View Full Version : Tech / Misc
- PROBLEM STARTING
- Car running cold?
- PISTON TECH QUESTION
- Clutch problems (240sx/Skyline related)
- Lowering Help
- Problems breaking in new motor!
- CLUTCH PROBLEM "HELP"!!!
- refill plug tranny b16a2
- after shock install. the front driver side squeeks when i slow down..
- best cam gear on market? lightest?
- 22 or 24 mm crank snout issues
- Please help with new motor
- Gear ratio gurus:: question about the B16 cable trans
- so i have a pr3-3 head
- LSD HELP?
- Need advice running super rich
- damn the knuckles......
- MoTeC users...
- Tranny guru's.....tell me what you think of this gearing setup......
- Cold? air intake
- JDM ITR swap - axle q's
- zc motor
- Possibly a dumb question
- P84 chipped ecu
- p72 ecu for H22
- No spark?
- 16 valve 1.5 cam broke need help new to honda's
- how do i install a aeromotive a1000 fuel pump
- o2 sensor question
- sound
- Could this be a grounding issue?
- Hondata Emulator Question
- wah is p75
- Modifying the head for a more efficent burn? Popular Science article.....
- blown shock? (agx)
- Removing Lower Ball Joint?
- OBD who?
- Tranni problem? Need help
- JDM
- Ever heard of a Toyota Corona?
- ITR fuel rail.
- craftsman screw extractor
- speedometer and tach don't work
- JDM SWAP PROBLEMS
- skunk2 coilovers
- link request.....gear chart calculator
- I NEED A QUICK TORQUE SPEC
- Fields vtec controller VS. Apexi VAFC
- need help with tach...
- Hondatas benefits from switching from OBD0 to OBD1.... is it just the o2 sensors??
- Fuel Pump
- autozone cv boots any good?
- dual point conversion..
- HELP on wireing up DC2 HID headlights.. !!!!!!
- erase engine code?
- I think this belongs in here. Question about tires. take a sec please.
- B18C1 w/ LS tranny? Gearing too tall?
- need new distributor... has anyone bought from Honda Acura Auto Parts?
- Does anyone know Ford Escorts?
- where can i find the spec of a h22a?
- how does VTEC differ from other variable valve timing setups?
- moroso oil pan Help
- I have H22 Civic, needs some suggestions..
- GM synchromesh bad in long run?
- g3 Integra have trouble starting
- TYPE R Crank in a ls block??
- which timing belt? gsr block/b16 head
- chipping p72 for uberdata
- signs of a failing vtec solenoid maybe?
- Chicago HT'r in search , white EG hatch w/integra interior b18c autocross guy Northbrook
- How Are Stock Ecu Cars Without Any Management Tuned on DYNO?
- Oversquare B20
- The legendary 3rd gear synchro grind
- problem after changing head
- STRAIT PIPES ON MY 2002 5.9L DODGE RAM 1500... OFF TOPIC BUT LOOK REAL QUICK PLEASE!!!
- 87 Accord 4 wheel drive conversion
- Hose & Pipe diagrams??
- For all of you with built motors?
- Help.... Washed car and now it won't start
- I swapped out my azenis and now I dont have wheel hop.
- oil in exhaust port..please read
- JG IM and Idle question..
- what short shiter to use on 90 CRX Si with B16a and S1 tranny?
- Need help with smog "test only"
- are my cams b18c1 or b17a??
- B16a misfiring...already searched.
- verify ITR exhaust cam??
- Question about the intake
- for those that chipped p72
- civic 2001 LX Coilover/spring installation Q?
- Does my Compression sound fine?
- Bad ECU?
- Leakin gas with S2 IM on LS...?
- Autometer in dash speedo?
- skunk2 launch kit
- Test Pipe, Good Idea, Bad idea?
- Main Bearing bridge/block girdle
- trouble code
- Loose rockers....help please
- distributors ?!?!?!?!?!?!?!?!?!? please help
- washington chippers
- fix it ticket for exaust
- B20B/Z tech Question
- degreeing your camshafts
- d16 or zc turbo swap!?
- 1997 ITR#122 Gets three rolls on the Dyno Jet: 56K you are warned!
- Injector problems
- HELP Suspension Technique rear sway bar on Integra!!!!??????????????
- non detergent oil bad for cams?
- completed my swap now im running rich
- HOW MUCH IS TO MUCH?
- broken rear strut bolt, BOTH!!!!
- Hondata/Code 16 - Fuel Injector
- bead blasting
- i can t downshift
- b16a block b17 mians
- Cheapest Wideband o2
- 0bd converter
- Car Won't Start
- friends not so fast car
- Uberdata problem...possibly my wiring
- where to put this hose on a 93 civic ex with a b16sirII swap?
- h23 accord will not start
- SOHC OBD2 Wiring Harness Pics?
