View Full Version : Tech / Misc
- nsx calipers with what kind of rotors?? (searched already)
- Prelude won't move.
- B16 tranny
- well i have sprung a leak and am completely lost!!
- What nitrous kit to get?
- i melted my piston how did this happen,cant figure it out.
- GC vs. eibach
- no CEL light , but CEL code blinks when jumped.. READ on
- 1995 EX sohc vtec, Timing belt broke... do i need new head?
- MAP sensor
- B20 motor build planning...
- tire question for 17x7
- in major need of advice. please help
- HELP, fuel concentration problem!
- HUGE problem
- Why is only one end of an intake manifold open?
- B16A vs B18C?
- will a 70mm throttle body go on a S2 IM w/o porting it.
- Anti Lock Brakes
- toda spec C and idle..
- CRX wiring From DX to SI... Has anyone ever done this?
- Ignition Guru Needed H22A Swap no spark Please Help!
- I need pin-outs for an ecu
- my turn signal is acting weird...
- tranny bearing question
- Replacing a Tranny
- Will a DA radiator work in an EG?
- gsr long block or type-r short block??
- jdm 4-1 collector mod
- Field sfc vtec controller settings
- ecucontrol.com and uberchip q's..?
- Which is better mugen or spoon
- ecu code and resetting
- best civic
- Winsheild removal & replacement
- injectors size for following cars
- S1 TRANY sencro question
- wiring diagram
- ls/vtec problem????
- ecu troublecode/ EGR
- All Motor Route....Help! I tried to search..
- AF gauge not working?
- Complete spoon engine
- NGK Wires?
- Just a quick question
- GReddy TD05H-18G
- Flat spot in powerband...suggestions??
- need some dino #'s
- JDM Mirror Install Question
- Head gasket blown between #1 nd #2
- Type R delsol
- team Honda-tech vs. the nissans just aird on TNN.
- fog lights as turn signals
- I got my code for the Check Engine Light.... need help
- b20 with 12.5 Compression...sleeve?
- clanking noise in my VR6
- idle probs with type r intake mani and gude tbody
- CAI v's Short Ram
- oil dipstick ?
- any one tried the e-ram electric supercharger
- Need help Anyone experienced with Weber carbs & methanol..??
- what rods do i need for my new ctr pistons to work in my b16a1 block
- Ignition system worth it?
- 14.7 ?
- A new stepless VTEC
- how to make a ls v-tec ?
- can a bseries map sensor work with a ZC??????
- Not a Good Day
- weight vs horsepower
- how do i tell if i have skunk,type r,or gsr camshafts?
- Building a B18C1, any opinions or help is appreciated.
- Driving Impressions: 2002 Hyundai Accent
- What the heck is wrong with my suspension????
- Slipping AEM Cam Gears?
- Adjusting my Skunk2 coils
- God, help my stupidity....
- Need help puttin my head on my Si motor
- nos kit part question
- stock EG. engine question(PH12)
- Tack Instalation for stock 95 cx
- crazy uniqe electrical prob. maybe one of a kind?!?
- several problems after swap
- low oil pressure
- AZ emissions
- What's up with these shady tuning shops? No one has any integrity...
- B18A Rods and ITR pistons
- gas saving valve in gen2 integra?
- broken intake mount
- can you guys help me out with a Racing Hart question...
- pin removal tool
- Need pick of a Nitrous item
- is the d16y8 a good motor for a turbo?
- How do i get the code for the check engine light????
- Need a Hose pic!!
- contimplating the test pipe idea
- High Comp B20 running lean
- sohc turbo or b16... or ls-vtec with type r internals? questions
- Can any one tell me if the skunk 2 ecu's by pass the VSS
- building Y8
- Removing Tranny on b16a2 HELP!!!!!!!!!!!!!!!!!!!!!!!
- cracked rotor?
- Any JDM aftermarket headers???
- what hp gains from skunk2 stg 2 cam has any one seen
- jdm 5 lug Question???
- b18b turbo help
- radiator fluid problems
- Benson's performance machine what are your opinions
- Grinding when clutch is disengaged...(not "gear grinding")..tranny experts
- Check engine light?! CODE 32?!?!
- Help...losing coolant (90 civic si)
- H22A EG swap MAP TPS EGR please help!
- koni yellows with gc $500
- ITR trans in GSR?? question
- Y8 Cam buying...
- Is it safe to torch drain bolt washer to reuse? Honda wants $4 for washer!
- SRS system problem, anyone?
- AEM CAI for Type R on my EJ
- FPR Gauge Problem. easy fix or no?
- Holy Crap rebuild expensive!!!!
- all spoon accord+h22a= why cant i find a cold air intake...żżżż?
- I searched but cant find this???
- whats best piston 4 b16a2?(upgrade)
- car won't idle...
- Has Any one used this combo...b18c+p30+B16 head , whatcha think?
- alignment after puttin in new tires?
