View Full Version : Tech / Misc
- Injectors
- How to fix a warped trunk board in seven steps
- Identifying Connecting Rods
- Dry engine
- will a 4 door gas tank fit on a eg hatch
- brownish/blackish sud in Dizzy
- Hazard Frought tools...
- Car Cranks but wont start then I smell gas
- Help with bearing size k24/eagle rods
- what alternator do i need? my car is a 98 civic si with a b18c (jdm engine) in it.
- HELP: Engine Cranks but wont start
- NEED SERIOUS HELP!!
- Nitrous help
- Oversized rings with standard size pistons?
- Help with wires
- Turbo Del Sol B16 dies under "load"
- help calibrating a s2000 cluster w/ speedohealer
- Weird oil pressure issue! Eeek!
- fuel delivery proplem
- S1 tranny and LSD need help
- What's the current price of complete engine swaps?
- piston to valve clearance degreeing cam
- B17 knocking need help
- Need help ASAP Vtec problem
- ej7 question? confused.
- ELD Electronic Load Detector test
- Boosted b18c1 rebuild
- Fog Lights: Where are my color choices?
- Unusual problem
- ls bottom end rebuild problem
- Noise after closing throttle at cruise
- just wonderin?
- Loosing fuel pressure.
- 1989 crx g23 axle length
- Melted bearings on crank journals, TOAST?
- lsvtec compression test results inside, need to worry?
- OBD2 distributor plug on OBD0 harness, OBD0-OBD1 ECU jumper harness
- No Brakes
- d16y7 to d15b swap need help
- question???
- spark plugs for lsvtec?
- 00 civic smokes alot at idle and under load
- Ebay rebuild kit (link) any good ?
- Oil pressure sensor and Vtec oil pressure sensor
- battery relocation trouble.
- 99-2000 civic hvac controls plug and play into 98 civic
- Gauge Cluster fuse keeps blowing (95' Civic HB)
- Prelude Jerking
- Cam shaft pulley mounting bolt broke
- 97 civic z6 block/y8 head huge hestitation problem
- 2.5 exhaust piping kit
- D16Y7 knock sensor
- I have an issue relating to my battery
- 96 civic ex No START!!!
- Jeep Shifter Extension for Honda
- MPG drop on 3.5L V6
- iac valve help
- Need help, blew a fuse and now my tail lights and guage lights dont work.
- HELP WITH B SERIES COP CONVERSION W/ K SERIES COILS
- Diagnostic tool Question
- California Emissions Question... Please help: Smog tomorrow again
- Bolt-in or Weld-in? Any ideas?
- Manual rack issue EG
- 2004 Honda Pilot no air in front vents. DTC codes J & N. PLEASE HELP!!!!
- Trouble code 15 on OBD1
- whats the name of this vacuum valve?
- Confused about fuel octane need guidance
- Power Windows Sticking ... is there a home remedy?
- OBD2A harness question, LS/Vtec-T on EJ6
- Ebay distributor td22u?
- rhd typer into eg
- Speed meter not working
- Help with condenser fan
- 205/50R15 Up front , 195/50/R50 in back?
- Fuel pressure regulator
- Gas tank cleaning sugestions????
- Power antenna??
- check engine light
- Turbo fans in Air Intakes. Fad or Real?
- B18a1 swap 92 civic hatch HELP!!!!!!
- B18C W/Hondata S300 Misfire/CEL issue
- is a/c condenser safe to submerge in water?
- Quick distributor question (OBDII JDM)
- K20A2 to K20Z2 parts?
- Mugen Dry Carbon spherical 6-speed shift knob
- Obd1 inj oring size???
- Did they stop selling ACL Duraglide Bearings?
- Does The D16z6 Vtec use a purge control solenoid?
- B18 TB rotor and spring on Y7 TB?
- can't take off skunk2 knob> locking nut stripped
- identifying b series cam help
- Cam help
- Big hep please no vtec
- HELP PLEASE OEM REBUILT BURNING COOLANT
- exhaust question.. which muffler? yep another
- aem cop ????
- Allen head plugs on timing side of motor, leak?
- Modified Car Insurance?
- Oil pressure readings
- Minor problems starting. Help please.
- d14 and d16 piston
- Can someone tell me what fuel rail is this
- 2003 Odyssey Blinkers and Hazardsdont work
- 96 ex issues idling and accelerating. help?
- Engine serial number
- Exhaust system fitment question
- Steering wheel alignment
- Steering wheel bolts thread pitch
- MPFI conversion help
- Dz16z6 won't start back up when it's hot
- Tell me ... do you think he is full of malarkey?
- fuel pulsation damper screw is missing
- wont rev right?
- riddle me this honda experts!
- Swapping valve springs from IN to EX
- 2007 Si cluster into an EG?
- purpose of extended wheel studs and lug nuts?
- Engine revving - load or no load - why a dyno?
- Recreating the B16B?
- 2000 ex pours out white smoke
- help with passing ca ref
- s300 in obd1 auto ecu
- 97 honda civic ex d16y8 help please
- Air Pressure in Cooling System
- Ef sedan Jdm auto cluster into usdm need wiring help
- Running rich GSR swap ?'s
- Honda CRV 2007 Stereo
- EGR at idle ???
