View Full Version : Tech / Misc
- Need help intalling ITR rear sway bar on EK coupe!
- WTB Good set of rims and wheels for my 5g HB
- Miles Rollback?
- Car Stolen!!!!!!!....ALERT
- new Guage cluster
- Cams for ex
- Cooling a GSR in a 96 cx Hatchback
- B16 head on GSR bottom end
- Question on Dyno tuning... thanks!
- Help!!! engine problem
- Timming question car is missing after T-belt??
- Can I resuse the Head gasket if tq'ed down for couple days, but never ran?
- tranny help
- Question for all motor peeps???
- Whats the largest size object that can pass thru the oil strainer
- Can anyone tell me what this is, pic inside ...
- Two quick questions...regard injectors
- Need technical diagnosis - Ignition problem?
- heads the same?
- fuel pump...help
- lube for engine rebuild?
- 17's Weight?
- mystery marvel oil?
- gsr spoiler removed
- VAFC settings on a stock gsr I/H/E
- size of open end wrench for o2 sensor
- Need Help ASAP
- skunk2 chip
- Today im gutting my 94 dx out like a dead squirrel!
- car won't start after 4 days
- Headwork: re-break in engine, or not needed?
- Mugen front strut bars 1st gen vs 2nd gen
- whats needed for engine swap! h23a to h22a?
- what effects does ignition timing have on emissions
- Emissions on dyno?
- MAP again..CEL 3
- Help please.....Power steering?
- Q's about the JDM P30-900 AT ECU.
- aem vs. paxton regulator
- How do I correct my air/fuel mixture??
- what are the chances of water getting inside of engine?
- piston rings: JE vs. Weisco
- Aftermarket ignition and stock tach?
- Will 99+ SI rear section bolt up to 94+ integra?
- spun bearing. new block or rebuild?
- vtec malfunction?????
- exhaust gasket?
- wat type of intake
- vtec wiring to the ecu2?
- Putting a Block back together?
- how important to resize rod when installing arp rod bolts?
- Alternator Solenoid Fuse location ??
- HELP: How does changing the timing supposedly give me 15-50 hp?
- b series question - jdm s1 tranny with ats final drive and ats lsd?
- o2 simulator diagrams
- Header on 96 civic DX?
- installing cai
- Steering Problem Need Help ASAP
- ls vtec ecu question
- need some advice with motor building...
- ASAP what is the torque for integra axles????????
- valve adjustment tool??
- tranny problem, i think
- dyno tuning questions????????????????????????
- 32RWill these tires fit?
- Piston to valve clearance, thoughts on this before i clay the motor
- eek! 911, need OS rings!!
- PGMFI Breakthrough: OBD1 Datalogging on stock ECUs
- getting closer to figuring out b16 woes
- JDM Master Cylinder/Booster Will it work?
- head bolt tourqe spec.
- When i'm in neutral - not braking - I can hear the pads rubbing on the rotors wtf?
- B18B, B18c1, B18c5: are the valves interchangable?
- Swap info please.
- My H22a powered accord won't start, constant Code 3 and dead alternator/battery! Help!
- what wire off a 99 ls ecu is the secondary o2 sensor lead???????
- i want to see a pic of your...
- How do I install an automatic tranny?
- SIR suspension
- spark plug wires? interchangable?
- change auto trans to stick
- Any way to replace wheel studs without removing hub?
- 98 civic dx swapping in a 00 si b16a2
- sohc tips
- auto to standard
- 1.6 sohc to 1.8 dohc
- A'PEXi V-AFC causing problems
- parts from ITR required to make my GSR 5bolt?
- lowered car, now some strange knocking noise
- burning oil smell!???
- igntion/bucking and surging question
- Piston Question
- Alternator is stuck
- Heated O2 sensors
- As long as my tranny is out, general maintenance?
- Need some help with and electrical problem...
- time for a new clutch?
- somebody help! i have questions about a 91 civic
- ever seen bearings like this????!?!?!?!
- switching oil viscosity
- REdoing the whole exhaust system.. i need help...
- blown GSR block still good???
- Which cam is the best for a bolt-on D16?
- Do I have to resurface the block and head everytime I take apart my motor?
- puttin on head gasket
- b18b all motor questions
- anyone heard of suspension spec-rm coilovers??
- Skunk2 StageIII Cams vs JUN StageIII
- Removing Heat Shields: What is the final decision?
- Vibration
- distributer
- Funking Ass Idle
- changing pads without resurfacing rotors
- How high can i rev my b20???
- tune up?
- What are main caps??
- JDM ECU's Limited to 120 MPH???
- Clutch replacement in '90 integra
- Help me please!!!!
- Removing the Water Pipe on the back of the block?
- problem with brake piston. need help please!
- Spring bolt things that bolt together stock manifold to cat.
- For those of you who still ask....Auto to Manual....follow this link.