- Need confirmation. 90-91 TEG ECU same as 92-93???
- 96-98 Civic Cx w/ 99-00 Si harness **HELP....It's a NIGHTMARE**
- Clutch/Tranny Question
- Question: What Cams To Go With???
- Denji projector headlamps
- Automatic Tranny Problems
- Is it true that after 3 to 4 years aftermarket springs become shity
- please help: identify these Cam Sprockets
- fuel concentration problems
- Zmax?!?!?!?!?!?
- msd external coil?
- Converting mm to degrees
- Swap TPS and MAP sensor connector Now wont start
- Decent Air Fuel Ratio Gauge?
- Air/Oil separator box ever go bad?
- Liquid Gasket = RTV?
- Dropping Idle, ECU. Alternator?
- Vtec works then quits??????
- feeler guage questions
- Leaking Motor Oil Out Of the Tranny....
- d16z6 swap into 91 crx
- shot peened vs. glass bead
- looking for the most bang for my buck on a motor swap
- What are the causes of a blown headgasket? And some help about install
- Transmission swap question. 86 Integra onto a D16Z6.
- vavle adjustment question
- Anyone have a pic of a C&R rad for a G3 TEG????
- Toyo Ra-1 ...Dot tires
- spark plug wires?
- Is my IAC valve fuxored.
- installing b20 in 89 crx,what mounts to use
- putting Type R LSD in GSR tranny... shims?
- what will happen if the old tin foil on O2 sensor trick fails?
- gsr exh cam vs. stock b16
- Idle not stable, engine stall sometimes
- How can you tell if cyl. 1 is TDC besides mark on cam gears?
- Replacing Windshield
- Clutch squeek
- distributer problem?
- Cam question
- Gauge pod wiring and tachometer
- gutted cat, what tool did you use?
- Vtec engaging Intermittenly
- Colder, hotter plugs???
- nitrous plate system?
- Hmm...What now ?
- carbing type one bar
- please help with my check engine light code
- Question?
- 3 years old oil - what to do?
- serious question about standalone's...
- timing belt change....tips? advice?
- Tire Balance Weights?
- h22eg or b18c5eg?
- Cluster Swapping in between 3rd generation Integras?? Any Problems
- how many quarts oil in 96 civic 4dr lx?
- How to install a small Autometer shift light...(did search)
- Race gas Versus Pump gas on high compression N-A app
- CEL #14 help!!
- rough idling when cold??
- Dimension of B18C5?
- new cams 4 B16a2
- H22 head on sohc F22B???
- Rear Shock Bolt **HELP PLEASE**
- 88 CRX rear swaybar
- Throttle body squeel, i think? Help.
- 97 Civic ex
- skunk 3 cams
- Custom intake manifold that I made :D
- si or gsr??
- learning how to weld...
- clink-clink-clink sound when I turn in my 94 hatch?
- How to build my b16 up
- Installing B&M fuel pressure gauge on AEM fuel rail... what do I seal with?
- portflow identification
- Battery Relocation Kit???
- crx help!! asap
- Motor With High Mileage
- What compression do YOU have?????
- Ooops, did I f-up my tranny?
- std tranny axles the same as auto tranny axles?
- spring tech shocks and struts?????
- ITR tb will it fit on .......
- what is code 4 or 14?
- 96 dx. b16 swap. buy an ex harness yay or nay?
- B16A, but I want Torque in the future...
- first gen b16 problems
- Someone give specs of a USDM type r cam vs. USDM gsr
- Tune Ups...
- leaking hydrolic clutch fluid.....
- Oil squirters?
- Koyo oem replacement radiator???
- ls/vtec
- how hard?
- what is a vtec controller?
- What happened to C-Speedracing?
- PM6 pistons + Z6 vtec head... What kinda compression and power?
- 5 Wire o2 to 4 Wire o2 wiring...
- Question on the idle adjustment
- i need a crazy header....
- how much nitrous can stock b16 handle?
- thread wanted....
- Darton sleeves (B20)
- Port and Polish, which company do you think is best...
- Foam or K&N style cotton air filte?
- testing
- 4-1 or 4-2-1 on b16a
- Need a little help..
- LS/VTEC vs B18C vs stroked B16A
- What MM is the ITR TB?
- What's Wrong With My RPM? Why Is My RPM So LOW at Any Speed?
- what does everyone else have there FPR at?
- simple question, dont know the answer
- making torque & midrange power in b16
- $250 o2
- Need info on injectors
- ok installin full energy suspension master kit/trailing arm/mount inserts tomorrow morning. what to
- what kind of chip
- what causes your car to just start being sluggish
- Will us Acura dealers do maintinance on 1997 jdm itr 4 lug
- Do all intakes w/ cone filters whistle?
- Oil Presure Gauge Install !!?? Question!!
- Looking for a thread regarding extra hanger for Kamikaze header
- stuck brake caliper after m/c/ swap
- V-AFC Tunning...??
