View Full Version : Tech / Misc
- Just got a B18a block! What do I do about the sensors?
- sohc vtec head studs/bolts torque????
- skunk2 stage1 with gsr stock valve train??
- holley airmass headers?
- best way to bleed clutch
- JDM cluster is off a lil bit
- ITR vs CTR......opinions?
- energy suspension shift bushings
- Machine Shops In Ny
- 85 Civic Sedan Brakes
- How To Sites
- ECU Question - P28
- Bog out at full throttle..............need help??
- AEM Injection,Ignition specs?
- reprograming ecu's
- H22a Ordeal
- Cel code 65
- Random Cat
- Camshaft/Valve Problems??
- B18C Type r Horsepower
- Anyone have info on making ODBII-ODBI harnesses?
- Tranny Info
- Anyone using the moroso spiral muffler/resonator?
- rebuilding head.. need suggestions
- Would a Fuel Cell in my trunk be worth it?
- Anyone had a gross pulluter in california??
- car storage question PLEASE HELP
- My low buck Type R
- diagnosing low compression
- Motor swap question
- Versable VSS sensor
- int/ext oil orfices??
- vaccum question
- Brake Bleeder Question
- cai install
- Extracting more power between 5000-8000rpm?
- CEL help pleasseeeee
- short shifter swap and clutch question
- Honda/Acura Part Number Help
- Piston Ring ?
- turbo h22
- how to tell if my shock is blown?
- Need ECU guru(s) input
- oem all motor parts for b16a2
- Do any one have the fact book of Stream & CRV
- Swap Guide
- OEM JDM blue valvecover, is this real?
- Motor Decision HELP!
- The TPS and why it is driveing me crazy
- Best BOV
- 4-2-1 headers
- Which is better for performance
- Is it worth the money
- question about the AEM fuel rail
- Car turns off when slowing down after driving 40-60mph
- need help removing torque converter....
- B18A Crankshaft Question
- what to do with $3500
- racing fuel
- polyurethane bushings in my ek hatch (squeaking) help
- how to make a ls v-tec ?
- VTEC oil pressure switch pin location
- B18C1 in an 88 CRX, suspension questions.
- diffrece between ls and gsr distributors????
- Recaro Sliders and rails
- the project has begun
- Would this engine fit
- Are these rods realy from a b16a?
- Auto ECU -> Manual ECU Conversion
- flow rate of non turbo dsm injectors...
- How to remove coilover sleeve?
- post header install questions
- Identifing Intake Camshaft Help
- Gsr with PR3 pistons compression?
- Dyno?
- Skunk 2 Manifold Problems..Please help!.........asap!
- Head Swap
- firewall back wiring
- In need of ECU
- cam adjustment with thicker head gasket...
- Need help really bad asap
- Can anyone install or help me install a clutch in my b16 in socal?
- Civic GSR vs. Integra GSR
- how do engine builders match Im/gasket/head?
- best vafc settings??
- What EAVC is needed for a 1 gen B16???
- Do-it-yourself garage
- A question for all you VTEC gurus.....
- cel code 72,73,74??
- b16 swap hatch, mad problems
- Any B16a or B17a Owners>W/ Ctr Pistons?(high domes) Q?:What perf. cams are safe to run?
- dx exhaust sys??
- Air conditioner stopped working
- Weird blip at 1500 rpms
- exhaust manifold bolt keep backing out
- OBD1 Dist. vs OBD2 Dist.
- code check in a crx obd1??
- Has my nitrous been useless?
- Quieting Rod bearing / Wrist pin noise
- How To - 4-lug to 5-lug conversion
- Auto transmission torque rating...
- Compression questions???
- cam timing...
- how to perform a leak down test
- EK W/ type R swap + OBD II = I conversion, no fuel
- any tips for timing belt adjusting with motor in car
- how to remove O2 sensor with shitty tools?
- power windows
- need some troubleshooters in here
- Rocket Challenge
- Leakdown test just after new head gasket?
- Car wont crank after swap!!!Help please
- ECU throwing codes.... need help!!!
- 1 to 4 wire o2 sensor conversion help please
- how do you tell if a water pump is bad
- PG7 ECU pins for tach and MAP sensor
- Neuspeed race/bilstien shocks...need better suspension!!!!
- Breakdown the HP the b18c5 has over the b16a?
- installed gsr cluster now problems
- Vtec is not WORKING
- something wrong with vtec? CEL
- any suggestions?
- Where is my coolant going? Stumped.
- 93 octane vs. 94 octane
- Wiring Apexi Super AFC II in 88 Integra
- D16 piston specs...
- physical differences in LS and GSR pistons?....i did a search BTW..
