View Full Version : Tech / Misc
- apex oil press gauge question
- identify this conversion harness
- B18c1 ARP Head Stud Question
- Just rebuilt gsr with TypeR internals .20 over is there too much compression????
- car wont start
- Catchcan baffeling question
- How do I get the program off of my S200 chip onto the computer to open with SManager?
- Dual Valve Springs with CTR Cams
- trans
- ? bout buying a turbo charged gsr swapped EK
- Compression checked
- Turbo Q
- How much would you pay for a USDM P30?
- hondata help
- Just picked up a CRX with a B16, have some ?
- important question really need opinions
- Shift Linkage
- Crank......Right hand thread?
- VTEC oil dowel pin
- no VTEC ,,, help me
- b18b rev limit
- nrg ground wire system????
- 100 octane stations in So Cal!
- Help, anyone know what this is?
- where to plug V-TEC
- 93 accord h22a speed sensor
- Good Cams?
- Is my math here wrong? (Gear ratios/tq multiplication inside)
- can someone please help me out with how much a b18c1 block weighs.
- removing lots of oil out of bay??? help!
- Car wont start after "Burnout". Shut off when clutch was released
- B18c internals in 18a block?
- Another VAFC thread, but about consistency
- IAB's on b18c1 after IM install - obd2
- Clutch on a 2004civic
- hondata s300 map?>? mildy built gsr
- Urethane bar repairs
- good question about OBD in LSVTEC.
- ITR lost motion assemblies
- NEED ADVICE! SUPER CONFUSED!!!!!
- d16a1 pistons into d16z6
- J&S Safeguard Help
- right side rear blinker not working
- VERY WEIRD IDLE ISSUE....
- Low spark
- Knock Tick Only While Revving :( Some Questions
- JDM B16 (Distrib. Help!)
- tb question
- STR Throttle body fix????
- Oil feeder lines from windage tray? Experience needed..
- fuel pressure???
- P14 in a H22a motor
- H to B series tranny adapter plate
- NEED HELP!! power window into an EG Si 94
- coolant temp switch - why is it connected to pin A12?
- D-series duel throdlebody (RARE!)
- help identify these OEM b-series vtec cams
- Z6 and Y8 trannys....Same Part #'s?
- cylinder temp vs. cylinder pressure in reference to long or short stroke?
- B20B and B18B
- How to determine the direction of rotation in an engine?
- Any good Chrome or Neptune Tuners in Miami?
- B16 deck height
- Driver side alxe problem???!!!!
- how to time a motor w/out the flywheel mark?
- Can a Moderator help me? I can't log in.
- polishing the tops and sides of pistons?
- Beadblasting pistons necessary?
- b16 flywheel and clutch bolt up to gsr block with b16 tranny??
- Was Low on Oil for THREE DAYS. could this have damaged my BOOSTED MOTOR?
- Which LSD for B16 Tranny?
- 00 GSR burning oil! Precious mobil 1!!!!
- h22 running rich
- do I need stock knock sensor
- Radiator Switch
- A question about my new ls/vtec build
- Exedy Clutch, Low clutch engagement (95 Integra)
- will stage 1 clutch on b18a1 do fine ?
- Building Brakes
- Best Crank/Rod/Piston (which do i use LSVTEC)
- Spring rates
- apexi vafc help
- Testing a GReddy EManage?
- how to fix cruise control button?
- Valve Adjustment on B20Vtec
- d15b problems
- What is the best oil and filter to use?
- b17 piston question
- wheel question!!
- Master cylinder/slave ???
- hondata s200 rom editor
- Odometer to work with H22
- just installed apexi fc ecu
- turbo
- Snap ring on transmission housing
- Easy question: Do Fluidyne rads come w/ a rad cap?
- Valve end mushroomed...
- losing power
- ground, but not micropolished...
- how to find out what cell's my car is throwing?
- Recomended Fluid for H22 Trans with Quaife?
- stock obd2 GSR work on an LS/VTEC?
- rom editor downloads
- S300 with 600 CBR RR engine....
- thermoswitch
- Needing Engine Mount Hardware
- ECU codes question-
- B16 variants
- VTEC solenoid HELP!
- Help....b16a obd0 into 97 coupe....parts needed...
- With crank to use on LSVTEC (gsr,ls)
- LS Vtec Turbo Setup HELP!!!
- how can i tell if the motor is stolen?
- Supertech customer service!
- Transmission limitations?
- please post pics of your dope tuning setups>>> just curious
- Accel Ignition Coils
- head studs: which one?
- s80 vs y80?
- Leak from header....need help
- Broken VSS?