- Both 'ludes down at once!!
- What do you think happened here H-T? CAM Issue long rant/read
- K series Fluidampr on f20c
- Poormans type r help!!!!!
- window sills or rubber molding
- Check Engine P0497
- ACs effect on MPG?
- need help with lsvtec
- help finding fittings for my oil sending unit
- ASU Poly SAE Baja
- Reduced vibration replacement bushings for Hasport motor mounts
- Overheating..
- GSR rough idle issues after missed gear...
- how to check lma's on a D16z6
- Timing belt tension
- Driver side window wont work
- 1994 Honda Accord. Not starting.
- How to test injector resistance at ecu?
- Builders help Torque reqd to turn crank estimate
- 94 civic ex sudden death
- H22a4 to F20B
- need help finding fitting adapter for boost gauge
- Low battery voltage under load
- MISC PROBLEMS!!
- 97 Ex Sedan B20B Swap...
- 95 integra, fuel pump wont prime
- k20a2 runs shitty or not normal...
- Troubleshooting 1992 Accord DX. Died/won't start.
- Ecu fried HELP...?
- TPS voltage problem
- vtec not kicking in?
- idle problem
- civic eg turn signals work but hazards dont?
- H22 Loud Valvetrain Noise, Valve Adjustment is in spec, Video
- Can this head be fixed?
- Stuck with crx battery light and upshift light and gas gauge
- Can someone please tell me what this manifold will fit?????
- Throttle cable problems
- d16y7 cel po505
- Tachometer stopped working
- swapping z6 for a k24?
- Gsr spun bearing?
- the best high reving cams
- 96 civic steering column into 92 help
- connecting rod with no side clearance
- B16 cranks but won't start.
- please help! ticking head!
- Any way to identify b16 oil pump?
- Stumped, 92si with 00itr problem *searched*
- Head Machined and every head bolt "creeking" when torquing
- QUESTION ABOUT BODY SEAL KIT
- CR-V P7H AC bracket info
- Helicoil HEL1130 Head Bolt Thread Repair Kit
- The possibility/utility of using OEM d-series Civic fuel pumps in a B-series Integra
- Wiring troubles
- distributor ckp/tdc/cyp harness differences between vtec and non vtec?
- 95 DB8 overheating issue
- lowering coolant temp.
- 98 Civic Ex starting rough and bogging down / losing power
- Rust on valve guides?
- help again....lol
- *****Identifying this "LS" crankshaft?*****
- Sneaky Alternator Swap???
- Help with 2003 civic turbo k24 temp signal
- Toda cam gear center bolt
- Help with blowing 20amp Wiper Washer Fuse
- no vtec
- D16z6 wont start!!
- Precision dead times
- 05 Civic EX Temp Gauge making me CRAZY!
- Suggestions for middle muffler?
- question regarding oxygen sensor wiring
- O2 sensor wire short macanic say have to replace trany and alternator
- EK3 D15B Loom & Ecu EF Question
- Is this normal???
- B18c1 clearances?
- timing belt changed, now its knocking
- Car rolls over but wont start- main relay is OK, ECU is bad?
- Rebulid or swap
- why is supertech products so much cheaper than other brands?
- Over heating problem in 89 Honda Civic DX
- H2B Header
- T1 cam trigger, AEM, COP?
- crv not running!
- loud tick on engine after swapping my b16 skunk for a JG custom mani. any ideas??
- How to make sure I get a B20B w/ 147hp
- Is my ecu bad? no spark no dome lights fuel pump dont kick on already changed main re
- 6th gen Ride Height SPecs STOCK
- pro comp vtec head
- electrical problem 95 civic need help
- sohc dizzy on dohc motor help!
- PLEASE HELP!!
- 6th gen coupe- Passenger window stopped working
- Losing Oil Pressure and losing antifreeze after warmup
- R-134a
- SiR Cluster Problems!!
- resistor box ?
- Alternator: Rebuild, Aftermarket, Performance?
- Where to get Honda Intake Flange
- Can I use aftermarket valve seals with OEM valves?
- Stripped oil pan hole
- GSR rebuild help!!
- Short Ram VS Cold Air Intakes, what is best?
- Help me save money? code 1 and 9
- H22 Reverse head Odyssey
- full blown kit top is leaking anyone elese had this issue
- CRV bogging down for a few seconds after starting up...
- B16A EF9 underneath front end problems
- 96-00 Civic Dx hatch o2 Housing
- 1.7L D series 01-06 coil pack dwell time?
- Need help figuring out what this part/thing is called
- JDM tech, orlando
- Engine overheating after shutdown
- b16a wont start
- Need help car won't start!
- VMS racing cam gears
- Ignition coils & pigtails / connectors
- ek civic manual transmission ignition question
- what block would be better for a turbo build?
- GSR swap - Rough idle, hesitation at low RPM, and slight smoke from exhaust??
- rebuild/turbo
- ordering rebuild kit
