View Full Version : Tech / Misc
- code 43????
- Need help with some suspension problems.
- I NEED HELP NOW (TONIGHT), my car brock down and i have to drive it tommaro
- I have a question...
- I hope none of you people are letting refrigerant into the atmosphere!
- replacing vtec oil pressure sensor
- JDM head on 94 si d-seriess
- how to tell if you have a leaky injector?
- 95 teg heater problems,no defrost!
- baffling code 67
- Cam gear question.
- How to clean coolant from oil/ block???
- How does a Fuel Pressure Gauge Work????
- h22 swap info into 99dx2dr
- Winter beater= no heatercore..solution?
- Fuel preparation for first dyno tuning session
- fastbrake question
- how to take off a stripped lugnut
- A temporary cure for bad ring lands or burning oil (blue smoke)!!
- loss of powere at high RPM's
- Anyone live in the PA NY NJ area who wants to help install a JRSC on a GSR ?????
- Crower titanium retainers for B16A what # what the hell is Spring coil bind
- Headers
- Compresion tested in the high 200's?!
- Need Help QUICKLY with two Engine Swap Questions: EVAC Line & Vtec Wiring
- Phantom Grip ........... Pros & Cons ?
- Is the RedLine oil good for Honda engines???
- Low Gas Light not working
- tick tick tick
- HELP Diff Bearing HELP
- Will I pass emissions with crower cams??????
- Strut Bar Help!
- question about arp head studs
- skunk2 stage1 or 2
- code 14 (kind of long sorry)
- Tein assembly problem. Urgent help needed!
- horrible idle when cold
- fuel pressure is too high
- stuck in 4th gear
- Exhaust Help
- car runs bad , know why???
- GSR intake manifold Install??
- GSR lsd
- if my o2 sensor is messed up will my check engine light come on?
- how hard to install FPR and FPG
- Which lowers the car more??
- Speedo dies and Vtec dies(together) whats up?
- Do I need resistors for a MSD Blaster SS coil?
- Exhaust question for EG hb??
- b16a2 crank
- ignition coil question
- need answer quick!!! I have OBD1 (1 o2 sensor) getting DC jdm 4-1 header.. 2.5 carsound cat... Shou
- Adjustable Cam Gear
- Changing a DC 4-2-1 header to a JDM DC 4-1 header? Is it worth it?
- Honda Prelude / Type R engine swap :|
- bs or not bs?
- Which plug is the TPS on the DOHC ZC?
- Has anyone had an oil pump go bad? Why? Aftermarket crank pulleys?
- removing head bolts?
- s2000 clutch
- When taking off hondata, does ECU need to be modified to wrk correctly again?
- Spoon SW388 what is it made of?
- Crossmember Question
- trying to pull codes but its not working
- How to ID 2001 ITR cams
- Head Gasket Size
- difference between GSR cams & CTR cams
- injector resistor box
- Question about helms manual??
- Action clutches; any good?
- Question about rod ratio on D16Y8??????
- BORE and hone B16A???
- Stupid question about pistons....
- Lowering....is a camber kit/allignment kit necessary?
- Question about Jun Type 3's.............
- Setup I'm looking at....
- Will this setup do the job?
- dropping car
- Apex-i super spiral header???
- high mileage cars
- AEM V2 New Cool Air Intake!
- light wattage question (did i spell that wrong?)
- B16a,B18b, or D16
- setting the VAFC for 92 Civic EG
- im truly truly tired of stupid people
- ls motor dead
- itr tranny to cable
- VSS questions
- IDLE problem with a chipped p28
- Oil's
- Idle Issues....
- chip my p28?
- keep gsr or get ls/vtec
- The two Black wires on the 02 sensor
- all motor
- Lets all ground our engines correctly! ~Together now~
- T-Belts and Deck plates
- What size bolts to use for 91 LS Teg Seats?
- Can stock GSR fuel pump hold up to JRSC with VAFC???
- Head Gasket Removal
- Anyone using their spade connector thingies?
- factory oil cooler removel?
- Valvesprings, retainers, and stage 1's - ?'s
- i need help with my swap...
- need help with fuel ?'s ASAP *HELP ME*
- Need to prove my friend wrong...All the fast N/A guys, post here!!!!!!
- knock sensor
- Check Engine Light/Intake
- Accord Seats in an Integra ?
- weird chit
- key chipped
- Converting to OBD1 ..........
- Hondata has a new s200 without full throttle shift.
- Key switch connector for TT
- Open Header at the flick of a switch...cool!
- JDM ITR rods
- car is idleing weird
- still having a problem with a high rpm hesitation
- Suggestions on ALL MOTOR power
- Distributor
- I converted DX to ZC, Car won't start
- Good valve spring/retainer kit to go with Crower stage 2?
- engine won't start, getting fuel and spark, what's wrong?
- Rear drums for HPDE...