- alternator relocation kit
- JHPUSA ECU tuning???
- D16y8 headwork, supporting mods for high revving
- please help , ls/vtec in pain
- anyone have clutch go out on them in 1 day ?
- EG Dash - Grey - How to remove?
- Clutch, Clutch, or Clutch
- Noise when shifting, help plz!
- Need help on B18A1 trouble shoot
- VSS code and tire size
- Y8, Input Shaft Bearing and casing. Part#?
- D16 Turbod - Ignitions?
- My truck stalls at high altitude!? Non-Honda help please?
- question about mixing transmission fluid with the oil
- Wiring problem
- threw tons of codes :(
- lol sunroof lol
- vibration hell...
- Transmission swap (NOT another auto to manual question)
- need clutch help!!!!!
- Failed BAR. Please help
- obd 0 to obd1 questions please help
- 2007 RDX Turbo
- haltech e6k b series..anyone using?
- car stuttering during gas fill up
- F22 SoCh VtEc in a EG CIVIC hatchback
- double clutch
- exhaust brackets
- Pilot Bearing Questions...
- black box, eh?
- how many different type of clutches are there ?
- Clutch is slipping Hard- needs replacement or cable ?
- Readng fault codes on OBD 0, I & II hondas
- help with new cams
- Honda MTF II
- how to tell which b16a?
- please help me identify these ECU's
- Which type of filter element breaths better - flat or cone?
- b16 problems
- NORCAL- clutch slipping but was running perfect last night. whats wrong ?
- Loud Valve Train Causing False Knock
- alright ive searched please help
- White smoke after headgasket replaced?!?
- What Kind of Radiator should i use for my H22
- Eagle rods in a d16.....Block notching?
- Towing a lowered car
- o2 sensor wiring on 01 EX Swap (from LX)
- throwing code 8 and 1...would this cause my vtec to not kick in?
- Wheel Studs
- weird tachometer readings.....
- What a mess im in..
- Competition Gravity Stage 1 cClutch...what's it like?
- How to identify dizzys?
- Hybrid-Tech
- What size pistons?
- which tranny do i have?
- cam specs
- HOW TO REMOVE HIDS???HELP
- Local Swap
- can't find motor mounts and bracket for 90 teg
- diognosing transmission problem
- ls/vtec
- ls/vtec question
- What to do next...I need opinions
- ITR header height?
- electrical
- jr supercharger
- cheap HID vs brand name HID kit?
- Urgent Help Needed: Headgasket?
- tranny questions
- Turbo leaking oil
- might have jumped a tooth
- Poor Man Type R?
- Converting LS/Vtec Back???
- Ignitor or not
- How do you install coil packs on a H22
- hey guys need help , what is 0.40 over , one the bore of a stock b18A
- Help me figure out if i was scammed!!!
- What grade and what kind of fluid to put in b16a1 tranny
- tuning b16a buddy club spec 4
- Identify these sensors please
- upgraded valvetrain clearence
- Question about ITR LSD...
- steering column help eg to ek
- Valve lift
- Main fuel relay causing problems? 95-gsr
- help...oil in spark plug hole- simple question...
- Viberant Exhaust opinion
- Real TDC or by the pointer..
- Difficult to turn Input shaft after rebuild
- Header Sounds Horrible
- Affordable Piggy Back
- Distributor ID?
- bouncy high idle (did iacv & fitv) *searched*
- no signal to speedo, tach, temp
- How to aim itr headlights??
- please help...car wont start did my search
- Bought an engine stand but dont have trans bolts!!!
- What do i need to attach a s2k intenna to my 95 teg?
- Clutch woes
- F22b motors questions
- valve seals ??
- p30 start problem
- Tach install help
- obd2 to obd1 conversion
- oil cooler how to fit?????
- LS/VTEC OIL BURNING PROBLE, NEED HELP
- How to become an active member?
- dyno tune
- Possible to chip a P14 ecu for tuning? crome, uberdata, etc. H23a1 prelude
- Axle problem
- D16Y8 in EG problem.
- jumper plug
- distributor bearing problem
- Clutch problum, please help.........
- car feels like its misfiring... help
- clutch pedal gets stiff after warmed
- instrument light problem. some help
- b18/b16 valve cover
- avid mnts???????
- Oil dipstick in b20b randomly pops out of its location. What to do?
- Ideling Problem (please help)
- MSD 3 step wiring help
- b16/gsr lower timing belt question
- what are the difference in gsr and ls axles? i have a b18b1 in a eg civic hatch
- Clutch Rod Adjustment?
- Problems with VTEC. JDM ITR engine
- help on brake pads.
- wiring a open down pipe solinoid plate