- searched found then lost/d6 jumped to a4 then to vtec silenoid
- Quick and stupid question about injector clips
- Please Help! CAS problem!
- rebuilt / used 1980 civic 5 spd trans
- lookin for apexi power fc tuner in southeast
- ecu help (big pic)
- installing motor mount inserts
- Tried to go open header.....Car will not run????
- cheap kaaz...
- B18b Oil Sensor reThreaded HELP
- axle on jdm itr 1996 4*114.3 ? 32 or 36mm ?
- Help me with this funny noise!!
- D16A8 cams?
- Bypassing the FITV???
- CTR catback with High flow cat
- are small amounts of dirt a real ememy to an engine?
- B18a Timing Setting
- Im in a bind, installation pricing...
- cam for mini me swap
- need advice on salvaging motor from my car
- need help changing from TBI to EFI
- Are balljoints for 88-95 Civics the same?
- Tranny related question
- tranny housing bolts?????
- Main caps/bearing question.
- water pump leaking - chevy astro
- instaling a auto meter electronic oil presser guage on a b16a1
- Cel Code 10 or 1, how to tell, IAT, what?????
- Storing car artical
- need help with window tint removal??
- Where to run vacume lines when using STR T/B with no vacume ports and Victor X mani
- caliper brakcket super hard to take off..
- Help me find a home for these connectors???
- Oil ring filing
- ex calipers on dx
- NOVA Mechanics? Steering Rack and Power Steering Pump Replacement?
- ls/vtec....why plug oil passage?
- Datalogging / Tuning software on Mac OS X
- Are there any REAL techs who may be able to tell me...
- is it necessary to aggressively set your timing to the verge of knocking??....
- which tie rod??
- PROS AND CONS?????
- ECU pin part number
- Valve adjustment help??????
- ls/vtec question
- b20vtec w/ITR head
- GSR Timing Ghost! Help Please!!!!!!
- brake question on a hybrid
- Vertical marks on cylinder walls
- HEAD BOLTS STRIPPED HELP!!
- How to set distributor to sixteen degrees?
- Crank case breather systems on models?
- starting up problem
- hard time restarting b18c5
- Running B20vtec w/ GSR ecu?
- I can not get shifter into rev
- can not shift into rev.
- Maybe a stupid question but
- EFI PMS or GReddy Emanage?
- Using a PS rack and pinion on a Non PS rack?
- Transmission Help Please.
- seals for my engine
- ball bearing t-70 .81ar on gsr
- ARC intake Ques???
- Bad allignment due to tie rod??
- car stutters at low rpm's and idle
- vtec profile specs
- axle clicking...good for track?
- CVT Transmision draing...
- help with engine light
- car wont stay in gear!?!
- Injector Sizing
- Suspension question
- MSD BTM 6 and HVC coil install
- Something VERY weird just happened.
- Head Drawing.
- intake manifold question
- Which cars have a 2.25" donut gasket for the stock exhaust??
- 97-01 Prelude H22 TB Question
- d16 ... v tech not workin
- Prelude suspension on an Integra.
- 94 accord engine replacement (question)
- valve lock angle
- Post cat O2 sensor endlessly sending out P0138 high volts error
- spun cam bearing head questions
- prelude keeps stalling out
- Used 403 cams install...any special prep needed?
- Need to pass inspection,please help NOx failed
- please help with idling problem!
- Help: Need to know the final gear ratio on 99-00 Civic SiR...............
- converting b16a to 94 del sol specs. pass CA ref. HELP!!
- knocking noise from engine????
- Emissions help needed *Long but need advice please help*
- tranny swap in so cal area
- gear ratio's
- helms manual
- combustion chamber
- Megan Racing header gasket, EP3
- Paddle shift?? anyone know about it or tried it? i did my searching
- question....
- Is my Timing off
- rod bearing clearance to lose???
- 00' GSR ECU (P72) in 98 civic?
- Quick Vtec question?
- what is this on the valve cover
- how do you tell if an ECU is for auto or manual?
- Which ecu and harness needed???
- How much oil would leak if ***URGENT***
- Stupid Brake Question...
- SOHC obd1 distributor on obd2 dohc motor?
- What size is this fitting? (water in/out on a wet T3 CHRA)
- Integra that won"t attempt to crank
- shift forks are the b series all the same
- i need help?
- ENTHUSIASTS I NEED YOUR HELP!
- rpm signal
- Autometer electronic boost gauge help????
- My Alignment Specs on 98 Honda Accord.......
- JDM B16 2Gen How do i know??
- Things to look for when purchasing a used block*Did a search*
- b20 in a '95 integra
- ZC Vtec head vs z6
- HELP! TRANNY/CLUTCH NOISE
- K24 92mm-95mm Crankshaft
- help identify valve springs!
- sputtering at low temps cold start
