View Full Version : Tech / Misc
- starting off
- AC belt.
- How do you take out an air bag equipped steering wheel from a 93 hatch....
- Recommend a good clutch & flywheel for 99 SI.....
- **performance brake pads**
- **KYB AGX shocks... eliminate wheel hop?**
- need new O2 sensor
- spoon, toda a or b, or even skunkwork?
- Weird ALternator Problem
- Comptech Icebox with AEM Short Ram?
- Would I notice a difference ? ( RE: B18C1)
- How do I remove my CX sticker w/o removing paint?
- what tools do I need
- Does exhaust sound decrease after installing an intake????
- Repair carbon fiber?
- 87 civic, with carb'd d15
- Brakes!!!!!! my front brakes keep locking up please help!!!!!!!!!!!!!!
- Valve Adjustment Tool
- What is the cheapest upgrade for EK b16a any expert suggestion needed thanks.
- i snapped my throttle cable , please help !
- prelude tranny swap = integra tranny swap?
- Damn it...ABS light
- water leak in my block
- How to remove window tint safely??
- HELP COOLANT DISSAPEARING....cant find leak!!!
- Tightest Car Ever
- Raising redline
- Urgent help with clutch differences!!!!!!!!!!
- kinda OT: ctr crank gridle
- car won't start.......hit head while welding........NED HELP!!!!!
- Honda or Acura electronic parts catalog
- JDM 23mm sway bar questions...(tried searching)
- Immobilizer
- Know anything about Kamikaze headers?
- QUICK! How does the JDM header bolt up to the Testpipe? (pics inside)
- Is there some magic way to plug in an ECU?
- help!!!
- AEM EMS Forum now online!
- 95 LS in a eg having problems
- ECU P28??
- raising odometer or lowering odometer?
- B16A header in a DC??
- What torque wrench to buy?
- Strange rattling from the wheels...help!!
- Car pulls to the left ..but only sometimes ?
- Eagle Phone Number
- Installing Bushings?
- Tranny Problems(Clicking Noise)
- Cylinder shim thickness calculation help
- bolts same from gsr and civic?
- How to tell a jacked FPR
- My car is slower....powerloss???
- CRX - Rev problems
- my car is lobsided. what i do?
- HAving a problem with B&M Regulator!!!
- Benifits of Advanced Timing ? ? ?
- Computer Chip help...
- Will and automatic engine work?
- Highway driving bad for clutch break-in?
- high compression valves. Flat top valves. Good???
- wierd rev pattern occuring
- Anyone suggest a company for an electric oil pump???
- Bad idle, please help!
- clutch going bad??? help
- OEM oil fiters....
- cr in sirII
- EBAY buyer trying to rip off me the seller on ECU.
- brake problems!!!! HELP!!!!
- VAFC on civic problems, please help.
- Electrical Oil Pressure Gauge - HELP!
- hmmm stainless braided vacuum hoses
- regrinded cams
- Swapping b16a bottom end for b18c some help please.
- installed new headers, Need Help!
- bore size
- 5 lug conversion?
- Torque Steer on a Teg...
- Replaced TPS. CEL still on???
- Cruising Problem - Help please - Did Search
- skunk2 coilovers?
- A little help on installing an SP camber kit on my 02 TLS
- Cooling fan problems - please help
- lightening stock flywheel..
- Oil on spark plug cylinder 4
- VAFC Throttle Output issue
- JDM LSD for 5th Gen Prelude.
- How do I get the dist. rotor screw to face up?
- Real Tech Dudes
- i have the jdm dc 2.5" collector 4-1 header on my b16, and i need help
- whos has the ctr vs itr vs aftermarket cam dyno comparisons??????
- Valve Adjustment Specs
- 4G 5-speed tranny spinning in neutral?
- what the hell is code 13???
- Hondata users, help needed!
- idle issues?!
- 98 ITR headers question
- DEL sol doch vtech Cold air intake ..... fit a 92 hatch with a b18c5
- Check engine light > Primary o2 Sensor??
- Re: Suspension BS
- quaife diff. group buy still on
- Inside of my broken tranny
- deciding on motor and performance possibilities
- More cool ducting, this time from the Maxima I was working on...
- H&R Race Spring setup with Koni Yellows ???
- Skunk2 Stage3 cams on the street.
- parts question... A/F... help, thanks!
- Ok guys need help deciding which gauges to buy DIGITAL OR ANALOG
- SAFC and VAFC experts. please help!!!
- need help on H22 on accord??
- cut springs?
- engine is making a tapping noise
- car lags while driving
- Axle install?
- HELP PLEASE My car is Freaking - fuel problem
- Type R transmission?
- ECU usage.... P28 over p72 with B18C1.
- resurfacing flywheel
- another question
- fan and/or radiator problem, need help ASAP!
- valve spring retainer and keepers
- i have a question
- Need lengths of studs on block/head...
- diagnose this sound....
- New version of VTEC.......
