View Full Version : Tech / Misc
- tps question!!!!
- Anyone Interested in a taller d-series 1st gear?
- ANOTHER HEAD PORTER QUESTION... CARTRIDGE ROLLS GRITS...??? i need some info on this!!!
- ls crank on gsr block ?????S need help pleeees
- Rattle??
- Turbo? or N/A?
- D16z6 (rear main seal)
- axle problem
- Length of H22
- CR-V problem
- LS BLOCK FOR A LSV!! Help!!
- i need a machine shop in miami fl
- gsr intake mani
- flux capacitor?
- Rocker Arm Scoring??
- researching a most compat ITB's for b-series motor.
- ITR front conversion for a 95 civic coupe
- p30 pistons with eagle rods?
- rotating mass equation
- help with charging system
- Injectors leaking
- Is running a typical honda car engine at WOT for extended periods of time bad?
- Best B-Series Bottom End
- do i have to remove the brake lines to change rear brakes
- HEAD PORTERS, HELP ME ON THIS!!!!
- need help
- NDC Bearings???
- Help B16a Hydro to TypeR modification
- Tuning Shops
- HH02SD exedy stage 3 hyperclutch single plate
- IMPORTANT QUESTION-------PLEASE HELP--------------------!
- vtec not engaging in 3rd gear?!?!?! please help
- Spoon ecu chip upgrade
- Hondata Question
- Help with smoking!
- quick question " engine installers"
- m12x1.25x80
- Tranny Gurus, I need help
- 99 Si Throw out bearing help
- California Exhaust ??
- what the hell should i do??? all help is appreciated im wayyyy confused
- B16 motor swap problems!
- What VTEC solenoid is this?
- who is running B16A with GSR Head?
- What sensors are required to just start?
- I dunno what year my H22A is?
- what throttle body cable do i use?..
- DataLink Connector missing, how to hook up new
- question about my b16a
- a Type R harness on a B16a2?
- NEED HELP!! Car losing power
- UBERDATA???? i need help
- street-tune timing????
- What is your poison of choice?
- Motor oil = horsepower?
- JDM b16...I need some feed back (PLEASE READ)
- flexible radiator hose for custom application
- maximum point of milling
- Idle speed adjustment on Typer TB?
- Crome pro?
- Wideband 02 Sensor on a Narrowband Gauge?
- How to I.D. Civic tranny?
- Chicago area shop for ring replacement?
- computer resistor
- longer wheel base better for traction.
- Question about Paint -How Much (volume)?
- manley h beam
- Doppler vs ultrasound parking sensors
- which tune board 2 use s300 or neptune rtp
- Is this an OBX or Quaife? (pics inside)
- Valve help "video"
- Common Honda Bolt thread pitch size dimension
- B16/Gsr same part # for head gasket??
- Max Xtreme pressure plate?
- I need help sizing my bearings?
- What spring rates?
- what makes more power in a b16......
- lsd or 5 speed?
- Volvo B16, B18, B20
- Turbod B18c 93 DC2 Integra
- Quaife LSD Install on LS Tranny
- Do I really need a tune?????????
- b18c1 assemly
- ported header with stock head?
- Question for techs
- Cam to Valvetrain question
- Battery Relocation Kits
- GSR - Accord - Legend brake swap for my EG hatch?
- OEM main bearing issues - bolt vs. stud and clearances
- bore b16 to 1.8
- motor shakes?
- 91 accord. trouble starting
- Which FPR do you run?
- How to remove wires from connector?!?!
- viPOWER DOORS
- how the hel do you get high rpm
- OBX part # ?
- what type of cams are these can't find help, please honda tech help me out!!!
- stock oil cooler info
- 14mm allen block plugs (b series) part #??
- putting GSR obd1 into EG. harness Q.?
- Who's got the lowest prices on new OEM Acura parts???
- b20vtec help!!!!
- diagnostic help
- Sohc vtec head question
- Any Zdyne Tuners out there?
- transmision or axles
- Mooninite Boston Terrorist tshirts $15
- transmission slips after engine warms up *NEED LINKS*
- B20z modification advice
- ECU help
- 97Integra w/95 civic motor HELP!
- gsr rods in ls block, or ls rods retangged to use gsr bearings?
- bent frame - easy fix?
- need help with a d16 build !
- need help quick. replacing headgasket and i see this in 1 of 4 chambers
- need help with z6 into a 00 ek
- Idles perfect for 1 second, then dies unless revving
- Engine stays on when key is turned to off position
- JDM GSR HEADER?
- which usdm ecu to work in a b18c?
- HELP: Need OS Giken Torque specs.
- pops out of 5th gear
- 88-91 TB
- da wheel locked
- HELP QUICK!!!
- So, My Motor Is Out
- Misshifted motor is all messed up. bent valve? HELP!! *searched*
- Making a gasket
- i need help with swaping a d15 head
- Shift fork question
- needing some help on what should be done to my transmission....
