View Full Version : Tech / Misc
- trying to pull the clutch; but trans won't come off
- state ref
- getting head milled, question of prep?
- which ecu do i use?
- PROBLEM!!! with DIY drop-in using K&N RU-2820 :(
- is it okay to use a fuel line hose in place of a heater hose?
- Moroso Oil Pan Efficientcy
- Moroso Oil Pan for B Series - Street/Strip application
- strange idle problem, help!!
- Rubber valve seals??
- i formatted my laptop and i forgot something, crome
- No Vtec??
- I need help with the removal of my dash.
- need dx to si conversion diagram
- How Strong is the CRV Trans/Rear end?
- Engine Building Help B18B
- exhaust question, need help
- Urgent help.. problems after engine bay wash
- Oil Pressure Gauge - Electrical Or Mechanical?
- Adding airbags Please Help!!!
- No pressure on clutch..??
- Seattle--NEED harness
- thrust washers.... how to install?
- b20vtec back to b16
- modifying valve cover
- 3500rpm 80mph what trans?
- water damage gsr.
- immobilizer
- Cable broke inside speedo cable driver!?!?
- Help Fast!!! No CEL @ all (even for 2 sec). Tried different ECU.
- Install MSD Coil and Cap only, is it ok? (already searched)
- gsr crank ctr piston gsr rods setup???'s
- IS ADJUSTABLE FPR NEEDED WITH FMU and it the rumor
- In Search For a knock sensor for h22 got one for sale?
- Aftermarket Connecting Rods for D15B7?
- Rear Baring replacement on 91 Honda Civic DX?
- Vtec/Vacuum Question...
- replaced starter and battery still no start?!?!?!?!?!
- Who's using GSR shift linkage on an LS or civic w/ b swap?
- Can I use an aftermarket fuel pump w/ stock ECU / injectors?
- will h22 throttle body fit b16a??
- B20VTEC budget buildup - comments/suggestions? )Flamers must die!)
- HELMS MANUAL SELECTION
- uberdata questions on timing, idle, vtec engaugment?????????
- B16A Timing help/info needed
- Oil filter test????? which one????
- need to change tranny fluid in my Y1
- Idle surging, vafc install
- wiring question for vtec pressure switch
- Breather Chamber oil leak
- will an obd-0 tps work on an obd-1 motor?
- 91 Accord EX HESITATION ON LOW RPM'S..."FIXED" Twice by Cert Mech HELP PLEASE Still Not Fixed!
- Oil loss question.....::compression test results::........
- Boosted b16a, What kind of horsepower???
- v-afc problem?...need help
- ATTN: Florida people! Need help, will pay $$$ for your time and skills...please read
- which head gasket to use
- break in on GSR w/ new piston rings and bearings....
- Please Help, Problems with New SPEC STAGE III Clutch
- tuning noob
- SWAP HELP!!!
- can someone identify these pistons
- good exhausts for 99/00 SI's
- d16z6 edelbrock intake manifold question
- Does it have to be a Honda motor?
- How much of a compression increase with std size b series flat top supertech valves?
- automatic trannies
- questions regarding swapping into b16
- messed up my axle ... little help
- Friend's car got jacked!!!!!!thread link inside
- b16 manifold removal in crx possible?
- Help Identify JDM Aftermarket Retainers w/ Oversized Keepers?
- OBD2-OBD1 conversion
- pics of ...
- dohc throttle body on sohc manifold
- Is this bad, or normal? (spark plugs)
- re sealing of tap on head questions...
- Power strearing on a b18c swap... I need some help...
- cap and rotor
- which is it: clutch, master cylinder, or slave cylinder
- b16 head weight
- how many miles to break in a motor?....
- what honda belt/waterpump/tensioner will work on a ls vtec?
- Can anyone identify
- Name that 3 bar ? Who manufactures this...
- i need help w/ my ecu code. 'Uberdata'
- Problem with car running rich/lean, bad injectors?
- Muffler choices... My experiences. Kind of long.
- B16 timing belt loose and vtec intermitten
- rebuild or block swap.
- b16a j1 tranny issue
- Swapped a b18b1 LS into my 99 civic coupe and having problems. HELP ASAP!!
- Map Sensors
- A/C belt for a swapped 97 ex
- Exhaust for k20a ??
- cel 13 crank angle sensor how to erase (i searched with no result)
- IAC Valve
- spark plug probelm???
- Bad Ground?
- Soon to be frankenstein
- Ported and polished HP Gains?
- weird
- obd0 b16 misfiring need help please!!!!!!!!!!!!!!1
- Injector wiring / IACV Issues ** Please help me out.
- One Week Engine
- arp head bolts torgue question
- Difference in obd-1 and obd-2 b16 blocks?
- help... no start spart and fuel
- Omni power or crower valvetrain components? I'm stuck..
- LS-V-TEC QUESTIONS
- Clutch Break-in
- Is 82mm bore GSR possible?
- b16 parts in bare gsr block
- timing belt question???
- OBD-0 OBD-1 questions YES i searched
- quick question with cam gear tuning
- what compression
- A/C blowing hot, coolant?
- obd1/obd2 wiring question
- problem with gauges
- HELP! LS/VTEC front main seal question... LS/B16 seals the same??