- Anyone delete their sunroof and replace it with something else?
- Help 95 EX motor in 91 SI hatch problems
- Custom Turbo
- my stoopid shifter bushing question???
- i need help my car is an auto
- streetimports.com
- Where to buy header gasket...?
- Help! my B18C sounds sick
- valve adj. w/advanced/retarded cams????
- Anyone with skunk 2 chipped ecu???
- Engine Rebuild. USDM R piston into B18C1
- Link for Mod'd JG header?
- Transmission gearing, tire size, speedometer ?? Engineers welcome!
- CEL Light came on after header install, help!!
- p30 ecu question.
- Help! EF Si fuel/ecu/electrical problems
- i have the DC jdm 2.5" collector, now what???
- Test pipe?
- Airbag question
- Have anyone heard Sparkco spark wires??
- stumbling @ low rpm and 5800-6500k
- leak down test
- So how do you exactly reset the ECU???
- Rusted distributor rotor
- 91 HF with b16a swap....speedometer doesn't work problem
- Backfire when engine is cold at high rpm 6800+
- WTF is wrong with some of these manufacturers?
- high flow cats?
- pulling cylinders out without removing the crank?
- Damaged bearing, any ideas? See details inside...
- whats the stock idle on a 99 Si??
- air/fuel ratio setup
- Oil pan interchangability?
- Need help w/ electrical problem
- Attn: those who have a HELM's Manual for 92-95 civic.. Read on..
- valve cover removal
- Nankang NS-1 Radial
- Cracked Cylinder head B18C1
- coil overs.....or....lowering springs
- removing tps
- LS/vtec head
- Integra Type-R questions
- anyone dyno with LSVTEC...what cam gear and FP settin do you run
- Idle stays high after engine is warm. No codes.
- Engine Overhaul Parts
- where can i get a power enterprises timing belt online?
- What does the Venom 400 REALLY do?
- sputtering at low rpms...???
- air conditioning belt
- Honda Mechanics: $170 brake job worth it, or other option?
- Re-DYNO Necessary??
- exhaust question
- Help in Mississippi!
- Please....... Help me pick a Header?
- Acura Says My Stock Brake Pads Aren't OEM!?
- Neat Tire Size Site!!!
- Transmission Help!!!!
- Rebuilding engine. Nitrous Oxide help??
- newbie questions part 2
- atenna got stuck on my 94 integra any suggestion to bring it back down, its stuck up.
- Help, Does fuel Inj. Cleaner lower octane of cause detonation?
- Cam gears showdown......
- Engine Knocking
- Tacho feed wire
- can i keep power steering with h22 transplant in a ek
- CEL light again... code 45
- Shipping Weight of b16 + tranny/axles/linkage = ??
- What chip should i use?
- Vtec engagement
- header install?!
- question for engine experts
- gasket removal / mating surface of head ports... ?
- D-series Compression Calculator
- is it ok to not use a throttle body gasket?
- Revving to 8000rpm safely in LS/VTEC ?
- Civic Throw-out Bearing Ques....
- How Do You Properly Remove The Vapor wrap off a "gutted" door?
- Help diagnose my oil burning problem....
- ARP HEAD STUDS what fits on my b16a
- high compression NA motor ?s, need techs
- Couple B-series questions
- Changing plugs while engine is hot: Ok to do or bad practice?
- starter checks out okay on a bench but car still wont start *grrr*
- where'd reverse go
- 93 EX won't start.
- installing integra rods on d series motor
- some weird sh|t going on with my car, no idea what is going on with the idle??
- opening up the engine...
- 1/4 mile times and sea-level's???
- OBDI d16z6 in '96 CX..how to convert that engine to OBDII ?
- help, gsr fuel pump install on EF??
- Valve stem seal removal
- Si mc/booster or ITR mc/booster???
- WHy can't you bore a b16 out past 84 mm?
- code 91 (evap)
- Crated import performance motors
- injectors
- Did I break my differential?
- Check Engine light
- Max RPM stock rods D16y8
- CTR Pistons
- oil pressure vtec code 22
- Fair Price for a swap?
- Civic SI -to- LSVTEC changeover.
- AEM Cold Air Induction on a 2000 EX question...
- Retrieving ECU Codes 98 Accord
- H22's in ek civics?
- Full-bodied coilovers.........
- is it really necessary to break in an ACT clutch?
- B&M fuel pressure qauge
- D16 Cam Poll! :)
- Pic Request: 00/01 ITR Cylinder Head
- 97 Civic Wheel Noise
- Warped Front Rotors
- 98 Accord Chk Eng light...
- Tighnting AC Belt
- Motor Swap Decision Help...
- problems with rear left wheel after a bit of spirited driving
- Passinger side air bag removial
- ignition timing woes. please help.
- Fopr those that boost and spray
- adjusting idle but starts to fluctuate!
- 92 Accord electrical system
- Vtec
- Inlet Manifold
- car dies and has a hard time starting!