- JDM F series engine
- ECU plug pin parts numbers?
- vtec not working
- Alternators
- lsd questions
- what esle to change while replacing head gasket?
- trying to find wiring diagrams
- Tranny Problems
- LS driver side cv shaft
- Idle drops when a/c is turned on
- how can I test if my diff is bad
- Hondata guys look here
- installing aem cai on 97 civic ex?
- Magnaflow muffler, General Questions
- corvette vs. supra tt?
- Conversion from coil packs to Plugs and Wires
- HELP! My pulley fell off!
- Unplug O2 sensor? Help...
- are there different kinds of vtec solenoid for b-series.
- How can I make my GSR's VTEC pop louder?
- please help wut cat to use for my hatch
- WTF, i don't understand this......
- Crank Pulley Bolt Vs. Me
- How should my Autometer A/F gauge behave?
- ignition problem, please help
- what to use to block the pcv on the block?
- I NEED HELP!!! Electrical Problem.....
- which springs are for the front? and which are for the rear?
- headlight problems!! HELP
- Does anyone remember the web page for OEM acura parts it gave the part numbers!
- car wont start. Need help quick!
- Building a Aluminum Cold air box for a Ram Air intake
- Hub bearing on 97 tegger help me please????
- Difference between OBD1 & OBD2 B16a's???
- h20 Power: q's about water injection and water cooling?
- Overhead light will not work!!
- B16a(1st gen) not cranking...
- Euro Accord-R H22A vs. JDM Prelude Type-S H22A
- anyone know anything about DINAN chips for ecu's
- Parking Brake Light Coming On 1st-4th gear!
- Exhaust before turbo
- What can i use to plug an o2 bung?
- Headwork & JRSC
- Links to popular import suspension setups
- ITR pistons in b16a1 block
- Need help ASAP-Oil pan question
- semi o/t How to ship a engine block. Detailed pics inside
- raise CR in b18b
- ATTN: Vancouver/B.C. ppl, has anyone done a b16 swap ?
- loss of power to everything
- Pressure plate??
- Port and polish
- Wireing a P13 H22 ecu
- high compression on 93 octane
- Help: Want to convert my 91 civic from auto to manual
- ATTN: b18c5-eh2 just making sure about my rear discs/coilovers
- what must this mean? help techs
- Info on ITR catalytic converters. 02 sensor..
- Broke a bolt while removing it from rear LCA...
- Helms
- O2 sensors???
- frustrating check engine light.. light comes on and kicks it out of OD
- My Dyno Please tell me what you think and help me out
- Air conditioning help!!!
- type r mirrors
- Attempted driveshaft removal = trip to emergency room
- need help! 90 accord tranny swap!
- engine coolant tempurature sensor check engine light
- striped motor mount bolts
- Has any one any experience with these
- Want to get diff gauge cluster but dont know which one help!!!???
- b18b bottom need to make a decision.... N/A internals
- Cams Questions-Important
- ALL VTECS burn oil?????!!!!
- I got Tranny Issues... Need Advice
- VTEC controller
- Exhaust manifold from D16Z6 -> D15B7?
- B&M FPR & Fuel Gauge
- s2000 head or dc5 type r head on h22!!
- Good shop in the Los Angeles/San Diego area to do a auto to manual tranny swap?????
- H22 internals
- Can you adjust the vafc while driving or idling with engine on?
- compression
- rebuilding PS rack?
- cel help
- VTEC testing questions
- Building Motor
- Spring Length for Ground Controls, what is the significance of it?
- Are JDM B20B pistons the same as USDM B20Z pistons?
- New to forums, honda ect, new questions
- Automatic tranny, is it supposed to be flush with the engine?
- alternator
- how to?
- GSR harness
- Civic and Integra spring rates?
- Calling San Diego Peoples!!!
- VTEC selenoid
- Install EGT guage on GSR ??? help
- any1 got ashematic for a 0bd2 distributor or now the color code?
- What to buy from wrecked GS-R?
- Differences
- testing fuel pump??
- ecu fuse question!
- check engine light on steady
- cam install price?
- Do it's possible that my P28 is bad ?
- Quick Car vs. Car(s) Question
- timing
- speed sensor wire
- HIGER the Offset, the lower you can drop, right?
- injector question
- Engine back fire
- head conversion
- OBX hi flow cats??
- JUN3 Killers - HondaSaver US4 CAM Dyno Shoot Out
- New Cat Problem
- Flowrates.
- What size injectors, 270cc or 310cc
- How to duplicate vss signal? Which Guage Cluster?
- is thier a B21 in the 1st gen prelude ????
- what type of oil?
- for the pro's
- Can i re-use the 2.5donut for a jdm header and the exhaust manifold gasket??
- Icebox fitment in a B-series hybrid
- b18a1 checklist - do i have everything?
- Any other type of line to use for nitrous applications?
- How much can i tune the 1.6 vtech??