- is the key chipped
- Toda Cam Gear Question
- Too rich
- H22A Erratic Idle Surging PLZ HELP
- Ls rods in D-series motor.
- what the f*($ happened to my intake manifold?!?!
- help! spoon cam getting flat spot ..exhaust 1st cylinder!
- Please Help!!!
- 96 hb LSVTEC HELP????
- K series oil filter on a B series motor
- i want to buy the ff... help me guys
- Question about REAL Spoon SW388 16"
- dynoed my 96 jdm type r with skunk2 stage 2 cams.. should I have higher #'s???
- valvespring retainers?
- how to tell if i have a ctr exhaust cam
- JDM B18C tranny question ...
- Ground Wires (more horsepower???????)
- cam gear settings????
- What kind of spark plugs for GSR w/JRSC
- Do u have to buy a fuel pump wit the JRSC i have the VAFC to tune though
- Where does a b-series get its air to idle?
- how EXACTLY do you remove the Cruise control panel on the steering wheel?
- Rear suspension problems. Please help!
- Its lowered now what about an alignment??
- downshifting and throttle blipping
- How to stop the damn squealing when i start up my car
- Speedo stopped working???
- coilover dilemma....
- How thick of oil should i use in GSR w/ JRSC
- scored crank
- HELP!!! Will rotors and pads for a 2000 Si fit my 1992 Hatchback Si?
- B16A Tranny question
- requesting pics of Erick's racing Throttle bodies
- Should I pour oil in the combustion chamber?
- non-vtec b20>>>code 45
- HELP Please! Walbro fuel pump, no start probs
- crankshaft pulley question
- Help Before I waste Money on part (please)
- ecu differences
- valve seals need to be replaced on my b18c?
- ECU's Auto - Manual (the same?)
- Anyone have ecu pinouts for a 2000 B18B?
- Fuel Pressure Problem
- Hunting idle....Some fixes
- Can i run JRSC with new stock integra clutch?
- Car goes lean when warming up...
- N2O Dry VS Wet?
- what would cause this...o2 sensor problem
- ATS Gearing
- immobilizer
- Switching Distributor w/o messing up timing?
- when engine is cold, BRAKE light is on.
- Got a B18C bottom end.. what to do now?
- How to check for bad LMA'S
- Spark plug wires stuck!!!?
- Salvage value on 97 Type R?
- EMS for newb wannabe tuner...
- Help! Rotors do not spin straight...
- Carsound cats on ebay? Are these the one's I should get?
- tach not workin on 2nd gen teg
- weight difference between sohc-dohc???
- what kind of power?
- Good JDM recyclers?
- TB Suggestion
- gsr brake upgrade!
- dual spring coilovers
- b16 valves in a gsr head?
- Help me with a stripped tuner lug nut!!!!!!!!!!!!
- Made some angel eyes. my how-to and pics.
- 15 x 7 Racing Hart CP-8's ****OPINIONS Please****
- 10 point socket for clutch installation. what size?
- fuel pump location
- Muffler for a Test Pipe???
- fuel pressure questions and emissions
- civic tps to xsi
- B Series Fuel System Interest??
- optima battery in a 2000 civic?
- Replacing Clutch
- OBD0 > OBD1 distributor wiring
- block heights
- need help a.s.a.p. > high idle @ cold start
- What Offset for 17 x 7.5 ~ 1 inch drop..?
- Mini Me swap
- D17 Crank + D16 Block?
- Vtec controller....
- Oil pump ?
- Bulb problems?!
- b16 hesitates...
- question for you tech guys need to know ASAP!
- Wheel Offset and Handling
- d16z6 head on a d15 block
- 89 Integra PG7 pinout
- APEXi Super afc
- ITR 4-lug conversion
- battery relocation - downsides?
- Compression test on motor out of car????
- Transmission AT Control Unit purpose?
- Would 1990 240Sx rims fit on G3 integra ??? please help
- Why cant I post in certain threads?
- type r throttle cable? (part number)
- Best Brand of Nitrous
- Need a part #?
- intake air temperature wiring
- Spoon Cams..?
- What's the difference between a 2000 Si exhaust and a 2000 non-Si civic Axleback exhaust?
- Problems with ignition
- 98 civic ex rear disc brake conversion..............
- NGK spark plugs interchangeable?
- D-series Cranks
- afc hack with P&H or Saturated Injectors? please read or help....
- Wiring diagram for vafc....
- Informative write for non-Honda owners....
- carsound cat gutted?
- reduce weight were should I start?
- b16 went out!!??
- Info on Nex SR coilovers
- ls vtec, leakin oil from headgasket
- Got a P28 ECU for me????????
- motor mounts???
- Piston rings for ctr pistons?? curious
- problems with engine??
- Oil leak, could it be the headgasket or a warped cylinder head?
- obd1 p72 and vafc running into big problems!!!! help
- Best Trany's
- what signals does the ecu need to pulse ground to injectors?
- high idle and distributor retard all the way
