View Full Version : Tech / Misc
- Axle question, can it pop out on its own?
- APEXi S-AFC Wiring Q's
- why is my b16 hesitating and missing
- need a new battery
- How does an O2 sensor work on a carb'ed engine?
- Need pics of nice and visible place to put gauges.
- Need help on replacing trany seal
- aftermarket timing belt comparison
- Bent Valve??? very quick question.
- Cel code help BARO code 13
- What is a good Dial Indicator/Guage?
- Plug in Vtec head that is used for ls/vtec question.
- need help...loud "whirrr"ing sound
- koni or agx
- LS 5th gear in GSR tranny
- h22 tb and b20 tb help me out someone
- Skunk2 swaybar ques???? did search
- s2000 throttle body on b series manifold?? sizing??
- CABLE TRANS LSD
- Building bottom end for my F20B
- Are vtec and non-vtec Throttle bodies interchangable?
- New DART VTEC HEAD
- H23 a problem
- depining
- Good Southern Tuner?
- New Headgasket.. Self install. I'll need-----------------
- Doing a hydro clutch setup in 89' crx
- Code Cel 19? Car wont start!!
- Why is a lean air/fuel ratio bad for an engine?
- VTEC pressure valve????
- GSR with Type R valve train
- distributor tech question!
- catalytic converter differences? 99 crv vs 99 ls
- tech
- 94-01 Integra/92-95 Civic suspension
- 1st gen B16's with single or dual spring valve train.....
- Anyone ever replaced their door seals?
- Still flashing Ecu code 1
- converting from 1 wire o2 to 4 wire o2...how-to, anyone?
- *car runs weird, dies, and has no spark?????* (please HELP)
- head bolts on B16A... where are they..?
- Smokin radiator ?
- Tein Stech springs on kyb gr2?
- Here's a good one about fuel system electric thingys....
- How To Post A Picture in thius Forum
- Swap almost done, 1 problem though :(
- What is a Stroker Kit?
- offset? how to pick good rims?
- SPC Front Camber Bolt Kit question(s)....
- b-series transmission internals question: 'small spline' to 'big spline' differences?
- fuel pressure
- 88-91 Si and DX fuel rails??
- My ls/vtec setup or buy a gsr motor?
- Bad clutch?? Car vibrates alot
- Violent Shaking Under Acceleration
- ?'s on a 1997 integra gs-r
- im doing a mini me swap on my 95 dx civic, any suggestions?
- fuel cell block off requirments for a civic h/b
- California smog and motor swap (regarding year of motor)
- bullit proof tranny's,lsd install,custom gearing for all hondas
- hondata
- VTEC activation troubleshooting!
- Manual tranny oil in H22 Goes where?
- Where can I buy this SS oil line cover (pic inside)?
- What Valve Spring Compressor for H22 Head?
- throwing code 1 and 14 STILL... Help me GOD!!!
- can 92 prelude si ecu fit the 90 accord
- best all motor lsvtec setup
- . b16 or b18??
- Help with Front Brakes
- ls/vtec running lean in 2 cylinder and rich in the other 2
- Distributor signal wire question.
- Im stumped! Need some help with my piece!! Crappy idle
- got my first cel with my new motor!
- HOW DO! I hookup My Aeromotive Fuel Pump to the fuse box of the stock fuel pump for the 12v
- Help: Problems with my B16A
- Injector Resistance??????? GSR vs. ITR????
- Clutch fork or transmission fork?
- HELP!!!!!VTEC NOT OPENING!!!
- proform shift light
- Where can I buy Clinder Sleeves
- Jerky, stagnate acceleration...
- Installed new clutch and now there is play and low pressure.....
- Automatic / Manual ECU Questions for OBD2b
- Speedmonkeyinc.com's project S-13 starto!
- Idle air control valve question. (auto to manual OBD2)
- comptech header questions
- This welder enough for mild exhaust work?
- Who knows of a Machine shop that lightens Honda Flywheels in Greater LA Area
- FACTORY JDM TACH QUESTION?
- need expierence's with crank pullies (aftermarket style) why the bad rep?
- Shift linkage fitment?
- cel code help
- gsr engine mods 8900 rpm
- compression test - what's bad?
- ITR swapped EG with Individual Throttle Bodies and Electromotive Tec3.....Questions
- B18C1 compershin Psi Test what shode the numbers be?
- Reassembling Axles.....Boot Strap?!
- need help w/ info on this clutch's spec
- OBD0 INJECTORS
- Anyone using the new AEM V2 Intake system?
- Question about final drive ring gear
- how do I replace the cv boot next to the rotor.
- Really dumb question about gasket sealant?
- My Civic is sputtering when Accelerating hard, HELP!!!
- How to check code on 89 crx
- 2 problems with completed swap
- Power Steering Speed Sensor
- Engine Info Help
- Question can I drop a 1999 ITR/GSR master cylinder and booster ON a 94 tegy
- help! What Connector is this????
- How do you raise your idle (idle issues)
- A1 tranny / what chasis?
- Modifying ITR Intake manifold to fit b20!
- turbo timer wiring diagrams
- ould my 97 b18c1 b18c5 camshafts
- Mixing engine coolant
- Need help- How do I convert a PM7 auto ECU to manual
- B16 block, GSR head
- Flywheels: Aluminum or Chromoly
- home depot trick instead of camber kit for the rear
- IACV....are d and b-series the same?