- 60ft times with a JDM LSD and a Y1 box in a B16a 'rex
- removing tie rod without touching locknut
- Which car?
- i need help with my turn signals.. please...
- Honing. By hand or by machine shop?
- How much gain with Mugen Gasket?
- ? About my Proposed LS/VTEC Setup
- slow slow slow wideband..
- Need help, sound coming from brakes!
- difference between intake and exhaust cam
- Hondata N/A tunes
- Quaife.
- sorry about this
- Car won't start .. possible timing issues? Please help.
- timing belt for crvtec??
- How do you calculate R/S ratio?
- TWM Induction
- Best cams gear tune...
- AC relay fuse
- distributor coil??
- What's the LEGAL process of buying a swap from a.....
- Need Help with Vtec Oil feed to the head...
- Simple Question. Oil Control Orifice......
- will this hurt my engine?
- I need help bad.
- Simple o2 question
- Front GSR Brakes for a 5th Gen hatch
- OBD1 H22a into 97 civic
- catalytic convertor question
- How to remove broken bolt in block????
- msd sci ignition box HELP PLEASE!!!! need wiring help!
- Water Lines on the throttle body and intake manifold????
- CRITICAL HELP: Engine Harness related question.
- brake proportioning valve
- head question?
- Msd pro cap for 00 gsr??
- I hit a pothole, when suddenly my car just turn off! Why?
- howdo i fix my CEL?
- Alternator for 1st Gen B16
- WTB: anything, $2500 or less
- Brake Cleaner +Wasps -----> Drop dead in the air!
- B17 engine W/Ctr pistons, *Concerned about valve-piston clearance w/ high dur.&lift. cams.
- Injector Q (450cc)
- Alarm horn died...what can I get?
- Highest but safest compression ratio on 92 octane
- comparing b-series dist
- fast idle valve y8
- gas pedal problem?
- help asap
- Oil pressure
- Attn: people who have done auto to manual swap (wiring questions)
- FULL JUN SETUP stage 3 cams / valvetrain MOTOR for sale
- Wiring Diagram?
- What do the size numbers/letters on tires mean?
- which CAI for a 88 CRX with a B16?
- B series clutchs
- itr valve springs?
- Now that is a stiff chassis.......
- ecu jumper.... please help
- shift so fast syncros cant line up???
- anyone use a vacuum pump for brake bleeding?
- Clutch lines.....?
- Raw material prices for chassis and body?
- damn squeeking from suspension !!@#$*&(@
- Ignition Coil installation.
- Timing Belt Swap Instructions?
- Built Honda Motors
- Quick transmission question
- coilovers or racing springs
- Coolant overflow question
- anyone do business with NRG on Longisland
- Ultra-Light Lower Control Arms.
- when i turn on my head lights, my cars idel drops about 300 rpms
- Exhaust leak?!?! What do you think? Couple pics of problem inside -> 56k ok!
- Anyone Heard Of "block Posting"
- Cel Code 43
- Camber
- Fuel pressure
- Nitto question
- looking for stuff for my 90 si
- Knife edged crank?
- shift lite
- Does anyone use Hondata on there h22?
- Transmission Problem
- JDM B16a (1st gen) vs JDM B16a2 (2nd gen) searched found nothing
- welded diff. on SOHC tranny?
- vtec not making power!!!!
- New project
- cleaning engine bay
- i need references to pics of camshafts and their durations
- Help squeezing power from the D17 motor.....
- cel
- what size custom piping?
- header stripped nut, what to do?
- What problems have you had with a B&M Command Flow?
- radiator fan not working help!!!!!
- rod length to crank arm ratio for GSR???
- Magnetic Drain Plug for Transmission
- do I still need a V-AFC?
- will itr lsd fit a b16 tranny
- dancing speedometer
- overheating problems.please i need some help
- tire rubbing
- TB ground wire
- H22 true or false...fact or fiction...yes or no, you get the idea...
- ITR Brake Tech ?s
- AEM ems?
- couple of Qs while rebuilding block (with pics)
- Problem with my crx overheating
- d16y8 Intake Manifold - Auto vs Manual
- Valve Clearence
- What are the signs of a headgasket failure?
- P28 Pinout for 4-wire O2 Sensor
- HELP! Did a search, need help with ls fifth gear swap.
- Camshaft install
- master clutch cylinder install problems
- will v-tec work if knock sensor isnt hooks up
- D16y8 Block Vs. D16z6 Block? whats the differance?
- How to clean carbon off motor internals
- CEL for Odyessy?
- obd2 test pipe question
- 6th gen accord H22A swap wiring info help!
- MOTUL 5w40
