View Full Version : Tech / Misc
- Made a bet, need your help!
- Gauge cluster?
- d16z6 bolts? on girdle under oil pickup.
- bottom end advice
- adjusting my projectors
- Eagle Rod Bearings, Did I pick the right one?
- Questions about a swap and the auto to manual conversion
- need part numbers for oem main and rod bearings
- Help! How to change brake
- vtec video
- re looming car, 3 orange plugs my car doesnt have, ABS?
- Garett TB02 Is This A Good Turbo For ZC?
- 00 LS AUTO TRANNY ??? NEED MAJOR HELP
- intake Manifold questions for b16a
- Need Help ASAP
- valve tap..question
- Hondata Experts, Please Help: Getting rid of sensor input
- Sidemarkers install?
- Air con condencer, heater units in the way of my loomness help!
- 5th Gear and Reverse GONE!! Car hasnt been Touched Though WTF HAPPENED!!
- rough idle
- PLEASE!!! Help Me!!! Check Engine Light While Launching
- any uberdata wiz i need major help
- AHHH IM GOING TO LOSE IT
- Idle problem lookin for possible causes?
- Will it detune if i unplug and swap ECU's
- catch can q's lsvtec b18b1
- Auto B18a1 Head?
- Code 22 almost fixed. 1 last Q.
- quick lsvtec question
- Timing belt woes *slight rip* fixable?
- Cam lift specs??? r they the same??
- problems with Speedomiter
- obd1 engine in odb2 car
- need help with some clicking noise
- High Flow Cat - Can They Pass Emissions?
- Engine starts to cut out when stepping on the pedal?
- Alternator relocation, B series?
- fuel pressure at 65
- CTR pistons tapping?
- Cx wire harness does not plug into o2 senor?
- Got bored, did some research, OEM Stroker B16A w/B17 crank
- What timing belt and Headgasket to use for LSVTEC?
- How to install a block guard the proper way!?!
- where do you gusy buy your o2 sensors?
- can you identify this tranny?
- obd1 swap done need help asap !!!!!!!!
- friedn just finsihed my ls swap in my ef and when we dr
- clutch kits
- vtec oil pressure and engine temp
- wich header do i buy
- Help, Obd 2-1 conversion
- refitting valves quertion. (grinding paste)
- troubleshooting
- CKF sensor on OBD1 cars??
- NA vs. FI (I know, I know)
- Question on my GSR swap
- HELP Conversion harness
- Swapping B series Tranny Cases
- clutch eating into the flywheel and pressure plate
- OBD1 help needed!
- Broken V-AFC Screen
- CEL codes 20,13??DSM injector install.
- obd0 to obd2 injector
- No Signal to Injector
- HELP!!! THROTTLE/VACUUM ISSUE!!!!
- replaced clutch... and still same flapping noise!? :(
- HELP! What ecu do I need
- UNUSUALLY FAST IDLE ON 88 ACCORD
- rs-r header??
- civic d16z6 - struggles to start and poor at low rpm
- Idle Problem...HELP!
- OEM Honda bearings w New Eagle Rods ?
- Need help, knock sensor CEL randomly, engine running odd.
- Peak and hold or saturated Injectors?
- help! 91 GEO STORM B16 VTEC or D16A9 engine swap possible?
- DSM 450cc into JDM B18c ???
- honda odyssey clock removal
- AEM EMS Vtec pressure switch???
- will prelude 4x114.3 hubs fit on an integra da knuckle
- F&H series OBX LSD evaluation
- AEM EMS calibration?
- ok... i want to jump into a wall. help
- clutch problem
- imput shaft replacement gone wrong...help!!!
- E-Cut Downpipes! Do They Last? How Can I Make It Effiecient? Emissions Friendly!
- BOTH shift linkage parts needed ???
- Need help identifying these pistons!!
- Stock head flow rates (would like some #'s or way to calculate)
- CODE 8 TDC need help someone !!!!
- ECU gurus... need a little help
- Replacing Rod Bearings!! Noob questions!! H22a JDM
- h22 head on f22 block
- Balancing Rods?
- Stage 2, Stage 3 clutches. How big are the differences?
- identify this tranny 3rd gear 80mph 3500rpm
- NGK Platinum vs. NGK Iridium
- TPS voltage backwards, WOT = .5v and CT = 4.5v
- cleaning spark plugs?
- Final Drive Question... 4.4 in 5spd & 4.765 in 6spd...
- need help! wire to tach on dash for shift light del sol 94
- Obd2 ECU compatible with OBD1 JDM GSR MOTOR?
- How long can gas sit in the tank?
- gearbox cv seal?!!!
- Winter vs Summer Tune?
- technical electronics question: voltage ratios for sensors, stock honda ecu
- big oil problem help please
- Need Honda Professional Help, H22a Swap problem, going to shoot myself in face!!!
- weird head noise
- Weird Idle and Charging light issue
- Studder/Misfire under load.
- Engine Building and/or Tuning book(s)
- Brake setup????????????
- obd2 tb on obd1 car....
- is it bad to leave a car sitting more than a week or longer and then start it?
- Power steering use it or not?
- Transmission/LSD Fluid
- 5W-20 oil
- Code 15, i have searched and tried everything. PROFESSIONAL HELP ASAP!
- Price check on Honda oil filters, Oil drain plug washers, Honda Filter Wrench
- LSD Question
- all Green bearings?
- Swaps Question?
- Caliper query.