- Who noticed a difference between B16 and GSR cams?
- Setting TDC on crank
- bent ctr cam?
- check engine light: code 45 - is it possibly related to the secondary o2 sensor? (obd2.2)
- dart block/ vtec head/wiring
- Bushings or Bars?
- problems regarding 2000 si motor into a 93 dx...
- What year do cars that have obd2 start?
- will engine fit????
- torque specs for cam bolts on b16??
- finally finished swap, now wont stay started
- Transmission only goes into first?? (did a search no help anywhere)
- D15 (CRX DX) Crank Pulley vs. D16Z6, Y8, Unorthedox - Why Lightweight = Kaboom
- Master Cylinder?
- GSR swap in civic Clutch/fluid/? problems
- jiffy lube fuel injection cleaning?
- ECU chipping software
- any EM Civic owners running Koni's?
- Is there a site that list all tranny ratios?
- How hard to swap final drive in 89' crx dx tranny
- 94 LS DC2 Type R conversion?
- Engine oil still dirty after change...
- difference between heads? d16a's vs d16z's vs d15b's
- PLEASE EVERYONE READ! HELP CENTRAL CALIFORNIA GET A NEW RACE TRACK!
- quick question about tps and map sensor
- auto tranny help
- GSR DualButterflymanifold or Aftermarket??????????
- injector fuses...?
- Where to buy axle's for my EG with an H22?
- will an OBD2a ECU plug into an OBD2b harness???
- Cubic feet to horespower?
- Brake Booster And Master Cylinder testing procedure...
- Help!! Clicking from near ECU 96 ex, wont start!!!
- Moonroof question.....
- --Are these signs of a bad motor mount?? Quick opinions please--
- HELP!!
- ENGINE SWAP: OBD1 VS OBD 2
- motor won't go passed 7200
- ECU question?
- What B series distributors are the same, if any?
- 1st gen b16 VS. 2nd gen b16 which one?
- Motor choices, and confusion...CTR pistons..
- BrakeBooster/Master Cyl Question on Replacement!!!!!
- installing Clutch???
- anyone order from jdmshit.com
- Knock Knock On My Cranks Door
- A wrap you can put around your muffler/s?
- ITR Rear swaybar with stock suspension on a EK?
- oem crank pullies
- Whats the difference: JDM gsr cam Vs. USDM gsr cam??
- Little electrical fire, I have a question.
- tranny pops out of gear.
- Is there a place I can look that will tell me what trannies will fit what?
- i know its not an SI! but is it an HF or a DX?
- Map Sensor Acting up in the rain?
- would DC2 coilovers fit an ek???
- What does a VTEC solenoid do?????
- Tach isn't working. Any idea's?
- compatible distributors?
- Chosing a tire size to match spedometer.
- Need suggestions...
- question bout plugs for ZEX set up
- how do i check breaks in the circuit with an ohmeter??
- timing belt cover install?
- check engine light on after clutch intall
- Cap and Rotor campatiblity....'94 GSR and '00 Si
- Oil Catch Can, waste of money or not?? OPINIONS ANYONE??
- Q for people with S1 jdm tranny for b16
- rusted bearing caps
- CTR head identity question ---->
- tranny problems
- compression and fuel
- car died with jumper wire
- Iridium vs Nitrous
- $800 race car
- 2 auto 2 manual questions , need help asap
- LS/VTEC car wont start unless i step on gas bad idle sometimes even dies
- Are adjustable cam gears worth it? Does a head swap raise compression?
- Redrilling the intake manifold for GSR
- honda's vr6 competition??
- Light problems??
- Read this.
- Next NSX (HSC) to be SOHC?
- B-Series Headers - downpipe fitment?
- Mines ECU
- brake pad change
- greddy blue box wiring on a 94 civic dx
- Here's a stupid question about silencers....
- Consequences of too much oil?
- Problem with Chipped P28..posted already but no answer.no
- help problem with 90 integra auto feeling like slipping
- MUGEN FAN SWITCH ON A B16A??????
- b20turbo question for all you know it alls
- Anyone know what this is???...hooks up to Throttle Position Sensor
- which vtec oil pump?
- Engine help
- need help car is making a wierd popping noise
- Where is the IAT(Intake Air Temperature) Sensor???!!!
- need tranny help
- doest this S H I E T work???!!!
- need a aem ems tuner around PA
- H&R vs. Neuspeed Spring Rates
- all my lights are on
- Assemble Bottom End to be Balanced?
- Removing VAFC..
- wat is that really good gear ratio site?
- New RS Machine B-Series Cams
- Cost of the labor for replacing valve spring and retainer?
- skunk2 stage 2 rebuild in 99 si
- Serious ignition problem, HELP!!!
- Oil Leak: Can it leak from head gasket?
- Manking Carbon FIber
- i need the adjuster for my tokico illuminas....
- Kaiten Karui Flywheels
- LS/VTEC HEADGASKET
- IM gasket that makes HP?
- Water leak in the civic coupe
- Low vacuum! Possible indicators?
- Distributor wiring
- Is there such a size as 1/8 PT thread?
- Just finished swap and having troubles....
- Built 01 GSR will not start??
- How to figure out redline
- 1 wire O2 SENSOR + AutoMeter Air/Fuel guage?????
- Integra Torque Converter question... yes, that means AT, not MT
- Srs light
- 5 lug compatability questions for the master honda mechanics.....
- Get rid of the heat