- CRX SI no start
- Post your COP setups and what was used for them.
- Door jammed!!!!Yes I searched
- vtec solenoid ?
- no power until 3500rpm?
- Car doesn't start up. V-AFC doesn't work. Bad main relay?
- Clutch application.. 1st gen B16a cable..??
- MSD 6A ign, and blaster coil install.
- What valvetrain does this look like?
- #2 cyl fouling plug, I think we got a bent valve? warranty?
- I cannot get datalogging to work with Uberdata no matter what I do. Anyone have any suggestions?
- Car wont start - need help
- do i need a relay or fuse for a switch? nitrous related
- Odd CEL Codes
- rocker assmbly question:
- Neuspeed Exhaust question
- vtec solenoid help
- Engine shuts off, V-AFC shuts off, everything else works
- what do i need to have a rolling chassis?
- Cruise Control Removal?
- sputtering or possible misfire at low end
- H22A engine swap. Wrong Ecu?
- will this engine work ?
- Help!! TPS Question!!
- Is an Oil Cooler needed for high compression LS/VTEC engine ??
- membership help
- Phantom Grip limited slip?
- Pinched a hose installing head...still have correct torque? need help...
- stumped...cant seem to tighten timing belt
- Need help ASAP.. tranny problem
- CTR/00-01 ITR Exhaust Cam ID
- hydrolock n shit
- Overtorqued Valve Cover Bolts
- Port and Polish Q
- D15B7 distributor
- got burner and datalogging stuff, having issues...
- Water Temp Gauge
- P13 stock fuel map
- Resonator Vs. Hi Flow Cat
- d16a9 grief..................help
- Where to buy a harness for the Walbro 255 fuel pump?
- Difference between GReddy's SP2 Exhaust and their EVO2 Exhaust?
- Electronic HorsePower Readers???
- What is this called? Radiator Fan
- Exceleration prob
- OBD2 Scan Tool Software: Freeware
- Hondata S300
- AEM cam gear necessary for me?
- Nology Wires?
- Radiator blew ... any easy way to temporarily fix?
- Can you tune without a Wideband O2 sensor ?
- High Mileage High Compression test.. Rebuilt?
- Cool and Must Have Tools....!
- code 21
- SLIGHT cold start main rattle
- best place to get an engine? help please
- Pros and Cons of UnderDrive Crank Pulleys
- Help with a couple of CEL codes
- always getting power
- trouble choosing clutch!
- Crank Pulley broken!!
- 2.5" to 60mm exhaust?
- aem cam gears
- anybody knows what size is the oil sending unit????????
- IAB ecu question...
- Possible Blown Headgasket: Symptoms
- DIY engine tuning
- jsut got a exedy HD clutch kit for my d16a8 EG. The OEM disc looks...thin ?
- is this a retarded cach can setup???
- Valve Adjustment Help!
- 89 crx si cluster into 88 civic hatchback dx
- (((Replacing Ring/pinion Please comment.)))
- something might have fallen in my spark plug hole.
- D15B2 to D16Z6
- Flywheel
- cf hood thread is stripped
- OBD2 sohc harness to fit on an OBD2 LS dizzy..HELP ME ASAP!!!!
- PLX M-300 Wide Band Problems
- stalling please help!
- Hondata Registration Code
- cel 3
- B16A2 boring
- new motor worth it
- any truth to this little black box?
- check engine light on?....NEED HELP!!!
- replace head studs???
- Issue's W/ B20 Swap. Help needed?
- d16z6 parts into a d16a6???
- clutch opinion
- overheating problem. stumped...
- Vtec at 4500 after Vafc2 removed?
- Compression test on new motor- 175 150 150 100
- Problem with titanium valve springs&bolsters
- LSVTEC engine problems. Almost dying.
- Vtec Controllers?
- ignition switch problem?
- oem gsr valve springs upgrade on LS?
- Wiring 2nd Fan (condenser fan) to mirror radiator fan with relay...help? :-/
- Zex cam for D15b7? D16A6 or D15B7
- Possible trany problem when swaping in built ls
- Anyone know if you can use a Civic/CRX ignitor on a DA teg?
- OBX Fuel Rails Suck Ass
- EMS Tuning Site?
- knocksensor..code 23. Help please
- TPS adjustement
- 74HC373 SOP
- Where do I find female connectors for harness?
- noob question for grinding noise
- someone please help if you have tech experience....
- header for b16/cams?
- For the TECH here, need help badly!
- I need a know good worikning stock p30 bin
- b16 misshift smoking in vtec rings?
- D16Y8 into DX hatch
- will d16 dizzy work on b16 head?
- Swaybar bushing install question???
- Noob advice on engine build
- Flywheel
- 95 Civic question on Tail lights
- got my civic tuned finally but still have some small problems
- i want to build a d15b
- Trannsmission Noise?
- uberdata tuning help!!!!!!!!!!
- P13 ECU Giving Me Problems. Only revs to 3000 rpm! WHY?!
- Gas Tank drain plug? Drag racers and Circuit racers welcome
- Car cd player stolen now blinkers and hazards wont work?
- Need help w/ e-manage support tool
- harbor freight air body saw
- Apexi'i N1