- have p28 and spoon chip? where to get it installed in SOCAL
- Anyone seen this yet?
- wiring harness info needed
- How many belts in timing belt replacement for 1999 CRV-EX 5 spd manual
- CTR crank pulley belt number?
- b18 block b16 rods ?ever done ?
- Ignition Switch question... Are they all the same per year and Auto/Manual trans?
- Ridge formation at the top of the cylinder
- msd digital 6, will it effect my tune?
- D16A6, Z6, or Y8 Crankshaft?
- d16a1 (zc dohc) parts list!!!!
- 84mm LS VTEC, what head gasket?
- ITbs with s200 question
- Clutch Kits
- tranny gurus input needed.
- How to Raise Oil Pressure
- b20z help....
- Cel #14, continuety when checking IAC valve??
- Need help with hondata s300
- Degreeing a Cam
- PA Sensor Location In P28 and How to Disable/Fix
- how to clean headlights?
- PLX M-300 wideband Bosch o2 sensor part number??
- NEED HELP ON D16Y8 O2 senor
- Only 110WHP from my B18C5? Need help!
- ls vtec torque specs i need them!!!!!
- in need of d16y8 cam cap torque spec
- Has anyone here ever had any experience with this gauge?
- ignition problems
- Limp mode..jumpy idle...code 12
- what motor for my 4 door?
- My car keeps turning off......HELP!!!!!!!
- Best Head Gasket for 84mm LS/VTEC?
- smoke out of intake help!!
- obd0-1 Apexi VAFC HELP!!!
- Break Engine running Rich? DRiving for tuning day - guru's help this guy out...!
- installing a steering wheel....??
- Valve Spring and revving to 9k
- ----GSR oil cooler removal installation (COMPARE WITH b17A-b18c)!!!!
- Intake Manifold Leak!!
- temporarily fitting a gsr distributor on an ls head..
- S2000 ECU
- Engine has trouble starting. WTF?
- Accident, Now Engine Troubles
- Lose power from throttle body, how big is too big?
- anyone know a good shop (so cal area)
- OBD0 to OBD1 ECU HARNESS THEN A MPFI CONVERSION HELP
- when I rev to 2k rpm it drops to almost to 0k, but if I rev to 3k it will stay?
- ::Video:: How VTEC works
- Exhaust question
- transmission shifting problem
- ITR head on GSR block?
- plastigauge, usage advise
- Need advice on compression ratio.
- piston rings
- P28 S300 CANT REV OVER 8950?
- s2k motor??? some questions
- are these parts interchangable????
- honda rod bearing developement
- Problem with Gauge Cluster...
- 90 si cable tranny question
- Question about cams and turbo
- HELP!!! Main relay/fuel pump/ ignition switch???
- engine swap 1990 si hatch to gsr
- Code 17(VSS)
- Did I just get a set of recalled Eagle rods?
- what are thos marking on the head for ?
- Hondata S300: loading up on fuel while shifting.
- S300, strange A/F on warm startup
- Hondata S300, closed loop operation: cyclical leaning out at constant rpm
- Clutch Chirping??
- EG B16 Swap problems
- Wisconsin Tuners
- oil smells like fuel
- Timing belt, blown HG, no start...
- jdm vs usdm h22 crank bolt issue??
- Will this need to be fixed. Local machine shop drilled to deep doing an insert. SOB!
- Do these look like OEM replacement REV Titanium Retainers to you????
- ecu made for engine vtec peak & hold 345cc use on engine vtec saturated 280cc.
- valve chatter?
- B16 Question
- idle issue, the shop suggests a valve and timing adjustment, are they trying to rip me off??
- hondata s300 problems?
- Piston ring end gap question (My ring end gap varies)
- so what do i use with my chipped ecu
- New Shop in Ohio!
- removing head
- HELP!!! 89' CRX W/ D16Y8 - STUMBLES ON ACCELRATION AND NOW WONT START !
- obd o wiring help? 88 Crx Si to 91 Crx hf
- Obd0 Obd1 Obd2 TPS, $ Map Sensor plugs
- any issues with t belt(cometic .120" head gasket)?
- URGENT -- crower cam - degreeing
- whats a code 20
- b16 tranny - Where is my Reverse Clip on tranny? (searched)
- im not crazy, my car is seriously throwing code 32
- Valve Cover Breather Issue?
- changing syncros
- Assembling head
- 92 civic idle bogs & stalls when throttle is floored
- Need Odyssey help
- 4k Idle senor questions... searched
- JDM Sir-G wire harness conversion question, need help asap
- Any way to change the steering hub guts?
- tps
- First time JDM B16A swap??? anyone please???
- 94 GSR oil pan and header question....rubbing issues
- What's the best clutch kit
- Need something to tune nitrous..
- B-Series Transmission Disassembly
- Sporadic Code P0420
- help doing A/T b18b1 in A/T civic eg hatch
- NEED HELP WITH TACH
- STALE CEL (Check Engine Light)
- Smoke comming from manifold
- No Spark, could use some help
- Speedo swap theory
- ADJUSTING OIL PSI ON EXTERNAL OIL SYTEM
- injectors
- ANY PICS OF MODED OIL PANS FOR EXTERNAL OIL SYSTEM???
- Honda Fit electric PS pump swap?
- DSM injectors on an h22 for startup?
- Instrument Cluster fuse blowing!!
- AN tube nut/sleeve
- CEL 22 vtec??
- b16 a2 knock sensor
- final gear reverse bolt torque