- suggestions/questions for 07 honda accord coupe ex v6
- installing new rings with engine still in car.
- Emission Test Results... briefly explain emission control systems and test results
- b18c1 rebuild question...
- k20 hatch
- 92 Honda Accord TPS
- BUILD b16a!!
- Help with b16a first gen. Ran a couple days ago, Now just cranking. Diagnose it
- Thrust Washers ?
- vacuum help?
- Will I pass Emmissions?
- d16z6 rings work for d16a6?
- KTeller?
- p05 to a p06?
- hone help
- T1R and WS2 ? Need asap
- Odometer Laws
- TPS for this Throttle Body?
- cam lobes???
- Cable b16 tranny. Will 95 acura integra hydraulic tranny axles seals work?
- !!!!! NEED HELP !!!!! throttle or feul?
- leaking oil
- How hard is it to rebuild a b series Tranny?
- CEL code #5 & #20 (p28) after obd0 to obd1 coversion! NEED HELP!!!
- jimFab Rear Mount Bushing
- somethings wrong with my H22
- Whats the difference?
- AEM EMS 1040 accord starting issues
- Some question about oil for my building civic turbo in Russia
- trying to fix a dent
- Great Performance shop in AZ
- Tuning problem on turbo b16a2. HELP!@!!
- Where to buy cabon coated syncros?(Gearspeed out of stock)
- air/fuel gauges
- passengerside axle keeps breaking?OUTER CV
- Write up for battery relocation..?
- ECU question for my 92 Integra
- Aligning everything TDC big question regarding bending valves and right procedure...HELP!
- SIR-I JDM B16A obd0 -Wiring for the second o2 sensor-
- Decisions, Decisions
- clutch question...
- lsd prob.
- Honda MTF vs. Amsoil synthetic
- Check Engine Light (IAT sensor)
- Provide me with a basemap, will give RomEditor software
- Tuning Question. (easy) Hi CAm, Lo Cam / Ignition
- New TV show - looking for cars
- the best way to fabricate shift linkage?
- anyone use ebay piston rings?
- performence chips
- 3 1/4" hone too big for cyl?
- Civic SI AEM FUEL RAIL 96-00 fit on AEBS IM?
- Boost creep from HELL!!
- Start problem!!!!Video incl.
- What do you guys think- OEM headgasket or aftermarket?
- AEM/ S300 imput
- Crankshaft Pulley
- Need help wire fogs JDM ITR front.....
- Tuning Discussion
- Manual brake conversions...
- Problems with my clutch pedal.
- 91 Integra DA rack and pinion support
- Car wont move when in gear
- higest milage twin disk
- Where Do i go to buy new sencro's, Becides Honda?
- Bad Compression Numbers...
- Need a used JDM trans for 96 civic. Anyone recommend an importer in So. Cal?
- Can O2 sensor cause vtec not to switch over?
- code: p1457 1999 honda civic ex
- how to tell if car is burning oil or running rich?
- need a carfax if anyone can please
- GSR internals into a cable tranny
- Head Stud?
- p28 ecu questions
- Line lock questions with pic
- Looking for a guide to ECU Chipping.
- Where can I get a Tune?
- tuning software...?
- vtec problem?
- coolant leak
- sol won't move, but still running??
- ANY CLUE ON WHAT KIND IS THIS MANIFOLD.......................................... ................
- Coolant loss again after replacing headgasket...
- Accidently posted in wrong forum. Trying again...
- Swapped civic throwing code p0453
- Alternator differences?
- car stalling!?
- replacement crank for ITR
- ZipTech O2 sim wiring, help!
- tach calibration
- tanabe super hyper medalion??
- can anyone?
- CFM flow of a B16a Head
- injector clip wiring help
- F1 RACING CLUTCH & FIDANZA FLYWHEEL
- Ticking w/clutch released. Press clutch pedal and the ticking goes away?
- Retune for different state? necessary?
- 8lb or 10lb flywheel?
- car unable to rev past 1500 rpm
- Blowing 15amp ACC fuse.
- HELP!! transmission/axle problem jdm swap with 91 honda civic 5spd Sedan HELP!!
- help with ITB's!!!!!!!!!
- What kind of spring compressor Do I need?
- gsr tranny wit itr final drive
- for the engine bulders/ring question
- do i need bigger injectors
- car wont start.. please help
- Real bad cooling problem on B18c turbo
- cam vs over sized valves?
- B16 Y1 cable tranny, can I rebuild it?
- shift linkage b16a
- Took my z6 head off and found these...what are they?
- Have to pump the clutch to get the motor to turn over or start ? only sometimes
- nitrous?
- Thanks anyways
- Car want stay heated up
- to powder coat or not to powder coat....
- LS/VTEC idle problems
