View Full Version : Tech / Misc
- springs/struts
- High feul consumption 1g crx w/ zc
- what to look for when buying a used block?
- If I get a wideband O2 sensor would I have more accurate readings on an A/F meter?
- VX rods??
- Intake swap
- would an LS gauge cluster work inside a GS-R?
- Who makes a after market SYNCRO???
- ecu code unknown
- hondata.com check engine codes?
- 2 exhaust or 1 exhaust
- Setting TPS correctly
- B series Compression ratio calculator
- Engine codes for Honda/Acura
- weisco pistons, crower rods...how reliable??
- Smart guys, please help me out
- still funny idling problem.
- are b16a1 the same same blocks as the b16a2?
- itr lsd fit in cable ys1 tranny?
- AC removal
- Replacing rings..is a hone required?
- Help: T/B Vacuum
- cold vs warm intakes
- What kind of dizzy car for obd0 B16 ????
- hid high beams?
- Deauville NTV650 Height Modification
- help...leaning out after vtec itr powered hatch
- over heating problem
- turn signal problem
- Buddy Club P1 Wheel question
- Will my harness work? mini-me related
- 3.2 CL-S engine in accord!?!?
- electrical load detector
- Where to buy and adjustable upper ball joint?
- Need Help!!
- hello
- single-cam swap to a b-16 in a civic, need help!!
- SPRINGS
- shift light wiring
- different tire pressures?
- no fuel what so ever???? please help asap
- Skunk2 coilovers+Tokico struts&shocks=good or bad???
- Cause of a blown HG? Also, tips. hints on removal,install D15Y7
- FPR question
- Swap is complete couple questions on running right...
- What could be the problem?
- Crank Swap
- HELP AND ADVISE NEEDED!!
- ? about bypassing the main realy
- b16 block tranny bolt re tap size?
- how to get 11:1 cr in ls
- Where to buy USED TIG Welder??????
- Help ID this sensor...
- Accord died, ran again, then died, now wont start...HELP
- my car runs like shit when it warms up
- Steering rack or tie rod?
- Purge control soleniod, needed?
- wide band sensor ?
- vtec solenoid working light
- how do i modify 2003 accord 3.0vtec
- All who own del Sol Helms Manuals READ!
- Do you know why a Civic would stall in neutral?
- CEL Code 6. ECT switch? or ECT sensor?
- distributor problem
- Hessitation and power loss when shifting at lower RPMS in a 1999 Civic EX
- big CRANKSHAFT question here.
- Electrical Problem?
- upper timing belt cover...
- quick timing belt brand question?
- idile problems
- Pics of your shift light?
- does anybody know how to make a 70mm throttle body gasket for b-series motor?
- Brake Problem: They stick/hang-up/drag sometimes.
- hybrid tranny
- Dumb question: Will putting a y8 cam and cam gear on a y7 do anything?
- What's the most HP possible from D16Y7?
- What is whp?
- B18C1, what year did it come from??
- energy susp. mounts
- Ebay header any good?
- TSW EVO: Lug is stuck
- Head bolts or studs?
- Ways to make more HP and R/S ratio better in B17A?
- Which temp sensor to use on B16 in a EF ????
- Need alittle Help on deciding to get Motor Mounts or not (yes I searched, just look!)
- Feeler guage came apart during valve adj. = loose washer floating in engine somewhere
- changing the rev limiter
- Fuel Pressure B16a b&M Fpr
- direct hits vs denso iridiums!!!
- Which ecu?
- what is the ray engineering duraluminum forged lugs TQ RATE?
- Automatic head parts vs Manual head parts
- help wont start?
- iac on b16a
- Car feels wobbly (axles?) turbocharged integra gsr w/axt xtss
- tom's motorsports coilovers
- single-cam gone wrong, ohh no
- flywheel question
- Crank pulley just flew off... now what?
- oil leakage
- Question about 02 Sensor reliabilty
- WTF! Strange revving sound and car won't start!
- JDM H22A Transmission PROBLEMS! REVERSE!! M2B4 / LSD Tranny
- A/C question!
- b16 cams on gsr engine.
- SMSP Header for 99-00 Si ?
- first it wouldnt idle...now it wont start...HELP!!
- What does a TB spacer do for you, exactly?
- Starter removal question
- is this the IAT?
- Alternator ground?????? ...........charging problems...
- Removing ITR oil cooler question....
- Constant CEL, Can't check CEL's 2 diff ecu's??
- 95 EX sohc vtec throttle body size
- HELP! (timing belt)
- b16a throwing code
- what kind of injectors do i need: peak and hold --or-- saturated
- how many revs?
- having trouble starting!!!! HELP
- Need info about my ECU
- What pistons and rods to put into an ls/vtec
- Having trouble installing SRR EK rear sway bar on my EM-1.
