map sensor
- Best Bang for Buck
- full throttle problems
- what are the symptoms of....
- what increase rear end rotation ????
- vacum leak
- apex'i coilovers vs koni/gc
- front end shuddering when cold
- very disappointing dyno figures
- Key stuck/shifting problems
- rear disc swap for 88-91 civic hatch
- plz help: hesitation problem
- distributor leak
- anybody know any good reliable tuners in the Bay Area, CA?
- Cams or underdrive pulley???
- bottom end
- ANNOUNCEMENT: pgmfi.crx-forum.org opens
- So Cal ~ South Bay Peeps That Can Help With V-AFC??
- once again....clutch cable brakes
- APEX VAFC install
- everything needed for a gsr swap in an ls
- which are the best shocks
- Is it possible to Switch Trans? Automatic to Manual for a 98 Civic HB?
- Oil for K & N
- Blown HeadGasket??? Help!!!!!!!!!!
- b20 bore??
- PW0/PR3 Hondata info needed!!!
- z10 block girdle
- what rotors do i get
- srs/cel ?
- Apexi Dunk
- best buys
- maybe an odd question about CAI
- check engine light
- cams in my si
- Different axles, drivetrain vibration?
- zex,web,or ctr cams who better
- Where to buy piston rings!?!?!?
- GSR W/ FI vs. LS W/ FI
- fuel vacuum lines..
- Rover with Honda engine and suspension?
- Transmission Gears: Main & Counter gears?
- dynos
- What type of grease to use with Urethane bushings?
- [ what's the dif? CAI/ DAC ]
- still getting code 1 & 2
- technical notes
- compression
- Clutch Cable in 91 CRX with B18B
- rev limiter?
- 88-89 integra ecu pinouts..... and 88-89 teg owners look....
- need help!! Strange squealing noise from gsr motor?
- code 9 cyp sensor
- need help, camber issue
- Speedo not working properly even after replacing VSS?
- What happened?
- ECT sensor
- Size difference between JDM and USDM ecu
- Eibach or Skunk2 or neuspeed search frozecomp
- JUN III's and Ferrea valvetrain vs Skunk2 stage 2's with Skunk valvetrain??
- abs control units
- hubcentric rings with rota wheels... will Konig work?
- My engine does weird thing once in a while!
- 12mm + lift cams..can I use oversize valves???
- quick mounts question
- OT: Hatchback Dyno... Not too bad.
- Coilovers
- Need informations for a swap
- Grinding Noise while Driving..
- Oil Press/Head Gasket problem???
- fuel filter banjo bolt ?
- Best resonable shot of nitrous for a high CR daily driver?
- Loud thump with my new coilovers!!!
- why is there gas in the ?gromet?
- header questions
- firing issue??
- tranny ?
- Bottom End??????????
- is it cuz not enough is going out?
- head bolt torque specs?
- Quick fuse question
- who runnin 12:5.1 compression-dailydriver
- coil on 89 crx
- symptoms of a bad water pump??
- Cams, Compression Ratio and Idle
- compression problems
- Projector Headlights
- torque wrench
- stupid fuel injection question...
- 70mm throttle body
- turbo accord problem
- worn piston rings....
- Does anyone know any good sites?.....
- Does anyone have a Fuel Pressure Gauge mounted on the fuel filter?
- Machine Shops in Dallas area?
- rev limiter???
- rip off? or not?
- weird noise coming from quaife lsd
- whats a pm9 ecu from?
- assembly lube?
- whats k wantanabe's website????
- Do integra fuel filters flow the same as civic fuel filters?
- ****suspension help!!!
- Cel
- Cams
- spark plugs + wires
- Auto and Manuals. Gearing still the same???
- longevity of shocks
- RedHot Exhuast Manifold
- First time at the track with the Si... disappointed.
- tranny drain plug
- Fuel Pressure Gauge Problems...
- Daily Driven 250hp+ which clutch?
- Honda Blocks Should the Sleeves be higher than the block??????????
- BAD ECU!!!!!!!!!!
- How much did you pay for your susspension?
- f22a dohc engine
- Help!!!
- Where do people get ideas like this?
- maint. required light flashing
- Mini-me timing belt
- Timing Belt Question
- backfire, slight bucking in b16
- roller rocker setup
- Overheating after coolant system flush...Help
- need urgent help..!!
- Will 98-01 Teg 2dr rear bumper fit on a 94-97 Teg 2 dr?
- Oil pressure guage question
- What should be the correct/best offset for a 16" wheel for a 99 GSR?
- BOLT dilemma with new EXHAUST - URGENT
- E-brake light keeps coming on
- PCV valve
- PYR Anyone got their head ported there???
- help my d16
- B18C5 81mm to 84mm Bore, p3f (B20B) piston wight in B18C5 block, ok ?
- V6 stuff
- CRVtec/LSVtec oil line question
- How to use you AC - not performance, but tech.
- B16A?
- Coolant problem???
- AEM Brake Pad ** Good ? ***
- Rod bolt torque for B16a?
- d16 trans. slop, play?
- exhaust temparature
- motor problems.. need help
- Dyno Tuning / engine power resistance training...
- 1995 honda accord engine swap
- Someone ID this harness ?
- ecu vs. pcm
- Code "2" on a 94-95 gsr ecu!!!
- tw sensor
- RSX oil filters on B16A?
- fuel pressure
- codes 3, 7, 10, and 14
- How much air is supposed to be in the tires?
- Comptech icebox on 00 Si...
- peeps with oil pressure guages...(electrcal)
- b16 JRSC fit a b18c ?
- motor dieing on me
- Clutch Cable???
- 1G B16a and CTR cams
- procedure for prepping b16 head for b20/vtec
- Problems, please help!
- $$ to fix my car
- Valve adjustment question
- how do you adjust idle???
- Si coupe --> ITR intake manifold..
- remove block without removing gearbox?
- valve springs- blue/yellow?
- Increasing Caster on a civic
- Advancing timing on 00 Civic Si
- Neuspeed sport springs
- removing cruise control actuator???
- ECU's for higher revs?
- Horsepower vs. a Stock 97 EX Tranny
- Deaking block?
- Synchro help
- What does code 90: "Evaporative Emission Control System leak detected in the fuel tank area" mean?
- Which is better headers, cam gears or pulleys
- anyone who has a hondata look inside
- CKP - crank position sensor code 4?
- B16a, Change parts?
- cold idle
- Will a GSR intake manifold fit on a B20???
- H22 aftermarket parts question ????????????????
- Going to flush my brake sys, should I use a 'better' fluid than OEM Honda?
- AC question
- Completely OT: What's the redline on a WRX
- Choosing new suspension components for the CRX
- vtec controller
- is it a SIR
- air filters
- what do you guys use to..............................
- p72 gsr ecu with a b16a
- Does this flywheel look safe
- Re: Ground controls with Koni yellows or Tokico Illumini
- Valve overlap question....
- Calling all tech gurus.
- Changing rod bearing question....
- Engine Stalling
- Strut Bar
- Serious B16A2 problem - dyno results = bad!!!
- Taking off oil pans
- Accord 4 disc brake proportioning valve
- I have run out of ideas, so i turn to you.......
- question and springs and shock combo
- SOHC vtec performance cam
- Can some1 run a carfax for me???
- fuel pressure