- Erractic idle..
- code 8 problem?
- How do I get to the sunroof motor in my civic?
- My 95 civic EX died on road after installing fuel system, help
- Any differences between obd-1 and obd2 02 sensors??
- lsvtec
- help me help me..
- high impedance injustors in ef.
- are 270cc injectors good for all motor or should i go w/310cc injectors
- not starting..
- best oil for stock?
- pr3 specs?
- is the jun chipped type r ecu worth it??
- Best cat back exhaust for a 97 Civic!
- how hot is too hot?
- any NJ(732,908 area) people with TOTIKO BLUES
- PW0 ecu Vs PR3?
- Sythetic vs Dyno Oil Consumption
- clapping noise from jdm h22a! please help!
- h22, turbo, aem problem
- Will Shocks from a Civic fit?
- Nitrous Express Direct Port Install.. Need some TIPS and HELP.
- Are TPS sensors universal?
- aem short ram... 99-00 ex and si... same intake ?
- can you make a obd1 or 2 distributor obd0
- SKUNK 2 TIMING GEARS NEED HELP.
- parts interchange questions (B-series)....
- VAFC HELP (nothing to search)***
- How many turns of the tie rods to get 1/16" toe?
- basic settings on my vafc
- Code 72, Coolant Bubbles, Fan Doesn't Turn on, Temp Gauge Way Up There, Sweet Smell from exhaust
- my car wont start
- cross drilled or slotted rotors???
- timing question
- What's the difference between closed loop and open
- obd1 dist.. help, did search
- Weights
- what's up with my tach?
- PR3?
- Tranny whinning-noise problem after Quaife & clutch install - help!
- Problem when starting cold
- P72 exhaust cam plug quetions.
- How often do you have to clean/replace your airfilter?
- Oil filter info
- gsr engine not running up to par help!!!
- vafc on a 1999 si
- Mugen Exhaust(WIll IT Fit)
- have you guys ever seen this!!!!
- Code 65 - 2nd O2 Heater malfunction
- which spindle / wheel bearing?
- would wrx/sti parts fit into a 93 impreza?
- what temp. in a oven to melt silicon off of stock lights?
- Rotary Engines
- weight redux in progress-need tech advice
- clutch question
- drop on ground control coilovers
- CTR Pinston install done, IDLE = OFF THE WALL INSANE!!!!!! need imedate help!
- Simple tire question
- Overheating b16a2
- Compression Ratio
- Where do get alignment done?
- Rear disc conversion...
- ABS or not to ABS
- ID this harness
- What tranny fluid to use with Quaife LSD
- emissions failure...
- Crankshaft Pulley Bolt...help
- Vtec controller
- cam question
- Cross threaded bolt, should i get it re-threaded or just buy a new piece?
- Vtec point question????
- FREE carfax reports!!!!!!!!!!!!!!!!!!!!!
- URGENT question need help PISTON RINGS
- Codes 71-73 and ABS light
- NGK Spark Plug Wires. . .
- help!!!!!!!!!
- tire size
- D16a6 in EG 92-95 civic, Dizzy Adv. Retard Question. HELP
- Does cyberdyne make decentgauges?
- Intermediate shaft question
- Car won't start-90'integra ls
- is my alternator bad
- Is this Normal?
- mounts for a rear low tie bar
- b18b vs b20 cams.
- Another A/C question
- Naked Pictures of my girlfriend!
- Axle or tranny clunking noise
- Can I just hone the cylinders?
- the infamous honda sliding shift! how do i corrct this? is this clutch from ebay a good one?
- Know of a good Machine Shop in Northern CA?
- ecu code
- Check Engine Light: Code P0171
- What all needed for engine swap?!?!?!
- engine bog, ignition?
- Question about nitrous
- 2 questions about oil and tranny fluid
- please help im stumped
- what happened?
- which fuse?
- instrumental lights dead
- Valve cleaning question
- Apexi Rev/Speed into OBD1 anyone have info?
- HELP!!!
- How can I tell??
- Will 270cc injectors be good for my setup?
- What overall size are those lexan windows you guys need or are making?
- missfire 96.ex vtec.
- Vtec help (B16) hondata
- Final drives
- guage cluster help
- black smoke @ full throttle b/c of timing advance?
- Does anybody know the diameter of a JDM GSR down pipe collector? I searched
- Mmmm Euro-R Intake Manifold
- b18c5 problems
- Awesome Camshaft Article
- what is Detonation
- Valve seats recut necessary on new head?
- Alarm or Kill switch??
- Engine Rebuild?
- Power Lock Relay??????
- What tps plug is on Twm Itb's
- code 4 DOHC 16
- ITR in EH2(eg6)??
- Primary O2 sensor (Heater)
- Introduction
- H22a Sensor Location
- Which way does the coolant flow in a Honda?
